Did some one get a higher resolution than 1080p working with the Rock5b? The kernel showed the right DDC Information even the frame buffer reports to 2560x1440, but this is not correct.
Is this issue known?
xrandr showes only 1920x1080.
It is my understanding that the 5:10 kernel used for both the Debian and Ubuntu Radxa 5b images only supports resolutions up to 1920x1080. I have a 4k Monitor so I just get blank screen with either. I’ve also tried the Android image and it does support higher resolution. I can get 4k@30hz but not 60hz. You should be able to get 2560x1440 with Android, but it’s Android.
Not sure if same setup as op, I used ubuntu server image and then installed ubuntu-desktop and I’m able to get 4k60hz on HDMI1.
Unfortunately I am unable to get 4k120hz on same port. Switching to 120hz loses video and then will revert to 60hz.
Thanks, is it the 5:10 kernel or does the desktop install update the kernel? I’ll give it another try.
rock@rock-5b:~$ uname -a
Linux rock-5b 5.10.66-27-rockchip-gea60d388902d #rockchip SMP Mon Oct 24 08:25:47 UTC 2022 aarch64 aarch64 aarch64 GNU/Linux
I have to use this device tree overlay to enable my Philips 4K monitor: https://github.com/amazingfate/radxa-rock5b-overlays/blob/main/rk3588-add-hdptxphy_hdmi_clk.dts.
I think only one port can provide 120fps at 4k
I found a solution:
compile the dts file
dtc -O dtb -o rk3588-add-hdptxphy_hdmi_clk.dtbo rk3588-add-hdptxphy_hdmi_clk.dts
and install it into your current kernel dtbs directory:
cp rk3588-add-hdptxphy_hdmi_clk.dtbo /boot/dtbs/uname -r/rockchip/overlay/
sudo vim /boot/extlinux/extlinux.conf
and replace /dtbs/5.10.66-27-rockchip-gea60d388902d/rockchip/overlay/rock-5b-hdmi1-8k.dtbo with /dtbs/5.10.66-27-rockchip-gea60d388902d/rockchip/overlay/rk3588-add-hdptxphy_hdmi_clk.dtbo
use uname -r to get your current kernel release string and replace it accordingly.
reboot and then change the resolution in you running X11 session.
My ultra wide monitor worked perfectly with my rock 5B. I use just one type-c cable to get 5b powered up and runs at 3440*1440 165Hz. By the way, I’m using the official debian image.
To be clear, your in display port alt-mode and the usb-c cable is providing both power to the 5b and video out to the monitor, correct?
Exactly…
Tested on the official Debian image
I managed to get 2560x1440@60 on my monitor (native res) through USB-C (through a hub with HDMI output), but not able to get more than 1080p60 from the board’s own HDMI output.
Can you try out my Solution (Ubuntu image with X11 and Resolution 2560x1440)?
Try it without build a new Kernel.
Thank you!
It’s working fine with 2560x1440 at 100 Hz @HDMI1 without a new kernel.
I didn’t have a rock-5b-hdmi1-8k.dtbo line and only added the line to the fdtoverlay-line in the extlinux.conf (I am using the Debian-Image, not Ubuntu - maybe that’s the difference)
I had to install the dtc-package, before i could compile the dtb:
sudo apt-get install device-tree-compiler
Hi n0x,
Roschach seemingly had a successful result, but on the contrary my main display capable of native 3440x1440 @ 75Hz was not totally usable out-of-the-box on the Debian X11 bullseye image, and only 1600x1200 was available.
But your suggested method, without kernel rebuild, worked fine for me too.
Thanks for your contributions
Actually I had exactly the same problem, and as you I was success just I was a bit confused with the /boot/extlinux/extlinux.conf but as you said I just set:
fdtoverlays /dtbs/5.10.66-27-rockchip-gea60d388902d/rockchip/overlay/rk3588-add-hdptxphy_hdmi_clk.dtbo
and also took 2560x1440 60Hz in both HDMIs ![]()
thanks
I can confirm that this also works for my 1920x1200 display on armbian, I used user_overlays as described here: https://docs.armbian.com/User-Guide_Allwinner_overlays/
otherwise a new kernel package will overwrite it.
I built the `rk3588-add-hdptxphy_hdmi_clk.dtbo and cp’ed it to kernel dtbo location and edited armbianEnv.txt. I also set the perms same as other dtbo’s. (no extlinux on Armbian). Any help to get 1440p res pls. I tried the user_overlays way also.
Can you be so kind to provide some additional info on how you got this to work on Armbian?
It is in armbianEnv.txt you are editing?
Can you make a step by step?
/boot/overlay-user/
user_overlays=rk3588-add-hdptxphy_hdmi_clk in armbianEnv.txtnote I I just wrote it from the top of my head, as I had to RMA my board.
The confusing thing here is the inconsistent nomenclature: overlay-user != user_overlays
