looks nice!
does it supports putting (and cooling as well) nvme there?
Looks great. Any info on availability?
Hey does anyone knows the sizes of radxa Acrylic standoffs? are they m2 or m3?
Muchas gracias! ![]()
Hi there,
another option would be my “Amiga 3000” case to print yourself.
Download STL´s: https://www.thingiverse.com/thing:5921605/files
Optionally, the customized “After burner” image versions that you can easily install via:
git clone --depth=1 GitHub - Jodels2002/AmiRock: Test
sudo chmod -R 777 AmiRock
cd AmiRock
./setup.sh
Greetings Bernd!
IMG_8233|666x500Beautifull ! Really cool man !
Tnx DarkevilPT
I think its 3mm because these ones are 2mm and obviously dont fit and were a bad purchase Ive ordered 3mm now lets see…
Well, I showed you the measure, the one that came with the case have an M2.5x0.45 thread. I don’t know if an M3 can fit
I know I know.. but you measured the screw not the standoff part and .. I haven’t found easily M2.5 so I am.. gonna risk 3MM as it should be probably the fat measured part I guess?
And to confirm yes m2’s wont fit eithr.. unless u get m2 screws but not good.. for feedback these images shows off well how it is
Much appreciated @Cyborgium!
A friend printed this out for me including the top without a fan opening.
Fitment is superb.
For others out there, I flipped over my RPi fan to pull cool air unto the CPU then stepped up from 3V to 5V with a generic 40x40x12mm heatsink. This yields idle temps around 37-40C and active temps in the 45-55C range. Running benchmarks shows a max of 67.5C at 100% utilisation across all cores (no thermal throttling). Before the above changes, temps were about 10C higher for each condition.
initially I was using all the standoffs I had along with some screws and the thin plastic case cut down to provide some protection…
The dream case with cooler has been built here !
Michael projects and their make of videos are great to watch, but this one seems to be just quickly moved from earlier design for raspberry placed on bottom. Nothing fits here correctly and case is way too big and so far just empty. ROCK 5 don’t require that big heatsink and cooler (which is not even connected to fan header causing some problems here). Whole thing looks like first, quick iteration and hopefully there will be next release smaller, fitted, reconsidered
I agree but there is always the size of the board that would make it look maybe larger on one side than another idk but its fun to see this creation.
