Good day all
i have tried to modify the rules so that my 4 drives will be visible. however on linux itself the 2 other drives are not detected
the light indicator is only working for disk 1 and disk 3.
i thought it was the HD that was not working, so i tried to switch the drives to these HD slots and they were detected but still the other 2 were not
HD ports 2 and 4 are not lighting up
any advise on how i can check if my SATA Hat HD ports are working well ?
here is my lsblk
sda 8:0 0 223.6G 0 disk
└─sda1 8:1 0 223.6G 0 part /srv/disk2
sdb 8:16 0 223.6G 0 disk
└─sdb1 8:17 0 223.6G 0 part /srv/disk1
mmcblk0 179:0 0 14.9G 0 disk
├─mmcblk0p1 179:1 0 256M 0 part /boot
└─mmcblk0p2 179:2 0 14.6G 0 part /
here is my dmesg
[ 0.000000] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1403 SMP Mon Feb 22 11:33:35 GMT 2021
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem [mem 0x0000000030000000-0x00000000fbffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x00000000fbffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
[ 0.000000] On node 0 totalpages: 1012736
[ 0.000000] DMA zone: 2304 pages used for memmap
[ 0.000000] HighMem zone: 816128 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
[ 0.000000] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1010432
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=DC:A6:32:87:E5:03 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=1aa9f0ed-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] Kernel parameter elevator= does not have any effect anymore.
Please use sysfs to set IO scheduler for individual devices.
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x0000000017cc0000-0x000000001bcc0000] (64MB)
[ 0.000000] Memory: 3654936K/4050944K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 133864K reserved, 262144K cma-reserved, 3264512K highmem)
[ 0.000000] ftrace: allocating 33942 entries in 67 pages
[ 0.000000] ftrace: allocated 67 pages with 3 groups
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
[ 0.000009] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000035] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000098] bcm2835: system timer (irq = 25)
[ 0.000753] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000775] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000796] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000814] Switching to timer-based delay loop, resolution 18ns
[ 0.001069] Console: colour dummy device 80x30
[ 0.001809] printk: console [tty1] enabled
[ 0.001874] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=540000)
[ 0.001928] pid_max: default: 32768 minimum: 301
[ 0.002111] LSM: Security Framework initializing
[ 0.002309] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002355] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.003929] Disabling memory control group subsystem
[ 0.004065] CPU: Testing write buffer coherency: ok
[ 0.004538] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.005759] Setting up static identity map for 0x200000 - 0x20003c
[ 0.005974] rcu: Hierarchical SRCU implementation.
[ 0.006917] smp: Bringing up secondary CPUs …
[ 0.008141] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.009505] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.010814] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.010973] smp: Brought up 1 node, 4 CPUs
[ 0.011019] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.011049] CPU: All CPU(s) started in HYP mode.
[ 0.011075] CPU: Virtualization extensions available.
[ 0.011921] devtmpfs: initialized
[ 0.025819] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.026078] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.026131] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.033181] pinctrl core: initialized pinctrl subsystem
[ 0.034277] NET: Registered protocol family 16
[ 0.038278] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.039066] audit: initializing netlink subsys (disabled)
[ 0.039338] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
[ 0.039909] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.040602] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.040657] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.041089] Serial: AMBA PL011 UART driver
[ 0.074151] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.090981] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-02-25T12:10:40, variant start
[ 0.100995] raspberrypi-firmware soc:firmware: Firmware hash is 564e5f9b852b23a330b1764bcf0b2d022a20afd0
[ 0.145898] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.150097] vgaarb: loaded
[ 0.150554] SCSI subsystem initialized
[ 0.150793] usbcore: registered new interface driver usbfs
[ 0.150868] usbcore: registered new interface driver hub
[ 0.150979] usbcore: registered new device driver usb
[ 0.151748] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.153641] clocksource: Switched to clocksource arch_sys_counter
[ 1.152358] VFS: Disk quotas dquot_6.6.0
[ 1.152487] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.152667] FS-Cache: Loaded
[ 1.152893] CacheFiles: Loaded
[ 1.163316] NET: Registered protocol family 2
[ 1.164182] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.164344] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.164425] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.164511] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.164689] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.164744] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.165024] NET: Registered protocol family 1
[ 1.165768] RPC: Registered named UNIX socket transport module.
[ 1.165801] RPC: Registered udp transport module.
[ 1.165829] RPC: Registered tcp transport module.
[ 1.165856] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.165894] PCI: CLS 0 bytes, default 64
[ 1.168800] Initialise system trusted keyrings
[ 1.169048] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 1.177632] zbud: loaded
[ 1.179532] FS-Cache: Netfs ‘nfs’ registered for caching
[ 1.180307] NFS: Registering the id_resolver key type
[ 1.180359] Key type id_resolver registered
[ 1.180387] Key type id_legacy registered
[ 1.180551] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.181588] Key type asymmetric registered
[ 1.181620] Asymmetric key parser ‘x509’ registered
[ 1.181825] bounce: pool size: 64 pages
[ 1.181900] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.182133] io scheduler mq-deadline registered
[ 1.182164] io scheduler kyber registered
[ 1.186657] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.186710] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.186812] brcm-pcie fd500000.pcie: MEM 0x0600000000…0x063fffffff -> 0x00c0000000
[ 1.186922] brcm-pcie fd500000.pcie: IB MEM 0x0000000000…0x00bfffffff -> 0x0400000000
[ 1.245743] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.246158] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.246195] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.246230] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.246339] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.246597] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.250090] PCI: bus0: Fast back to back transfers disabled
[ 1.250445] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.250590] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.251040] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 1.254546] PCI: bus1: Fast back to back transfers disabled
[ 1.254659] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.254699] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.254801] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.254841] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.255261] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 1.255504] pcieport 0000:00:00.0: PME: Signaling with IRQ 63
[ 1.264073] iproc-rng200 fe104000.rng: hwrng registered
[ 1.264399] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.265290] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.277565] brd: module loaded
[ 1.289822] loop: module loaded
[ 1.291506] Loading iSCSI transport class v2.0-870.
[ 1.294022] libphy: Fixed MDIO Bus: probed
[ 1.295748] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.313716] libphy: bcmgenet MII bus: probed
[ 1.393802] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.394983] usbcore: registered new interface driver r8152
[ 1.395069] usbcore: registered new interface driver lan78xx
[ 1.395146] usbcore: registered new interface driver smsc95xx
[ 1.396770] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
[ 1.396950] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.397000] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.400365] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
[ 1.401718] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 1.401759] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.401795] usb usb1: Product: xHCI Host Controller
[ 1.401825] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
[ 1.401855] usb usb1: SerialNumber: 0000:01:00.0
[ 1.402613] hub 1-0:1.0: USB hub found
[ 1.402738] hub 1-0:1.0: 1 port detected
[ 1.403423] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.403479] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.403525] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.404118] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 1.404157] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.404193] usb usb2: Product: xHCI Host Controller
[ 1.404223] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
[ 1.404253] usb usb2: SerialNumber: 0000:01:00.0
[ 1.404980] hub 2-0:1.0: USB hub found
[ 1.405088] hub 2-0:1.0: 4 ports detected
[ 1.406820] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.407149] dwc_otg: FIQ enabled
[ 1.407164] dwc_otg: NAK holdoff enabled
[ 1.407178] dwc_otg: FIQ split-transaction FSM enabled
[ 1.407196] Module dwc_common_port init
[ 1.407635] usbcore: registered new interface driver uas
[ 1.407765] usbcore: registered new interface driver usb-storage
[ 1.407976] mousedev: PS/2 mouse device common for all mice
[ 1.409678] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.413192] sdhci: Secure Digital Host Controller Interface driver
[ 1.413226] sdhci: Copyright© Pierre Ossman
[ 1.413975] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 1.414635] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.418828] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.419190] hid: raw HID events driver © Jiri Kosina
[ 1.419416] usbcore: registered new interface driver usbhid
[ 1.419447] usbhid: USB HID core driver
[ 1.425176] Initializing XFRM netlink socket
[ 1.425237] NET: Registered protocol family 17
[ 1.425371] Key type dns_resolver registered
[ 1.425741] Registering SWP/SWPB emulation handler
[ 1.425938] registered taskstats version 1
[ 1.425979] Loading compiled-in X.509 certificates
[ 1.426829] Key type ._fscrypt registered
[ 1.426860] Key type .fscrypt registered
[ 1.426888] Key type fscrypt-provisioning registered
[ 1.438390] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.438731] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.438838] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
[ 1.445568] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.446645] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.446679] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.476977] of_cfs_init
[ 1.477258] of_cfs_init: OK
[ 1.498353] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.500060] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.501764] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.504957] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.506660] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.514476] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 1.515168] Waiting for root device PARTUUID=1aa9f0ed-02…
[ 1.548862] random: fast init done
[ 1.573180] mmc1: new high speed SDIO card at address 0001
[ 1.617721] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
[ 1.618733] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[ 1.622150] mmcblk0: p1 p2
[ 1.656244] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.656341] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.663383] devtmpfs: mounted
[ 1.672303] Freeing unused kernel memory: 2048K
[ 1.683995] Run /sbin/init as init process
[ 1.684026] with arguments:
[ 1.684040] /sbin/init
[ 1.684055] with environment:
[ 1.684069] HOME=/
[ 1.684083] TERM=linux
[ 1.773704] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.956329] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.956376] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.956410] usb 1-1: Product: USB2.0 Hub
[ 1.958402] hub 1-1:1.0: USB hub found
[ 1.958711] hub 1-1:1.0: 4 ports detected
[ 2.116925] systemd[1]: System time before build time, advancing clock.
[ 2.228164] NET: Registered protocol family 10
[ 2.229537] Segment Routing with IPv6
[ 2.295718] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.297022] systemd[1]: Detected architecture arm.
[ 2.343318] systemd[1]: Set hostname to .
[ 2.772485] random: lvmconfig: uninitialized urandom read (4 bytes read)
[ 3.292377] systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
[ 3.321836] systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
[ 3.386794] systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
[ 3.459687] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.487335] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.487454] systemd[1]: Reached target Swap.
[ 3.493880] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 3.497528] systemd[1]: Created slice system-getty.slice.
[ 3.498603] systemd[1]: Listening on LVM2 poll daemon socket.
[ 3.742448] Installing knfsd (copyright © 1996 [email protected]).
[ 4.287079] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.385753] systemd-journald[131]: Received request to flush runtime journal from PID 1
[ 5.006698] Driver for 1-wire Dallas network protocol.
[ 5.011858] gpio-4 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 5.056032] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 5.056653] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 5.057557] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 5.059321] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 5.118797] mc: Linux media interface: v0.10
[ 5.121448] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.126158] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 5.126186] [vc_sm_connected_init]: start
[ 5.138013] [vc_sm_connected_init]: installed successfully
[ 5.145530] videodev: Linux video capture interface: v2.00
[ 5.185167] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.197965] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 5.200376] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.200383] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.226911] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 5.227416] bcmgenet fd580000.ethernet eth0: Link is Down
[ 5.253148] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.254342] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.274945] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 5.275480] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 5.275946] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 5.276383] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 5.276414] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 5.276440] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 5.276463] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 5.276486] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 5.276758] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 5.299863] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.320491] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 5.320561] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 5.338548] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 5.338609] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 5.346933] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 5.347049] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 5.508589] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.527685] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 5.661346] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 5.662999] [drm] No displays found. Consider forcing hotplug if HDMI is attached
[ 5.663129] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 5.665397] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 5.724650] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 5.738814] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.740716] usbcore: registered new interface driver brcmfmac
[ 5.769065] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
[ 6.007879] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 6.024266] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan 4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
[ 7.274036] bcmgenet fd580000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 7.274094] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 10.011946] uart-pl011 fe201000.serial: no DMA platform data
[ 10.580329] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 11.983752] random: crng init done
[ 11.983773] random: 7 urandom warning(s) missed due to ratelimiting
[ 12.475764] NFSD: Using UMH upcall client tracking operations.
[ 12.475793] NFSD: starting 90-second grace period (net f0000089)
[ 13.127641] i2c /dev entries driver
[ 14.534129] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 14.575435] usb 2-1: New USB device found, idVendor=152d, idProduct=0561, bcdDevice= 0.01
[ 14.575460] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 14.575479] usb 2-1: Product: JMS56x Series
[ 14.575496] usb 2-1: Manufacturer: JMicron
[ 14.575513] usb 2-1: SerialNumber: RANDOM__04AD244B74CD
[ 14.582345] usb-storage 2-1:1.0: USB Mass Storage device detected
[ 14.583176] scsi host0: usb-storage 2-1:1.0
[ 15.474179] usb 2-2: new SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 15.515712] usb 2-2: New USB device found, idVendor=1058, idProduct=0a10, bcdDevice=81.36
[ 15.515735] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 15.515753] usb 2-2: Product: JMS56x Series
[ 15.515771] usb 2-2: Manufacturer: JMicron
[ 15.515788] usb 2-2: SerialNumber: 1234567890123
[ 15.540573] scsi host1: uas
[ 15.542106] scsi 1:0:0:0: Direct-Access kimtigo SSD 240GB 8136 PQ: 0 ANSI: 6
[ 15.545443] sd 1:0:0:0: [sda] 468862128 512-byte logical blocks: (240 GB/224 GiB)
[ 15.545729] sd 1:0:0:0: [sda] Write Protect is off
[ 15.545750] sd 1:0:0:0: [sda] Mode Sense: 67 00 10 08
[ 15.545925] scsi 1:0:0:1: Direct-Access kimtigo SSD 240GB 8136 PQ: 0 ANSI: 6
[ 15.546437] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 15.549495] sd 1:0:0:0: [sda] Optimal transfer size 33553920 bytes
[ 15.554044] sd 1:0:0:1: [sdb] 468862128 512-byte logical blocks: (240 GB/224 GiB)
[ 15.554373] sd 1:0:0:1: [sdb] Write Protect is off
[ 15.554394] sd 1:0:0:1: [sdb] Mode Sense: 67 00 10 08
[ 15.554974] sd 1:0:0:1: [sdb] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 15.555920] sd 1:0:0:1: [sdb] Optimal transfer size 33553920 bytes
[ 15.639424] sdb: sdb1
[ 15.639922] sda: sda1
[ 15.646186] sd 1:0:0:1: [sdb] Attached SCSI disk
[ 15.646286] sd 1:0:0:0: [sda] Attached SCSI disk
[ 15.661802] sd 1:0:0:0: Attached scsi generic sg0 type 0
[ 15.662050] sd 1:0:0:1: Attached scsi generic sg1 type 0
[ 16.926463] Bluetooth: Core ver 2.22
[ 16.926566] NET: Registered protocol family 31
[ 16.926582] Bluetooth: HCI device and connection manager initialized
[ 16.926611] Bluetooth: HCI socket layer initialized
[ 16.926635] Bluetooth: L2CAP socket layer initialized
[ 16.926676] Bluetooth: SCO socket layer initialized
[ 16.943484] Bluetooth: HCI UART driver ver 2.3
[ 16.943508] Bluetooth: HCI UART protocol H4 registered
[ 16.943609] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 16.944166] Bluetooth: HCI UART protocol Broadcom registered
[ 17.267328] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,acl
[ 17.289421] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,acl
[ 17.349159] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 17.349179] Bluetooth: BNEP filters: protocol multicast
[ 17.349208] Bluetooth: BNEP socket layer initialized
thank you for the help in advance
