Hi!
My SATA2 and SATA4 ports are not working.
The HDDs are not recognized.
I tried to put another HDDs which are recognized in the SATA1 and SATA3, but nothing happen.
The HDDs are okay and the two port (SATA2 and SATA4) worked yesterday.
lsusb:
Bus 002 Device 003: ID 1058:0a10 Western Digital Technologies, Inc.
Bus 002 Device 052: ID 152d:0561 JMicron Technology Corp. / JMicron USA Technology Corp. JMS551 - Sharkoon SATA QuickPort Duo
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
dmesg:
[ 0.000000] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1403 SMP Mon Feb 22 11:33:35 GMT 2021
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem [mem 0x0000000030000000-0x00000000fbffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x00000000fbffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
[ 0.000000] On node 0 totalpages: 966656
[ 0.000000] DMA zone: 2304 pages used for memmap
[ 0.000000] HighMem zone: 770048 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
[ 0.000000] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 964352
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:76:2E:65 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait usbhid.mousepoll=0
[ 0.000000] Kernel parameter elevator= does not have any effect anymore.
Please use sysfs to set IO scheduler for individual devices.
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x0000000017cc0000-0x000000001bcc0000] (64MB)
[ 0.000000] Memory: 3472776K/3866624K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 131704K reserved, 262144K cma-reserved, 3080192K highmem)
[ 0.000000] ftrace: allocating 33942 entries in 67 pages
[ 0.000000] ftrace: allocated 67 pages with 3 groups
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
[ 0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000034] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000103] bcm2835: system timer (irq = 25)
[ 0.000765] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000787] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000810] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000829] Switching to timer-based delay loop, resolution 18ns
[ 0.001095] Console: colour dummy device 80x30
[ 0.001846] printk: console [tty1] enabled
[ 0.001916] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ 0.001971] pid_max: default: 32768 minimum: 301
[ 0.002156] LSM: Security Framework initializing
[ 0.002364] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002413] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.004063] Disabling memory control group subsystem
[ 0.004202] CPU: Testing write buffer coherency: ok
[ 0.004703] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.005943] Setting up static identity map for 0x200000 - 0x20003c
[ 0.006163] rcu: Hierarchical SRCU implementation.
[ 0.007139] smp: Bringing up secondary CPUs ...
[ 0.008424] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.009847] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.011314] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.011474] smp: Brought up 1 node, 4 CPUs
[ 0.011522] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.011554] CPU: All CPU(s) started in HYP mode.
[ 0.011580] CPU: Virtualization extensions available.
[ 0.012443] devtmpfs: initialized
[ 0.026711] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.026993] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.027049] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.034482] pinctrl core: initialized pinctrl subsystem
[ 0.035626] NET: Registered protocol family 16
[ 0.039862] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.040684] audit: initializing netlink subsys (disabled)
[ 0.041006] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[ 0.041586] thermal_sys: Registered thermal governor 'step_wise'
[ 0.042341] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.042396] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.042830] Serial: AMBA PL011 UART driver
[ 0.078531] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.090940] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-02-16T14:17:31, variant start
[ 0.100952] raspberrypi-firmware soc:firmware: Firmware hash is d6d82cf99bcb3e9a166a34cfde53130957a36bd3
[ 0.146043] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.150347] vgaarb: loaded
[ 0.150822] SCSI subsystem initialized
[ 0.151402] usbcore: registered new interface driver usbfs
[ 0.151480] usbcore: registered new interface driver hub
[ 0.151586] usbcore: registered new device driver usb
[ 0.151971] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.153985] clocksource: Switched to clocksource arch_sys_counter
[ 1.153957] VFS: Disk quotas dquot_6.6.0
[ 1.154177] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.154384] FS-Cache: Loaded
[ 1.154586] CacheFiles: Loaded
[ 1.155686] simple-framebuffer 3e3cf000.framebuffer: framebuffer at 0x3e3cf000, 0x7f8000 bytes, mapped to 0x(ptrval)
[ 1.155732] simple-framebuffer 3e3cf000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[ 1.166883] Console: switching to colour frame buffer device 240x67
[ 1.177070] simple-framebuffer 3e3cf000.framebuffer: fb0: simplefb registered!
[ 1.185921] NET: Registered protocol family 2
[ 1.186908] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.187142] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.187292] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.187438] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.187670] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.187778] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.188113] NET: Registered protocol family 1
[ 1.188921] RPC: Registered named UNIX socket transport module.
[ 1.189001] RPC: Registered udp transport module.
[ 1.189067] RPC: Registered tcp transport module.
[ 1.189131] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.189218] PCI: CLS 0 bytes, default 64
[ 1.192346] Initialise system trusted keyrings
[ 1.192680] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 1.201457] zbud: loaded
[ 1.203527] FS-Cache: Netfs 'nfs' registered for caching
[ 1.204427] NFS: Registering the id_resolver key type
[ 1.204533] Key type id_resolver registered
[ 1.204596] Key type id_legacy registered
[ 1.204785] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.205891] Key type asymmetric registered
[ 1.205958] Asymmetric key parser 'x509' registered
[ 1.206204] bounce: pool size: 64 pages
[ 1.206303] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.206603] io scheduler mq-deadline registered
[ 1.206670] io scheduler kyber registered
[ 1.211432] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.211545] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.211713] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[ 1.211901] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
[ 1.276090] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.279408] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.282320] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.285293] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.288287] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.291388] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.297878] PCI: bus0: Fast back to back transfers disabled
[ 1.301101] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.304150] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.307511] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 1.313890] PCI: bus1: Fast back to back transfers disabled
[ 1.316802] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.319647] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.322477] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.325290] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.328501] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 1.331528] pcieport 0000:00:00.0: PME: Signaling with IRQ 64
[ 1.346345] iproc-rng200 fe104000.rng: hwrng registered
[ 1.349520] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.353276] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.368671] brd: module loaded
[ 1.384185] loop: module loaded
[ 1.388770] Loading iSCSI transport class v2.0-870.
[ 1.394245] libphy: Fixed MDIO Bus: probed
[ 1.398893] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.414049] libphy: bcmgenet MII bus: probed
[ 1.494155] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.498176] usbcore: registered new interface driver r8152
[ 1.501025] usbcore: registered new interface driver lan78xx
[ 1.503829] usbcore: registered new interface driver smsc95xx
[ 1.508172] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
[ 1.511047] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.513745] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.519885] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
[ 1.523873] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 1.526595] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.529276] usb usb1: Product: xHCI Host Controller
[ 1.531938] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
[ 1.534612] usb usb1: SerialNumber: 0000:01:00.0
[ 1.537985] hub 1-0:1.0: USB hub found
[ 1.540672] hub 1-0:1.0: 1 port detected
[ 1.544038] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.546715] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.549407] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.552562] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 1.555280] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.557958] usb usb2: Product: xHCI Host Controller
[ 1.560638] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
[ 1.563318] usb usb2: SerialNumber: 0000:01:00.0
[ 1.566746] hub 2-0:1.0: USB hub found
[ 1.569518] hub 2-0:1.0: 4 ports detected
[ 1.573951] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.577032] dwc_otg: FIQ enabled
[ 1.577047] dwc_otg: NAK holdoff enabled
[ 1.577062] dwc_otg: FIQ split-transaction FSM enabled
[ 1.577081] Module dwc_common_port init
[ 1.577563] usbcore: registered new interface driver uas
[ 1.580340] usbcore: registered new interface driver usb-storage
[ 1.583190] mousedev: PS/2 mouse device common for all mice
[ 1.587585] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.593808] sdhci: Secure Digital Host Controller Interface driver
[ 1.596540] sdhci: Copyright(c) Pierre Ossman
[ 1.599896] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 1.603193] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.608993] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.612044] hid: raw HID events driver (C) Jiri Kosina
[ 1.614957] usbcore: registered new interface driver usbhid
[ 1.617644] usbhid: USB HID core driver
[ 1.626372] Initializing XFRM netlink socket
[ 1.629141] NET: Registered protocol family 17
[ 1.632012] Key type dns_resolver registered
[ 1.635112] Registering SWP/SWPB emulation handler
[ 1.637868] registered taskstats version 1
[ 1.640402] Loading compiled-in X.509 certificates
[ 1.643846] Key type ._fscrypt registered
[ 1.646736] Key type .fscrypt registered
[ 1.649301] Key type fscrypt-provisioning registered
[ 1.663538] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.666610] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.669255] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
[ 1.679352] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.683062] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.685775] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.717559] of_cfs_init
[ 1.720512] of_cfs_init: OK
[ 1.734436] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.738708] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.742919] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.748498] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.752690] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.757841] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 1.761518] Waiting for root device /dev/mmcblk0p7...
[ 1.798835] random: fast init done
[ 1.828435] mmc1: new high speed SDIO card at address 0001
[ 1.864422] mmc0: new ultra high speed DDR50 SDXC card at address aaaa
[ 1.867962] mmcblk0: mmc0:aaaa SN64G 59.5 GiB
[ 1.874855] mmcblk0: p1 p2 < p5 p6 p7 >
[ 1.894579] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[ 1.897284] VFS: Mounted root (ext4 filesystem) readonly on device 179:7.
[ 1.904088] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.908179] devtmpfs: mounted
[ 1.919836] Freeing unused kernel memory: 2048K
[ 1.954330] Run /sbin/init as init process
[ 1.956799] with arguments:
[ 1.956814] /sbin/init
[ 1.956828] with environment:
[ 1.956843] HOME=/
[ 1.956858] TERM=linux
[ 2.086659] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 2.089274] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.091934] usb 1-1: Product: USB2.0 Hub
[ 2.096852] hub 1-1:1.0: USB hub found
[ 2.099779] hub 1-1:1.0: 4 ports detected
[ 2.420662] systemd[1]: System time before build time, advancing clock.
[ 2.535695] NET: Registered protocol family 10
[ 2.539741] Segment Routing with IPv6
[ 2.619159] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.626148] systemd[1]: Detected architecture arm.
[ 2.709882] systemd[1]: Set hostname to <raspberry-pi-4>.
[ 3.377510] systemd[1]: /lib/systemd/system/winbind.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/winbindd.pid → /run/samba/winbindd.pid; please update the unit file accordingly.
[ 3.567540] systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
[ 3.619614] systemd[1]: /lib/systemd/system/fail2ban.service:12: PIDFile= references path below legacy directory /var/run/, updating /var/run/fail2ban/fail2ban.pid → /run/fail2ban/fail2ban.pid; please update the unit file accordingly.
[ 3.710168] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.729973] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.733318] systemd[1]: Reached target Swap.
[ 3.741636] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.745709] systemd[1]: Listening on udev Control Socket.
[ 3.753882] systemd[1]: Listening on udev Kernel Socket.
[ 3.765271] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 3.897517] i2c /dev entries driver
[ 4.530939] EXT4-fs (mmcblk0p7): re-mounted. Opts: (null)
[ 4.730156] systemd-journald[117]: Received request to flush runtime journal from PID 1
[ 4.975351] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 4.995480] fuse: init (API version 7.32)
[ 5.463445] Driver for 1-wire Dallas network protocol.
[ 5.470453] gpio-4 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 5.497502] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 5.498101] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 5.498621] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 5.502894] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 5.555977] mc: Linux media interface: v0.10
[ 5.577737] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.580165] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 5.580196] [vc_sm_connected_init]: start
[ 5.590051] videodev: Linux video capture interface: v2.00
[ 5.635689] [vc_sm_connected_init]: installed successfully
[ 5.649036] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.649979] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.652215] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.673763] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.675371] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 5.708868] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.732144] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 5.733734] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 5.734724] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 5.735313] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 5.735683] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 5.735720] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 5.735746] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 5.735769] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 5.735792] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 5.736004] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 5.757275] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.771348] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 5.771402] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 5.776007] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 5.776056] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 5.786881] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 5.786928] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 6.022855] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 6.073515] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 6.162406] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 6.268511] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 6.284375] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 6.286441] usbcore: registered new interface driver brcmfmac
[ 6.351723] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 6.351754] checking generic (3e3cf000 7f8000) vs hw (0 ffffffffffffffff)
[ 6.351771] fb0: switching to vc4drmfb from simple
[ 6.360143] Console: switching to colour dummy device 80x30
[ 6.376406] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 6.382062] vc4-drm gpu: [drm] HDMI-A-1: EDID is invalid:
[ 6.382086] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 6.382102] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 6.382164] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 6.382179] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 6.382194] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 6.382209] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 6.382224] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 6.382247] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 6.531076] Console: switching to colour frame buffer device 240x67
[ 6.561034] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[ 6.566299] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 6.578090] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan 4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
[ 6.956129] rtc-pcf8563 1-0051: registered as rtc0
[ 9.527642] uart-pl011 fe201000.serial: no DMA platform data
[ 9.619828] random: crng init done
[ 9.619855] random: 7 urandom warning(s) missed due to ratelimiting
[ 9.750225] 8021q: 802.1Q VLAN Support v1.8
[ 10.544216] Adding 2097148k swap on /var/swap. Priority:-2 extents:5 across:3309564k SSFS
[ 10.710695] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 10.711990] bcmgenet fd580000.ethernet eth0: Link is Down
[ 14.876659] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[ 14.876696] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 15.094318] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 15.125417] usb 2-1: New USB device found, idVendor=152d, idProduct=0561, bcdDevice= 0.01
[ 15.125428] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 15.125436] usb 2-1: Product: JMS56x Series
[ 15.125443] usb 2-1: Manufacturer: JMicron
[ 15.125449] usb 2-1: SerialNumber: RANDOM__7067CDEBB6A0
[ 15.130490] usb-storage 2-1:1.0: USB Mass Storage device detected
[ 15.130874] scsi host0: usb-storage 2-1:1.0
[ 15.614800] broken atomic modeset userspace detected, disabling atomic
[ 16.234338] usb 2-2: new SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 16.265464] usb 2-2: New USB device found, idVendor=1058, idProduct=0a10, bcdDevice=81.36
[ 16.265476] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 16.265484] usb 2-2: Product: JMS56x Series
[ 16.265491] usb 2-2: Manufacturer: JMicron
[ 16.265498] usb 2-2: SerialNumber: 1234567890123
[ 16.283856] scsi host1: uas
[ 16.285784] scsi 1:0:0:0: Direct-Access HGST HTS 721010A9E630 8136 PQ: 0 ANSI: 6
[ 16.288530] sd 1:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 16.288799] sd 1:0:0:0: [sda] Write Protect is off
[ 16.288808] sd 1:0:0:0: [sda] Mode Sense: 67 00 10 08
[ 16.289294] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 16.290099] sd 1:0:0:0: [sda] Optimal transfer size 33553920 bytes
[ 16.291919] scsi 1:0:0:1: Direct-Access HGST HTS 721010A9E630 8136 PQ: 0 ANSI: 6
[ 16.297725] sd 1:0:0:1: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 16.297976] sd 1:0:0:1: [sdb] Write Protect is off
[ 16.297990] sd 1:0:0:1: [sdb] Mode Sense: 67 00 10 08
[ 16.298495] sd 1:0:0:1: [sdb] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 16.299276] sd 1:0:0:1: [sdb] Optimal transfer size 33553920 bytes
[ 16.372225] sd 1:0:0:0: Attached scsi generic sg0 type 0
[ 16.373582] sd 1:0:0:1: Attached scsi generic sg1 type 0
[ 16.376330] sda: sda1
[ 16.387052] sdb: sdb1
[ 16.389869] sd 1:0:0:0: [sda] Attached SCSI disk
[ 16.390505] sd 1:0:0:1: [sdb] Attached SCSI disk
[ 16.626179] Bluetooth: Core ver 2.22
[ 16.626248] NET: Registered protocol family 31
[ 16.626255] Bluetooth: HCI device and connection manager initialized
[ 16.626272] Bluetooth: HCI socket layer initialized
[ 16.626282] Bluetooth: L2CAP socket layer initialized
[ 16.626298] Bluetooth: SCO socket layer initialized
[ 16.637138] Bluetooth: HCI UART driver ver 2.3
[ 16.637149] Bluetooth: HCI UART protocol H4 registered
[ 16.637204] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 16.637374] Bluetooth: HCI UART protocol Broadcom registered
[ 17.426008] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 17.426017] Bluetooth: BNEP filters: protocol multicast
[ 17.426032] Bluetooth: BNEP socket layer initialized
[ 17.532982] Bluetooth: RFCOMM TTY layer initialized
[ 17.533001] Bluetooth: RFCOMM socket layer initialized
[ 17.533021] Bluetooth: RFCOMM ver 1.11
[ 19.658400] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 20.120879] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
[ 23.564022] usb 2-1: USB disconnect, device number 2
[ 24.008708] usb 2-1: new SuperSpeed Gen 1 USB device number 4 using xhci_hcd
[ 24.035458] usb 2-1: New USB device found, idVendor=152d, idProduct=0561, bcdDevice= 0.01
[ 24.035470] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 24.035478] usb 2-1: Product: JMS56x Series
[ 24.035484] usb 2-1: Manufacturer: JMicron
[ 24.035491] usb 2-1: SerialNumber: RANDOM__FC090397067C
[ 24.038123] usb-storage 2-1:1.0: USB Mass Storage device detected
[ 24.042098] scsi host0: usb-storage 2-1:1.0
[ 47.224290] usb 2-1: USB disconnect, device number 4
[ 47.634318] usb 2-1: new SuperSpeed Gen 1 USB device number 5 using xhci_hcd
[ 47.665424] usb 2-1: New USB device found, idVendor=152d, idProduct=0561, bcdDevice= 0.01
[ 47.665435] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 47.665443] usb 2-1: Product: JMS56x Series
[ 47.665450] usb 2-1: Manufacturer: JMicron
[ 47.665457] usb 2-1: SerialNumber: RANDOM__1CC4CDBF833E
[ 47.668703] usb-storage 2-1:1.0: USB Mass Storage device detected
[ 47.669167] scsi host0: usb-storage 2-1:1.0
I don’t know what is JMicron Technology Corp. / JMicron USA Technology Corp. JMS551 - Sharkoon SATA QuickPort Duo, it should be Western Digital Technologies, Inc.
What could be the problem?
@setq do you have any idea how to determine what could be the issue?
