Linux minidlna 5.10.17-v7l+ #1403 SMP Mon Feb 22 11:33:35 GMT 2021 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Tue Mar 16 18:51:01 2021 from 192.168.178.45
e]0;pi@minidlna: ~ae[01;32mpi@minidlnae[00m:e[01;34m~ $e[00m dmesg
e[32m[ 0.000000] e[0mBooting Linux on physical CPU 0x0
e[32m[ 0.000000] e[0mLinux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1403 SMP Mon Feb 22 11:33:35 GMT 2021
e[32m[ 0.000000] e[0me[33mCPUe[0m: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
e[32m[ 0.000000] e[0me[33mCPUe[0m: div instructions available: patching division code
e[32m[ 0.000000] e[0me[33mCPUe[0m: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
e[32m[ 0.000000] e[0me[33mOFe[0m: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
e[32m[ 0.000000] e[0me[33mMemory policye[0m: Data cache writealloc
e[32m[ 0.000000] e[0me[33mReserved memorye[0m: created CMA memory pool at 0x000000001ec00000, size 256 MiB
e[32m[ 0.000000] e[0me[33mOFe[0m: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
e[32m[ 0.000000] e[0mZone ranges:
e[32m[ 0.000000] e[0m DMA [mem 0x0000000000000000-0x000000002fffffff]
e[32m[ 0.000000] e[0m Normal empty
e[32m[ 0.000000] e[0m HighMem [mem 0x0000000030000000-0x00000000fbffffff]
e[32m[ 0.000000] e[0mMovable zone start for each node
e[32m[ 0.000000] e[0mEarly memory node ranges
e[32m[ 0.000000] e[0me[33m node 0e[0m: [mem 0x0000000000000000-0x000000003b3fffff]
e[32m[ 0.000000] e[0me[33m node 0e[0m: [mem 0x0000000040000000-0x00000000fbffffff]
e[32m[ 0.000000] e[0mInitmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
e[32m[ 0.000000] e[0me[33mOn node 0 totalpagese[0m: 1012736
e[32m[ 0.000000] e[0me[33m DMA zonee[0m: 2304 pages used for memmap
e[32m[ 0.000000] e[0me[33m DMA zonee[0m: 0 pages reserved
e[32m[ 0.000000] e[0me[33m DMA zonee[0m: 196608 pages, LIFO batch:63
e[32m[ 0.000000] e[0me[33m HighMem zonee[0m: 816128 pages, LIFO batch:63
e[32m[ 0.000000] e[0me[33mpercpue[0m: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
e[32m[ 0.000000] e[0me[33mpcpu-alloce[0m: s50700 r8192 d23028 u81920 alloc=20*4096
e[32m[ 0.000000] e[0me[33mpcpu-alloce[0m: [0] 0 [0] 1 [0] 2 [0] 3
e[32m[ 0.000000] e[0me[33mBuilt 1 zonelists, mobility grouping on. Total pagese[0m: 1010432
e[32m[ 0.000000] e[0me[33mKernel command linee[0m: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=DC:A6:32:24:34:20 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=d4c604ee-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
e[32m[ 0.000000] e[0me[1mKernel parameter elevator= does not have any effect anymore.
Please use sysfs to set IO scheduler for individual devices.e[0m
e[32m[ 0.000000] e[0me[33mDentry cache hash table entriese[0m: 131072 (order: 7, 524288 bytes, linear)
e[32m[ 0.000000] e[0me[33mInode-cache hash table entriese[0m: 65536 (order: 6, 262144 bytes, linear)
e[32m[ 0.000000] e[0me[33mmem auto-inite[0m: stack:off, heap alloc:off, heap free:off
e[32m[ 0.000000] e[0me[33msoftware IO TLBe[0m: mapped [mem 0x0000000017cc0000-0x000000001bcc0000] (64MB)
e[32m[ 0.000000] e[0me[33mMemorye[0m: 3654936K/4050944K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 133864K reserved, 262144K cma-reserved, 3264512K highmem)
e[32m[ 0.000000] e[0me[33mSLUBe[0m: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
e[32m[ 0.000000] e[0me[33mftracee[0m: allocating 33942 entries in 67 pages
e[32m[ 0.000000] e[0me[33mftracee[0m: allocated 67 pages with 3 groups
e[32m[ 0.000000] e[0me[33mrcue[0m: Hierarchical RCU implementation.
e[32m[ 0.000000] e[0m Rude variant of Tasks RCU enabled.
e[32m[ 0.000000] e[0m Tracing variant of Tasks RCU enabled.
e[32m[ 0.000000] e[0me[33mrcue[0m: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
e[32m[ 0.000000] e[0me[33mNR_IRQSe[0m: 16, nr_irqs: 16, preallocated irqs: 16
e[32m[ 0.000000] e[0me[33mGICe[0m: Using split EOI/Deactivate mode
e[32m[ 0.000000] e[0me[33mrandome[0m: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
e[32m[ 0.000007] e[0me[33msched_clocke[0m: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
e[32m[ 0.000034] e[0me[33mclocksourcee[0m: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
e[32m[ 0.000096] e[0me[33mbcm2835e[0m: system timer (irq = 25)
e[32m[ 0.000750] e[0me[33march_timere[0m: cp15 timer(s) running at 54.00MHz (phys).
e[32m[ 0.000771] e[0me[33mclocksourcee[0m: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
e[32m[ 0.000793] e[0me[33msched_clocke[0m: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
e[32m[ 0.000812] e[0mSwitching to timer-based delay loop, resolution 18ns
e[32m[ 0.001067] e[0me[33mConsolee[0m: colour dummy device 80x30
e[32m[ 0.001805] e[0me[33mprintke[0m: console [tty1] enabled
e[32m[ 0.001871] e[0mCalibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=540000)
e[32m[ 0.001925] e[0me[33mpid_maxe[0m: default: 32768 minimum: 301
e[32m[ 0.002108] e[0me[33mLSMe[0m: Security Framework initializing
e[32m[ 0.002305] e[0me[33mMount-cache hash table entriese[0m: 2048 (order: 1, 8192 bytes, linear)
e[32m[ 0.002351] e[0me[33mMountpoint-cache hash table entriese[0m: 2048 (order: 1, 8192 bytes, linear)
e[32m[ 0.003927] e[0mDisabling memory control group subsystem
e[32m[ 0.004061] e[0me[33mCPUe[0m: Testing write buffer coherency: ok
e[32m[ 0.004533] e[0me[33mCPU0e[0m: thread -1, cpu 0, socket 0, mpidr 80000000
e[32m[ 0.005756] e[0mSetting up static identity map for 0x200000 - 0x20003c
e[32m[ 0.005971] e[0me[33mrcue[0m: Hierarchical SRCU implementation.
e[32m[ 0.006909] e[0me[33msmpe[0m: Bringing up secondary CPUs …
e[32m[ 0.008132] e[0me[33mCPU1e[0m: thread -1, cpu 1, socket 0, mpidr 80000001
e[32m[ 0.009501] e[0me[33mCPU2e[0m: thread -1, cpu 2, socket 0, mpidr 80000002
e[32m[ 0.010807] e[0me[33mCPU3e[0m: thread -1, cpu 3, socket 0, mpidr 80000003
e[32m[ 0.010963] e[0me[33msmpe[0m: Brought up 1 node, 4 CPUs
e[32m[ 0.011009] e[0me[33mSMPe[0m: Total of 4 processors activated (432.00 BogoMIPS).
e[32m[ 0.011039] e[0me[33mCPUe[0m: All CPU(s) started in HYP mode.
e[32m[ 0.011065] e[0me[33mCPUe[0m: Virtualization extensions available.
e[32m[ 0.011903] e[0me[33mdevtmpfse[0m: initialized
e[32m[ 0.025851] e[0me[33mVFP support v0.3e[0m: implementor 41 architecture 3 part 40 variant 8 rev 0
e[32m[ 0.026112] e[0me[33mclocksourcee[0m: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
e[32m[ 0.026166] e[0me[33mfutex hash table entriese[0m: 1024 (order: 4, 65536 bytes, linear)
e[32m[ 0.033229] e[0me[33mpinctrl coree[0m: initialized pinctrl subsystem
e[32m[ 0.034326] e[0me[33mNETe[0m: Registered protocol family 16
e[32m[ 0.038317] e[0me[33mDMAe[0m: preallocated 1024 KiB pool for atomic coherent allocations
e[32m[ 0.039100] e[0me[33maudite[0m: initializing netlink subsys (disabled)
e[32m[ 0.039372] e[0me[33maudite[0m: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
e[32m[ 0.039942] e[0me[33mthermal_syse[0m: Registered thermal governor ‘step_wise’
e[32m[ 0.040635] e[0me[33mhw-breakpointe[0m: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
e[32m[ 0.040690] e[0me[33mhw-breakpointe[0m: maximum watchpoint size is 8 bytes.
e[32m[ 0.041126] e[0me[33mSeriale[0m: AMBA PL011 UART driver
e[32m[ 0.074185] e[0me[33mbcm2835-mbox fe00b880.mailboxe[0m: mailbox enabled
e[32m[ 0.091015] e[0me[33mraspberrypi-firmware soc:firmwaree[0m: Attached to firmware from 2021-02-25T12:10:40, variant start
e[32m[ 0.101028] e[0me[33mraspberrypi-firmware soc:firmwaree[0m: Firmware hash is 564e5f9b852b23a330b1764bcf0b2d022a20afd0
e[32m[ 0.145960] e[0me[33mbcm2835-dma fe007000.dmae[0m: DMA legacy API manager, dmachans=0x1
e[32m[ 0.150153] e[0me[33mvgaarbe[0m: loaded
e[32m[ 0.150608] e[0mSCSI subsystem initialized
e[32m[ 0.150847] e[0me[33musbcoree[0m: registered new interface driver usbfs
e[32m[ 0.150923] e[0me[33musbcoree[0m: registered new interface driver hub
e[32m[ 0.151033] e[0me[33musbcoree[0m: registered new device driver usb
e[32m[ 0.151800] e[0me[33musb_phy_generic phye[0me[1m: supply vcc not found, using dummy regulatore[0m
e[32m[ 0.153688] e[0me[33mclocksourcee[0m: Switched to clocksource arch_sys_counter
e[32m[ 1.153458] e[0me[33mVFSe[0m: Disk quotas dquot_6.6.0
e[32m[ 1.153586] e[0me[33mVFSe[0m: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
e[32m[ 1.153811] e[0me[33mFS-Cachee[0m: Loaded
e[32m[ 1.154036] e[0me[33mCacheFilese[0m: Loaded
e[32m[ 1.164507] e[0me[33mNETe[0m: Registered protocol family 2
e[32m[ 1.165344] e[0me[33mtcp_listen_portaddr_hash hash table entriese[0m: 512 (order: 0, 6144 bytes, linear)
e[32m[ 1.165502] e[0me[33mTCP established hash table entriese[0m: 8192 (order: 3, 32768 bytes, linear)
e[32m[ 1.165583] e[0me[33mTCP bind hash table entriese[0m: 8192 (order: 4, 65536 bytes, linear)
e[32m[ 1.165670] e[0me[33mTCPe[0m: Hash tables configured (established 8192 bind 8192)
e[32m[ 1.165846] e[0me[33mUDP hash table entriese[0m: 512 (order: 2, 16384 bytes, linear)
e[32m[ 1.165901] e[0me[33mUDP-Lite hash table entriese[0m: 512 (order: 2, 16384 bytes, linear)
e[32m[ 1.166180] e[0me[33mNETe[0m: Registered protocol family 1
e[32m[ 1.166914] e[0me[33mRPCe[0m: Registered named UNIX socket transport module.
e[32m[ 1.166948] e[0me[33mRPCe[0m: Registered udp transport module.
e[32m[ 1.166976] e[0me[33mRPCe[0m: Registered tcp transport module.
e[32m[ 1.167004] e[0me[33mRPCe[0m: Registered tcp NFSv4.1 backchannel transport module.
e[32m[ 1.167041] e[0me[33mPCIe[0m: CLS 0 bytes, default 64
e[32m[ 1.169956] e[0mInitialise system trusted keyrings
e[32m[ 1.170199] e[0me[33mworkingsete[0m: timestamp_bits=14 max_order=20 bucket_order=6
e[32m[ 1.178796] e[0me[33mzbude[0m: loaded
e[32m[ 1.180696] e[0me[33mFS-Cachee[0m: Netfs ‘nfs’ registered for caching
e[32m[ 1.181453] e[0me[33mNFSe[0m: Registering the id_resolver key type
e[32m[ 1.181505] e[0mKey type id_resolver registered
e[32m[ 1.181534] e[0mKey type id_legacy registered
e[32m[ 1.181694] e[0me[33mnfs4filelayout_inite[0m: NFSv4 File Layout Driver Registering…
e[32m[ 1.182721] e[0mKey type asymmetric registered
e[32m[ 1.182753] e[0mAsymmetric key parser ‘x509’ registered
e[32m[ 1.182959] e[0me[33mbouncee[0m: pool size: 64 pages
e[32m[ 1.183033] e[0mBlock layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
e[32m[ 1.183264] e[0mio scheduler mq-deadline registered
e[32m[ 1.183295] e[0mio scheduler kyber registered
e[32m[ 1.187752] e[0me[33mbrcm-pcie fd500000.pciee[0m: host bridge /scb/pcie@7d500000 ranges:
e[32m[ 1.187805] e[0me[33mbrcm-pcie fd500000.pciee[0m: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
e[32m[ 1.187906] e[0me[33mbrcm-pcie fd500000.pciee[0m: MEM 0x0600000000…0x063fffffff -> 0x00c0000000
e[32m[ 1.188015] e[0me[33mbrcm-pcie fd500000.pciee[0m: IB MEM 0x0000000000…0x00bfffffff -> 0x0400000000
e[32m[ 1.245827] e[0me[33mbrcm-pcie fd500000.pciee[0m: link up, 5.0 GT/s PCIe x1 (SSC)
e[32m[ 1.246238] e[0me[33mbrcm-pcie fd500000.pciee[0m: PCI host bridge to bus 0000:00
e[32m[ 1.246275] e[0me[33mpci_bus 0000:00e[0m: root bus resource [bus 00-ff]
e[32m[ 1.246310] e[0me[33mpci_bus 0000:00e[0m: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
e[32m[ 1.246419] e[0me[33mpci 0000:00:00.0e[0m: [14e4:2711] type 01 class 0x060400
e[32m[ 1.246677] e[0me[33mpci 0000:00:00.0e[0m: PME# supported from D0 D3hot
e[32m[ 1.250182] e[0me[33mPCIe[0m: bus0: Fast back to back transfers disabled
e[32m[ 1.250537] e[0me[33mpci 0000:01:00.0e[0m: [1106:3483] type 00 class 0x0c0330
e[32m[ 1.250681] e[0me[33mpci 0000:01:00.0e[0m: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
e[32m[ 1.251131] e[0me[33mpci 0000:01:00.0e[0m: PME# supported from D0 D3cold
e[32m[ 1.254638] e[0me[33mPCIe[0m: bus1: Fast back to back transfers disabled
e[32m[ 1.254751] e[0me[33mpci 0000:00:00.0e[0m: BAR 8: assigned [mem 0x600000000-0x6000fffff]
e[32m[ 1.254791] e[0me[33mpci 0000:01:00.0e[0m: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
e[32m[ 1.254894] e[0me[33mpci 0000:00:00.0e[0m: PCI bridge to [bus 01]
e[32m[ 1.254934] e[0me[33mpci 0000:00:00.0e[0m: bridge window [mem 0x600000000-0x6000fffff]
e[32m[ 1.255358] e[0me[33mpcieport 0000:00:00.0e[0m: enabling device (0140 -> 0142)
e[32m[ 1.255602] e[0me[33mpcieport 0000:00:00.0e[0m: PME: Signaling with IRQ 63
e[32m[ 1.264158] e[0me[33miproc-rng200 fe104000.rnge[0m: hwrng registered
e[32m[ 1.264483] e[0me[33mvc-meme[0m: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
e[32m[ 1.265370] e[0me[33mgpiomem-bcm2835 fe200000.gpiomeme[0m: Initialised: Registers at 0xfe200000
e[32m[ 1.277644] e[0me[33mbrde[0m: module loaded
e[32m[ 1.289908] e[0me[33mloope[0m: module loaded
e[32m[ 1.291584] e[0mLoading iSCSI transport class v2.0-870.
e[32m[ 1.294111] e[0me[33mlibphye[0m: Fixed MDIO Bus: probed
e[32m[ 1.295832] e[0me[33mbcmgenet fd580000.ethernete[0m: GENET 5.0 EPHY: 0x0000
e[32m[ 1.313765] e[0me[33mlibphye[0m: bcmgenet MII bus: probed
e[32m[ 1.393885] e[0me[33munimac-mdio unimac-mdio.-19e[0m: Broadcom UniMAC MDIO bus
e[32m[ 1.395067] e[0me[33musbcoree[0m: registered new interface driver r8152
e[32m[ 1.395154] e[0me[33musbcoree[0m: registered new interface driver lan78xx
e[32m[ 1.395231] e[0me[33musbcoree[0m: registered new interface driver smsc95xx
e[32m[ 1.396859] e[0me[33mxhci_hcd 0000:01:00.0e[0m: enabling device (0140 -> 0142)
e[32m[ 1.397040] e[0me[33mxhci_hcd 0000:01:00.0e[0m: xHCI Host Controller
e[32m[ 1.397089] e[0me[33mxhci_hcd 0000:01:00.0e[0m: new USB bus registered, assigned bus number 1
e[32m[ 1.400444] e[0me[33mxhci_hcd 0000:01:00.0e[0m: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
e[32m[ 1.401795] e[0me[33musb usb1e[0m: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
e[32m[ 1.401836] e[0me[33musb usb1e[0m: New USB device strings: Mfr=3, Product=2, SerialNumber=1
e[32m[ 1.401871] e[0me[33musb usb1e[0m: Product: xHCI Host Controller
e[32m[ 1.401901] e[0me[33musb usb1e[0m: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
e[32m[ 1.401932] e[0me[33musb usb1e[0m: SerialNumber: 0000:01:00.0
e[32m[ 1.402695] e[0me[33mhub 1-0:1.0e[0m: USB hub found
e[32m[ 1.402821] e[0me[33mhub 1-0:1.0e[0m: 1 port detected
e[32m[ 1.403503] e[0me[33mxhci_hcd 0000:01:00.0e[0m: xHCI Host Controller
e[32m[ 1.403560] e[0me[33mxhci_hcd 0000:01:00.0e[0m: new USB bus registered, assigned bus number 2
e[32m[ 1.403605] e[0me[33mxhci_hcd 0000:01:00.0e[0m: Host supports USB 3.0 SuperSpeed
e[32m[ 1.404209] e[0me[33musb usb2e[0m: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
e[32m[ 1.404249] e[0me[33musb usb2e[0m: New USB device strings: Mfr=3, Product=2, SerialNumber=1
e[32m[ 1.404285] e[0me[33musb usb2e[0m: Product: xHCI Host Controller
e[32m[ 1.404314] e[0me[33musb usb2e[0m: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
e[32m[ 1.404345] e[0me[33musb usb2e[0m: SerialNumber: 0000:01:00.0
e[32m[ 1.405065] e[0me[33mhub 2-0:1.0e[0m: USB hub found
e[32m[ 1.405157] e[0me[33mhub 2-0:1.0e[0m: 4 ports detected
e[32m[ 1.406860] e[0me[33mdwc_otge[0m: version 3.00a 10-AUG-2012 (platform bus)
e[32m[ 1.407189] e[0me[33mdwc_otge[0m: FIQ enabled
e[32m[ 1.407203] e[0me[33mdwc_otge[0m: NAK holdoff enabled
e[32m[ 1.407218] e[0me[33mdwc_otge[0m: FIQ split-transaction FSM enabled
e[32m[ 1.407236] e[0mModule dwc_common_port init
e[32m[ 1.407666] e[0me[33musbcoree[0m: registered new interface driver uas
e[32m[ 1.407793] e[0me[33musbcoree[0m: registered new interface driver usb-storage
e[32m[ 1.408001] e[0me[33mmousedeve[0m: PS/2 mouse device common for all mice
e[32m[ 1.409691] e[0me[33mbcm2835-wdt bcm2835-wdte[0m: Broadcom BCM2835 watchdog timer
e[32m[ 1.413204] e[0me[33msdhcie[0m: Secure Digital Host Controller Interface driver
e[32m[ 1.413237] e[0me[33msdhcie[0m: Copyright© Pierre Ossman
e[32m[ 1.414058] e[0me[33mmmc-bcm2835 fe300000.mmcnre[0m: could not get clk, deferring probe
e[32m[ 1.414721] e[0me[33msdhci-pltfme[0m: SDHCI platform and OF driver helper
e[32m[ 1.418921] e[0me[33mledtrig-cpue[0m: registered to indicate activity on CPUs
e[32m[ 1.419284] e[0me[33mhide[0m: raw HID events driver © Jiri Kosina
e[32m[ 1.419510] e[0me[33musbcoree[0m: registered new interface driver usbhid
e[32m[ 1.419540] e[0me[33musbhide[0m: USB HID core driver
e[32m[ 1.425314] e[0mInitializing XFRM netlink socket
e[32m[ 1.425376] e[0me[33mNETe[0m: Registered protocol family 17
e[32m[ 1.425510] e[0mKey type dns_resolver registered
e[32m[ 1.425880] e[0mRegistering SWP/SWPB emulation handler
e[32m[ 1.426074] e[0mregistered taskstats version 1
e[32m[ 1.426115] e[0mLoading compiled-in X.509 certificates
e[32m[ 1.426962] e[0mKey type ._fscrypt registered
e[32m[ 1.426993] e[0mKey type .fscrypt registered
e[32m[ 1.427021] e[0mKey type fscrypt-provisioning registered
e[32m[ 1.438592] e[0me[33muart-pl011 fe201000.seriale[0m: there is not valid maps for state default
e[32m[ 1.438934] e[0me[33muart-pl011 fe201000.seriale[0m: cts_event_workaround enabled
e[32m[ 1.439039] e[0me[33mfe201000.seriale[0m: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
e[32m[ 1.445756] e[0me[33mbcm2835-power bcm2835-powere[0m: Broadcom BCM2835 power domains driver
e[32m[ 1.446832] e[0me[33mmmc-bcm2835 fe300000.mmcnre[0m: mmc_debug:0 mmc_debug2:0
e[32m[ 1.446866] e[0me[33mmmc-bcm2835 fe300000.mmcnre[0m: DMA channel allocated
e[32m[ 1.477155] e[0mof_cfs_init
e[32m[ 1.477436] e[0me[33mof_cfs_inite[0m: OK
e[32m[ 1.497455] e[0me[33mmmc1e[0me[1m: queuing unknown CIS tuple 0x80 (2 bytes)e[0m
e[32m[ 1.499162] e[0me[33mmmc1e[0me[1m: queuing unknown CIS tuple 0x80 (3 bytes)e[0m
e[32m[ 1.500865] e[0me[33mmmc1e[0me[1m: queuing unknown CIS tuple 0x80 (3 bytes)e[0m
e[32m[ 1.503978] e[0me[33mmmc1e[0me[1m: queuing unknown CIS tuple 0x80 (7 bytes)e[0m
e[32m[ 1.505682] e[0me[33mmmc1e[0me[1m: queuing unknown CIS tuple 0x80 (3 bytes)e[0m
e[32m[ 1.513662] e[0me[33mmmc0e[0m: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
e[32m[ 1.515877] e[0mWaiting for root device PARTUUID=d4c604ee-02…
e[32m[ 1.550131] e[0me[33mrandome[0m: fast init done
e[32m[ 1.573048] e[0me[33mmmc1e[0m: new high speed SDIO card at address 0001
e[32m[ 1.763734] e[0me[33musb 1-1e[0m: new high-speed USB device number 2 using xhci_hcd
e[32m[ 1.786481] e[0me[33mmmc0e[0m: new ultra high speed DDR50 SDHC card at address 1b1c
e[32m[ 1.787404] e[0me[33mmmcblk0e[0m: mmc0:1b1c UC0D5 29.8 GiB
e[32m[ 1.789520] e[0me[33m mmcblk0e[0m: p1 p2
e[32m[ 1.821924] e[0me[33mEXT4-fs (mmcblk0p2)e[0m: INFO: recovery required on readonly filesystem
e[32m[ 1.821967] e[0me[33mEXT4-fs (mmcblk0p2)e[0m: write access will be enabled during recovery
e[32m[ 1.920574] e[0me[33mEXT4-fs (mmcblk0p2)e[0m: recovery complete
e[32m[ 1.925103] e[0me[33mEXT4-fs (mmcblk0p2)e[0m: mounted filesystem with ordered data mode. Opts: (null)
e[32m[ 1.925198] e[0me[33mVFSe[0m: Mounted root (ext4 filesystem) readonly on device 179:2.
e[32m[ 1.930025] e[0me[33mdevtmpfse[0m: mounted
e[32m[ 1.938991] e[0me[33mFreeing unused kernel memorye[0m: 2048K
e[32m[ 1.939333] e[0mRun /sbin/init as init process
e[32m[ 1.939362] e[0m with arguments:
e[32m[ 1.939376] e[0m /sbin/init
e[32m[ 1.939390] e[0m with environment:
e[32m[ 1.939404] e[0m HOME=/
e[32m[ 1.939418] e[0m TERM=linux
e[32m[ 1.946401] e[0me[33musb 1-1e[0m: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
e[32m[ 1.946444] e[0me[33musb 1-1e[0m: New USB device strings: Mfr=0, Product=1, SerialNumber=0
e[32m[ 1.946479] e[0me[33musb 1-1e[0m: Product: USB2.0 Hub
e[32m[ 1.948563] e[0me[33mhub 1-1:1.0e[0m: USB hub found
e[32m[ 1.948857] e[0me[33mhub 1-1:1.0e[0m: 4 ports detected
e[32m[ 2.382998] e[0me[33msystemd[1]e[0m: System time before build time, advancing clock.
e[32m[ 2.494233] e[0me[33mNETe[0m: Registered protocol family 10
e[32m[ 2.495648] e[0mSegment Routing with IPv6
e[32m[ 2.558831] e[0me[33msystemd[1]e[0m: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
e[32m[ 2.559640] e[0me[33msystemd[1]e[0m: Detected architecture arm.
e[32m[ 2.621505] e[0me[33msystemd[1]e[0m: Set hostname to .
e[32m[ 3.065934] e[0me[33mrandome[0m: lvmconfig: uninitialized urandom read (4 bytes read)
e[32m[ 3.589336] e[0me[33msystemd[1]e[0m: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
e[32m[ 3.618262] e[0me[33msystemd[1]e[0m: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
e[32m[ 3.696130] e[0me[33msystemd[1]e[0m: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
e[32m[ 3.776046] e[0me[33mrandome[0m: systemd: uninitialized urandom read (16 bytes read)
e[32m[ 3.805496] e[0me[33mrandome[0m: systemd: uninitialized urandom read (16 bytes read)
e[32m[ 3.806244] e[0me[33msystemd[1]e[0m: Listening on Syslog Socket.
e[32m[ 3.807771] e[0me[33msystemd[1]e[0m: Listening on udev Control Socket.
e[32m[ 3.808513] e[0me[33msystemd[1]e[0m: Started Forward Password Requests to Wall Directory Watch.
e[32m[ 3.809242] e[0me[33msystemd[1]e[0m: Listening on initctl Compatibility Named Pipe.
e[32m[ 3.936696] e[0mInstalling knfsd (copyright © 1996 [email protected]).
e[32m[ 4.561556] e[0me[33mEXT4-fs (mmcblk0p2)e[0m: re-mounted. Opts: (null)
e[32m[ 4.675966] e[0me[33msystemd-journald[147]e[0m: Received request to flush runtime journal from PID 1
