After updating the PI software and packages, upgrading the firmware and reinstalling the script the top hat fan will not spin. Several reboots and complete power shutdown/unplugged the fan will not activate at any temp. I verified the fan does have power and is not defective. My thought is that in the updating process the code to activate the fan is stopped working. Thoughts/ideas? Appreciate the help.
What about uname -a?
Please downgrade your kernel to stable.
Results of uname -a
Linux PiNAS 4.19.118-v7l+ #1311 SMP Mon Apr 27 14:26:42 BST 2020 armv7l GNU/Linux
To be clear the kernel was not updated when I performed the standard sudo apt update && sudo apt -y full-upgrade
What kernel do you suggest I downgrade to?
I thought you have done an rpi-update.
Please tell me the result of sudo systemctl status pigpiod.service
Results below:
pigpiod.service - Daemon required to control GPIO pins via pigpio
Loaded: loaded (/lib/systemd/system/pigpiod.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2020-07-09 10:33:16 CDT; 7h ago
Process: 650 ExecStart=/usr/bin/pigpiod -l (code=exited, status=0/SUCCESS)
Main PID: 663 (pigpiod)
Tasks: 4 (limit: 4915)
Memory: 760.0K
CGroup: /system.slice/pigpiod.service
└─663 /usr/bin/pigpiod -l
Jul 09 10:33:16 PiNAS systemd[1]: Starting Daemon required to control GPIO pins via pigpio…
Jul 09 10:33:16 PiNAS systemd[1]: Started Daemon required to control GPIO pins via pigpio.
sudo systemctl status rockpi-sata.service
Results below:
rockpi-sata.service - Rockpi SATA Hat
Loaded: loaded (/lib/systemd/system/rockpi-sata.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2020-07-09 10:39:17 CDT; 11h ago
Main PID: 3429 (python3)
Memory: 12.1M
CGroup: /system.slice/rockpi-sata.service
├─3429 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
├─3455 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
├─3456 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
└─3457 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
Jul 09 10:39:20 PiNAS python3[3429]: self._target(*self._args, **self._kwargs)
Jul 09 10:39:20 PiNAS python3[3429]: File “/usr/bin/rockpi-sata/fan.py”, line 80, in running
Jul 09 10:39:20 PiNAS python3[3429]: change_dc(get_dc())
Jul 09 10:39:20 PiNAS python3[3429]: File “/usr/bin/rockpi-sata/fan.py”, line 74, in change_dc
Jul 09 10:39:20 PiNAS python3[3429]: gpio.hardware_PWM(12, 25000, dc * 10000)
Jul 09 10:39:20 PiNAS python3[3429]: File “/usr/lib/python3/dist-packages/pigpio.py”, line 2013, in hardware_PWM
Jul 09 10:39:20 PiNAS python3[3429]: self.sl, _PI_CMD_HP, gpio, PWMfreq, 4, extents))
Jul 09 10:39:20 PiNAS python3[3429]: File “/usr/lib/python3/dist-packages/pigpio.py”, line 1030, in _pigpio_command_ex
Jul 09 10:39:20 PiNAS python3[3429]: sl.s.sendall(ext)
Jul 09 10:39:20 PiNAS python3[3429]: AttributeError: ‘NoneType’ object has no attribute ‘sendall’
cat /etc/network/interfaces
cat /etc/hosts
ping localhost
netstat -a | grep 8888
I’m experiencing the same problem here, I just updated the rockpi drivers and now temperature a rocketing to 70 celsius on idle. Also, my fans are reversed and I didn’t reach above 55 after doing it.
I’m seeing the same Python errors while checking the Rockpi service
Jul 11 12:04:57 stockage python3[680]: self._target(*self._args, **self._kwargs)
Jul 11 12:04:57 stockage python3[680]: File "/usr/bin/rockpi-sata/fan.py", line 80, in running
Jul 11 12:04:57 stockage python3[680]: change_dc(get_dc())
Jul 11 12:04:57 stockage python3[680]: File "/usr/bin/rockpi-sata/fan.py", line 74, in change_dc
Jul 11 12:04:57 stockage python3[680]: gpio.hardware_PWM(12, 25000, dc * 10000)
Jul 11 12:04:57 stockage python3[680]: File "/usr/lib/python3/dist-packages/pigpio.py", line 2013, in hardware_PWM
Jul 11 12:04:57 stockage python3[680]: self.sl, _PI_CMD_HP, gpio, PWMfreq, 4, extents))
Jul 11 12:04:57 stockage python3[680]: File "/usr/lib/python3/dist-packages/pigpio.py", line 1030, in _pigpio_command_ext
Jul 11 12:04:57 stockage python3[680]: sl.s.sendall(ext)
Jul 11 12:04:57 stockage python3[680]: AttributeError: 'NoneType' object has no attribute 'sendall'
root@stockage:~# netstat -a | grep 8888
tcp6 0 0 ip6-localhost:8888 [::]:* LISTEN
I don’t have any custom kernels or anything, it’s just a standard Raspbian
Linux stockage 4.19.118-v7l+ #1311 SMP Mon Apr 27 14:26:42 BST 2020 armv7l GNU/Linux
cat /etc/hosts
ping localhost
pi@stockage:~ $ cat /etc/network/interfaces# This file is auto-generated by openmediavault (https://www.openmediavault.org)# WARNING: Do not edit this file, your changes will get lost.
interfaces(5) file used by ifup(8) and ifdown(8)
Better use netplan.io or systemd-networkd to configure additional interface stanzas.
Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
pi@stockage:~ $ cat /etc/hosts# This file is auto-generated by openmediavault (https://www.openmediavault.org)
127.0.0.1 localhost.localdomain localhost
127.0.1.1 stockage
The following lines are desirable for IPv6 capable hosts.
::1 ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
ff02::3 ip6-allhosts
192.168.0.2 stockage
pi@stockage:~ $ ping localhost
PING localhost.localdomain (127.0.0.1) 56(84) bytes of data.
64 bytes from localhost.localdomain (127.0.0.1): icmp_seq=1 ttl=64 time=0.040 ms
64 bytes from localhost.localdomain (127.0.0.1): icmp_seq=2 ttl=64 time=0.070 ms
64 bytes from localhost.localdomain (127.0.0.1): icmp_seq=3 ttl=64 time=0.087 ms
64 bytes from localhost.localdomain (127.0.0.1): icmp_seq=4 ttl=64 time=0.088 ms
64 bytes from localhost.localdomain (127.0.0.1): icmp_seq=5 ttl=64 time=0.059 ms
^C
— localhost.localdomain ping statistics —
5 packets transmitted, 5 received, 0% packet loss, time 127ms
rtt min/avg/max/mdev = 0.040/0.068/0.088/0.020 ms
Thank you for your information. I will fix it tomorrow.
Hello, I uploaded a new version and I think the bug should be fixed.
Please reinstall it and let me know the result.
That worked for me, thanks @setq
Fix and working. Curious to know what the bug was. - Thanks for your help.
The pigpio daemon listening ip6-localhost but the pigpio client uses localhost by default.
The bug may be caused by the different content of /etc/hosts.
I’m running Ubuntu 20.04, and the top fan was working fine until today when I updated some packages.
Start-Date: 2020-08-05 11:12:39
Commandline: apt upgrade
Requested-By: mediadmin (1001)
Upgrade: apport:arm64 (2.20.11-0ubuntu27.4, 2.20.11-0ubuntu27.6), python3-apport:arm64 (2.20.11-0ubuntu27.4, 2.20.11-0ubuntu27.6), python3-problem-report:arm64 (2.20.11-0ubuntu27.4, 2.20.11-0ubuntu27.6)
End-Date: 2020-08-05 11:12:54
After that the fan no longer spins up.
Drop-In: /etc/systemd/system/rockpi-sata.service.d
└─local.conf
Active: active (running) since Wed 2020-08-05 13:35:28 UTC; 3min 45s ago
Process: 5203 ExecStartPost=/bin/sleep 10 (code=exited, status=0/SUCCESS)
Main PID: 5202 (python3)
Tasks: 4 (limit: 9255)
├─5202 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
├─5223 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
├─5224 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
└─5225 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
Aug 05 13:35:20 mediatca python3[5226]: File "/usr/bin/rockpi-sata/fan.py", line 81, in running
Aug 05 13:35:20 mediatca python3[5226]: change_dc(get_dc())
Aug 05 13:35:20 mediatca python3[5226]: File "/usr/bin/rockpi-sata/fan.py", line 75, in change_dc
Aug 05 13:35:20 mediatca python3[5226]: gpio.hardware_PWM(12, 25000, dc * 10000)
Aug 05 13:35:20 mediatca python3[5226]: File "/usr/local/lib/python3.8/dist-packages/pigpio.py", line 2044, in hardware_PWM
Aug 05 13:35:20 mediatca python3[5226]: return _u2i(_pigpio_command_ext(
Aug 05 13:35:20 mediatca python3[5226]: File "/usr/local/lib/python3.8/dist-packages/pigpio.py", line 1062, in _pigpio_command_ext
Aug 05 13:35:20 mediatca python3[5226]: sl.s.sendall(ext)
Aug 05 13:35:20 mediatca python3[5226]: AttributeError: 'NoneType' object has no attribute 'sendall'
Aug 05 13:35:28 mediatca systemd[1]: Started Rockpi SATA Hat.
I reinstalled the rockpi-sata drivers (now it shows 0.14) which rebuilt the pigpiod drivers and it’s working fine now.
$ uname -a
Linux mediatca 5.4.0-1015-raspi #15-Ubuntu SMP Fri Jul 10 05:34:24 UTC 2020 aarch64 aarch64 aarch64 GNU/Linux
● pigpiod.service - Daemon required to control GPIO pins via pigpio
Loaded: loaded (/lib/systemd/system/pigpiod.service; enabled; vendor prese>
Active: active (running) since Thu 2020-08-06 14:03:39 +08; 5min ago
Process: 1630 ExecStart=/usr/local/bin/pigpiod -l (code=exited, status=0/SU>
Main PID: 1647 (pigpiod)
Tasks: 6 (limit: 9255)
└─1647 /usr/local/bin/pigpiod -l
Aug 06 14:03:38 mediatca systemd[1]: Starting Daemon required to control GPIO p>
Aug 06 14:03:39 mediatca systemd[1]: Started Daemon required to control GPIO pi>
Warning: The unit file, source configuration file or drop-ins of rockpi-sata.se>
● rockpi-sata.service - Rockpi SATA Hat
Loaded: loaded (/lib/systemd/system/rockpi-sata.service; enabled; vendor p>
└─local.conf
Active: active (running) since Thu 2020-08-06 14:03:49 +08; 5min ago
Process: 1649 ExecStartPost=/bin/sleep 10 (code=exited, status=0/SUCCESS)
Main PID: 1648 (python3)
├─1648 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
├─2105 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
├─2106 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
├─2107 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
└─2108 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
Aug 06 14:03:39 mediatca systemd[1]: Starting Rockpi SATA Hat…
Aug 06 14:03:49 mediatca systemd[1]: Started Rockpi SATA Hat.
Hi
unfortunately, I have the same issue. But with all the settings above.
$ uname -a
Linux nextpy01-aro 5.4.72-v7l+ #1356 SMP Thu Oct 22 13:57:51 BST 2020 armv7l GNU/Linux
$ systemctl status pigpiod.service
Drop-In: /etc/systemd/system/pigpiod.service.d
└─public.conf
Active: active (running) since Fri 2020-11-13 21:12:32 CET; 29min ago
Main PID: 470 (pigpiod)
└─470 /usr/bin/pigpiod
Nov 13 21:12:32 nextpy01-aro systemd[1]: Starting Daemon required to control GPIO pins via pigpio…
Nov 13 21:12:32 nextpy01-aro systemd[1]: Started Daemon required to control GPIO pins via pigpio.
$ systemctl status rockpi-sata.service
Active: active (running) since Fri 2020-11-13 21:39:09 CET; 3min 50s ago
Main PID: 7172 (python3)
├─7172 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
├─7200 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
├─7201 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
└─7202 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
Nov 13 21:39:11 nextpy01-aro python3[7172]: self._target(*self._args, **self._kwargs)
Nov 13 21:39:11 nextpy01-aro python3[7172]: File “/usr/bin/rockpi-sata/fan.py”, line 81, in running
Nov 13 21:39:11 nextpy01-aro python3[7172]: change_dc(get_dc())
Nov 13 21:39:11 nextpy01-aro python3[7172]: File “/usr/bin/rockpi-sata/fan.py”, line 75, in change_dc
Nov 13 21:39:11 nextpy01-aro python3[7172]: gpio.hardware_PWM(12, 25000, dc * 10000)
Nov 13 21:39:11 nextpy01-aro python3[7172]: File “/usr/lib/python3/dist-packages/pigpio.py”, line 2013, in hardware_PWM
Nov 13 21:39:11 nextpy01-aro python3[7172]: self.sl, _PI_CMD_HP, gpio, PWMfreq, 4, extents))
Nov 13 21:39:11 nextpy01-aro python3[7172]: File “/usr/lib/python3/dist-packages/pigpio.py”, line 1030, in _pigpio_command_ext
Nov 13 21:39:11 nextpy01-aro python3[7172]: sl.s.sendall(ext)
Nov 13 21:39:11 nextpy01-aro python3[7172]: AttributeError: ‘NoneType’ object has no attribute ‘sendall’
$ lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 10 (buster)
Release: 10
Codename: buster
I can’t find the problem. Maybe someone has an idea.
If I start the main.py I got the following error message:
$ python3 main.py
Can’t connect to pigpio at
Did you start the pigpio daemon? E.g. sudo pigpiod
Did you specify the correct Pi host/port in the environment
variables PIGPIO_ADDR/PIGPIO_PORT?
E.g. export PIGPIO_ADDR=soft, export PIGPIO_PORT=8888
pigpio.pi() function? E.g. pigpio.pi(‘soft’, 8888)
Process Process-4:
File “/usr/lib/python3.7/multiprocessing/process.py”, line 297, in _bootstrap
self.run()
File “/usr/lib/python3.7/multiprocessing/process.py”, line 99, in run
change_dc(get_dc())
sl.s.sendall(ext)
Can anyone help me with this problem?
