Take a look at
netstat | grep 8888
Take a look at
netstat | grep 8888
Hi setq
this is the result from netstat -an
$ sudo netstat -an | grep 8888
tcp6 0 0 :::8888 :::* LISTEN
Hi @orionzrh,
I had the same problem as you a few days ago, I found a temporary solution.
You just have to modify the file /etc/systemd/system/pigpiod.service.d/public.conf
And change the ExecStart to ExecStart=/usr/bin/pigpiod -l -n 127.0.0.1
This will force the use of ipv4, then restart !
I hope it will help you, for more information about this method, you can go to this git page : pigpio/issues/203
Bests Regards,
Hi gus_dev
great !!! It works with that temporary solution.
I changed the start of the daemon and the fan was working how I expect as a fan is working ![]()
$ sudo netstat -a | grep 8888
tcp 0 0 localhost:8888 0.0.0.0:* LISTEN
tcp 0 0 localhost:40696 localhost:8888 ESTABLISHED
tcp 0 0 localhost:40692 localhost:8888 ESTABLISHED
tcp 0 0 localhost:8888 localhost:40696 ESTABLISHED
tcp 0 0 localhost:8888 localhost:40692 ESTABLISHED
Thanks for this solution.
Best Regards,
