Thanks for your quick reply. I want to use it with 1080p at HDMI.
But even when it is used with LCD (I guess you mean the 7" RasPi display?) there should be an option for a safe shutdown.
This will just be an option to cut off power the hard way. I am looking for a safe shutdown that protects the file system to be corrupted, which could happen in case of hard cut off.
Please include the shutdown / reboot options also in the “normal” Android images.
The power button is not available in the plain 7.1 image and only this supports Raspberry Pi’s TouchScreen and Pi camera. Please make it available also there (and also in the new version 9 image).
Found a workaround that is working for me (on the plain Android 9 Pie image):
If you install “Qute” terminal, you can create a script with command reboot -p
and you can create a shortcut to that script on the desktop. Clicking this shortcut will trigger a shutdown (without confirmation!),
Ok. Thank you.
I need android sleep state when my car isn’t running. How to enter to sleep?
When I try to close the ADC key contacts, board does not go to sleep.
