SATA HAT issue Installation
I bought the 4C with the quad sata hat.
I use a 32 GB emmc module for the operating system. (Armbian_21.05.1_Rockpi-4c_buster_legacy_4.4.213.img.xz)
The installation according to the instructions works without problems,
until I install the latest u-boot
sudo apt-get install -y rockpi4c-rk-u-boot-latest
I get the followin error:
Step two: upgrade bootloader on uSD card or eMMC
Boot device, uSD card or eMMC, is found. Would you like to upgrade bootloader on it?
If yes, type Y/y. If no, type N/n.
Y
Backup bootloader on boot device (/dev/mmcblk1p1).
dd: writing to ‘/usr/lib/u-boot-rockpi4c/rockpi4c-rk-uboot_bkp.img’: No space left on device
55888153+0 records in
55888152+0 records out
28614733824 bytes (29 GB, 27 GiB) copied, 1884.64 s, 15.2 MB/s
dpkg: error processing package rockpi4c-rk-ubootimg (–configure):
installed rockpi4c-rk-ubootimg package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of rockpi4c-rk-u-boot-latest:
rockpi4c-rk-u-boot-latest depends on rockpi4c-rk-ubootimg (= 2017.09-2700-g70b4cfe057); however:
Package rockpi4c-rk-ubootimg is not configured yet.
Version of rockpi4c-rk-ubootimg on system, provided by rockpi4c-rk-ubootimg:all, is .
dpkg: error processing package rockpi4c-rk-u-boot-latest (–configure):
dependency problems - leaving unconfigured
Processing triggers for man-db (2.8.5-2) …
dpkg: unrecoverable fatal error, aborting:
unable to flush /var/lib/dpkg/updates/tmp.i after padding: No space left on device
E: Sub-process /usr/bin/dpkg returned an error code (2)
Did I need a larger emmc module?
Thank you for your help.
Since you use Armbian - you don’t need uboot, better use Armbian from here
thanks for your tip.
The system looks nice.
But unfortunately I don’t need a GUI.
@skais, ah, then everything simplier.i thought you needed gui since you picked buster. Then you need to go here
https://mirrors.netix.net/armbian/dl/rockpi-4c/archive/
Also you can remove desktop from buster with apt-get remove lightdm
I was now able to solve the problem with the instructions.
https://docs.armbian.com/User-Guide_Getting-Started/#how-to-update-u-boot
The system is now running very well.
Thanks
