Figured it out, I couldnt get screensaver settings to open.
- https://github.com/theothernt/AerialViews#chromecast-with-google-tv-users
- adb settings put system screen_off_timeout 300000
Hi iam new user do you have same 4k img for h96 max v58?
Thanks in advance
Did you have 4k img for h96max v58?
Thanks in advance
Canot SignIn Youtube.
nope , no box no images
Got something
there is also a gpt image for the nvme if flashing the nvme giving trouble with rkdevtool , monkasBlyat afterburner has balena etcher and boots from sd even if spi is flashed .
but you need to flash this spi img to run this android build from nvme
https://drive.google.com/drive/folders/1Ui0548e-qKm9uFx3FT-QJgavzSOu8TRT?usp=share_link
Thank you very much for your efforts and sharing.
Getting closer - I now get solid blue/green LED and the Rockchip splash screen but android never boots.
@ Tungmeister , are you still struggling to boot from emmc? I was having that issue and I now solved it by flashing a new SPI loader as per explained in the following link
Rock5/install/spi - Radxa Wiki
This image was a disappointment though, as when trying to side load my favorite apps they fail (I believe it is because this image is based on an old android version - 5.1?)
Read the link I mentioned above. You also need to flash a new SPI bootloader to boot from NVME. Just out of curiosity, why boot from nvme and not from emmc?
The required SPI is included in thc013’s latest release. I’m using NVME because I’ve got a 256GB one spare and don’t have an EMMC.
lol cant you read the spi needed for that android image is included no need for bad spi images
and got even emmc+nvme combined images
and works nice side loading and adding apk’s
dont hang usb drives fan or such that will help , 5b booting draws some more power
but for me it boots 8 of 10 times ,
wich splash screen the uboot or the kernel with dready ?
i got it working on a xpg 256gb with leds
I did tried to flash the spi + image in maskrom mode and that never worked, hence why I flashed a different spi.
As per side loading the apps, can you please test the “all4” app and let me know if you have it working?
that is why added a gpt image to flash the nvme with another tool , spi just flash thats is no issue .
Ok. Thanks for your help. Would you please try and side load the “all4” app and let me know what your results are.
just the uboot logo, doesn’t seem to access the NVME
it does acces the nvme , no nvme no logo
wich power supply your using or your setup what is attached ?
i got it booting so it must be close to figure out why yours wont .
you wanted sd/emmc with boot and kernel and on nvme the rest of android
https://drive.google.com/drive/folders/13hV-YCdiiTrw71Vnpo6y7lvrtITZlmWT?usp=share_link
works just as fast as running it with spi boot only now the kernel kicks the nvme in instead of the spi bootloader.
