[ROM] ROCK 5B Android 12.1 rkr10 GoogleTV
That sounds great stuff! I am still strugling with getting my nvme detected in the android image. Is there anything I need to do to ? When I run your android image and open a file explorer I only see my emmc and not the nvme.
cannot started dmesg.zip (18.3 KB)
[ 3.917963][ T210] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 2112000000
[ 3.917972][ T210] rockchip-dmc dmc: performance_rate = 2112000000
[ 3.917983][ T210] rockchip-dmc dmc: hdmirx_rate = 2112000000
[ 3.917990][ T9] mali fb000000.gpu: GPU hardware issue table may need updating:
[ 3.917990][ T9] r0p0 status 5 is unknown; treating as r0p0 status 0
[ 3.917996][ T9] mali fb000000.gpu: GPU identified as 0x7 arch 10.8.6 r0p0 status 0
[ 3.918011][ T210] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 3.918020][ T210] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 3.918032][ T9] mali fb000000.gpu: No priority control manager is configured
[ 3.918175][ T210] rockchip-dmc dmc: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 3.918190][ T9] mali fb000000.gpu: No memory group manager is configured
[ 3.918204][ T9] mali fb000000.gpu: Protected memory allocator not available
[ 3.918551][ T9] mali fb000000.gpu: Capping CSF_FIRMWARE_TIMEOUT to CSF_FIRMWARE_PING_TIMEOUT
[ 3.918646][ T210] rockchip-dmc dmc: could not find power_model node
[ 3.919049][ T9] mali fb000000.gpu: Couldn’t find power_model DT node matching ā€˜arm,mali-simple-power-model’
[ 3.919056][ T9] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.static-coefficient = 1*[0]
[ 3.919238][ T9] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.dynamic-coefficient = 1*[0]
[ 3.919398][ T9] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.ts = 4*[0]
[ 3.919564][ T9] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.thermal-zone = ā€˜ā€™
[ 3.921681][ T9] mali fb000000.gpu: Using configured power model mali-lodx-power-model, and fallback mali-simple-power-model
[ 3.921776][ T9] mali fb000000.gpu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0
[ 3.922325][ T9] mali fb000000.gpu: Probed as mali0
[ 3.925683][ T210] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x5, primary plane phy id: 2
[ 3.925703][ T210] rockchip-vop2 f
did you empty the spi with emmc - nvme booting
the spi is not needed and can cause trouble with the emmc - nvme
yes I empty the spi and I flash the ā€œupdate_spi_nvme.imgā€.
When I start the board, I need to power on repeatedly. Sometimes it will start successfully.
But it often gets stuck, like the dmesg I uploaded
You mean it will started without SPI?
use the ā€œsd-atv.7zā€?
just empty the spi ?
Let me try
Perfect, you are a genius!
more stuborn to get something working.:innocent:
it is more stable at booting only uboot kernel and recovery on a emmc and rest of android on nvme.
and it is also possible to make dual boot , not that some linux distro are fan for such partion sheme.
Yes, It’s perfect.Thank you very much!:smiley:
@thc013 I swapped my NVME with a different one from work and now I can finally boot. Thanks for all your hard work! I just need to sort out BT/WiFi now as the older intel card I’m using doesn’t work.
EDIT: boot doesn’t seem to be reliable. I’ll have to power cycle several times to get it to boot, Tried a few power supplied including rpi 4 one.
tvbox is 24/7 :innocent:, no joking
yep emmc or sd and then nvme works better
i have edit the kernel more to be little more stable. or a delay or such in the beginning or let it reset till it boots
and also depends what you have connected .
I had nothing connected other than usb keyboard (waiting for the wifi/bt module to be delivered)
This version is perfect. Thank you for your hard work,But can I add Magisk to the root version?Thank you very much if you can do it.Because I need Magisk’s firmware too much.
there is no need for magisk ,
there is root and the games are already unlocked
i didnt do magisk because most of the magisk things are just already built in .
root
propsutils
and spoofing
In that case, it’s too bad
why should it be bad !!!
it is not my problem if you wanne add magisk
i just tell what is buildin and why magisk is not needed .
I mean, it’s bad for me
Any chance of a new build to improve the boot stability with NVME? I have to power-cycle 10+ times to get a successful boot.
EDIT: Also iv’e been testing on my TV now that I’ve got the wifi/bt card - I’m not having any luck with HDR content - when playing HDR in youtube I get ā€œno signalā€ to my TV and when playing HDR content in plex the media plays but doesn’t switch the TV to HDR.
@thc013 new radxa android image seems to fix some of the sd card not bootable issue, maybe its a good idea to rebuild with the latest kernel.
Thanks for your great work! It’s very fast running with nvme ssd.
But the pwm fan did not work with this version, while ATV-4K-SD-Image run in sdcard works fine.
