Rock5 as Samba file share
Since we finally have pcie 3.0 x4 lanes (and 2.1 x1 lane), I have decided to expand my RockPi4 storage to Rock5. While I’m still waiting for a few parts, namely
Here is first tests of network&storage performance. At first I was testing speed with FIO, but it’s results always lower than diskspd or real performance, so I have choosed to use diskspd. Both U.2 NVMe drives in mdadm raid0
The graphs:
Reading:
Writing:
The raw data:
smb tests.zip (47.2 KB)
The scheme right now
The NIC is connected by using M.2 e-key (x1 pcie 2.1) to x8 pcie adapter
iperf3 between Windows & Rock5
root@rock-5b:/home/rock# iperf3 -s
Server listening on 5201
Accepted connection from 192.168.1.43, port 50063
[ 5] local 192.168.1.45 port 5201 connected to 192.168.1.43 port 50064
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 376 MBytes 3.16 Gbits/sec 0 4.01 MBytes
[ 5] 1.00-2.00 sec 368 MBytes 3.08 Gbits/sec 0 4.01 MBytes
[ 5] 2.00-3.00 sec 368 MBytes 3.08 Gbits/sec 0 4.01 MBytes
[ 5] 3.00-4.00 sec 368 MBytes 3.08 Gbits/sec 0 4.01 MBytes
[ 5] 4.00-5.00 sec 368 MBytes 3.08 Gbits/sec 0 4.01 MBytes
[ 5] 5.00-6.00 sec 368 MBytes 3.08 Gbits/sec 0 4.01 MBytes
[ 5] 6.00-7.00 sec 368 MBytes 3.08 Gbits/sec 0 4.01 MBytes
[ 5] 7.00-8.00 sec 366 MBytes 3.07 Gbits/sec 0 4.01 MBytes
[ 5] 8.00-9.00 sec 368 MBytes 3.08 Gbits/sec 0 4.01 MBytes
[ 5] 9.00-10.00 sec 368 MBytes 3.08 Gbits/sec 0 4.01 MBytes
[ 5] 10.00-10.02 sec 6.25 MBytes 3.02 Gbits/sec 0 4.01 MBytes
[ 5] 0.00-10.02 sec 3.60 GBytes 3.09 Gbits/sec 0 sender
root@rock-5b:/home/rock# iperf3 -c 192.168.1.43
Connecting to host 192.168.1.43, port 5201
[ 5] local 192.168.1.45 port 40424 connected to 192.168.1.43 port 5201
[ 5] 0.00-1.00 sec 357 MBytes 2.99 Gbits/sec 816 1.06 MBytes
[ 5] 1.00-2.00 sec 358 MBytes 3.00 Gbits/sec 0 1.45 MBytes
[ 5] 2.00-3.00 sec 362 MBytes 3.04 Gbits/sec 15 1.23 MBytes
[ 5] 3.00-4.00 sec 360 MBytes 3.02 Gbits/sec 1 970 KBytes
[ 5] 4.00-5.00 sec 362 MBytes 3.04 Gbits/sec 0 1.37 MBytes
[ 5] 5.00-6.00 sec 361 MBytes 3.03 Gbits/sec 1 1.13 MBytes
[ 5] 6.00-7.00 sec 361 MBytes 3.03 Gbits/sec 10 851 KBytes
[ 5] 7.00-8.00 sec 362 MBytes 3.04 Gbits/sec 0 1.30 MBytes
[ 5] 8.00-9.00 sec 361 MBytes 3.03 Gbits/sec 3 1.05 MBytes
[ 5] 9.00-10.00 sec 362 MBytes 3.04 Gbits/sec 0 1.45 MBytes
[ 5] 0.00-10.00 sec 3.52 GBytes 3.03 Gbits/sec 846 sender
[ 5] 0.00-10.00 sec 3.51 GBytes 3.01 Gbits/sec receiver
iperf Done.
The target scheme
Also thanks @tkaiser for advice regarding HELIOS lantest. Here is also results from it:
The m.2 to SATA is working with switch. The power consumption is much lesser than i expected.
because of all ssds/ pcie card / sbc has connect ground together, so you should use only one power supply to offer power
Easy since ‘real performance’ since Windows 7 at least when copying with Windows Explorer is characterized by
  • auto-tuning block sizes
  • using parallel streams
For your iperf tests… can you repeat them with server on the Windows PC and then
  • taskset -c 5 iperf3 -c 192.168.1.43
  • taskset -c 5 iperf3 -R -c 192.168.1.43 (reverse direction)
Also do you see interrupts being bottlenecked by cpu0 (checking /proc/interrupts afterwards and in a separate run checking while benchmarking with atop what’s going on)?
Of course testing with Helios LanTest would also be welcomed :slight_smile:
That would explain fio vs explorer, but no fio vs diskspd. There is (average) ~7% difference based on 20 tests
Just a quick reminder, I’m bottlenecked by x1 pcie 2.1 lane, so 3.0Gb/s sounds true enough.
Erm, no? The ground is still on power cables.
And It’s not high speed system, where I need to sync everything to reach max performance.
Especially the 1st three numbers (not sequential transfer speeds) are super low and results variation (the orange triangles) is extremely high. You might want to compare with the 10GbE SMB numbers here if you want: https://github.com/openmediavault/openmediavault/issues/101#issuecomment-468270197 (made with macOS but shouldn’t matter since Microsoft should still be able to fabricate a better SMB client than Apple).
As for diskspd performance and iperf3 numbers. I was neither aware that your NIC card sits in the Key E slot nor that Explorer and diskspd numbers differed. Anyway: without knowing CLI parameters (count of parallel/asynchronous threads for example) it’s a bit pointless to compare and I’m still interested in /proc/interrupts output to get a better understanding of RK’s 5.10 BSP kernel and PCIe.
Well, connection wholly explained on scheme:
and as for diskspd cli - it’s all here
And as for
the first run is a few hundreds ms, but later it’s becoming ~5s
That took a bit more time than I expected, but I finally collected all necessary materials
2x A4 plasticine board
7x A5 plasticine board
3x DC-DC converted 20V to 5v based on XL4015
2x PD trigger for 20V5A and 1x PD trigger for 12V3A
2x QB826 as UPS to power up all of this
1x ANM24PE16 (PLX 8748)
2x JMB585
10x Samsung 870 EVO 1tb
3x noctua fans (one for board, one for DC-DC, one for ANM24PE16)
A lot of screws M3x5
A lot of Molex–2xMolex and Molex–2xSata_power
After a bit of soldering and drilling
:slight_smile:
This project (almost) finished.
There two downsides -
first - ANM24PE16 requires cooling, it’s getting very hot very fast
second - there is no good way of monitor QB826
So 1 year and 3 months later, the NAS with 10 ssd drives powered by Power delivery trigger is still working just fine.
As for kernel it’s a bit tricky, since I dont update it because of NC552SFP that is connected to the top M.2 slot.
Right now its working by using mdadm raid5 from 10ssd drives. The roles are:
  • SMB share for personal usage
  • NFS share for vcenter
  • Torrent node
  • Nextcloud server
  • Decentralised java based image hosting server
The only problem I met is MOLEX cables, it’s actually better to use sata power cables because so far, there were a few situations (like 4 so far) where because of molex connection the ssd (from 1 to 4 ssd) were cut off, since they were powered off.
So mdadm raid had a bit of hiccup, but --force assemble always fixed it (and fsck.ext4).
Hi There, fyi, I’m using 2x2,5gbe and smb 3.1.1 to get full 5gbe connection. It’s working wonderful with single connection - better than trunk port i used before… Best
Welp, not bad at all :slight_smile:
But in my case I still have windows 7 and some other legacy stuff, so I’m gonna failover to smb2 anyway, not even taking in account that I only have csr305 and all 4 ports are taken
great to see your work! @Dante4
i was also using the hp 10gbps nic with rock 5b before as my nas setup and it’s really fast! (it gave me 7xxMB/s using [5B ram disk] <> [nvme SSD on desktop] file transfer in samba). However, as the data in ramdisk is flashed jn each reboot and size is limited. I’ve came up with the idea of pcie bifurcation to separate two pcie3x2 slots for 10G NIC and nvme SSD in hope to get a decent 10Gbps NAS.
