To Save space and utilize Rock 5B for my project I am planning to design a custom hat for Rock 5B.
I want to supply the power through the GPIO pins instead of the USB type-C port.
I connected a 5V 4A power supply 5V at Pin 2 and 4 and GND at pins 6 and 14 but it does not seem to power up the system.
For previous versions PoE hats are available, no such hats are available for Model 5B not sure if we need to jump the PoE pins or add passive components to it.
Hi there. Have you found a solution yet? I want to do something similar by having the smallest profile possible to cluster multiple 5B boards together using PoE to power them.
are you guys using a repurposed usb power supply? If so, the power supply might not properly detect the load. Try connecting the d+/d- line on the cable leading to the power supply, on some supplies this enables high current charging mode(this is how android phones do it. Since not all power supplies handle this equally, consider shorting them through a resistor(10-50Ohms). Make sure you do NOT short the power lines!
Hey there, I am powering the Rock 5b through GPIO Pins 4 and 6. It works on my device. But even though I am using a 5V 4A supply (not sure whether those Pins are meant to carry 4A!! at 5V) it (ir)regularly demands more power than the supply delivers, which results in a sudden restart. (no nvme, only sd-card + usb keyboard + usb mouse + hdmi & usb powering a small touchscreen)
If I power the touchscreen separately there are less of those sudden restarts. Also setting the governor to performance seems to be more stable paradoxically (maybe the power supply I use canât ramp up as fast as necessary. The power issues got worse since I switched to faster settings for the on_demand governor)
My findings from running the Rockpi 5b over GPIOs:
If you power the board through USB froma sufficient charger and then switch over to GPIO power it works fine.I am guesing there some software loop depending on some signal from the USB or voltage to boot up.
The above suggested settings only affect cpufreq behaviour with I/O workloads and have been adopted by Radxa recently.
As for powering using 5V at 4A is nonsense since you get either/or but never both at the same time with this kind of cabling. Ohmâs law still is in place and both cable and contact resistance will result in underpowering (most probably undervoltage).
Since youâre still focused on the irrelevant number (4A) to the basics first: Ohm's law - Wikipedia
A 5V/4A power brick can be considered almost a scam since at only 5V cable and contact resistance are that high that you never get 5V at 4A at the device in question. You either get 5V (with low loads) or 4A (with voltage dropped below sane levels) but never both at the same time. Thereâs a reason why none of the USB-C and USB PD power modes exceeds 3A at 5V: since it canât work due to resistance too high â voltage drop.
Thatâs why the following advise has already been given:
With tiny Dupont wiring and at 5V undervoltage might occur below 2A or even 1A! And undervoltage is defined as the tolerable voltage drop until some protection mechanism kicks in. The buck converter the GPIO pins are fed into is rated at 4.5V - 26V so as soon as the input voltage drops below 4.5V you will see random reboots.
And depending on how long and thin those Dupont cables are and if only two pins are used (contact resistance adds to the problem) at 5V youâll have almost no chance of stable operation under any significant load since the 5V at the other end of the cable drops way too low on the board.
At least you failed the second time in this thread to get the basics and these basics are still Ohmâs law. When powering with tiny cables, connecting with just two tiny contacts and all of this is at a very low voltage like 5V it canât work. Amperage still doesnât matter.
@RadxaYuntian for those of your users lacking any understanding of electronics basics (like this guy here who tries to insult others all the time instead of using his brain in a better way) you might want to add a small section to Wiki and product page that explains that 5V with more than 3A doesnât work well in general and what the challenges are when powering with tiny cables and more than minimum loads.
Dumb people seem to be immune to explanations and seek for authority so it might be the vendorâs job to fix their misunderstandings since otherwise these people flood the forums with even more BS than they already do
The issue seems to be with the Radxa OS release instead of voltage drop issues with the supply.
The latest Android 12 OS release provided by Radxa seems to have no boot issues while powering up with a supply or a custom hat with a 5V 4A buck converter.
To be honest, while I donât understand tangents about âstupid peopleâ, I agree with @tkaiser at pushing 4A to power the board seems like a bad idea. Even if there are no power issues now, they may let themselves be known as soon as one connects something.
Sure, it is the capacity of the power supply, but ohmâs law holds, so you get a higher resistance, higher energy losses and voltage drops. Also, it seems that this board is prone to transient power spikes and with 5V youâll have less headroom to deal with them than with a higher voltage (well, unless you use 9V2A for example).
I mean, you get less energy loss when powering with 12V 1.5A than with 5V3.6A, for example, if the boardâs power is 18 watt
I really donât know what you mean by âeuroturdâ and I have no interest.
By âpushing 4Aâ I meant pushing this kind of current through a cable. Which is one of the key limiting factors here I suppose. As it has a resistance of its own.
The best is to use the USB C power point because it offers also some protection to the board. However, Dupont wires can be used on a Rock 5 board, but itâs important to make sure that the wire gauge is appropriate for the amount of current being carried. Thicker wires (such as 22AWG) can carry more current than thinner wires (such as 26AWG). Check what you have/buy.
In general, a 22AWG Dupont wire can carry up to 2.5 amps of current, while a 26AWG Dupont wire can carry up to 1.5 amps of current. However, itâs always best to consult the specifications of the specific wire youâre using to ensure it can handle the current you need. The above is valid for a short wire (150mm).
Itâs also important to ensure that the Dupont connector is properly connected and not loose on the Rock pin, as this can lead to resistance and overheating. Again ohm law applies here.
If youâre experiencing current issues, it may be helpful to connect multiple pins in parallel to increase the current-carrying capacity. For example, you could connect pins 2 and 4 in parallel for positive, and connect two ground pins (such as 34 and 39) in parallel as well. This will offer a larger cross-sectional area for the wires and reduce resistance, allowing for more current to flow without overheating. As said in the above posts, ohm law applies, thicker is the wire, more current you can carry. However you are still limited by the Dupoint connector and the size of the pin/copper on the board.
The above has been tested and works.
@RadxaYuntian you should really spend some time/efforts on providing some basic knowledge about the relationship of voltage, current and resistance somewhere in your wiki since what happens here in the forums is just nuts.
Your consumers should be educated about these simple facts but maybe this already happens somewhere in a hidden/smelly corner of Discord or Telegram or wherever else community fragmentation happensâŚ
