Raid creation failure - hardware issues
Ever since i received my SATA HAT i have had issues i am trying to resolve. I love the product, just can’t get it to work as intended.
Problem - Drives/Raid will never complete synchronization. They always fail early in the process. Everything else seems to work fine.
I have tried creating the raid via mdadm and Openmediavault. I have tried different power adapters that all provide enough power, different raspberry pi, different sd card, reimaged and loaded the os numerous times (rasbian). The hard drives all check out good, and i tried in both 2 and 4 drive configuration. I followed the video by Novaspirit step by step. The drives just never want to seem to cooperate with each other. The only thing i have not replaced is the HAT itself and the USB bridge.
Does anyone have any other ideas or things i can try? I’m about to give up the project. Would appreciate any help i could get.
I’m sorry you had an unpleasant problem. I want to know dmesg.
Thank you for the response. Hope this is what you were needing.
[ 0.000000] Linux version 4.19.97-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1294 SMP Thu Jan 30 13:21:14 GMT 2020
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
[ 0.000000] cma: Reserved 256 MiB at 0x000000001ec00000
[ 0.000000] On node 0 totalpages: 1012736
[ 0.000000] DMA zone: 1728 pages used for memmap
[ 0.000000] HighMem zone: 816128 pages, LIFO batch:63
[ 0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with crng_init=0
[ 0.000000] percpu: Embedded 17 pages/cpu s36928 r8192 d24512 u69632
[ 0.000000] pcpu-alloc: s36928 r8192 d24512 u69632 alloc=17*4096
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1011008
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M cma=256M video=HDMI-A-1:1920x1080M@60,margin_left=48,margin_right=48,margin_top=48,margin_bottom=48 smsc95xx.macaddr=DC:A6:32:37:00:89 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=738a4d67-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 3735564K/4050944K available (8192K kernel code, 687K rwdata, 2408K rodata, 2048K init, 850K bss, 53236K reserved, 262144K cma-reserved, 3264512K highmem)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0x(ptrval) - 0x(ptrval) (10208 kB)
.init : 0x(ptrval) - 0x(ptrval) (2048 kB)
.data : 0x(ptrval) - 0x(ptrval) ( 688 kB)
.bss : 0x(ptrval) - 0x(ptrval) ( 851 kB)
[ 0.000000] ftrace: allocating 28692 entries in 85 pages
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000021] Switching to timer-based delay loop, resolution 18ns
[ 0.000260] Console: colour dummy device 80x30
[ 0.000724] console [tty1] enabled
[ 0.000784] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=540000)
[ 0.000820] pid_max: default: 32768 minimum: 301
[ 0.001112] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001146] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001958] CPU: Testing write buffer coherency: ok
[ 0.002408] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.003089] Setting up static identity map for 0x200000 - 0x20003c
[ 0.003271] rcu: Hierarchical SRCU implementation.
[ 0.004168] smp: Bringing up secondary CPUs …
[ 0.005039] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.006018] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.006955] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.007090] smp: Brought up 1 node, 4 CPUs
[ 0.007159] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.007184] CPU: All CPU(s) started in HYP mode.
[ 0.007204] CPU: Virtualization extensions available.
[ 0.008062] devtmpfs: initialized
[ 0.018569] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.018810] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.018854] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.026419] pinctrl core: initialized pinctrl subsystem
[ 0.027316] NET: Registered protocol family 16
[ 0.030449] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.031903] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.031934] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.032166] Serial: AMBA PL011 UART driver
[ 0.035415] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.050029] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-02-12 12:36, variant start
[ 0.060043] raspberrypi-firmware soc:firmware: Firmware hash is c3c8dbdf147686fb0c3f32aece709d0653368810
[ 0.103384] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[ 0.106693] vgaarb: loaded
[ 0.107089] SCSI subsystem initialized
[ 0.107319] usbcore: registered new interface driver usbfs
[ 0.107387] usbcore: registered new interface driver hub
[ 0.107471] usbcore: registered new device driver usb
[ 0.108734] clocksource: Switched to clocksource arch_sys_counter
[ 0.188358] VFS: Disk quotas dquot_6.6.0
[ 0.188467] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.188633] FS-Cache: Loaded
[ 0.188855] CacheFiles: Loaded
[ 0.189513] simple-framebuffer 3e513000.framebuffer: framebuffer at 0x3e513000, 0x6e7000 bytes, mapped to 0x(ptrval)
[ 0.189551] simple-framebuffer 3e513000.framebuffer: format=a8r8g8b8, mode=1824x984x32, linelength=7296
[ 0.199233] Console: switching to colour frame buffer device 228x61
[ 0.208049] simple-framebuffer 3e513000.framebuffer: fb0: simplefb registered!
[ 0.215960] NET: Registered protocol family 2
[ 0.216724] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.216830] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.216973] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.217111] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.217307] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.217398] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.217680] NET: Registered protocol family 1
[ 0.218350] RPC: Registered named UNIX socket transport module.
[ 0.218425] RPC: Registered udp transport module.
[ 0.218482] RPC: Registered tcp transport module.
[ 0.218540] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.218619] PCI: CLS 0 bytes, default 64
[ 0.221798] Initialise system trusted keyrings
[ 0.222032] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 0.231292] FS-Cache: Netfs ‘nfs’ registered for caching
[ 0.231902] NFS: Registering the id_resolver key type
[ 0.231988] Key type id_resolver registered
[ 0.232044] Key type id_legacy registered
[ 0.232109] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.234523] Key type asymmetric registered
[ 0.234587] Asymmetric key parser ‘x509’ registered
[ 0.234753] bounce: pool size: 64 pages
[ 0.234848] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.235107] io scheduler noop registered
[ 0.235162] io scheduler deadline registered (default)
[ 0.237920] io scheduler cfq registered
[ 0.240523] io scheduler mq-deadline registered (default)
[ 0.242977] io scheduler kyber registered
[ 0.279351] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
[ 0.281984] brcm-pcie fd500000.pcie: could not get clock
[ 0.284582] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 0.287140] brcm-pcie fd500000.pcie: MEM 0x600000000…0x603ffffff -> 0xf8000000
[ 0.348760] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
[ 0.351563] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 0.354083] pci_bus 0000:00: root bus resource [bus 00-01]
[ 0.356573] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ 0.359094] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 0.359236] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 0.361989] PCI: bus0: Fast back to back transfers disabled
[ 0.364506] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.367212] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 0.367337] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.367654] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 0.370433] PCI: bus1: Fast back to back transfers disabled
[ 0.372938] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
[ 0.372988] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 0.375485] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 0.377994] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.380538] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 0.383333] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 0.386075] pcieport 0000:00:00.0: Signaling PME with IRQ 54
[ 0.388816] pcieport 0000:00:00.0: AER enabled with IRQ 54
[ 0.391506] pci 0000:01:00.0: enabling device (0140 -> 0142)
[ 0.398130] iproc-rng200 fe104000.rng: hwrng registered
[ 0.400981] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.404077] vc-sm: Videocore shared memory driver
[ 0.407028] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 0.419906] brd: module loaded
[ 0.432332] loop: module loaded
[ 0.435650] Loading iSCSI transport class v2.0-870.
[ 0.439959] libphy: Fixed MDIO Bus: probed
[ 0.442798] bcmgenet fd580000.genet: failed to get enet clock
[ 0.445244] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
[ 0.447690] bcmgenet fd580000.genet: failed to get enet-wol clock
[ 0.450166] bcmgenet fd580000.genet: failed to get enet-eee clock
[ 0.452564] bcmgenet: Skipping UMAC reset
[ 0.455170] unimac-mdio unimac-mdio.-19: DMA mask not set
[ 0.468766] libphy: bcmgenet MII bus: probed
[ 0.509266] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
[ 0.512542] usbcore: registered new interface driver r8152
[ 0.515000] usbcore: registered new interface driver lan78xx
[ 0.517422] usbcore: registered new interface driver smsc95xx
[ 0.520143] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.522559] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 0.527138] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[ 0.529955] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 55
[ 0.533245] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.535711] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.538167] usb usb1: Product: xHCI Host Controller
[ 0.540658] usb usb1: Manufacturer: Linux 4.19.97-v7l+ xhci-hcd
[ 0.543015] usb usb1: SerialNumber: 0000:01:00.0
[ 0.545941] hub 1-0:1.0: USB hub found
[ 0.548452] hub 1-0:1.0: 1 port detected
[ 0.551352] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.553780] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 0.556200] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 0.558950] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 0.561359] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.563814] usb usb2: Product: xHCI Host Controller
[ 0.566261] usb usb2: Manufacturer: Linux 4.19.97-v7l+ xhci-hcd
[ 0.568697] usb usb2: SerialNumber: 0000:01:00.0
[ 0.571654] hub 2-0:1.0: USB hub found
[ 0.574125] hub 2-0:1.0: 4 ports detected
[ 0.577649] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.580293] dwc_otg: FIQ enabled
[ 0.580302] dwc_otg: NAK holdoff enabled
[ 0.580311] dwc_otg: FIQ split-transaction FSM enabled
[ 0.580324] Module dwc_common_port init
[ 0.580546] usbcore: registered new interface driver uas
[ 0.583067] usbcore: registered new interface driver usb-storage
[ 0.585635] mousedev: PS/2 mouse device common for all mice
[ 0.589271] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 0.593071] sdhci: Secure Digital Host Controller Interface driver
[ 0.595400] sdhci: Copyright© Pierre Ossman
[ 0.598107] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 0.600875] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.606299] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.608968] hidraw: raw HID events driver © Jiri Kosina
[ 0.611416] usbcore: registered new interface driver usbhid
[ 0.613760] usbhid: USB HID core driver
[ 0.616903] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[ 0.621206] [vc_sm_connected_init]: start
[ 0.664803] [vc_sm_connected_init]: end - returning 0
[ 0.668362] Initializing XFRM netlink socket
[ 0.670779] NET: Registered protocol family 17
[ 0.673193] Key type dns_resolver registered
[ 0.675684] Registering SWP/SWPB emulation handler
[ 0.678454] registered taskstats version 1
[ 0.680765] Loading compiled-in X.509 certificates
[ 0.690899] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 0.693170] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
[ 0.700580] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 0.703517] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[ 0.706556] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 0.708987] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 0.737397] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.3
[ 0.739958] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.4
[ 0.762663] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.766660] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.770716] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.774216] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 0.778214] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 0.778939] of_cfs_init
[ 0.782280] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.783152] of_cfs_init: OK
[ 0.788349] Waiting for root device PARTUUID=738a4d67-02…
[ 0.834162] random: fast init done
[ 0.882474] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
[ 0.887719] mmcblk0: mmc0:aaaa SS08G 7.40 GiB
[ 0.893692] mmc1: new high speed SDIO card at address 0001
[ 0.896675] mmcblk0: p1 p2
[ 0.913359] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 0.915764] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 0.918784] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 0.989971] EXT4-fs (mmcblk0p2): recovery complete
[ 0.993944] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 0.996390] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.004126] devtmpfs: mounted
[ 1.014346] Freeing unused kernel memory: 2048K
[ 1.016987] Run /sbin/init as init process
[ 1.101413] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.103904] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.106385] usb 1-1: Product: USB2.0 Hub
[ 1.110599] hub 1-1:1.0: USB hub found
[ 1.113291] hub 1-1:1.0: 4 ports detected
[ 1.453419] systemd[1]: System time before build time, advancing clock.
[ 1.548186] NET: Registered protocol family 10
[ 1.552012] Segment Routing with IPv6
[ 1.590299] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.596213] systemd[1]: Detected architecture arm.
[ 1.623982] systemd[1]: Set hostname to .
[ 2.005946] random: lvmconfig: uninitialized urandom read (4 bytes read)
[ 2.560342] systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
[ 2.610506] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.635502] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.638947] systemd[1]: Listening on Network Service Netlink Socket.
[ 2.646202] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 2.653203] systemd[1]: Reached target Swap.
[ 2.668193] systemd[1]: Listening on Syslog Socket.
[ 2.675401] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 2.682784] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.888786] Installing knfsd (copyright © 1996 [email protected]).
[ 3.530801] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.662513] systemd-journald[128]: Received request to flush runtime journal from PID 1
[ 4.223038] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x0000ffff
[ 4.223550] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00000fff
[ 4.224017] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x0000ffff
[ 4.224486] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x0000ffff
[ 4.228287] Driver for 1-wire Dallas network protocol.
[ 4.239472] gpio-4 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 4.287161] media: Linux media interface: v0.10
[ 4.298765] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.300849] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 4.300866] [vc_sm_connected_init]: start
[ 4.309233] [vc_sm_connected_init]: installed successfully
[ 4.345417] w1_master_driver w1_bus_master1: Attaching one wire slave 28.00000bd4a398 crc bd
[ 4.354878] videodev: Linux video capture interface: v2.00
[ 4.387869] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.390688] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.394528] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.405790] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.412993] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.425746] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 4.425781] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 4.433784] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 4.433832] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 4.442486] bcm2835_audio soc:audio: card created with 8 channels
[ 4.442658] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 4.442694] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 4.695231] bcmgenet: Skipping UMAC reset
[ 4.707415] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 4.775656] vc4-drm soc:gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 4.775673] checking generic (3e513000 6e7000) vs hw (0 ffffffffffffffff)
[ 4.775684] fb: switching to vc4drmfb from simple
[ 4.775912] Console: switching to colour dummy device 80x30
[ 4.781347] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 1
[ 4.781361] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 4.781371] [drm] No driver support for vblank timestamp query.
[ 4.781380] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[ 4.789467] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
[ 4.790193] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.905887] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 4.971740] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 4.983416] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.984073] usbcore: registered new interface driver brcmfmac
[ 5.051234] Console: switching to colour frame buffer device 240x67
[ 5.086969] vc4-drm soc:gpu: fb0: DRM emulated frame buffer device
[ 5.240946] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.260038] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 2 2020 23:30:41 version 7.45.202 (r724630 CY) FWID 01-72f6ece2
[ 5.848962] bcmgenet fd580000.genet eth0: Link is Down
[ 6.853796] uart-pl011 fe201000.serial: no DMA platform data
[ 7.072941] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 7.948414] NFSD: starting 90-second grace period (net f0000041)
[ 8.180963] random: crng init done
[ 8.180982] random: 7 urandom warning(s) missed due to ratelimiting
[ 8.812105] i2c /dev entries driver
[ 8.968923] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 13.592932] Bluetooth: Core ver 2.22
[ 13.592978] NET: Registered protocol family 31
[ 13.592982] Bluetooth: HCI device and connection manager initialized
[ 13.592994] Bluetooth: HCI socket layer initialized
[ 13.593001] Bluetooth: L2CAP socket layer initialized
[ 13.593021] Bluetooth: SCO socket layer initialized
[ 13.602009] Bluetooth: HCI UART driver ver 2.3
[ 13.602016] Bluetooth: HCI UART protocol H4 registered
[ 13.602083] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 13.602225] Bluetooth: HCI UART protocol Broadcom registered
[ 13.817867] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.817873] Bluetooth: BNEP filters: protocol multicast
[ 13.817884] Bluetooth: BNEP socket layer initialized
[ 15.219158] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 15.250347] usb 2-2: New USB device found, idVendor=1058, idProduct=0a10, bcdDevice=80.34
[ 15.250355] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 15.250360] usb 2-2: Product: Go To Final Lap
[ 15.250365] usb 2-2: SerialNumber: 1234567890123
[ 15.261509] scsi host0: uas
[ 15.262530] scsi 0:0:0:0: Direct-Access ACASIS 8034 PQ: 0 ANSI: 6
[ 15.265218] scsi 0:0:0:1: Direct-Access ACASIS 8034 PQ: 0 ANSI: 6
[ 15.265806] sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 15.266041] sd 0:0:0:0: [sda] Write Protect is off
[ 15.266057] sd 0:0:0:0: [sda] Mode Sense: 67 00 10 08
[ 15.267495] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 15.267557] sd 0:0:0:1: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 15.268128] sd 0:0:0:1: [sdb] Write Protect is off
[ 15.268136] sd 0:0:0:1: [sdb] Mode Sense: 67 00 10 08
[ 15.268212] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
[ 15.268646] sd 0:0:0:1: [sdb] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 15.269960] sd 0:0:0:1: [sdb] Optimal transfer size 33553920 bytes
[ 15.303741] sda:
[ 15.334242] sd 0:0:0:0: [sda] Attached SCSI disk
[ 15.334673] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 15.335168] sd 0:0:0:1: Attached scsi generic sg1 type 0
[ 15.336247] sd 0:0:0:1: [sdb] Attached SCSI disk
[ 15.789177] usb 2-1: new SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 15.820493] usb 2-1: New USB device found, idVendor=1058, idProduct=0a10, bcdDevice=80.34
[ 15.820500] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 15.820505] usb 2-1: Product: Go To Final Lap
[ 15.820510] usb 2-1: SerialNumber: 1234567890123
[ 15.831226] scsi host1: uas
[ 15.832496] scsi 1:0:0:0: Direct-Access ACASIS 8034 PQ: 0 ANSI: 6
[ 15.834575] sd 1:0:0:0: Attached scsi generic sg2 type 0
[ 15.835081] sd 1:0:0:0: [sdc] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 15.835331] sd 1:0:0:0: [sdc] Write Protect is off
[ 15.835338] sd 1:0:0:0: [sdc] Mode Sense: 67 00 10 08
[ 15.835819] sd 1:0:0:0: [sdc] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 15.835944] scsi 1:0:0:1: Direct-Access ACASIS 8034 PQ: 0 ANSI: 6
[ 15.836566] sd 1:0:0:0: [sdc] Optimal transfer size 33553920 bytes
[ 15.838630] sd 1:0:0:1: Attached scsi generic sg3 type 0
[ 15.839455] sd 1:0:0:1: [sdd] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 15.839672] sd 1:0:0:1: [sdd] Write Protect is off
[ 15.839679] sd 1:0:0:1: [sdd] Mode Sense: 67 00 10 08
[ 15.840300] sd 1:0:0:1: [sdd] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 15.841044] sd 1:0:0:1: [sdd] Optimal transfer size 33553920 bytes
[ 15.900173] sdd:
[ 15.901974] sd 1:0:0:0: [sdc] Attached SCSI disk
[ 15.902930] sd 1:0:0:1: [sdd] Attached SCSI disk
[ 16.199000] raid6: int32x1 gen() 423 MB/s
[ 16.368862] raid6: int32x1 xor() 381 MB/s
[ 16.538916] raid6: int32x2 gen() 562 MB/s
[ 16.708878] raid6: int32x2 xor() 418 MB/s
[ 16.878911] raid6: int32x4 gen() 748 MB/s
[ 17.048905] raid6: int32x4 xor() 444 MB/s
[ 17.218878] raid6: int32x8 gen() 721 MB/s
[ 17.388932] raid6: int32x8 xor() 446 MB/s
[ 17.558890] raid6: neonx1 gen() 1613 MB/s
[ 17.728891] raid6: neonx1 xor() 1607 MB/s
[ 17.898884] raid6: neonx2 gen() 2283 MB/s
[ 18.068892] raid6: neonx2 xor() 2188 MB/s
[ 18.238886] raid6: neonx4 gen() 3075 MB/s
[ 18.408888] raid6: neonx4 xor() 2335 MB/s
[ 18.578892] raid6: neonx8 gen() 2749 MB/s
[ 18.748897] raid6: neonx8 xor() 2208 MB/s
[ 18.748905] raid6: using algorithm neonx4 gen() 3075 MB/s
[ 18.748910] raid6: … xor() 2335 MB/s, rmw enabled
[ 18.748915] raid6: using neon recovery algorithm
[ 18.755001] xor: measuring software checksum speed
[ 18.848894] arm4regs : 4221.600 MB/sec
[ 18.948900] 8regs : 2740.800 MB/sec
[ 19.048897] 32regs : 2450.000 MB/sec
[ 19.148908] neon : 5609.200 MB/sec
[ 19.148915] xor: using function: neon (5609.200 MB/sec)
[ 19.151210] async_tx: api initialized (async)
[ 19.169801] md/raid:md0: device sdc operational as raid disk 2
[ 19.169808] md/raid:md0: device sdb operational as raid disk 1
[ 19.169812] md/raid:md0: device sda operational as raid disk 0
[ 19.171352] md/raid:md0: raid level 5 active with 3 out of 4 devices, algorithm 2
[ 19.178004] md0: detected capacity change from 0 to 6000790929408
The information seems normal, no hard disk crash was found.
Please tell me again lsusb after the failure.
Bus 002 Device 002: ID 1058:0a10 Western Digital Technologies, Inc.
Bus 002 Device 003: ID 1058:0a10 Western Digital Technologies, Inc.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Just to mention for extra information, I am running 4 of the exact same drive. I took it down to 2, just to test it at one point. Still had issues building the raid.
Is there any more information about demsg?
A fresh dmesg after trying to create the raid. Had to take some of the generic stuff out, so it wasn’t too long. Take note of the xHCI host controller not responding, assume dead. There is something going on or failing within the usb controller itself?
[ 0.060048] raspberrypi-firmware soc:firmware: Firmware hash is c3c8dbdf147686fb0c3f32aece709d0653368810
[ 0.103451] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[ 0.106755] vgaarb: loaded
[ 0.107147] SCSI subsystem initialized
[ 0.107377] usbcore: registered new interface driver usbfs
[ 0.107445] usbcore: registered new interface driver hub
[ 0.107532] usbcore: registered new device driver usb
[ 0.108838] clocksource: Switched to clocksource arch_sys_counter
[ 0.188367] VFS: Disk quotas dquot_6.6.0
[ 0.188481] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.188678] FS-Cache: Loaded
[ 0.188918] CacheFiles: Loaded
[ 0.189570] simple-framebuffer 3e513000.framebuffer: framebuffer at 0x3e513000, 0x6e7000 bytes, mapped to 0x(ptrval)
[ 0.189607] simple-framebuffer 3e513000.framebuffer: format=a8r8g8b8, mode=1824x984x32, linelength=7296
[ 0.199432] Console: switching to colour frame buffer device 228x61
[ 0.208118] simple-framebuffer 3e513000.framebuffer: fb0: simplefb registered!
[ 0.217474] NET: Registered protocol family 2
[ 0.218231] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.218336] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.218478] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.218615] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.218808] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.218938] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.219216] NET: Registered protocol family 1
[ 0.219855] RPC: Registered named UNIX socket transport module.
[ 0.219926] RPC: Registered udp transport module.
[ 0.219981] RPC: Registered tcp transport module.
[ 0.220037] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.220113] PCI: CLS 0 bytes, default 64
[ 0.223144] Initialise system trusted keyrings
[ 0.223381] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 0.232735] FS-Cache: Netfs ‘nfs’ registered for caching
[ 0.233325] NFS: Registering the id_resolver key type
[ 0.233409] Key type id_resolver registered
[ 0.233464] Key type id_legacy registered
[ 0.233528] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.235941] Key type asymmetric registered
[ 0.236000] Asymmetric key parser ‘x509’ registered
[ 0.236157] bounce: pool size: 64 pages
[ 0.236240] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.236480] io scheduler noop registered
[ 0.236535] io scheduler deadline registered (default)
[ 0.239301] io scheduler cfq registered
[ 0.241864] io scheduler mq-deadline registered (default)
[ 0.244426] io scheduler kyber registered
[ 0.280681] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
[ 0.283322] brcm-pcie fd500000.pcie: could not get clock
[ 0.285909] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 0.288368] brcm-pcie fd500000.pcie: MEM 0x600000000…0x603ffffff -> 0xf8000000
[ 0.348866] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
[ 0.351661] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 0.354065] pci_bus 0000:00: root bus resource [bus 00-01]
[ 0.356552] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ 0.359160] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 0.359304] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 0.362080] PCI: bus0: Fast back to back transfers disabled
[ 0.364597] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.367328] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 0.367453] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.367770] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 0.370570] PCI: bus1: Fast back to back transfers disabled
[ 0.373058] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
[ 0.373108] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 0.375649] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 0.378246] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.380805] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 0.383586] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 0.386286] pcieport 0000:00:00.0: Signaling PME with IRQ 54
[ 0.388950] pcieport 0000:00:00.0: AER enabled with IRQ 54
[ 0.391657] pci 0000:01:00.0: enabling device (0140 -> 0142)
[ 0.398403] iproc-rng200 fe104000.rng: hwrng registered
[ 0.401244] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.404264] vc-sm: Videocore shared memory driver
[ 0.407231] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 0.420359] brd: module loaded
[ 0.432888] loop: module loaded
[ 0.436181] Loading iSCSI transport class v2.0-870.
[ 0.440403] libphy: Fixed MDIO Bus: probed
[ 0.443330] bcmgenet fd580000.genet: failed to get enet clock
[ 0.445808] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
[ 0.448251] bcmgenet fd580000.genet: failed to get enet-wol clock
[ 0.450720] bcmgenet fd580000.genet: failed to get enet-eee clock
[ 0.453072] bcmgenet: Skipping UMAC reset
[ 0.455603] unimac-mdio unimac-mdio.-19: DMA mask not set
[ 0.468899] libphy: bcmgenet MII bus: probed
[ 0.509434] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
[ 0.512763] usbcore: registered new interface driver r8152
[ 0.515228] usbcore: registered new interface driver lan78xx
[ 0.517652] usbcore: registered new interface driver smsc95xx
[ 0.520294] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.522666] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 0.527311] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[ 0.530074] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 55
[ 0.533356] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.535805] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.538162] usb usb1: Product: xHCI Host Controller
[ 0.540652] usb usb1: Manufacturer: Linux 4.19.97-v7l+ xhci-hcd
[ 0.543124] usb usb1: SerialNumber: 0000:01:00.0
[ 0.546078] hub 1-0:1.0: USB hub found
[ 0.548583] hub 1-0:1.0: 1 port detected
[ 0.551496] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.553822] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 0.556216] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 0.559004] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 0.561476] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.563936] usb usb2: Product: xHCI Host Controller
[ 0.566408] usb usb2: Manufacturer: Linux 4.19.97-v7l+ xhci-hcd
[ 0.568897] usb usb2: SerialNumber: 0000:01:00.0
[ 0.571696] hub 2-0:1.0: USB hub found
[ 0.574170] hub 2-0:1.0: 4 ports detected
[ 0.577807] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.580453] dwc_otg: FIQ enabled
[ 0.580462] dwc_otg: NAK holdoff enabled
[ 0.580471] dwc_otg: FIQ split-transaction FSM enabled
[ 0.580483] Module dwc_common_port init
[ 0.580713] usbcore: registered new interface driver uas
[ 0.583228] usbcore: registered new interface driver usb-storage
[ 0.585785] mousedev: PS/2 mouse device common for all mice
[ 0.589301] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 0.593171] sdhci: Secure Digital Host Controller Interface driver
[ 0.595524] sdhci: Copyright© Pierre Ossman
[ 0.598222] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 0.600992] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.606347] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.609101] hidraw: raw HID events driver © Jiri Kosina
[ 0.611590] usbcore: registered new interface driver usbhid
[ 0.613940] usbhid: USB HID core driver
[ 0.617086] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[ 0.621253] [vc_sm_connected_init]: start
[ 0.632282] [vc_sm_connected_init]: end - returning 0
[ 0.635857] Initializing XFRM netlink socket
[ 0.638110] NET: Registered protocol family 17
[ 0.640550] Key type dns_resolver registered
[ 0.643115] Registering SWP/SWPB emulation handler
[ 0.646021] registered taskstats version 1
[ 0.648303] Loading compiled-in X.509 certificates
[ 0.657675] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 0.660118] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
[ 0.667717] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 0.670578] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[ 0.673600] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 0.676037] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 0.702060] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.3
[ 0.704463] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.4
[ 0.724278] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.728306] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.732312] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.737565] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 0.739961] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 0.743717] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.744744] of_cfs_init
[ 0.748511] of_cfs_init: OK
[ 0.751494] Waiting for root device PARTUUID=738a4d67-02…
[ 0.796600] random: fast init done
[ 0.847840] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
[ 0.853596] mmcblk0: mmc0:aaaa SS08G 7.40 GiB
[ 0.858062] mmc1: new high speed SDIO card at address 0001
[ 0.862432] mmcblk0: p1 p2
[ 0.879974] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 0.882389] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 0.892600] devtmpfs: mounted
[ 0.902801] Freeing unused kernel memory: 2048K
[ 0.918886] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 0.921341] Run /sbin/init as init process
[ 1.101532] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.103887] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.106315] usb 1-1: Product: USB2.0 Hub
[ 1.110772] hub 1-1:1.0: USB hub found
[ 1.113511] hub 1-1:1.0: 4 ports detected
[ 1.353494] systemd[1]: System time before build time, advancing clock.
[ 1.434465] NET: Registered protocol family 10
[ 1.438062] Segment Routing with IPv6
[ 1.448895] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
[ 1.479081] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.485056] systemd[1]: Detected architecture arm.
[ 1.512973] systemd[1]: Set hostname to .
[ 2.122179] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.133038] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.141255] systemd[1]: Created slice system-getty.slice.
[ 2.147755] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.158384] systemd[1]: Listening on Syslog Socket.
[ 2.166275] systemd[1]: Created slice User and Session Slice.
[ 2.173307] systemd[1]: Listening on udev Control Socket.
[ 2.179819] systemd[1]: Reached target Slices.
[ 2.186171] systemd[1]: Reached target Swap.
[ 2.194143] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 2.912551] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.045954] systemd-journald[119]: Received request to flush runtime journal from PID 1
[ 3.520410] Driver for 1-wire Dallas network protocol.
[ 3.571621] media: Linux media interface: v0.10
[ 3.579993] w1_master_driver w1_bus_master1: Attaching one wire slave 28.00000bd4a398 crc bd
[ 3.605708] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.607810] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 3.607828] [vc_sm_connected_init]: start
[ 3.613289] videodev: Linux video capture interface: v2.00
[ 3.615883] [vc_sm_connected_init]: installed successfully
[ 3.665771] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.682420] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.694879] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.719972] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 3.720015] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 3.726702] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 3.726739] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 3.742241] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.746952] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 3.746986] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 3.771273] bcm2835_audio soc:audio: card created with 8 channels
[ 3.835659] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 3.840417] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 3.986072] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 4.039673] vc4-drm soc:gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 4.039694] checking generic (3e513000 6e7000) vs hw (0 ffffffffffffffff)
[ 4.039704] fb: switching to vc4drmfb from simple
[ 4.039975] Console: switching to colour dummy device 80x30
[ 4.042710] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 1
[ 4.042725] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 4.042735] [drm] No driver support for vblank timestamp query.
[ 4.042744] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[ 4.069905] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 4.078008] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.078376] usbcore: registered new interface driver brcmfmac
[ 4.261999] Console: switching to colour frame buffer device 240x67
[ 4.304437] vc4-drm soc:gpu: fb0: DRM emulated frame buffer device
[ 4.314334] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.332708] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 2 2020 23:30:41 version 7.45.202 (r724630 CY) FWID 01-72f6ece2
[ 6.064632] random: crng init done
[ 6.064646] random: 7 urandom warning(s) missed due to ratelimiting
[ 6.291437] uart-pl011 fe201000.serial: no DMA platform data
[ 6.301918] 8021q: 802.1Q VLAN Support v1.8
[ 6.479771] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 6.768722] bcmgenet: Skipping UMAC reset
[ 6.869192] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
[ 6.869533] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.187471] i2c /dev entries driver
[ 7.929082] bcmgenet fd580000.genet eth0: Link is Down
[ 11.049155] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 11.049196] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 12.911501] Bluetooth: Core ver 2.22
[ 12.911563] NET: Registered protocol family 31
[ 12.911572] Bluetooth: HCI device and connection manager initialized
[ 12.911590] Bluetooth: HCI socket layer initialized
[ 12.911602] Bluetooth: L2CAP socket layer initialized
[ 12.911639] Bluetooth: SCO socket layer initialized
[ 12.928420] Bluetooth: HCI UART driver ver 2.3
[ 12.928431] Bluetooth: HCI UART protocol H4 registered
[ 12.928527] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 12.928736] Bluetooth: HCI UART protocol Broadcom registered
[ 13.122726] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.122734] Bluetooth: BNEP filters: protocol multicast
[ 13.122745] Bluetooth: BNEP socket layer initialized
[ 16.679113] usb 1-1.3: device descriptor read/64, error -110
[ 32.039151] usb 1-1.3: device descriptor read/64, error -110
[ 32.309149] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 32.340183] usb 2-2: New USB device found, idVendor=1058, idProduct=0a10, bcdDevice=80.34
[ 32.340190] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 32.340195] usb 2-2: Product: Go To Final Lap
[ 32.340200] usb 2-2: SerialNumber: 1234567890123
[ 32.351364] scsi host0: uas
[ 32.352770] scsi 0:0:0:0: Direct-Access ACASIS 8034 PQ: 0 ANSI: 6
[ 32.355132] sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 32.355464] sd 0:0:0:0: [sda] Write Protect is off
[ 32.355471] sd 0:0:0:0: [sda] Mode Sense: 67 00 10 08
[ 32.355539] scsi 0:0:0:1: Direct-Access ACASIS 8034 PQ: 0 ANSI: 6
[ 32.355976] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 32.356766] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
[ 32.359062] sd 0:0:0:1: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 32.359333] sd 0:0:0:1: [sdb] Write Protect is off
[ 32.359341] sd 0:0:0:1: [sdb] Mode Sense: 67 00 10 08
[ 32.359855] sd 0:0:0:1: [sdb] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 32.402047] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 32.402144] sd 0:0:0:1: Attached scsi generic sg1 type 0
[ 32.438851] usb 1-1.3: new full-speed USB device number 4 using xhci_hcd
[ 32.703523] sda:
[ 32.703619] sd 0:0:0:1: [sdb] Optimal transfer size 33553920 bytes
[ 32.706330] sd 0:0:0:0: [sda] Attached SCSI disk
[ 33.051620] sd 0:0:0:1: [sdb] Attached SCSI disk
[ 47.629084] usb 1-1.3: device descriptor read/64, error -110
[ 62.989104] usb 1-1.3: device descriptor read/64, error -110
[ 63.109206] usb 1-1-port3: attempt power cycle
[ 63.259181] usb 2-1: new SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 63.290542] usb 2-1: New USB device found, idVendor=1058, idProduct=0a10, bcdDevice=80.34
[ 63.290558] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 63.290571] usb 2-1: Product: Go To Final Lap
[ 63.290584] usb 2-1: SerialNumber: 1234567890123
[ 63.313554] scsi host1: uas
[ 63.314952] scsi 1:0:0:0: Direct-Access ACASIS 8034 PQ: 0 ANSI: 6
[ 63.317184] sd 1:0:0:0: Attached scsi generic sg2 type 0
[ 63.319011] scsi 1:0:0:1: Direct-Access ACASIS 8034 PQ: 0 ANSI: 6
[ 63.319015] sd 1:0:0:0: [sdc] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 63.319520] sd 1:0:0:0: [sdc] Write Protect is off
[ 63.319537] sd 1:0:0:0: [sdc] Mode Sense: 67 00 10 08
[ 63.320170] sd 1:0:0:0: [sdc] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 63.320976] sd 1:0:0:1: Attached scsi generic sg3 type 0
[ 63.321203] sd 1:0:0:0: [sdc] Optimal transfer size 33553920 bytes
[ 63.329178] sd 1:0:0:1: [sdd] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 63.329460] sd 1:0:0:1: [sdd] Write Protect is off
[ 63.329476] sd 1:0:0:1: [sdd] Mode Sense: 67 00 10 08
[ 63.330084] sd 1:0:0:1: [sdd] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 63.330982] sd 1:0:0:1: [sdd] Optimal transfer size 33553920 bytes
[ 63.768877] usb 1-1.3: new full-speed USB device number 5 using xhci_hcd
[ 64.010071] sdd:
[ 64.011681] sd 1:0:0:0: [sdc] Attached SCSI disk
[ 64.013405] sd 1:0:0:1: [sdd] Attached SCSI disk
[ 68.809237] usb 1-1.3: device descriptor read/8, error -110
[ 74.009384] usb 1-1.3: device descriptor read/8, error -110
[ 74.229181] usb 1-1.3: new full-speed USB device number 6 using xhci_hcd
[ 79.289628] usb 1-1.3: device descriptor read/8, error -110
[ 84.489734] usb 1-1.3: device descriptor read/8, error -110
[ 84.609929] usb 1-1-port3: unable to enumerate USB device
[ 370.095815] sda:
[ 371.241879] sdd:
[ 371.263472] sdd:
[ 371.429246] raid6: int32x1 gen() 335 MB/s
[ 371.599286] raid6: int32x1 xor() 314 MB/s
[ 371.769220] raid6: int32x2 gen() 617 MB/s
[ 371.939232] raid6: int32x2 xor() 379 MB/s
[ 372.109200] raid6: int32x4 gen() 743 MB/s
[ 372.279190] raid6: int32x4 xor() 430 MB/s
[ 372.449213] raid6: int32x8 gen() 731 MB/s
[ 372.619240] raid6: int32x8 xor() 447 MB/s
[ 372.789191] raid6: neonx1 gen() 1804 MB/s
[ 372.959189] raid6: neonx1 xor() 1477 MB/s
[ 373.129182] raid6: neonx2 gen() 2337 MB/s
[ 373.299180] raid6: neonx2 xor() 1950 MB/s
[ 373.469186] raid6: neonx4 gen() 3032 MB/s
[ 373.639181] raid6: neonx4 xor() 2534 MB/s
[ 373.809199] raid6: neonx8 gen() 2804 MB/s
[ 373.979191] raid6: neonx8 xor() 2133 MB/s
[ 373.979196] raid6: using algorithm neonx4 gen() 3032 MB/s
[ 373.979200] raid6: … xor() 2534 MB/s, rmw enabled
[ 373.979204] raid6: using neon recovery algorithm
[ 373.984448] xor: measuring software checksum speed
[ 374.079180] arm4regs : 4217.200 MB/sec
[ 374.179179] 8regs : 2733.200 MB/sec
[ 374.279179] 32regs : 2444.400 MB/sec
[ 374.379178] neon : 5604.800 MB/sec
[ 374.379183] xor: using function: neon (5604.800 MB/sec)
[ 374.383723] async_tx: api initialized (async)
[ 374.399866] md/raid:md0: device sdc operational as raid disk 2
[ 374.399872] md/raid:md0: device sdb operational as raid disk 1
[ 374.399877] md/raid:md0: device sda operational as raid disk 0
[ 374.401376] md/raid:md0: raid level 5 active with 3 out of 4 devices, algorithm 2
[ 374.422834] md0: detected capacity change from 0 to 6000790929408
[ 374.424655] md: recovery of RAID array md0
[ 405.629192] sd 1:0:0:0: [sdc] tag#7 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD IN
[ 405.629210] sd 1:0:0:0: [sdc] tag#7 CDB: opcode=0x28 28 00 00 04 ab 38 00 04 00 00
[ 405.629881] sd 1:0:0:1: [sdd] tag#9 uas_eh_abort_handler 0 uas-tag 3 inflight: CMD OUT
[ 405.629895] sd 1:0:0:1: [sdd] tag#9 CDB: opcode=0x2a 2a 00 00 04 aa b8 00 00 80 00
[ 410.749189] sd 1:0:0:0: [sdc] tag#8 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD
[ 410.749209] sd 1:0:0:0: [sdc] tag#8 CDB: opcode=0x35 35 00 00 00 00 00 00 00 00 00
[ 410.789212] scsi host1: uas_eh_device_reset_handler start
[ 410.940104] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 410.975642] scsi host1: uas_eh_device_reset_handler success
[ 412.758636] scsi host1: uas_eh_device_reset_handler start
[ 412.910070] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 412.945470] scsi host1: uas_eh_device_reset_handler success
[ 444.029144] sd 1:0:0:0: [sdc] tag#7 uas_eh_abort_handler 0 uas-tag 3 inflight: CMD IN
[ 444.029163] sd 1:0:0:0: [sdc] tag#7 CDB: opcode=0x28 28 00 00 04 c8 f8 00 04 00 00
[ 444.029733] sd 1:0:0:1: [sdd] tag#6 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD OUT
[ 444.029747] sd 1:0:0:1: [sdd] tag#6 CDB: opcode=0x2a 2a 00 00 04 c8 38 00 00 c0 00
[ 444.069168] scsi host1: uas_eh_device_reset_handler start
[ 444.219940] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 444.255555] scsi host1: uas_eh_device_reset_handler success
[ 445.709084] scsi host1: uas_eh_device_reset_handler start
[ 445.860054] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 445.895430] scsi host1: uas_eh_device_reset_handler success
[ 445.915114] sd 1:0:0:1: [sdd] tag#6 data cmplt err -71 uas-tag 1 inflight: CMD
[ 445.915136] sd 1:0:0:1: [sdd] tag#6 CDB: opcode=0x2a 2a 00 00 04 c4 38 00 04 00 00
[ 476.059120] scsi host1: uas_eh_device_reset_handler start
[ 476.060421] sd 1:0:0:1: [sdd] tag#7 uas_zap_pending 0 uas-tag 2 inflight: CMD
[ 476.060438] sd 1:0:0:1: [sdd] tag#7 CDB: opcode=0x2a 2a 00 00 04 c8 38 00 00 c0 00
[ 476.060457] sd 1:0:0:0: [sdc] tag#8 uas_zap_pending 0 uas-tag 3 inflight: CMD
[ 476.060471] sd 1:0:0:0: [sdc] tag#8 CDB: opcode=0x28 28 00 00 04 c8 f8 00 04 00 00
[ 476.209922] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 476.245044] scsi host1: uas_eh_device_reset_handler success
[ 481.063398] scsi host1: uas_eh_device_reset_handler start
[ 481.210014] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 481.245383] scsi host1: uas_eh_device_reset_handler success
[ 511.869057] sd 1:0:0:1: [sdd] tag#7 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD OUT
[ 511.869076] sd 1:0:0:1: [sdd] tag#7 CDB: opcode=0x2a 2a 00 00 04 c4 38 00 04 00 00
[ 511.919075] scsi host1: uas_eh_device_reset_handler start
[ 511.919728] xhci_hcd 0000:01:00.0: WARNING: Host System Error
[ 516.969025] xhci_hcd 0000:01:00.0: xHCI host not responding to stop endpoint command.
[ 516.969042] xhci_hcd 0000:01:00.0: xHCI host controller not responding, assume dead
[ 516.969368] xhci_hcd 0000:01:00.0: HC died; cleaning up
[ 516.969471] sd 1:0:0:1: [sdd] tag#8 uas_zap_pending 0 uas-tag 2 inflight: CMD
[ 516.969489] sd 1:0:0:1: [sdd] tag#8 CDB: opcode=0x2a 2a 00 00 04 c8 38 00 00 c0 00
[ 516.969508] sd 1:0:0:0: [sdc] tag#9 uas_zap_pending 0 uas-tag 3 inflight: CMD
[ 516.969521] sd 1:0:0:0: [sdc] tag#9 CDB: opcode=0x28 28 00 00 04 c8 f8 00 04 00 00
[ 516.969537] scsi host1: uas_eh_device_reset_handler FAILED err -22
[ 516.969557] scsi host1: uas_eh_device_reset_handler FAILED to get lock err -19
[ 516.969574] sd 1:0:0:1: Device offlined - not ready after error recovery
[ 516.969588] sd 1:0:0:0: Device offlined - not ready after error recovery
[ 516.969601] sd 1:0:0:1: Device offlined - not ready after error recovery
[ 516.969696] sd 1:0:0:1: [sdd] tag#7 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x06
[ 516.969711] sd 1:0:0:1: [sdd] tag#7 CDB: opcode=0x2a 2a 00 00 04 c4 38 00 04 00 00
[ 516.969726] print_req_error: I/O error, dev sdd, sector 312376
[ 516.970581] sd 0:0:0:1: [sdb] tag#9 sense submit err -19 uas-tag 1 inflight: s-st a-cmd s-cmd
[ 516.970599] sd 0:0:0:1: [sdb] tag#9 CDB: opcode=0x35 35 00 00 00 00 00 00 00 00 00
[ 516.970681] sd 0:0:0:0: [sda] tag#9 sense submit err -19 uas-tag 1 inflight: s-st a-cmd s-cmd
[ 516.970695] sd 0:0:0:0: [sda] tag#9 CDB: opcode=0x35 35 00 00 00 00 00 00 00 00 00
[ 516.970745] usb 1-1: USB disconnect, device number 2
[ 516.971619] usb 2-1: USB disconnect, device number 3
[ 516.974573] sd 1:0:0:0: [sdc] Synchronizing SCSI cache
[ 516.974618] print_req_error: I/O error, dev sdc, sector 16
[ 516.974634] md: super_written gets error=10
[ 516.974651] md/raid:md0: Disk failure on sdc, disabling device.
md/raid:md0: Operation continuing on 2 devices.
[ 516.983264] print_req_error: I/O error, dev sdc, sector 313592
[ 516.983291] md/raid:md0: read error not correctable (sector 313592 on sdc).
[ 516.983312] md/raid:md0: read error not correctable (sector 313600 on sdc).
[ 516.983327] md/raid:md0: read error not correctable (sector 313608 on sdc).
[ 516.983341] md/raid:md0: read error not correctable (sector 313616 on sdc).
[ 516.983354] md/raid:md0: read error not correctable (sector 313624 on sdc).
[ 516.983372] md/raid:md0: read error not correctable (sector 313632 on sdc).
[ 516.983391] md/raid:md0: read error not correctable (sector 313640 on sdc).
[ 516.983410] md/raid:md0: read error not correctable (sector 313648 on sdc).
[ 516.983428] md/raid:md0: read error not correctable (sector 313656 on sdc).
[ 516.983447] md/raid:md0: read error not correctable (sector 313664 on sdc).
[ 516.989123] sd 1:0:0:1: rejecting I/O to offline device
[ 516.989143] print_req_error: I/O error, dev sdd, sector 16
[ 516.989156] md: super_written gets error=10
[ 516.989170] md/raid:md0: Disk failure on sdd, disabling device.
[ 516.995793] sd 1:0:0:1: rejecting I/O to offline device
[ 516.995809] print_req_error: I/O error, dev sdd, sector 313400
[ 517.029070] sd 0:0:0:0: [sda] tag#9 sense submit err -19 uas-tag 1 inflight: s-st a-cmd s-cmd
[ 517.029085] sd 0:0:0:0: [sda] tag#9 CDB: opcode=0x35 35 00 00 00 00 00 00 00 00 00
[ 518.489113] sd 0:0:0:0: [sda] tag#9 CDB: opcode=0x35 35 00 00 00 00 00 00 00 00 00
[ 518.540089] xhci_hcd 0000:01:00.0: WARN Can’t disable streams for endpoint 0x82, streams are being disabled already
[ 518.541748] usb 2-2: USB disconnect, device number 2
[ 518.544584] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 518.544622] print_req_error: I/O error, dev sda, sector 16
[ 518.544636] md: super_written gets error=10
[ 518.544652] md/raid:md0: Disk failure on sda, disabling device.
md/raid:md0: Operation continuing on 1 devices.
[ 518.749097] sd 0:0:0:1: [sdb] tag#10 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
[ 518.749119] sd 0:0:0:1: [sdb] tag#10 CDB: opcode=0x35 35 00 00 00 00 00 00 00 00 00
[ 518.749143] print_req_error: I/O error, dev sdb, sector 16
[ 518.749156] md: super_written gets error=10
[ 518.749172] md/raid:md0: Disk failure on sdb, disabling device.
md/raid:md0: Operation continuing on 0 devices.
[ 518.779067] md: md0: recovery interrupted.
[ 519.179080] sd 0:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=0x00
[ 519.341332] sd 0:0:0:1: [sdb] Synchronizing SCSI cache
[ 519.378843] Buffer I/O error on dev md0, logical block 1465036832, async page read
[ 519.405356] Buffer I/O error on dev md0, logical block 1465036832, async page read
[ 519.939083] sd 0:0:0:1: [sdb] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=0x00
[ 520.109395] xhci_hcd 0000:01:00.0: WARN Can’t disable streams for endpoint 0x82, streams are being disabled already
It looks like USB may have bad contact, please try to clean up the USB connector.
Thank you for the suggestion.
We have cleaned the contacts on the usb and made sure there is nothing on them. Still having issues.
Could it not be the usb bridge or the embedded connector?
On boot up
[ 67.405283] md/raid:md0: raid level 5 active with 3 out of 4 devices, algorithm 2
[ 67.414856] md0: detected capacity change from 0 to 6000790929408
[ 68.728756] usb 1-1.3: device descriptor read/8, error -110
[ 73.928791] usb 1-1.3: device descriptor read/8, error -110
[ 74.148532] usb 1-1.3: new full-speed USB device number 6 using xhci_hcd
[ 79.208724] usb 1-1.3: device descriptor read/8, error -110
[ 84.408755] usb 1-1.3: device descriptor read/8, error -110
[ 84.528860] usb 1-1-port3: unable to enumerate USB device
Do you have any other hard drives? I saw some sector errors in dmesg.
But I still think it’s a connection problem, maybe USB or SATA.
It looks like a usb problem of raspi. Have you tried different raspi?
Tested all 4 hard drives, and even reduced. Down to two. All of them check out as good.
Tried a different raspi. Only thing I havnt replaced is the USB bridge and the sata hat itself.
@Frawtch : Do you realize that this is NOT a raspberry pi forum? This is a forum for a chinese knockoff that uses completely different hardware. You’d probably be better off using the actual raspberry pi forum for raspberry pi problems. Sounds like a kernel or distro related problem.
Actually this HAT can be attached to RPI too.
@lbdroidman
I am trying to troubleshoot the SATA HAT in the section of the forum for talking about the SATA HAT. Seems like the appropriate forum to me.
The distro or kernal is the same one all guides have instructed me to use.
It all points to some sort of SATA/USB issue consisting within the bridge or the HAT itself.
I am just hoping someone can confirm or tell me a resolution. It took me this long to troubleshoot and try all the different options/hardware, so i have surpassed my return date. Considering i have replaced everything else, i would have liked to get a replacement HAT.
I’m sorry to waste so much of your time. Our product was rigorously tested before it was shipped. I also want to find out what went wrong.
There is no problem with using two hard disks, I wonder if it is SATA1 and SATA2. Have you ever tried to use three hard drives, leave SATA4 empty.
We had tried to run with 3 and 2 drives on every SATA port (leaving each one empty and testing). No improvement in the raid failures.
Please try cleaning usb (bridge & hat) again, using cotton swabs and alcohol.
