Quad SATA Hat not detecting any HDDs
Hi, I am pretty new at operating in a linux environment, but I have been looking into setting up a Rasp Pi NAS setup for a while now.
So I have set up a 32 bit Raspberry PI OS install (was trying 64 bit before but was encountering a whole host of other issues) and the RockPi sata hat script install seems to go pretty well, but it doesnt seem that my hard drives are being detected. I have them installed in SATA1 and 2, but I have moved to other ports and not seen any changes. I have tried multiple OS installs, the first time I installed OMV and the hard drives were not identified in the GUI. Now I am just trying to get them detected through the command line.
OLED seems to work fine, and the blue activity lights are present on the board.
Below are my ls and lsusb. I will comment with dmesg
haste@piomv:~ $ ls /dev/sd
ls: cannot access ‘/dev/sd’: No such file or directory
lsusb:
haste@piomv:~ $ lsusb
Bus 002 Device 007: ID 152d:0561 JMicron Technology Corp. / JMicron USA Technology Corp. JMS551 - Sharkoon SATA QuickPort Duo
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Things I noticed here, I don’t have the western digital devices that I seem to see on the standard lsusb (like on the install thread). Also it appears the JMicron chip is a JMS551 and not a JMS561? It seems like this would limit me to SATA Gen II rather than SATA Gen 3. Wouldn’t that affect the write speeds to the hard drive?
Sorry for the massive posts already. I really appreciate the help!
haste@piomv:~ $ dmesg
[ 0.000000] Linux version 5.10.92-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1514 SMP Mon Jan 17 17:38:03 GMT 2022
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
[ 0.000000] random: fast init done
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem [mem 0x0000000030000000-0x00000000fbffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x00000000fbffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
[ 0.000000] On node 0 totalpages: 1012736
[ 0.000000] DMA zone: 1728 pages used for memmap
[ 0.000000] HighMem zone: 816128 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u81920
[ 0.000000] pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1011008
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=DC:A6:32:5F:1A:9F vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=cfc8243f-02 rootfstype=ext4 fsck.repair=yes rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x0000000014890000-0x0000000018890000] (64MB)
[ 0.000000] Memory: 3601136K/4050944K available (10240K kernel code, 1366K rwdata, 3196K rodata, 2048K init, 882K bss, 122128K reserved, 327680K cma-reserved, 3264512K highmem)
[ 0.000000] ftrace: allocating 34360 entries in 101 pages
[ 0.000000] ftrace: allocated 101 pages with 4 groups
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 25)
[ 0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=1
[ 0.000007] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000034] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000093] bcm2835: system timer (irq = 26)
[ 0.000759] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000780] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000802] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000821] Switching to timer-based delay loop, resolution 18ns
[ 0.001091] Console: colour dummy device 80x30
[ 0.001834] printk: console [tty1] enabled
[ 0.001899] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=540000)
[ 0.001953] pid_max: default: 32768 minimum: 301
[ 0.002130] LSM: Security Framework initializing
[ 0.002331] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002376] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.003851] cgroup: Disabling memory control group subsystem
[ 0.004103] CPU: Testing write buffer coherency: ok
[ 0.004576] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.005794] Setting up static identity map for 0x200000 - 0x20003c
[ 0.006008] rcu: Hierarchical SRCU implementation.
[ 0.006948] smp: Bringing up secondary CPUs …
[ 0.008163] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.009516] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.010827] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.010984] smp: Brought up 1 node, 4 CPUs
[ 0.011031] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.011061] CPU: All CPU(s) started in HYP mode.
[ 0.011088] CPU: Virtualization extensions available.
[ 0.011932] devtmpfs: initialized
[ 0.026412] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.026663] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.026715] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.035133] pinctrl core: initialized pinctrl subsystem
[ 0.036213] NET: Registered protocol family 16
[ 0.040180] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.041037] audit: initializing netlink subsys (disabled)
[ 0.041311] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[ 0.041881] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.042546] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.042600] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.043019] Serial: AMBA PL011 UART driver
[ 0.088315] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.100918] raspberrypi-firmware soc:firmware: Attached to firmware from 2022-01-20T13:56:48, variant start
[ 0.110931] raspberrypi-firmware soc:firmware: Firmware hash is bd88f66f8952d34e4e0613a85c7a6d3da49e13e2
[ 0.151675] Kprobes globally optimized
[ 0.157179] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.162344] vgaarb: loaded
[ 0.162830] SCSI subsystem initialized
[ 0.163084] usbcore: registered new interface driver usbfs
[ 0.163173] usbcore: registered new interface driver hub
[ 0.163260] usbcore: registered new device driver usb
[ 0.163683] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.165590] clocksource: Switched to clocksource arch_sys_counter
[ 1.190247] VFS: Disk quotas dquot_6.6.0
[ 1.190379] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.190579] FS-Cache: Loaded
[ 1.190768] CacheFiles: Loaded
[ 1.200084] NET: Registered protocol family 2
[ 1.200336] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 1.201699] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.201864] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.201949] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.202034] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.202212] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.202268] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.202962] NET: Registered protocol family 1
[ 1.203695] RPC: Registered named UNIX socket transport module.
[ 1.203729] RPC: Registered udp transport module.
[ 1.203757] RPC: Registered tcp transport module.
[ 1.203785] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.203823] PCI: CLS 0 bytes, default 64
[ 1.207223] Initialise system trusted keyrings
[ 1.207473] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 1.215839] zbud: loaded
[ 1.217626] FS-Cache: Netfs ‘nfs’ registered for caching
[ 1.218415] NFS: Registering the id_resolver key type
[ 1.218479] Key type id_resolver registered
[ 1.218508] Key type id_legacy registered
[ 1.218664] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.218697] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 1.219765] Key type asymmetric registered
[ 1.219797] Asymmetric key parser ‘x509’ registered
[ 1.220005] bounce: pool size: 64 pages
[ 1.220073] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.220314] io scheduler mq-deadline registered
[ 1.220346] io scheduler kyber registered
[ 1.225276] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.225328] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.225431] brcm-pcie fd500000.pcie: MEM 0x0600000000…0x063fffffff -> 0x00c0000000
[ 1.225541] brcm-pcie fd500000.pcie: IB MEM 0x0000000000…0x00bfffffff -> 0x0400000000
[ 1.287699] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.288084] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.288122] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.288158] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.288271] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.288530] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.292118] PCI: bus0: Fast back to back transfers disabled
[ 1.292474] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.292618] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.293073] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 1.296691] PCI: bus1: Fast back to back transfers disabled
[ 1.296805] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.296847] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.296950] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.296989] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.297416] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 1.297665] pcieport 0000:00:00.0: PME: Signaling with IRQ 82
[ 1.308440] iproc-rng200 fe104000.rng: hwrng registered
[ 1.308838] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.310371] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.322564] brd: module loaded
[ 1.334760] loop: module loaded
[ 1.336822] Loading iSCSI transport class v2.0-870.
[ 1.340067] libphy: Fixed MDIO Bus: probed
[ 1.341984] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.355675] libphy: bcmgenet MII bus: probed
[ 1.435758] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.436961] usbcore: registered new interface driver r8152
[ 1.437046] usbcore: registered new interface driver lan78xx
[ 1.437136] usbcore: registered new interface driver smsc95xx
[ 1.438802] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
[ 1.438982] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.439032] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.442441] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x00000e0000000890
[ 1.443778] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 1.443820] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.443857] usb usb1: Product: xHCI Host Controller
[ 1.443887] usb usb1: Manufacturer: Linux 5.10.92-v7l+ xhci-hcd
[ 1.443918] usb usb1: SerialNumber: 0000:01:00.0
[ 1.444658] hub 1-0:1.0: USB hub found
[ 1.444771] hub 1-0:1.0: 1 port detected
[ 1.445460] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.445503] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.445549] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.446093] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 1.446133] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.446168] usb usb2: Product: xHCI Host Controller
[ 1.446198] usb usb2: Manufacturer: Linux 5.10.92-v7l+ xhci-hcd
[ 1.446228] usb usb2: SerialNumber: 0000:01:00.0
[ 1.446970] hub 2-0:1.0: USB hub found
[ 1.447070] hub 2-0:1.0: 4 ports detected
[ 1.448903] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.449302] dwc_otg: FIQ enabled
[ 1.449317] dwc_otg: NAK holdoff enabled
[ 1.449331] dwc_otg: FIQ split-transaction FSM enabled
[ 1.449349] Module dwc_common_port init
[ 1.449819] usbcore: registered new interface driver uas
[ 1.449966] usbcore: registered new interface driver usb-storage
[ 1.450169] mousedev: PS/2 mouse device common for all mice
[ 1.451989] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.455689] sdhci: Secure Digital Host Controller Interface driver
[ 1.455724] sdhci: Copyright© Pierre Ossman
[ 1.456502] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 1.457171] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.461856] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.462208] hid: raw HID events driver © Jiri Kosina
[ 1.462427] usbcore: registered new interface driver usbhid
[ 1.462458] usbhid: USB HID core driver
[ 1.468494] Initializing XFRM netlink socket
[ 1.468557] NET: Registered protocol family 17
[ 1.468689] Key type dns_resolver registered
[ 1.469048] Registering SWP/SWPB emulation handler
[ 1.469240] registered taskstats version 1
[ 1.469281] Loading compiled-in X.509 certificates
[ 1.470146] Key type ._fscrypt registered
[ 1.470178] Key type .fscrypt registered
[ 1.470205] Key type fscrypt-provisioning registered
[ 1.482372] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.482703] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.482814] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 38, base_baud = 0) is a PL011 rev2
[ 1.491531] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.492631] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.492666] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.522989] of_cfs_init
[ 1.523273] of_cfs_init: OK
[ 1.543662] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.545387] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.547178] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.550246] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.551967] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.558357] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.559016] Waiting for root device PARTUUID=cfc8243f-02…
[ 1.660599] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
[ 1.661581] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[ 1.666496] mmcblk0: p1 p2
[ 1.670086] mmc1: new high speed SDIO card at address 0001
[ 1.687319] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.687414] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.692603] devtmpfs: mounted
[ 1.702864] Freeing unused kernel memory: 2048K
[ 1.745663] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.745969] Run /sbin/init as init process
[ 1.746000] with arguments:
[ 1.746015] /sbin/init
[ 1.746029] with environment:
[ 1.746043] HOME=/
[ 1.746057] TERM=linux
[ 1.928278] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.928325] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.928359] usb 1-1: Product: USB2.0 Hub
[ 1.930370] hub 1-1:1.0: USB hub found
[ 1.930676] hub 1-1:1.0: 4 ports detected
[ 2.092253] systemd[1]: System time before build time, advancing clock.
[ 2.192009] NET: Registered protocol family 10
[ 2.193454] Segment Routing with IPv6
[ 2.255652] usb 1-1.4: new full-speed USB device number 3 using xhci_hcd
[ 2.262008] systemd[1]: systemd 247.3-6+rpi1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 2.262956] systemd[1]: Detected architecture arm.
[ 2.270157] systemd[1]: Set hostname to .
[ 2.393087] usb 1-1.4: New USB device found, idVendor=051d, idProduct=0002, bcdDevice= 0.90
[ 2.393140] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.393181] usb 1-1.4: Product: Back-UPS RS 1350MS FW:951.e4 .D USB FW:e4
[ 2.393220] usb 1-1.4: Manufacturer: American Power Conversion
[ 2.393257] usb 1-1.4: SerialNumber: 3B2011X24624
[ 2.426801] hid-generic 0003:051D:0002.0001: hiddev96,hidraw0: USB HID v1.00 Device [American Power Conversion Back-UPS RS 1350MS FW:951.e4 .D USB FW:e4 ] on usb-0000:01:00.0-1.4/input0
[ 3.105398] systemd[1]: Queued start job for default target Graphical Interface.
[ 3.107166] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.109558] systemd[1]: Created slice system-getty.slice.
[ 3.110276] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.111315] systemd[1]: Created slice system-modprobe.slice.
[ 3.111758] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.112693] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 3.113864] systemd[1]: Created slice User and Session Slice.
[ 3.114640] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 3.115398] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.116845] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.117483] systemd[1]: Reached target Local Encrypted Volumes.
[ 3.118215] systemd[1]: Reached target Paths.
[ 3.118798] systemd[1]: Reached target Slices.
[ 3.119308] systemd[1]: Reached target Swap.
[ 3.120693] systemd[1]: Listening on Syslog Socket.
[ 3.121742] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 3.122509] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 3.123897] systemd[1]: Listening on Journal Audit Socket.
[ 3.125014] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.126607] systemd[1]: Listening on Journal Socket.
[ 3.135498] systemd[1]: Listening on udev Control Socket.
[ 3.136794] systemd[1]: Listening on udev Kernel Socket.
[ 3.138003] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 3.142845] systemd[1]: Mounting POSIX Message Queue File System…
[ 3.149246] systemd[1]: Mounting RPC Pipe File System…
[ 3.156292] systemd[1]: Mounting Kernel Debug File System…
[ 3.163684] systemd[1]: Mounting Kernel Trace File System…
[ 3.164767] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 3.172860] systemd[1]: Starting Restore / save the current clock…
[ 3.181755] systemd[1]: Starting Set the console keyboard layout…
[ 3.188523] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 3.196138] systemd[1]: Starting Load Kernel Module configfs…
[ 3.203436] systemd[1]: Starting Load Kernel Module drm…
[ 3.211005] systemd[1]: Starting Load Kernel Module fuse…
[ 3.219230] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 3.226087] systemd[1]: Starting File System Check on Root Device…
[ 3.241486] systemd[1]: Starting Journal Service…
[ 3.256104] systemd[1]: Starting Load Kernel Modules…
[ 3.263180] systemd[1]: Starting Coldplug All udev Devices…
[ 3.277381] fuse: init (API version 7.32)
[ 3.281119] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.288901] systemd[1]: Mounted RPC Pipe File System.
[ 3.300699] systemd[1]: Mounted Kernel Debug File System.
[ 3.301712] systemd[1]: Mounted Kernel Trace File System.
[ 3.318311] systemd[1]: Finished Restore / save the current clock.
[ 3.321990] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 3.325170] systemd[1]: modprobe@configfs.service: Succeeded.
[ 3.329261] systemd[1]: Finished Load Kernel Module configfs.
[ 3.332798] systemd[1]: modprobe@drm.service: Succeeded.
[ 3.334438] systemd[1]: Finished Load Kernel Module drm.
[ 3.336973] systemd[1]: modprobe@fuse.service: Succeeded.
[ 3.338831] systemd[1]: Finished Load Kernel Module fuse.
[ 3.347145] systemd[1]: Mounting FUSE Control File System…
[ 3.354425] systemd[1]: Mounting Kernel Configuration File System…
[ 3.361516] systemd[1]: Started File System Check Daemon to report status.
[ 3.366145] systemd[1]: Finished Load Kernel Modules.
[ 3.373104] systemd[1]: Starting Apply Kernel Variables…
[ 3.384738] systemd[1]: Mounted FUSE Control File System.
[ 3.409533] systemd[1]: Mounted Kernel Configuration File System.
[ 3.449469] systemd[1]: Finished Apply Kernel Variables.
[ 3.485930] systemd[1]: Finished File System Check on Root Device.
[ 3.491679] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 3.599761] systemd[1]: Started Journal Service.
[ 3.694575] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.770595] systemd-journald[132]: Received client request to flush runtime journal.
[ 3.786706] systemd-journald[132]: File /var/log/journal/ce513f1a44ff4c9dbd382eb66e08c51e/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 5.007205] Driver for 1-wire Dallas network protocol.
[ 5.009767] gpio-4 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 5.112032] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 5.112631] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 5.113169] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 5.113702] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 5.269372] mc: Linux media interface: v0.10
[ 5.295897] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.299652] videodev: Linux video capture interface: v2.00
[ 5.304534] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.307118] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 5.307143] [vc_sm_connected_init]: start
[ 5.319985] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.321332] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.324948] [vc_sm_connected_init]: installed successfully
[ 5.344959] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.349582] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 5.363195] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.365878] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.368894] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.381661] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 5.384314] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 5.384360] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 5.390427] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 5.390472] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 5.403073] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 5.403135] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 5.404955] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 5.405557] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 5.408885] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 5.409576] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 5.409649] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 5.421702] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 5.423405] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 5.423440] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 5.423465] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 5.423489] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 5.423511] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 5.447802] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 5.448539] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 5.449177] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 5.449552] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 5.449581] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 5.449605] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 5.449628] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 5.449651] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 5.449921] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 5.461745] brcmstb-i2c fef04500.i2c: @97500hz registered in polling mode
[ 5.461935] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 5.462982] brcmstb-i2c fef09500.i2c: @97500hz registered in polling mode
[ 5.492056] Registered IR keymap rc-cec
[ 5.492264] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 5.492496] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input0
[ 5.645056] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 5.665234] Registered IR keymap rc-cec
[ 5.665445] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 5.665762] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input1
[ 5.767262] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.781841] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 1
[ 5.814460] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 5.815219] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 5.838547] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 5.838786] Registered IR keymap rc-cec
[ 5.839011] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 5.839277] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input2
[ 5.954093] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 5.970677] Registered IR keymap rc-cec
[ 5.970926] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 5.971186] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input3
[ 5.981851] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 6.046831] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 6.147496] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 6.175193] Registered IR keymap rc-cec
[ 6.175473] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 6.175881] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input4
[ 6.311876] usbcore: registered new interface driver brcmfmac
[ 6.318350] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 6.318507] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 6.329830] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[ 6.739850] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 6.788229] Registered IR keymap rc-cec
[ 6.788425] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 6.788668] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input5
[ 6.793412] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 6.834814] Registered IR keymap rc-cec
[ 6.835008] rc rc1: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[ 6.835244] input: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input6
[ 6.842295] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ 6.842716] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[ 6.843068] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 6.843398] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 6.843713] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 6.843991] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 6.844298] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 6.923974] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 0
[ 6.924189] vc4-drm gpu: [drm] Cannot find any crtc or sizes
[ 7.018428] random: crng init done
[ 7.018445] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.225154] uart-pl011 fe201000.serial: no DMA platform data
[ 7.385938] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 7.795660] 8021q: 802.1Q VLAN Support v1.8
[ 8.358786] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 8.359901] bcmgenet fd580000.ethernet eth0: Link is Down
[ 9.112050] i2c /dev entries driver
[ 12.565967] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 12.566020] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 14.162231] Bluetooth: Core ver 2.22
[ 14.162337] NET: Registered protocol family 31
[ 14.162352] Bluetooth: HCI device and connection manager initialized
[ 14.162984] Bluetooth: HCI socket layer initialized
[ 14.163005] Bluetooth: L2CAP socket layer initialized
[ 14.163037] Bluetooth: SCO socket layer initialized
[ 14.181882] Bluetooth: HCI UART driver ver 2.3
[ 14.181902] Bluetooth: HCI UART protocol H4 registered
[ 14.182002] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 14.183262] Bluetooth: HCI UART protocol Broadcom registered
[ 14.504857] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 14.504865] Bluetooth: BNEP filters: protocol multicast
[ 14.504878] Bluetooth: BNEP socket layer initialized
[ 14.516947] NET: Registered protocol family 38
[ 14.537584] cryptd: max_cpu_qlen set to 1000
[ 16.926007] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 16.957218] usb 2-1: New USB device found, idVendor=152d, idProduct=0561, bcdDevice=81.36
[ 16.957237] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 16.957253] usb 2-1: Product: External Disk 3.0
[ 16.957268] usb 2-1: Manufacturer: JMicron
[ 16.957283] usb 2-1: SerialNumber: RANDOM__BF833EEF5DA5
[ 17.127235] scsi host0: uas
[ 17.128309] scsi 0:0:0:0: Direct-Access JMicron Tech 8136 PQ: 0 ANSI: 6
[ 17.130799] sd 0:0:0:0: [sda] 11721045168 512-byte logical blocks: (6.00 TB/5.46 TiB)
[ 17.131043] sd 0:0:0:0: [sda] Write Protect is off
[ 17.131052] sd 0:0:0:0: [sda] Mode Sense: 67 00 10 08
[ 17.131516] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 17.132194] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
[ 17.194389] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 17.221189] sd 0:0:0:0: [sda] Attached SCSI disk
[ 31.835634] cam-dummy-reg: disabling
[ 31.835662] cam1-reg: disabling
[ 950.523575] usb 1-1.4: USB disconnect, device number 3
[ 1044.046464] usb 1-1.1: new high-speed USB device number 4 using xhci_hcd
[ 1044.456472] usb 2-1: USB disconnect, device number 2
[ 1044.458812] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 1045.056577] sd 0:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=0x00
[ 1045.566739] usb 2-1: new SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 1045.597983] usb 2-1: New USB device found, idVendor=152d, idProduct=0561, bcdDevice=81.36
[ 1045.597992] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 1045.598000] usb 2-1: Product: External Disk 3.0
[ 1045.598007] usb 2-1: Manufacturer: JMicron
[ 1045.598014] usb 2-1: SerialNumber: RANDOM__359879645F5D
[ 1045.605554] scsi host0: uas
[ 1045.610970] scsi 0:0:0:0: Direct-Access JMicron Tech 8136 PQ: 0 ANSI: 6
[ 1045.612246] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1045.613501] sd 0:0:0:0: [sda] 11721045168 512-byte logical blocks: (6.00 TB/5.46 TiB)
[ 1045.613754] sd 0:0:0:0: [sda] Write Protect is off
[ 1045.613764] sd 0:0:0:0: [sda] Mode Sense: 67 00 10 08
[ 1045.614230] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 1045.614952] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
[ 1045.888104] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1047.846531] usb 1-1.1: new high-speed USB device number 5 using xhci_hcd
[ 1048.058046] usb 1-1.1: New USB device found, idVendor=152d, idProduct=0561, bcdDevice=81.36
[ 1048.058065] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 1048.058081] usb 1-1.1: Product: External Disk 3.0
[ 1048.058096] usb 1-1.1: Manufacturer: JMicron
[ 1048.058111] usb 1-1.1: SerialNumber: RANDOM__7B7E21ACDEBB
[ 1048.064736] scsi host1: uas
[ 1048.066815] scsi 1:0:0:0: Direct-Access JMicron Tech 8136 PQ: 0 ANSI: 6
[ 1048.069362] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 1048.071897] sd 1:0:0:0: [sdb] 11721045168 512-byte logical blocks: (6.00 TB/5.46 TiB)
[ 1048.072387] sd 1:0:0:0: [sdb] Write Protect is off
[ 1048.072406] sd 1:0:0:0: [sdb] Mode Sense: 67 00 10 08
[ 1048.073390] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 1048.074135] sd 1:0:0:0: [sdb] Optimal transfer size 33553920 bytes
[ 1048.136246] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 1051.626688] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 1051.626798] usb 2-1: USB disconnect, device number 3
[ 1051.629045] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 1052.146676] sd 0:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=0x00
[ 1056.816756] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 1057.221954] usb 1-1.1: USB disconnect, device number 5
[ 1057.226791] sd 1:0:0:0: [sdb] Synchronizing SCSI cache
[ 1057.826740] sd 1:0:0:0: [sdb] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=0x00
[ 1061.156846] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 1061.157287] usb usb2-port1: attempt power cycle
[ 2342.862580] usb 2-1: new SuperSpeed Gen 1 USB device number 7 using xhci_hcd
[ 2342.893891] usb 2-1: New USB device found, idVendor=152d, idProduct=0561, bcdDevice=81.36
[ 2342.893909] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 2342.893925] usb 2-1: Product: External Disk 3.0
[ 2342.893941] usb 2-1: Manufacturer: JMicron
[ 2342.893956] usb 2-1: SerialNumber: RANDOM__A5313073F491
[ 2342.905214] scsi host0: uas
[ 2342.906801] scsi 0:0:0:0: Direct-Access JMicron Tech 8136 PQ: 0 ANSI: 6
[ 2342.908512] scsi 0:0:0:0: Attached scsi generic sg0 type 0
[ 2357.078837] sd 0:0:0:0: [sda] 11721045168 512-byte logical blocks: (6.00 TB/5.46 TiB)
[ 2357.079143] sd 0:0:0:0: [sda] Write Protect is off
[ 2357.079161] sd 0:0:0:0: [sda] Mode Sense: 67 00 10 08
[ 2357.079692] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 2357.080517] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
[ 2357.142240] sd 0:0:0:0: [sda] Attached SCSI disk
Multiple errors seem like they call out that the usb cable might be bad? also it seems like it sees the hard drives, but I’m not sure why I am not able to mount them, or why ls /dev/sd doesnt identify them.
UPDATE:
I moved the drive in SATA 1 to SATA 3 and now it appears lsblk can detect both drives (drives in SATA 3 and 4 slots). However, I am getting I/O errors in dmesg. I posted just a section, because they seem like similar errors. I can post more if needed.
[ 167.130273] blk_update_request: I/O error, dev sda, sector 488 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 167.130294] Buffer I/O error on dev sda, logical block 61, async page read
[ 167.132832] sd 0:0:0:0: rejecting I/O to offline device
[ 167.132859] blk_update_request: I/O error, dev sda, sector 488 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 167.132879] Buffer I/O error on dev sda, logical block 61, async page read
[ 167.133034] usb 2-1: USB disconnect, device number 8
[ 167.142943] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 167.197237] sd 0:0:0:1: [sdb] tag#13 UNKNOWN(0x2003) Result: hostbyte=0x07 dr iverbyte=0x00 cmd_age=0s
[ 167.197261] sd 0:0:0:1: [sdb] tag#13 CDB: opcode=0x85 85 06 20 00 05 00 fe 00 00 00 00 00 00 40 ef 00
[ 167.740676] sd 0:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte= 0x07 driverbyte=0x00
[ 167.861893] sd 0:0:0:1: [sdb] Synchronizing SCSI cache
[ 168.510735] sd 0:0:0:1: [sdb] Synchronize Cache(10) failed: Result: hostbyte= 0x07 driverbyte=0x00
[ 172.990735] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 173.220999] usb 2-1: new SuperSpeed Gen 1 USB device number 10 using xhci_hcd
[ 173.252346] usb 2-1: New USB device found, idVendor=152d, idProduct=0561, bcd Device=81.36
[ 173.252365] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 173.252380] usb 2-1: Product: External Disk 3.0
[ 173.252395] usb 2-1: Manufacturer: JMicron
[ 173.252410] usb 2-1: SerialNumber: RANDOM__33EEF5DA5313
[ 173.267380] scsi host0: uas
[ 173.269002] scsi 0:0:0:0: Direct-Access JMicron Tech 8136 PQ : 0 ANSI: 6
[ 173.271683] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 173.272215] sd 0:0:0:0: [sda] 11721045168 512-byte logical blocks: (6.00 TB/5 .46 TiB)
[ 173.272502] sd 0:0:0:0: [sda] Write Protect is off
[ 173.272521] sd 0:0:0:0: [sda] Mode Sense: 67 00 10 08
[ 173.273148] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, supp orts DPO and FUA
[ 173.273890] scsi 0:0:0:1: Direct-Access JMicron Tech 8136 PQ : 0 ANSI: 6
[ 173.273995] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
[ 173.275714] sd 0:0:0:1: Attached scsi generic sg1 type 0
[ 173.277085] sd 0:0:0:1: [sdb] 11721045168 512-byte logical blocks: (6.00 TB/5 .46 TiB)
[ 173.277390] sd 0:0:0:1: [sdb] Write Protect is off
[ 173.277408] sd 0:0:0:1: [sdb] Mode Sense: 67 00 10 08
[ 173.277958] sd 0:0:0:1: [sdb] Write cache: enabled, read cache: enabled, supp orts DPO and FUA
[ 173.278817] sd 0:0:0:1: [sdb] Optimal transfer size 33553920 bytes
[ 173.386482] sd 0:0:0:0: [sda] Attached SCSI disk
[ 173.387337] sd 0:0:0:1: [sdb] Attached SCSI disk
[ 173.463956] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 dri verbyte=0x08 cmd_age=0s
[ 173.463968] sd 0:0:0:0: [sda] tag#0 Sense Key : 0xb [current]
[ 173.463976] sd 0:0:0:0: [sda] tag#0 ASC=0x0 ASCQ=0x0
[ 173.463987] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x88 88 00 00 00 00 02 ba a0 f4 00 00 00 00 08 00 00
[ 173.463998] blk_update_request: I/O error, dev sda, sector 11721044992 op 0x0 :(READ) flags 0x80700 phys_seg 1 prio class 0
[ 173.476555] sd 0:0:0:0: [sda] tag#1 UNKNOWN(0x2003) Result: hostbyte=0x00 dri verbyte=0x08 cmd_age=0s
[ 173.476565] sd 0:0:0:0: [sda] tag#1 Sense Key : 0xb [current]
[ 173.476573] sd 0:0:0:0: [sda] tag#1 ASC=0x0 ASCQ=0x0
[ 173.476583] sd 0:0:0:0: [sda] tag#1 CDB: opcode=0x88 88 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00
[ 173.476593] blk_update_request: I/O error, dev sda, sector 0 op 0x0:(READ) fl ags 0x80700 phys_seg 1 prio class 0
[ 173.551918] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 dri verbyte=0x08 cmd_age=0s
[ 173.551939] sd 0:0:0:0: [sda] tag#0 Sense Key : 0xb [current]
[ 173.551950] sd 0:0:0:0: [sda] tag#0 ASC=0x0 ASCQ=0x0
[ 173.551962] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x88 88 00 00 00 00 02 ba a0 f3 a8 00 00 00 08 00 00
[ 173.551976] blk_update_request: I/O error, dev sda, sector 11721044904 op 0x0 :(READ) flags 0x80700 phys_seg 1 prio class 0
[ 173.828282] sd 0:0:0:0: [sda] tag#4 UNKNOWN(0x2003) Result: hostbyte=0x00 dri verbyte=0x08 cmd_age=0s
[ 173.828303] sd 0:0:0:0: [sda] tag#4 Sense Key : 0xb [current]
[ 173.828314] sd 0:0:0:0: [sda] tag#4 ASC=0x0 ASCQ=0x0
[ 173.828327] sd 0:0:0:0: [sda] tag#4 CDB: opcode=0x88 88 00 00 00 00 02 ba a0 f3 a8 00 00 00 08 00 00
[ 173.828340] blk_update_request: I/O error, dev sda, sector 11721044904 op 0x0 :(READ) flags 0x0 phys_seg 1 prio class 0
[ 173.828354] Buffer I/O error on dev sda, logical block 1465130613, async page read
I have not tried installing OMV or mounting the drives since the drives have been detected in lsblk. A bit out of my element at this point.
[… Sharkoon SATA QuickPort Duo …]
As I see the USB-Bridge Adapter is not connecting very well.
In my case, it’s VERY sensitive. If I move it a little bit all of the HDDs will dropped out.
Try to pull out and plug (of course between a power off and a reboot) until:
  1. SerialNumber: RANDOM__33EEF5DA5313 can’t be RANDOM. It means there is a connection issue.
  2. usb usb2-port1: Cannot enable. Maybe the USB cable is bad? This is also means there is a connection issue.
So repeat the plug and pull out until you see kind of these messages.
And also try to clean with compressed air the USB-Bridge Adaptor.
I suggest use the lsblk command to display the devices.
I’m working on trying to get it to recognize. Seems like sda and sdb get recognized, however, the I/O errors still seem to be there. Also the serial number is still not showing up. Ill keep working at it.
What is the best way to power cycle the setup? All of my reboot commands seem to get hanged up and dont fully restart. I think its because it stays plugged into 12V line, and never powers completely off. Unfortunately that leaves me with pulling out the 12V line, but then the HDDs crash. Is there any better way to do this?
Usually if sudo reboot not working, I try with sudo poweroff, keep watching the green LED which indicates is there any working in the background. After this, I pull out the adapter, wait 5 secs, and plug it back.
It appears that the USB bridge is pretty flakey, and its intermittently identifying the hard drives. Tinkering with it hasn’t got it more reliable unfortunately. I guess my only option is to wait till they are back in stock?
