Did manage to find out that the DT debian image does seem to report “Link Up” in dmesg and detect the card in lspci, but it’s in some weird limbo state where trying to activate the driver gives a NVRM: objClInitPcieChipset: *** Chipset Setup Function Error!, NVRM: clCheckUpstreamLtrSupport_IMPL: PCIE config space is inaccessible!, NVRM: GPU 0002:c1:00.0: RmInitAdapter failed! (0x62:0x0:1929), *ERROR* [nvidia-drm] [GPU ID 0x0001c100] Failed to allocate NvKmsKapiDevice among other errors. Note that NVreg_OpenRmEnableUnsupportedGpus=1 in kernel cmdline. Trying a hot reset (link retrain) was very weird:
Uhh wtf
<this is just me removing the device and rescanning the bus etc>
[ 1171.287222] [2025:04:08 18:11:52][pid:32007,cpu8,tee]pci 0001:c1:00.0: [10de:2882] type 00 class 0x030000
[ 1171.287256] [pid:32007,cpu8,tee]pci 0001:c1:00.0: reg 0x10: [mem 0x61000000-0x61ffffff]
[ 1171.287276] [pid:32007,cpu8,tee]pci 0001:c1:00.0: reg 0x14: [mem 0x1800000000-0x180fffffff 64bit pref]
[ 1171.287296] [pid:32007,cpu8,tee]pci 0001:c1:00.0: reg 0x1c: [mem 0x1810000000-0x1811ffffff 64bit pref]
[ 1171.287309] [pid:32007,cpu8,tee]pci 0001:c1:00.0: reg 0x24: [io 0x100000-0x10007f]
[ 1171.287323] [pid:32007,cpu8,tee]pci 0001:c1:00.0: reg 0x30: [mem 0x00000000-0x0007ffff pref]
[ 1171.287454] [pid:32007,cpu8,tee]pci 0001:c1:00.0: PME# supported from D0 D3hot
[ 1171.287562] [pid:32007,cpu8,tee]pci 0001:c1:00.0: 16.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x8 link at 0001:c0:00.0 (capable of 126.024 Gb/s with 16.0 GT/s PCIe x8 link)
[ 1171.287763] [pid:32007,cpu8,tee]pci 0001:c1:00.0: vgaarb: setting as boot VGA device
[ 1171.287766] [pid:32007,cpu8,tee]pci 0001:c1:00.0: vgaarb: bridge control possible
[ 1171.287768] [pid:32007,cpu8,tee]pci 0001:c1:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 1171.287848] [pid:32007,cpu8,tee]pci 0001:c1:00.1: [10de:22be] type 00 class 0x040300
[ 1171.287866] [pid:32007,cpu8,tee]pci 0001:c1:00.1: reg 0x10: [mem 0x60880000-0x60883fff]
[ 1171.300979] [pid:32007,cpu8,tee]pci 0001:c1:00.0: BAR 1: assigned [mem 0x1800000000-0x180fffffff 64bit pref]
[ 1171.300991] [pid:32007,cpu8,tee]pci 0001:c1:00.0: BAR 3: assigned [mem 0x1810000000-0x1811ffffff 64bit pref]
[ 1171.300997] [pid:32007,cpu8,tee]pci 0001:c1:00.0: BAR 0: assigned [mem 0x61000000-0x61ffffff]
[ 1171.301001] [pid:32007,cpu8,tee]pci 0001:c1:00.0: BAR 6: assigned [mem 0x60800000-0x6087ffff pref]
[ 1171.301004] [pid:32007,cpu8,tee]pci 0001:c1:00.1: BAR 0: assigned [mem 0x60880000-0x60883fff]
[ 1171.301008] [pid:32007,cpu8,tee]pci 0001:c1:00.0: BAR 5: assigned [io 0x100000-0x10007f]
[ 1171.301088] [pid:32007,cpu8,tee]pci 0001:c1:00.1: extending delay after power-on from D3hot to 20 msec
[ 1171.301151] [pid:32007,cpu8,tee]pci 0001:c1:00.1: D0 power state depends on 0001:c1:00.0
[ 1171.335209] [pid:32012,cpu9,modprobe]nvidia-nvlink: Nvlink Core is being initialized, major device number 506
[ 1171.335229] [pid:32012,cpu9,modprobe]NVRM: CPUID: unknown implementer/part 0x41/0xd81.
[ 1171.335601] [pid:32012,cpu9,modprobe]The NVIDIA GPU driver for AArch64 has not been qualified on this CPU
and therefore it is not recommended or intended for use in any production
environment.
[ 1171.337222] [pid:32012,cpu7,modprobe]nvidia 0001:c1:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 1171.380528] [pid:32012,cpu7,modprobe]NVRM: loading NVIDIA UNIX Open Kernel Module for aarch64 535.216.01 Release Build (buildd@debian) Wed Nov 20 09:22:33 UTC 2024
[ 1238.452866] [2025:04:08 18:13:00][pid:33816,cpu8,modprobe]nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64 535.216.01 Release Build (buildd@debian) Wed Nov 20 09:22:33 UTC 2024
[ 1238.473584] [pid:33814,cpu11,modprobe][drm] [nvidia-drm] [GPU ID 0x0001c100] Loading driver
[ 1238.495638] [pid:33814,cpu11,modprobe]NVRM: objClInitPcieChipset: *** Chipset Setup Function Error!
[ 1238.495652] [pid:33814,cpu11,modprobe]NVRM: Chipset not recognized (vendor ID 0x1f6c, device ID 0x0001)
[ 1238.495656] [pid:33814,cpu11,modprobe]The NVIDIA GPU driver for AArch64 has not been qualified on this platform
environment.
[ 1238.495673] [pid:33814,cpu11,modprobe]NVRM: clCheckUpstreamLtrSupport_IMPL: PCIE config space is inaccessible!
[ 1239.491965] [2025:04:08 18:13:01][pid:33814,cpu11,modprobe]NVRM: clCheckUpstreamLtrSupport_IMPL: PCIE config space is inaccessible!
[ 1239.607068] [pid:33814,cpu11,modprobe]NVRM: Open nvidia.ko is only ready for use on Data Center GPUs.
[ 1239.607077] [pid:33814,cpu11,modprobe]NVRM: To force use of Open nvidia.ko on other GPUs, see the
[ 1239.607079] [pid:33814,cpu11,modprobe]NVRM: 'OpenRmEnableUnsupportedGpus' kernel module parameter described
[ 1239.607081] [pid:33814,cpu11,modprobe]NVRM: in the README.
[ 1239.773132] [pid:33814,cpu11,modprobe]NVRM: GPU 0001:c1:00.0: RmInitAdapter failed! (0x62:0x0:1929)
[ 1239.773936] [pid:33814,cpu11,modprobe]NVRM: GPU 0001:c1:00.0: rm_init_adapter failed, device minor number 0
[ 1239.774415] [pid:33814,cpu11,modprobe][drm:nv_drm_load [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x0001c100] Failed to allocate NvKmsKapiDevice
[ 1239.774702] [pid:33814,cpu11,modprobe][drm:nv_drm_probe_devices [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x0001c100] Failed to register device
[ 1239.774728] [pid:33814,cpu11,modprobe]do_boottime_initcall, initcall nv_linux_drm_init+0x0/0x1000 [nvidia_drm] returned 0 after 1301523 usecs
<runs sudo ./pcie_hot_reset.sh 0001:c1:00.0, chaos ensues>
[ 1940.538725] [2025:04:08 18:24:42][pid:0,cpu0,in irq]sky1-pcie a010000.pcie: line = 438 sta = 0x80000000
[ 1940.538738] [pid:0,cpu0,in irq]sky1-pcie a010000.pcie: local err0 int: LTSSTTRAN happend
[ 1940.538741] [pid:0,cpu0,in irq]sky1-pcie a010000.pcie: AXI_SLAVE_CTRL = 0x00000001
[ 1940.538743] [pid:0,cpu0,in irq]sky1-pcie a010000.pcie: AXI_SLAVE_CTRL = 0x00000000
[ 1940.538745] [pid:0,cpu0,in irq]sky1-pcie a010000.pcie: LTSSM_TRANS_DEBUG_CTRL_STATUS = 0xff000040
[ 1940.538747] [pid:0,cpu0,in irq]sky1-pcie a010000.pcie: ltssttran changed: HOT_RESET -> HOT_RESET_1
[ 1940.538749] [pid:0,cpu0,in irq]sky1-pcie a010000.pcie: line = 452 sta = 0x00000000
[ 1962.062955] [2025:04:08 18:25:03][pid:0,cpu5,in irq]rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
[ 1962.062966] [pid:0,cpu5,in irq]rcu: 6-...!: (0 ticks this GP) idle=485c/1/0x4000000000000000 softirq=47969/47969 fqs=338
[ 1962.062971] [pid:0,cpu5,in irq] (detected by 5, t=5255 jiffies, g=148585, q=78 ncpus=12)
[ 1962.062975] [pid:0,cpu5,in irq]Sending NMI from CPU 5 to CPUs 6:
[ 1972.064180] [pid:0,cpu5,in irq]rcu: rcu_preempt kthread starved for 4579 jiffies! g148585 f0x0 RCU_GP_WAIT_FQS(5) ->state=0x0 ->cpu=10
[ 1972.064184] [pid:0,cpu5,in irq]rcu: Unless rcu_preempt kthread gets sufficient CPU time, OOM is now expected behavior.
[ 1972.064186] [pid:0,cpu5,in irq]rcu: RCU grace-period kthread stack dump:
[ 1972.064188] [pid:0,cpu5,in irq]task:rcu_preempt state:R running task stack:0 pid:14 ppid:2 flags:0x00000008
[ 1972.064193] [pid:0,cpu5,in irq]Call trace:
[ 1972.064195] [pid:0,cpu5,in irq] __switch_to+0xdc/0x150
[ 1972.064214] [pid:0,cpu5,in irq] __schedule+0x2dc/0x7d0
[ 1972.064217] [pid:0,cpu5,in irq] schedule+0x5c/0x100
[ 1972.064220] [pid:0,cpu5,in irq] schedule_timeout+0x8c/0x100
[ 1972.064227] [pid:0,cpu5,in irq] rcu_gp_fqs_loop+0x140/0x420
[ 1972.064243] [pid:0,cpu5,in irq] rcu_gp_kthread+0x134/0x164
[ 1972.064250] [pid:0,cpu5,in irq] kthread+0x108/0x10c
[ 1972.064255] [pid:0,cpu5,in irq] ret_from_fork+0x10/0x20
[ 1972.064262] [pid:0,cpu5,in irq]rcu: Stack dump where RCU GP kthread last ran:
[ 1972.064263] [pid:0,cpu5,in irq]Sending NMI from CPU 5 to CPUs 10:
[ 2004.066554] [2025:04:08 18:25:45][pid:325,cpu11,in irq]watchdog: BUG: soft lockup - CPU#11 stuck for 21s! [systemd-journal:325]
[ 2004.066561] [pid:325,cpu11,in irq]Modules linked in: nvidia_drm(O) nvidia_modeset(O) nvidia(O) qrtr xt_MASQUERADE nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 uhid 8021q garp mrp stp llc rtk_btusb snd_soc_hdmi_codec btusb btrtl btintel r8126 mali_kbase(O) protected_memory_allocator(O) snd_hda_codec_realtek clk_sky1_audss crct10dif_ce sm3_ce amvx(O) snd_soc_hda sm3 snd_hda_ext_core sha3_ce reset_sky1_audss cros_ec_chardev goodix_ts arm_dma350 aipu(O) sha3_generic rtc_hym8563 cix_dsp_rproc snd_soc_cdns_i2s_mc memory_group_manager(O) trilin_dpsub snd_hda_core sha512_ce sha512_arm64 linlon_dp rfkill_bt pwm_bl armcb_isp snd_soc_sky1_sound_card drm_display_helper binfmt_misc video nf_tables libcrc32c nfnetlink fuse dm_mod ip_tables x_tables ipv6 [last unloaded: nvidia(O)]
[ 2004.066623] [pid:325,cpu11,in irq]CPU: 11 PID: 325 Comm: systemd-journal Tainted: G S O 6.1.44-cix-build-generic #2
[ 2004.066626] [pid:325,cpu11,in irq]Hardware name: Radxa Computer (Shenzhen) Co., Ltd. Radxa Orion O6/Radxa Orion O6, BIOS 1.0 Jan 1 1980
[ 2004.066627] [pid:325,cpu11,in irq]pstate: 02400009 (nzcv daif +PAN -UAO +TCO -DIT -SSBS BTYPE=--)
[ 2004.066630] [pid:325,cpu11,in irq]pc : queued_spin_lock_slowpath+0x54/0x370
[ 2004.066641] [pid:325,cpu11,in irq]lr : _raw_spin_lock+0x70/0x80
[ 2004.066643] [pid:325,cpu11,in irq]sp : ffff80000ad93c10
[ 2004.066644] [pid:325,cpu11,in irq]x29: ffff80000ad93c10 x28: fffffc00025026c0 x27: ffff000091d1fd80
[ 2004.066647] [pid:325,cpu11,in irq]x26: ffff00008fc602a0 x25: 0000000000000000 x24: 0000000000000000
[ 2004.066650] [pid:325,cpu11,in irq]x23: 0800000102183003 x22: 0000ffff915f0000 x21: ffff80000ad93d28
[ 2004.066653] [pid:325,cpu11,in irq]x20: 00000000000005ff x19: 00000000000005f0 x18: 0000000000000000
[ 2004.066656] [pid:325,cpu11,in irq]x17: 0000000000000000 x16: ffff800009486770 x15: 0000ffff923fffff
[ 2004.066659] [pid:325,cpu11,in irq]x14: 0000000000000000 x13: 1fffe00012ad82e1 x12: ffff80000ad93d38
[ 2004.066661] [pid:325,cpu11,in irq]x11: ffff0000956c1700 x10: ffff0000956c170c x9 : 00000000000005f0
[ 2004.066664] [pid:325,cpu11,in irq]x8 : 00000000000005ff x7 : ffff80000ad93c90 x6 : ffff00008f891ff0
[ 2004.066667] [pid:325,cpu11,in irq]x5 : ffff80000ad93c90 x4 : 0000000000000001 x3 : fffffc00020860e8
[ 2004.066670] [pid:325,cpu11,in irq]x2 : 0000000000000001 x1 : 0000000000000000 x0 : 0000000000000101
[ 2004.066672] [pid:325,cpu11,in irq]
PC: 0xffff800009258914:
[ 2004.066674] [pid:325,cpu11,in irq]8894 d5184600 d5184600 d5384613 521b0a61 d5184601 d5384613 521b0a60 d5184600
[ 2004.066680] [pid:325,cpu11,in irq]88b4 00000000 00000000 00000000 aa0003e3 7104003f 540008e0 7103fc3f 54000408
[ 2004.066686] [pid:325,cpu11,in irq]88d4 d503201f 52802000 b8a03060 7103fc1f 54000308 35000160 52800020 79000060
[ 2004.066692] [pid:325,cpu11,in irq]88f4 d65f03c0 93407c00 d50320bf d503205f 885f7c61 4a000021 35000041 d503205f
[ 2004.066698] [pid:325,cpu11,in irq]8914 88dffc60 72001c1f 54fffee1 52800020 79000060 d65f03c0 f9800071 885ffc60
[ 2004.066703] [pid:325,cpu11,in irq]8934 32180001 88027c61 35ffffa2 17ffffe8 72181c1f 54001100 d503201f b0003d64
[ 2004.066709] [pid:325,cpu11,in irq]8954 912a0084 910003e1 aa0403e5 d53cd040 8b0000a5 d503233f f0003d00 91002000
[ 2004.066715] [pid:325,cpu11,in irq]8974 b9400ca6 110004c2 b9000ca2 d53cd041 b8616809 71000cdf 540006ac 937c7cc8
[ 2004.066721] [pid:325,cpu11,in irq]
LR: 0xffff800009258100:
[ 2004.066722] [pid:325,cpu11,in irq]8080 d50323bf d65f03c0 d503201f d503201f d5384102 b9400841 aa0003e3 11000421
[ 2004.066727] [pid:325,cpu11,in irq]80a0 b9000841 d503201f 52800001 52800022 2a0103e4 88e47c02 2a0403e0 35000160
[ 2004.066733] [pid:325,cpu11,in irq]80c0 d65f03c0 d2800001 52800022 f9800071 885ffc60 4a010004 35000064 88047c62
[ 2004.066739] [pid:325,cpu11,in irq]80e0 35ffff84 34fffee0 d503233f a9bf7bfd 2a0003e1 910003fd aa0303e0 940001f1
[ 2004.066745] [pid:325,cpu11,in irq]8100 a8c17bfd d50323bf d65f03c0 d503201f d5384102 b9400841 aa0003e3 11080421
[ 2004.066751] [pid:325,cpu11,in irq]8120 b9000841 d503201f 52800001 52801fe2 2a0103e4 88e47c02 2a0403e0 35000160
[ 2004.066756] [pid:325,cpu11,in irq]8140 d65f03c0 d2800001 52801fe2 f9800071 885ffc60 4a010004 35000064 88047c62
[ 2004.066762] [pid:325,cpu11,in irq]8160 35ffff84 34fffee0 d503233f a9bf7bfd aa0303e0 910003fd 9400030a a8c17bfd
[ 2004.066768] [pid:325,cpu11,in irq]
SP: 0xffff80000ad93c10:
[ 2004.066769] [pid:325,cpu11,in irq]3b90 8fc602a0 ffff0000 91d1fd80 ffff0000 025026c0 fffffc00 0ad93c10 ffff8000
[ 2004.066775] [pid:325,cpu11,in irq]3bb0 09258100 ffff8000 0ad93c10 ffff8000 09258914 ffff8000 02400009 00000000
[ 2004.066781] [pid:325,cpu11,in irq]3bd0 0ad93c20 ffff8000 083eacfc 3fbd8000 000005f0 00000000 000005ff 00000000
[ 2004.066787] [pid:325,cpu11,in irq]3bf0 0ad93c10 ffff8000 09258914 ffff8000 86379ff0 ffff0000 00000000 00000000
[ 2004.066793] [pid:325,cpu11,in irq]3c10 0ad93c20 ffff8000 083eae68 5db48000 0ad93cd0 ffff8000 084275a8 29db8000
[ 2004.066799] [pid:325,cpu11,in irq]3c30 000005ff 00000000 91d1fd80 ffff0000 0ad93d28 ffff8000 000005f0 00000000
[ 2004.066805] [pid:325,cpu11,in irq]3c50 86379ff0 ffff0000 000000fb 00000000 84b28780 ffff0000 00000003 00000000
[ 2004.066811] [pid:325,cpu11,in irq]3c70 00000000 00000000 85195880 ffff0000 86fc7500 ffff0000 80000000 00000000
[ 2004.066817] [pid:325,cpu11,in irq]
X3: 0xfffffc00020860e8:
[ 2004.066818] [pid:325,cpu11,in irq]6068 00000000 00000000 ffffffff 00000000 00000000 00000000 00000000 0bfffc00
[ 2004.066825] [pid:325,cpu11,in irq]6088 00000000 00000000 00000122 dead0000 00000000 00000000 00000000 00000000
[ 2004.066830] [pid:325,cpu11,in irq]60a8 00000000 00000000 ffffffff 00000001 00000000 00000000 00000000 0bfffc00
[ 2004.066836] [pid:325,cpu11,in irq]60c8 00000000 00000000 00000122 dead0000 00000000 00000000 00000000 00000000
[ 2004.066842] [pid:325,cpu11,in irq]60e8 00000101 00000000 fffffdff 00000001 86c24602 ffff0000 00002030 0bfffc00
[ 2004.066848] [pid:325,cpu11,in irq]6108 021a04c8 fffffc00 020e77c8 fffffc00 83c08b60 ffff0000 0000159e 00000000
[ 2004.066854] [pid:325,cpu11,in irq]6128 8fe62548 ffff0000 ffffffff 00000002 82917000 ffff0000 00000000 0bfffc00
[ 2004.066859] [pid:325,cpu11,in irq]6148 00000000 00000000 00000122 dead0000 00000000 00000000 00000000 00000000
[ 2004.066865] [pid:325,cpu11,in irq]
X5: 0xffff80000ad93c90:
[ 2004.066866] [pid:325,cpu11,in irq]3c10 0ad93c20 ffff8000 083eae68 5db48000 0ad93cd0 ffff8000 084275a8 29db8000
[ 2004.066872] [pid:325,cpu11,in irq]3c30 000005ff 00000000 91d1fd80 ffff0000 0ad93d28 ffff8000 000005f0 00000000
[ 2004.066878] [pid:325,cpu11,in irq]3c50 86379ff0 ffff0000 000000fb 00000000 84b28780 ffff0000 00000003 00000000
[ 2004.066884] [pid:325,cpu11,in irq]3c70 00000000 00000000 85195880 ffff0000 86fc7500 ffff0000 80000000 00000000
[ 2004.066889] [pid:325,cpu11,in irq]3c90 8fc602a8 ffff0000 000005f0 00000000 00300000 00000000 8f891ff0 ffff0000
[ 2004.066895] [pid:325,cpu11,in irq]3cb0 00000000 00000000 00000000 00000000 00000000 00000000 dcbb2e00 bc72e43a
[ 2004.066901] [pid:325,cpu11,in irq]3cd0 0ad93da0 ffff8000 0842792c 078c8000 00000254 00000000 91d1fd80 ffff0000
[ 2004.066907] [pid:325,cpu11,in irq]3cf0 915f4da8 0000ffff 0ad93eb0 ffff8000 00000040 00000000 92000007 00000000
[ 2004.066913] [pid:325,cpu11,in irq]
X6: 0xffff00008f891ff0:
[ 2004.066914] [pid:325,cpu11,in irq]1f70 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2004.066920] [pid:325,cpu11,in irq]1f90 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2004.066926] [pid:325,cpu11,in irq]1fb0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2004.066931] [pid:325,cpu11,in irq]1fd0 00000000 00000000 00000000 00000000 00000000 00000000 8f893230 ffff0000
[ 2004.066937] [pid:325,cpu11,in irq]1ff0 00381700 00000000 8f8d8ff8 ffff0000 8fc602a8 ffff0000 8f892008 ffff0000
[ 2004.066943] [pid:325,cpu11,in irq]2010 8f892008 ffff0000 02a8e4c0 fffffc00 02b3f3c0 fffffc00 028ec580 fffffc00
[ 2004.066949] [pid:325,cpu11,in irq]2030 02ad9140 fffffc00 028788c0 fffffc00 02b3f6c0 fffffc00 028abf00 fffffc00
[ 2004.066954] [pid:325,cpu11,in irq]2050 024c9c00 fffffc00 02b49e80 fffffc00 02a83100 fffffc00 024c2440 fffffc00
[ 2004.066960] [pid:325,cpu11,in irq]
X7: 0xffff80000ad93c90:
[ 2004.066961] [pid:325,cpu11,in irq]3c10 0ad93c20 ffff8000 083eae68 5db48000 0ad93cd0 ffff8000 084275a8 29db8000
[ 2004.066967] [pid:325,cpu11,in irq]3c30 000005ff 00000000 91d1fd80 ffff0000 0ad93d28 ffff8000 000005f0 00000000
[ 2004.066973] [pid:325,cpu11,in irq]3c50 86379ff0 ffff0000 000000fb 00000000 84b28780 ffff0000 00000003 00000000
[ 2004.066979] [pid:325,cpu11,in irq]3c70 00000000 00000000 85195880 ffff0000 86fc7500 ffff0000 80000000 00000000
[ 2004.066984] [pid:325,cpu11,in irq]3c90 8fc602a8 ffff0000 000005f0 00000000 00300000 00000000 8f891ff0 ffff0000
[ 2004.066990] [pid:325,cpu11,in irq]3cb0 00000000 00000000 00000000 00000000 00000000 00000000 dcbb2e00 bc72e43a
[ 2004.066996] [pid:325,cpu11,in irq]3cd0 0ad93da0 ffff8000 0842792c 078c8000 00000254 00000000 91d1fd80 ffff0000
[ 2004.067002] [pid:325,cpu11,in irq]3cf0 915f4da8 0000ffff 0ad93eb0 ffff8000 00000040 00000000 92000007 00000000
[ 2004.067008] [pid:325,cpu11,in irq]
X10: 0xffff0000956c170c:
[ 2004.067009] [pid:325,cpu11,in irq]168c ffff0000 88b72e10 ffff0000 90d5dbd0 ffff0000 90d5dab0 ffff0000 90d5db40
[ 2004.067015] [pid:325,cpu11,in irq]16ac ffff0000 90d5da20 ffff0000 88b726c0 ffff0000 00000000 00000000 88760cf0
[ 2004.067020] [pid:325,cpu11,in irq]16cc ffff0000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2004.067026] [pid:325,cpu11,in irq]16ec 00000000 00000000 00000000 0000000a 00000000 956c1d06 ffff0000 de94ffff
[ 2004.067032] [pid:325,cpu11,in irq]170c 0000aaaa de974fff 0000aaaa de98dfff 0000aaaa de98ffff 0000aaaa de990fff
[ 2004.067038] [pid:325,cpu11,in irq]172c 0000aaaa 0b7a0fff 0000aaab 0b818fff 0000aaab 907effff 0000ffff 907fffff
[ 2004.067044] [pid:325,cpu11,in irq]174c 0000ffff 90ffffff 0000ffff 917fffff 0000ffff 91bfffff 0000ffff 923fffff
[ 2004.067050] [pid:325,cpu11,in irq]176c 0000ffff 00000000 00000000 00000000 00000000 00000000 00000000 8355bb40
[ 2004.067056] [pid:325,cpu11,in irq]
X11: 0xffff0000956c1700:
[ 2004.067056] [pid:325,cpu11,in irq]1680 83bf5c60 ffff0000 86e757e0 ffff0000 88b72e10 ffff0000 90d5dbd0 ffff0000
[ 2004.067062] [pid:325,cpu11,in irq]16a0 90d5dab0 ffff0000 90d5db40 ffff0000 90d5da20 ffff0000 88b726c0 ffff0000
[ 2004.067068] [pid:325,cpu11,in irq]16c0 00000000 00000000 88760cf0 ffff0000 00000000 00000000 00000000 00000000
[ 2004.067074] [pid:325,cpu11,in irq]16e0 00000000 00000000 00000000 00000000 00000000 00000000 0000000a 00000000
[ 2004.067080] [pid:325,cpu11,in irq]1700 956c1d06 ffff0000 de94ffff 0000aaaa de974fff 0000aaaa de98dfff 0000aaaa
[ 2004.067086] [pid:325,cpu11,in irq]1720 de98ffff 0000aaaa de990fff 0000aaaa 0b7a0fff 0000aaab 0b818fff 0000aaab
[ 2004.067091] [pid:325,cpu11,in irq]1740 907effff 0000ffff 907fffff 0000ffff 90ffffff 0000ffff 917fffff 0000ffff
[ 2004.067097] [pid:325,cpu11,in irq]1760 91bfffff 0000ffff 923fffff 0000ffff 00000000 00000000 00000000 00000000
[ 2004.067103] [pid:325,cpu11,in irq]
X12: 0xffff80000ad93d38:
[ 2004.067104] [pid:325,cpu11,in irq]3cb8 00000000 00000000 00000000 00000000 dcbb2e00 bc72e43a 0ad93da0 ffff8000
[ 2004.067110] [pid:325,cpu11,in irq]3cd8 0842792c 078c8000 00000254 00000000 91d1fd80 ffff0000 915f4da8 0000ffff
[ 2004.067115] [pid:325,cpu11,in irq]3cf8 0ad93eb0 ffff8000 00000040 00000000 92000007 00000000 84b28780 ffff0000
[ 2004.067121] [pid:325,cpu11,in irq]3d18 0ad93eb0 ffff8000 00000001 00000000 91d1fd80 ffff0000 00100cca 00000000
[ 2004.067127] [pid:325,cpu11,in irq]3d38 000005f4 00000000 915f4000 0000ffff 915f4da8 0000ffff 00000a54 00000000
[ 2004.067133] [pid:325,cpu11,in irq]3d58 85377450 ffff0000 86379ff0 ffff0000 00000000 00000000 00000000 00000000
[ 2004.067139] [pid:325,cpu11,in irq]3d78 00000000 00000000 00000000 00000000 020860e8 fffffc00 00000000 00000000
[ 2004.067145] [pid:325,cpu11,in irq]3d98 dcbb2e00 bc72e43a 0ad93de0 ffff8000 082245a4 b5ca8000 0ad93eb0 ffff8000
[ 2004.067151] [pid:325,cpu11,in irq]
X16: 0xffff800009486770:
[ 2004.067152] [pid:325,cpu11,in irq]66f0 65766575 6d20746e 61737365 74206567 62206f6f 00006769 096ed610 ffff8000
[ 2004.067158] [pid:325,cpu11,in irq]6710 0977ac10 ffff8000 09834bf0 ffff8000 0973e010 ffff8000 0980fae8 ffff8000
[ 2004.067164] [pid:325,cpu11,in irq]6730 096dbcb8 ffff8000 096fc210 ffff8000 0977b508 ffff8000 6a626f6b 5f746365
[ 2004.067170] [pid:325,cpu11,in irq]6750 65766575 655f746e 0000766e 00000000 41444f4d 5341494c 0000003d 00000000
[ 2004.067175] [pid:325,cpu11,in irq]6770 090f0f00 00000000 0a10101f 00000000 0406060f 00000000 5f696d6e 6b636162
[ 2004.067181] [pid:325,cpu11,in irq]6790 63617274 61622e65 72746b63 5f656361 656c6469 00000000 00000049 00000000
[ 2004.067187] [pid:325,cpu11,in irq]67b0 00000000 00000000 00000000 00000000 008d0000 00880002 006e0074 00680000
[ 2004.067193] [pid:325,cpu11,in irq]67d0 000e0000 00bf0000 00080000 00c400a8 00000000 00020014 00570000 0000005d
[ 2004.067199] [pid:325,cpu11,in irq]
X21: 0xffff80000ad93d28:
[ 2004.067200] [pid:325,cpu11,in irq]3ca8 8f891ff0 ffff0000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2004.067206] [pid:325,cpu11,in irq]3cc8 dcbb2e00 bc72e43a 0ad93da0 ffff8000 0842792c 078c8000 00000254 00000000
[ 2004.067212] [pid:325,cpu11,in irq]3ce8 91d1fd80 ffff0000 915f4da8 0000ffff 0ad93eb0 ffff8000 00000040 00000000
[ 2004.067218] [pid:325,cpu11,in irq]3d08 92000007 00000000 84b28780 ffff0000 0ad93eb0 ffff8000 00000001 00000000
[ 2004.067223] [pid:325,cpu11,in irq]3d28 91d1fd80 ffff0000 00100cca 00000000 000005f4 00000000 915f4000 0000ffff
[ 2004.067229] [pid:325,cpu11,in irq]3d48 915f4da8 0000ffff 00000a54 00000000 85377450 ffff0000 86379ff0 ffff0000
[ 2004.067235] [pid:325,cpu11,in irq]3d68 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2004.067241] [pid:325,cpu11,in irq]3d88 020860e8 fffffc00 00000000 00000000 dcbb2e00 bc72e43a 0ad93de0 ffff8000
[ 2004.067247] [pid:325,cpu11,in irq]
X26: 0xffff00008fc602a0:
[ 2004.067248] [pid:325,cpu11,in irq]0220 861cbc00 ffff0000 00000016 0000ffff 8fc60230 ffff0000 8fc60230 ffff0000
[ 2004.067254] [pid:325,cpu11,in irq]0240 8fe1d4f0 ffff0000 8fc606d8 ffff0000 8fc60250 ffff0000 8fc60250 ffff0000
[ 2004.067259] [pid:325,cpu11,in irq]0260 8f8fc9b0 ffff0000 00000000 00000000 00000006 00000000 00000000 00000000
[ 2004.067265] [pid:325,cpu11,in irq]0280 00000001 00000000 00000001 00000000 092b3500 ffff8000 00000000 00000000
[ 2004.067271] [pid:325,cpu11,in irq]02a0 8fc60128 ffff0000 00000000 28000021 8f8d8ffa ffff0000 00000000 00000000
[ 2004.067277] [pid:325,cpu11,in irq]02c0 00000000 00000000 00000000 00000000 8fc602d0 ffff0000 8fc602d0 ffff0000
[ 2004.067283] [pid:325,cpu11,in irq]02e0 00100cca 00000002 91d1fe38 ffff0000 91d1fe38 ffff0000 00000200 00000000
[ 2004.067289] [pid:325,cpu11,in irq]0300 83620ec1 ffff0000 00000000 00000000 8fc60310 ffff0000 8fc60310 ffff0000
[ 2004.067295] [pid:325,cpu11,in irq]
X27: 0xffff000091d1fd80:
[ 2004.067296] [pid:325,cpu11,in irq]fd00 8362f440 ffff0000 00000fc3 00600000 00100073 00000000 881944a9 ffff0000
[ 2004.067301] [pid:325,cpu11,in irq]fd20 00000000 00000000 00000000 00000000 00000090 00000000 8313ad90 ffff0000
[ 2004.067307] [pid:325,cpu11,in irq]fd40 8313a710 ffff0000 91d83680 ffff0000 092b3340 ffff8000 00000090 00000000
[ 2004.067313] [pid:325,cpu11,in irq]fd60 86fbab00 ffff0000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2004.067319] [pid:325,cpu11,in irq]fd80 91000000 0000ffff 91800000 0000ffff 84b28780 ffff0000 00000fc3 00600000
[ 2004.067325] [pid:325,cpu11,in irq]fda0 000000fb 00000000 91d1fe38 ffff0000 00000000 00000000 00000000 00000000
[ 2004.067331] [pid:325,cpu11,in irq]fdc0 000007ff 00000000 91d1fdc8 ffff0000 91d1fdc8 ffff0000 00000000 00000000
[ 2004.067336] [pid:325,cpu11,in irq]fde0 092b3340 ffff8000 00000000 00000000 86fc7500 ffff0000 00000000 00000000
