@Salvador my comment wasn’t nice and I’m sorry for acting like an asshole, I was upset to log on and saw my troubleshooting thread turned into pointless off topic semantic arguments. My point still stands but I shouldn’t have acted like that. Sorry.
You are certanly not helping by calling me wrong and giving no reason as to why im wrong. I already able to do more with the O6 with the 2nd bios that showed up than in 4 years with the useless RK3588. and in 10 years of $10 to $200 SBCs.
@ShivanSpS Im confused, where did I call you wrong. Yeah this board is way more capable than cheap credit-card SBCs, I mean that’s the whole reason I bought it in the first place.
If you all rich people that can buy $5000 server boards and call it a consumer board want to call me wrong go right ahead.
You can pretty easily purchase boards like LX2 or put together used ampere for less than 1/5 that. But anyways this is the pointless argument I was trying to get away from, stop it already.
Yes there are problems and i tried to help you, i dont have the tecnical knowledge to go deeper.
I appreciate trying to help, even if I don’t understand how bridging the sense pin would do anything, especially when its an x8 gpu in an x8 slot anyways and the card is at least discovered in the devicetree image, and the 3.0x16 cards work at x8 perfectly even on old bios. But I’m down to try it if you think it would change something. I mean it’s the only suggestion I’ve gotten here…
Again I’d appreciate anyone suggesting how to determine what the 40 series are doing differently than my working ones.
There is a slight possibility that the BIOS update to come might solve this issue, hopefully, considering you have signaled this issue for a while. The BIOS that enabled the 30XX generation seems to be a bit pre-release, so who knows.
I was doing that; ASPM was disabled (which should mean the port should run at full speed, IIRC), and I also checked lspci under load, and monitored in real time with nvtop. It was always showing at 2.5 GT/s.
Could also be a quirk in the Nvidia driver… or with some userland applications (I didn’t re-check today while I was testing some LLMs, though they don’t need tons of PCIe bandwidth).
Do you have any other x8 machine to test it on ? It’s possible that the card automatically downgrades to Gen1 when detecting it’s not in x16 mode. I would find this surprising for such a high-end board, but not totally unlikely. In the worst case if you’re feeling lucky, you can put some paper on the connector at the position that starts after x8 and insert it in an x16 slot. I admit that it’s not my preferred approach though!
