So far i tried turning off GOP. That was bad idea. If it turned off there no HDMI output (thanks that keyboard was still working so i was able to reset bios).
If it’s still possible, it would definitely be awesome to get a sample as well!
The project I had in mind was to build multiple Android/Windows cloud gaming devices in mini-game console form factors. I’ve tried other SBC boards but none had quite the performance needed or the right form factor either. The Z8350 with 4GB of RAM should definitely be sufficient performance for this. I’ve been following the progress on this SBC for awhile too and am very excited either way that it’s finally coming!
How big is the display connector on the bottom of the board compared to the microSD slot? I’m hoping it’s still very flat/slim so it can fit in an existing case I have that would be perfect for a project I’m working on. But the case would of course rely on the physical dimensions being similar to an RPi 3 so there’s no much extra space at the bottom of the case. I had that issue with the Rock Pi 4 since it had a PCIe connector at the bottom of it and that was too big to fit in the case.
Another question that I have: are there any plans of removing or at least disabling the Intel Management Engine with a solution such as this one or this other one? Or is the chipset recent enough to be no longer capable of being disabled?
@TomaszJ, about BSODs you have met. I had a lot of them too, the problem with them is in drivers for one of the following device: PCI\VEN_8086&DEV_22B8&SUBSYS_72708086&REV_36\3&11583659&0&18 ACPI\BCM2EA4\4&29E26D5C&0
SD\VID_02d0&PID_a0bf&FN_1 SD\VID_02d0&PID_a0bf&FN_2 SD\VID_02d0&PID_a0bf&FN_3
As long as I don’t have them installed - i have yet to meet any BSOD (from every 1-2 hours to already 2 days without any)
Update:
I discovered at least one of the driver that just summoning BSOD. It’s
Update 2:
Ugh, now i know why. Latest Windows 10 update just incompatible with bcm43455\bcm43456
I hope it will. I would install linux too, but i need Heroes 3&5 with Microsoft Office, and using wine is…not optimal (like why emulate something when i can use it without it).
Your videos do not play at all. Here is the output i’m getting from the VLC app:
[00007fb4f8c4a3c0] avcodec decoder error: more than 5 seconds of late video -> dropping frame (computer too slow ?)
[hevc @ 0x7fb4f8c46b70] Could not find ref with POC 176
[hevc @ 0x7fb4f8c46b70] Could not find ref with POC 174
[hevc @ 0x7fb4f8c46b70] Could not find ref with POC 172
[hevc @ 0x7fb4f8c46b70] Could not find ref with POC 170
[hevc @ 0x7fb4f8c46b70] Could not find ref with POC 166
[hevc @ 0x7fb4f8cace10] Could not find ref with POC 198
I am a software developer, working for ARM architectures. I think that Rock Pi X is a very interesting alternative and I would like to contribute to this platform. Please, I would like to apply for a sample. Thank you.
