That solves the majority of my thoughts as I am thinking a constant decent amperage 12v bus is likely going to be a ‘thing’.
I guess it could be the reverse and a hat that provides 5v to the GPIO but 12V at the I/O instead for me is preferable, but guess its dependent on the utilised type-c connector as how much connector dictates volts/amps.
I think with the Pi4 its use the Pi USB C PSU as its 3.0 amp and a great price as some rave about how great it is for low cost.
I think @tkaiser once said it was raspberries best product and he his a pretty good reviewer of product.
Erm, and why so? You still need HAT to convert PCIe to SATA. Just to remind you. Motherboard doesn’t not supply 12v to disks. Also to remind you, NVMe and SSD doesn’t require 12v.
And my example is that you don’t need 100V. And you can have enough with any QC3.0 phone adapter.
No it can not. GPU requires much more than 100W. Also it’s totally can’t be used with RK chip because of architectures.
There are many GPUs that still run on ATX PCIe 75watt (GTX 1650) and likely will always be and much work has been done with resizable BAR on ARM that GPUs on ARM might very much become a thing.
Read it power connectors none the rest is to power a x86 cpu and all the peripherals a mobo might contain and yeah that could be 250watt and thats a guesstimate for a PC PSU and nothing to do solely with the gpu.
TDP stands for Thermal Design Power, in watts, and refers to the power consumption under the maximum theoretical load
Because you stuck in old age and refuse to use modern technology? Your point of cost is invalid, since you don’t need 100W in Rock5 case (or any other SBC out there). Your point about this
is bullshit. 10 years ago - maybe. Now? You are kidding me. Your point about power length or
go and buy ATX powersupply and micro-ITX board with Pentium. As for length. Yeah. Totally no. PD takes that thing in account.
Yes The Strix OC ones do but as a design the 1650 and such cards are aimed at 75 watt as that is what standard native PCIe will supply and as said likely will always be a supply of new and used cards avail at that level as there is and that is also reality.
Then you just need to find this card in magazine and also tests that does indeed confirm that it’s never goes more than 75w. So, when you find one - just don’t forget, that RK3568 doesn’t have enough juice to actually use it. Also read about PCI address spaces
