Hello
I prepaid $ 5 on SBC rock pi5. It was promised that sales would start in the second quartal. When will you start selling the goods?
best regards
Whatâs the consumption at idle and peak?
Said expected so unfortunately not a promise.
Likely not before Sept as we still havenât seen the RadxaZero2 yet.
And what does radxaZero2 have to do with it? The announcements were made for the second quarter of 2022. Almost 6 months have passed since January.
Will this power supply suffice for the Rock5?
I am also hunting for a case to help with thermals on this thing, is there a case with a heat sink and fan that will be well suited to the Rock5?
expected and no firm date was given irrespective of your demands and April, May, June so it is also still Q2.
Radxa are a relatively small firm and have a hunch resources will dictate and new product releases will come sequentially and the RadxaZero2 is in advance of the Rock5b in terms of release so likely you can use the RadxaZero2 as a rule of thumb and expect the Rock5b sometime after its release.
I think Q3 is also reasonable, just hope that it wonât get pass into Q4.
Are you from raxda. It is official statement?
Can anybody from raxda say when pi5 wll be ship?
Nope but I can read
They are still doing debugging and working with pre samples I guess which is an advancement from the initial Rockchip BSP.
I guess we will have to wait and read what they say.
ŕźź 㤠â_â ༽㤠GIVE DC-IN connector instead of audio jack!
Just use dcâtype-c
DC-IN connector is very user unfriendly because it has two parameters, hole size and the inner plug diameter. USB C is very common, small and low cost, easy to source power adapters.
I think there is a spectrum of opinion here that a guaranteed 12v rail might be a very welcome addition and 12v barrel âCCTVâ PSU tend to be larger but very low cost and easy to source.
You could agree to both camps as likely disagree, but on this one I am not that certain.
I am not expecting things to change, but this is often a side thought that maybe a static 12v rail is a way forward than PD due to possible peripherals than merely board supply.
PD support 12v. Even dumb 12v willwork. So what the reason to use only 12v when you can get 5,9,12,20V and all of this just a mobile charger?
Are you developing Rock Pi 6 with A78/A55 with G78MP24 and eGPU support,
Just to beat MediaTek Genio 1200? ![]()
Will be available in Q3 of this year, time to jump directly Rock Pi 6 lol
PD can provide 12v but at what ampage 2.1mm/5.5mm jack is 10 amp @ 12v whilst PD is now this confusing array of differing specs and connector upgrades.
PD 1/2 can only supply 2 amps @ 12v and what devices can supply and what there actuall specs are is far from clear.
If I go on Amazon and go for a quick Amazon choice 100 watt PD then I am paying ÂŁ50.
Quick 1st grab again but 8amp 96 watt as close enough ÂŁ15
PD power is both expensive as the above is PD3.0 not 3.1 but many are 2.0 and 1.0 with much lower amperageâs as add another ÂŁ10 for a 100watt cable.
Sometimes I honestly do think PD USB is not as plain sailing as some think or that cost effective than a plain old 2.1mm/5.5mm jack âcctvâ style psuâŚ
Its a consumer grade PSU that likely may not be that great of a deal for a dedicated SBC PSU.
There seems a lot of sales speak behind PD power that I can use on any device as yes I could but it happens to be plugged in my SBC and neededâŚ
I am sort of undecided but I have tried to source for 12v PD and a splitter and thought why is this so sodding hard and expensiveâŚ
Also the cctv with the ac lead 1st â smps â dc lead has a much longer reach than with PD is going to be a 1 - 2m max to smps and thats it, with most brick plugs.
Again a quick grab with an ac lead but like ÂŁ79 and doesnât even have the actual charging lead!
The alternative ÂŁ15 job done does tend to make you question things and I know its going to negotiate 12v as that is all its got.
No, itâs not. Unless you are buying from Aliexpress from no-name brand.
Also, are you serious? DC barrels just horrible
and where you can find 1/2 PD? Right, even the most cheap phone charger support at least QC.
Yeah, you totally need 100W for SBC. Rock5 doesnât have power output. And itâs incredibly hard to find portable lightweight UPS for 12v. While for Type-C i have this one https://aliexpress.com/item/1005002004123046.html
Still this ![]()
How is this connected to Rock5?
Well, Rock5 is also consumer grade product.
A lot of usefulness*
Barrel DC is truly old relic of past
10A requires different DC connector, the DC connector on SATA HAT supports 10A, very big.
Watch how many forum posts we get when powering multiple peripherals as yeah 100 watt is OTT but my example was about price and what I was saying is you can get 100watt 12v dc cctv/led type psuâs for very low prices and be absolutely sure of 12v and peak headroom.
PD your going to get such an array that no its not completely clear.
2.1mm/5.5mm is the size, Jack and all 2.1/5.5mm are approx same size as that is there size such as this these the 10amp is merely 0.5mm longer than the 5amp if that is what you mean as very big, they are bigger than current USB C (not by a lot though) and guess that is the answer.
But it does force more expensive PD style PSUâs but if that is all that will fit that is all that will fit as do like the Pico ITX format.
If I had a 10amp 2.1mm/5.5mm and 100 watt âcctvâ type psu I wouldnât need a sata hat or expensive PD psu as just the single low cost one would suffice, is what I have been thinking.
Also as the Arm board progress with the PCIe that 12v might also be used for other peripherals as well such as GPUâs⌠But I forget how tiny that Pico Itx format is really but PD is a mweh to me and extra expense for little else that what is a relatively tiny size reduction.
for PD, I do buy quite a few power supply before ![]()
Basically for PD, you can expect up to 5A
PD 1 is kinda ânon-existenceâ, or I would have bought one too⌠I want PD running on USB-A socket ![]()
for PD 2, it should have negotiable voltage at 5V, 9V, 12V, 15V and 20V, and it is the most common PD protocol version I think. again, ânormallyâ you can use a unmarked âstraightâ USB-C cable and that would support up to 3A (also depends on cable quality), while I do see USB-C failed to negotiate higher voltage (guess it is the cable missing many pins and wires).
USB-C cable in itself is also âkinda funâ⌠you can have the worse cable like Iâs said, which cannot go pass 5V; then you can have power cable that do up to 20V@3A (or 5A if it has e-marker chip in it); then you can have power + USB âdata transferâ cable; then you can have power + USB + DP cable (maybe HDMI too, not very sure as I use DP only). I remember my Pi 4 has problem with e-marker cables, for instance; but the most annoying issue with my Pi 4 is that I cannot find a reliable way to supply 5V to its USB-C⌠voltage drops to like 4.3V, and thus making my Pi 4 running very unstable, no matter what cable I use.
Back to the PSU, there are many âcheapâ ones from China (I bought some from Taobao) ranging from 20W to 120W at reasonable prices. I remember someone from Radxa said before Rock 5 would use perhaps 60W max? That means a PD PSU that can do 20V@3A, no special cable, should be sufficient for Rock 5. 12V @5A will also be fine, but 5A means you need e-marker cables I guess. There are plenty of GaN based 65W PSU thatâ s cheap nowadays⌠I think they are around US$15 + shipping (I think I got one cheap 2-port for US$10 + S/H only).
In terms of a DC connector, would it be good if we can have a 12V at the I/O instead? Or, may we use the PoE 4-pin header to âsomehow support thatâ?
