I know the Rock5B is still relatively new (not that new now, let’s be honest) but with hardware video encode and decode being a massive part of the sales pitch for this SBC, actually being able to leverage the hardware to encode video should be a lot easier.
I’ve been attempting to get hardware accelerated video encoding working for quite a few weeks now, but with no success thus far. Documentation on getting this to work seems very sparse - basically non existent, and I just don’t have time (or inclination tbh) to spend endless days on trial and error until I finally work it out.
So far installation of MPP appears to be fine, following this guide, although the demo fails so it seems this is not actually entirely successful. Then my understanding is that I need to add MPP hardware encoding support to the recording software - so ffmpeg or gstreamer seem to be the primary choices.
However I believe I’m right in saying that ffmpeg is no longer a possibility due to licensing issues, and the repo to add rockchip support to gstreamer has long since been archived with no apparent replacement. So how exactly can I add encoding support? This is on Armbian.
I would love it if someone could tell me I’ve missed this or that resource and actually it’s really easy - but I suspect that won’t be what happens. Either way if anyone actually has this working can they give some insight and instruction on how to get it working that would certainly be appreciated. I don’t mind which OS I use, doesn’t have to be Armbian, and also I don’t have a problem with totally wiping the storage and starting again.
Looking forward to an answer!
I use Reborn OS.
They have in their repo ffmpeg-mpp and mpp-git ,which works nicely with mplayer and vlc.
Up to 8k videos with hw acceleration.
regards
I thought Reborn OS was just hardware decoding built in, does it also support encoding?
avaf
April 10, 2023, 6:10pm
4
Encoding is done by gstreamer , there is a ffmpeg (posted by a user in the forum) that can do hw encoding (DRM_PRIME).
Basic encoding example with gstreamer:
Update from my side, decoding is working with ffplay, i tested the following files:
bbb_sunflower_1080p_30fps_normal.mp4
jellyfish-20-mbps-hd-hevc-10bit.mkv
jellyfish-120-mbps-4k-uhd-h264.mkv
jellyfish-20-mbps-hd-hevc.mkv
jellyfish-20-mbps-hd-h264.mkv
OPS, i realized ffplay is using software decoding:
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
5823 rock 20 0 1861860 200304 63700 S 195.0 1.2 0:43.55 ffplay
Encoding with gstreamer also …
For the newbies and users @amazingfate has integrated OBS and HW encoder, please search the forum for his instructions. I think he uses Wayland and i am currently using X11.
I haven’t written a guide on how to use obs for video recording. Here is a brief one:
0, flash a jammy image, armbian jammy is recommended.
1, add my two ppa and do a system upgrade:
2, install related packages
a, install rockchip-multimedia-config for basic permssion settings
b, install obs-studio and obs-plugins for obs app
c, install obs-gstreamer for obs’s gstreamer encoding plugin
d, iinstall gstreamer1.0-plugins-bad and gstreamer1.0-rockchip1 for gstreamer rockchip encoding/decoding support
e, install qtwayland5 for qt wayland support
f, install xdg-desktop-portal-gnome for obs pipewire screen capture support
3, do a reboot, login to a wayland session, and launch obs from the app menu, use pipewire to capture the screen, and use rkmpp encoder to encode the video.
Thanks for the replies, I appreciate it! So I’ve actually got encoding working now via gstreamer which is great. Unfortunately on playback I see lines of corruption in the image very much the same as the screenshots in this thread (you can ignore the rest of the thread, it’s just visually what you can see in the images I’m referring to. This is with both H264 and H265 hardware encoding.
Any ideas on that one?
avaf
April 11, 2023, 12:50pm
7
At least it does not happen with NV12 pixel format. I know there are some issues with YUYV and I will try with that later.
Running the same test with Radxa Camera (200 frames):
mpi_enc_test -i /dev/video11 -f 0 -w 1920 -h 1080 -o out_200frames_1920x1080.h264 -t 7 -n 200 -d 1
Result here:
https://mega.nz/file/VC4RCS5J#yCSIZy4Ehe3TOvAbbqEfPM7U9cBTWzbHiU8PzFR0kio
Output:
Apr 11 08:48:18 rock5b mpp[2135]: mpp_opt: invalid option d
Apr 11 08:48:18 rock5b mpp[2135]: mpi_enc_utils: cmd parse result:
Apr 11 08:48:18 rock5b mpp[2135]: mpi_enc_utils: input file name: /dev/video11
Apr 11 08:48:18 rock5b mpp[2135]: mpi_enc_utils: output file name: out_200frames_1920x1080.h264
Apr 11 08:48:18 rock5b mpp[2135]: mpi_enc_utils: width : 1920
Apr 11 08:48:18 rock5b mpp[2135]: mpi_enc_utils: height : 1080
Apr 11 08:48:18 rock5b mpp[2135]: mpi_enc_utils: format : 0
Apr 11 08:48:18 rock5b mpp[2135]: mpi_enc_utils: type : 7
Apr 11 08:48:18 rock5b mpp[2135]: mpi_enc_test: mpi_enc_test start
Apr 11 08:48:18 rock5b mpp[2135]: mpi_enc_test: open camera device
Apr 11 08:48:18 rock5b mpp[2135]: camera_source: get width 1920 height 1080
Apr 11 08:48:18 rock5b mpp[2135]: camera_source: get dma buf(0)-fd: 5
Apr 11 08:48:18 rock5b mpp[2135]: camera_source: get dma buf(1)-fd: 6
Apr 11 08:48:18 rock5b mpp[2135]: camera_source: get dma buf(2)-fd: 7
Apr 11 08:48:18 rock5b mpp[2135]: camera_source: get dma buf(3)-fd: 8
Apr 11 08:48:18 rock5b kernel: rkisp_hw fdcb0000.rkisp: set isp clk = 594000000Hz
Apr 11 08:48:18 rock5b kernel: rkcif-mipi-lvds2: sditf_reinit_mode, mode->rdbk_mode 0, mode->name rkisp0-vir0, link_mode 1
Apr 11 08:48:18 rock5b rkaiq[426]: DBG: /dev/media1: wait stream start event success ...
Apr 11 08:48:18 rock5b rkaiq[426]: DBG: device manager start
Apr 11 08:48:18 rock5b rkaiq[426]: DBG: rkisp_init engine succeed
Apr 11 08:48:18 rock5b rkaiq[426]: DBG: /dev/media1: wait stream stop event...
Apr 11 08:48:18 rock5b kernel: rkisp rkisp0-vir0: first params buf queue
Apr 11 08:48:18 rock5b kernel: rkcif-mipi-lvds2: stream[0] start streaming
Apr 11 08:48:18 rock5b kernel: rockchip-mipi-csi2 fdd30000.mipi2-csi2: stream on, src_sd: 00000000208ea651, sd_name:rockchip-csi2-dphy0
Apr 11 08:48:18 rock5b kernel: rockchip-mipi-csi2 fdd30000.mipi2-csi2: stream ON
Apr 11 08:48:18 rock5b kernel: rockchip-csi2-dphy0: dphy0, data_rate_mbps 892
Apr 11 08:48:18 rock5b kernel: rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:1, dphy0
Apr 11 08:48:18 rock5b kernel: imx415 3-001a: s_stream: 1. 3864x2192, hdr: 0, bpp: 10
Apr 11 08:48:18 rock5b kernel: imx415 3-001a: set vblank 0x3a vts 2250
Apr 11 08:48:18 rock5b kernel: imx415 3-001a: set exposure(shr0) 900 = cur_vts(2250) - val(1350)
Apr 11 08:48:18 rock5b kernel: imx415 3-001a: set analog gain 0x23
Apr 11 08:48:18 rock5b rkaiq[426]: [08:48:18.263533][CAMHW]:XCAM ERROR Isp20Params.cpp:4036: get blc params failed!
Apr 11 08:48:18 rock5b kernel: imx415 3-001a: set analog gain 0x1e
Apr 11 08:48:18 rock5b mpp[2135]: mpi_enc_test: new framecap ok
Apr 11 08:48:18 rock5b mpp[2135]: mpp_info: mpp version: 7b7bca6 author: Yandong Lin 2023-02-22 [av1d]: fix loss frame when eos packet has one more frame
Apr 11 08:48:18 rock5b mpp[2135]: mpi_enc_test: 0x7f9c002400 encoder test start w 1920 h 1080 type 7
Apr 11 08:48:18 rock5b mpp[2135]: mpp_enc: MPP_ENC_SET_RC_CFG bps 7776000 [486000 : 8262000] fps [30:30] gop 60
Apr 11 08:48:18 rock5b mpp[2135]: h264e_api_v2: MPP_ENC_SET_PREP_CFG w:h [1920:1080] stride [1920:1080]
Apr 11 08:48:18 rock5b mpp[2135]: mpp_enc: mode vbr bps [486000:7776000:8262000] fps fix [30/1] -> fix [30/1] gop i [60] v [0]
Apr 11 08:48:18 rock5b kernel: imx415 3-001a: set analog gain 0x1f
Apr 11 08:48:18 rock5b kernel: imx415 3-001a: set analog gain 0x20
Apr 11 08:48:18 rock5b kernel: imx415 3-001a: set analog gain 0x21
Apr 11 08:48:18 rock5b kernel: imx415 3-001a: set analog gain 0x22
Apr 11 08:48:18 rock5b kernel: imx415 3-001a: set analog gain 0x24
Apr 11 08:48:18 rock5b kernel: imx415 3-001a: set analog gain 0x25
Apr 11 08:48:18 rock5b kernel: imx415 3-001a: set analog gain 0x26
Apr 11 08:48:19 rock5b kernel: imx415 3-001a: set analog gain 0x25
Apr 11 08:48:19 rock5b kernel: imx415 3-001a: set analog gain 0x24
Apr 11 08:48:19 rock5b kernel: imx415 3-001a: set analog gain 0x23
Apr 11 08:48:19 rock5b kernel: imx415 3-001a: set analog gain 0x22
Apr 11 08:48:19 rock5b kernel: imx415 3-001a: set analog gain 0x21
Apr 11 08:48:20 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 0 size 388353 qp 20
Apr 11 08:48:20 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 1 size 96563 qp 23
Apr 11 08:48:20 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 2 size 41940 qp 26
Apr 11 08:48:20 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 3 size 45172 qp 26
Apr 11 08:48:20 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 4 size 37635 qp 27
Apr 11 08:48:20 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 5 size 37642 qp 27
Apr 11 08:48:20 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 6 size 36011 qp 27
Apr 11 08:48:20 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 7 size 30015 qp 27
Apr 11 08:48:20 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 8 size 29452 qp 27
Apr 11 08:48:20 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 9 size 28800 qp 27
Apr 11 08:48:20 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 10 size 28473 qp 27
Apr 11 08:48:20 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 11 size 26594 qp 27
Apr 11 08:48:20 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 12 size 25630 qp 27
Apr 11 08:48:20 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 13 size 26174 qp 27
Apr 11 08:48:20 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 14 size 26859 qp 27
Apr 11 08:48:20 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 15 size 26858 qp 27
Apr 11 08:48:20 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 16 size 20814 qp 27
Apr 11 08:48:20 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 17 size 21393 qp 27
Apr 11 08:48:20 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 18 size 20629 qp 27
Apr 11 08:48:20 rock5b kernel: imx415 3-001a: set analog gain 0x22
Apr 11 08:48:20 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 19 size 21283 qp 27
Apr 11 08:48:20 rock5b kernel: imx415 3-001a: set analog gain 0x23
Apr 11 08:48:20 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 20 size 20662 qp 27
Apr 11 08:48:20 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 21 size 21809 qp 27
Apr 11 08:48:20 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 22 size 30417 qp 29
Apr 11 08:48:20 rock5b kernel: imx415 3-001a: set analog gain 0x24
Apr 11 08:48:20 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 23 size 32982 qp 30
Apr 11 08:48:20 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 24 size 29775 qp 28
Apr 11 08:48:20 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 25 size 22608 qp 29
Apr 11 08:48:20 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 26 size 30996 qp 30
Apr 11 08:48:21 rock5b kernel: imx415 3-001a: set analog gain 0x25
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 27 size 23697 qp 29
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 28 size 22893 qp 29
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 29 size 22096 qp 29
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 30 size 31344 qp 30
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 31 size 24576 qp 29
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 32 size 16176 qp 29
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 33 size 22545 qp 28
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 34 size 20733 qp 28
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 35 size 20793 qp 28
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 36 size 19082 qp 28
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 37 size 18598 qp 28
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 38 size 18390 qp 28
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 39 size 17966 qp 28
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 40 size 17639 qp 28
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 41 size 17134 qp 28
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 42 size 17401 qp 28
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 43 size 17267 qp 28
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 44 size 24351 qp 28
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 45 size 15483 qp 28
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 46 size 22702 qp 28
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 47 size 21695 qp 27
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 48 size 20864 qp 27
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 49 size 19855 qp 27
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 50 size 19071 qp 27
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 51 size 20349 qp 27
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 52 size 19703 qp 27
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 53 size 19293 qp 27
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 54 size 19811 qp 27
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 55 size 27908 qp 26
Apr 11 08:48:21 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 56 size 18217 qp 27
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 57 size 25680 qp 26
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 58 size 24849 qp 26
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 59 size 26375 qp 26
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 60 size 363462 qp 21
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 61 size 22488 qp 26
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 62 size 26360 qp 27
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 63 size 27508 qp 27
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 64 size 27255 qp 26
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 65 size 26774 qp 26
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 66 size 18061 qp 27
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 67 size 27091 qp 26
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 68 size 27019 qp 26
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 69 size 20339 qp 27
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 70 size 25605 qp 27
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 71 size 26238 qp 27
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 72 size 22637 qp 28
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 73 size 28244 qp 27
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 74 size 22625 qp 28
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 75 size 23692 qp 28
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 76 size 28620 qp 28
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 77 size 22830 qp 28
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 78 size 24919 qp 28
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 79 size 28836 qp 27
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 80 size 22940 qp 28
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 81 size 23631 qp 28
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 82 size 28662 qp 27
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 83 size 21926 qp 27
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 84 size 28461 qp 27
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 85 size 27164 qp 27
Apr 11 08:48:22 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 86 size 27930 qp 27
Apr 11 08:48:23 rock5b kernel: imx415 3-001a: set analog gain 0x26
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 87 size 27743 qp 27
Apr 11 08:48:23 rock5b kernel: imx415 3-001a: set analog gain 0x27
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 88 size 27600 qp 27
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 89 size 18773 qp 27
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 90 size 37611 qp 29
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 91 size 32645 qp 30
Apr 11 08:48:23 rock5b kernel: imx415 3-001a: set analog gain 0x28
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 92 size 29042 qp 28
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 93 size 26085 qp 28
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 94 size 25487 qp 28
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 95 size 36267 qp 29
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 96 size 26550 qp 28
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 97 size 30644 qp 28
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 98 size 30576 qp 28
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 99 size 29176 qp 28
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 100 size 30314 qp 28
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 101 size 28797 qp 28
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 102 size 29536 qp 28
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 103 size 28799 qp 27
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 104 size 27941 qp 28
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 105 size 29887 qp 27
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 106 size 26976 qp 27
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 107 size 29005 qp 27
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 108 size 27745 qp 27
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 109 size 28888 qp 27
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 110 size 28162 qp 27
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 111 size 30565 qp 27
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 112 size 29671 qp 27
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 113 size 30248 qp 27
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 114 size 29854 qp 27
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 115 size 29492 qp 27
Apr 11 08:48:23 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 116 size 29804 qp 27
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 117 size 28045 qp 27
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 118 size 30178 qp 27
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 119 size 28655 qp 27
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 120 size 267163 qp 23
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 121 size 30337 qp 26
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 122 size 30358 qp 27
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 123 size 30531 qp 27
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 124 size 30190 qp 27
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 125 size 30160 qp 27
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 126 size 30008 qp 27
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 127 size 30040 qp 27
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 128 size 31008 qp 27
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 129 size 31604 qp 27
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 130 size 31410 qp 27
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 131 size 32710 qp 27
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 132 size 33465 qp 27
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 133 size 31689 qp 27
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 134 size 30935 qp 27
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 135 size 30907 qp 27
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 136 size 31763 qp 27
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 137 size 28598 qp 27
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 138 size 29336 qp 27
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 139 size 29176 qp 27
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 140 size 29172 qp 27
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 141 size 29863 qp 27
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 142 size 29157 qp 27
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 143 size 28312 qp 27
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 144 size 28784 qp 27
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 145 size 29995 qp 27
Apr 11 08:48:24 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 146 size 30976 qp 27
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 147 size 30926 qp 27
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 148 size 30924 qp 27
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 149 size 31104 qp 27
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 150 size 31414 qp 27
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 151 size 30871 qp 27
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 152 size 30681 qp 27
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 153 size 30723 qp 27
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 154 size 30698 qp 27
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 155 size 30645 qp 27
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 156 size 30139 qp 27
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 157 size 31777 qp 27
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 158 size 29911 qp 27
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 159 size 31825 qp 27
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 160 size 30433 qp 27
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 161 size 30803 qp 27
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 162 size 30007 qp 27
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 163 size 30702 qp 27
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 164 size 30573 qp 28
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 165 size 30544 qp 28
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 166 size 30981 qp 28
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 167 size 31704 qp 28
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 168 size 31960 qp 28
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 169 size 32708 qp 28
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 170 size 31006 qp 28
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 171 size 25863 qp 28
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 172 size 30637 qp 28
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 173 size 28968 qp 28
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 174 size 29715 qp 28
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 175 size 29976 qp 28
Apr 11 08:48:25 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 176 size 30323 qp 27
Apr 11 08:48:26 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 177 size 31029 qp 28
Apr 11 08:48:26 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 178 size 27676 qp 28
Apr 11 08:48:26 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 179 size 31630 qp 28
Apr 11 08:48:26 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 180 size 247914 qp 24
Apr 11 08:48:26 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 181 size 25344 qp 28
Apr 11 08:48:26 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 182 size 34488 qp 28
Apr 11 08:48:26 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 183 size 29324 qp 28
Apr 11 08:48:26 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 184 size 30046 qp 28
Apr 11 08:48:26 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 185 size 30677 qp 28
Apr 11 08:48:26 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 186 size 29632 qp 28
Apr 11 08:48:26 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 187 size 30494 qp 28
Apr 11 08:48:26 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 188 size 30403 qp 28
Apr 11 08:48:26 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 189 size 31253 qp 28
Apr 11 08:48:26 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 190 size 29348 qp 28
Apr 11 08:48:26 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 191 size 29460 qp 28
Apr 11 08:48:26 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 192 size 28889 qp 28
Apr 11 08:48:26 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 193 size 27579 qp 28
Apr 11 08:48:26 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 194 size 27139 qp 28
Apr 11 08:48:26 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 195 size 27557 qp 28
Apr 11 08:48:26 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 196 size 26721 qp 28
Apr 11 08:48:26 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 197 size 26753 qp 28
Apr 11 08:48:26 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 198 size 26452 qp 28
Apr 11 08:48:26 rock5b mpp[2135]: mpi_enc_test: chn 0 encoded frame 199 size 25617 qp 28
Apr 11 08:48:26 rock5b kernel: rkcif-mipi-lvds2: stream[0] start stopping, total mode 0x2, cur 0x2
Apr 11 08:48:26 rock5b kernel: rockchip-mipi-csi2 fdd30000.mipi2-csi2: stream off, src_sd: 00000000208ea651, sd_name:rockchip-csi2-dphy0
Apr 11 08:48:26 rock5b kernel: rockchip-mipi-csi2 fdd30000.mipi2-csi2: stream OFF
Apr 11 08:48:26 rock5b kernel: rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream_stop stream stop, dphy0
Apr 11 08:48:26 rock5b kernel: rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:0, dphy0
Apr 11 08:48:26 rock5b kernel: imx415 3-001a: s_stream: 0. 3864x2192, hdr: 0, bpp: 10
Apr 11 08:48:26 rock5b kernel: rkcif-mipi-lvds2: stream[0] stopping finished, dma_en 0x0
Apr 11 08:48:26 rock5b rkaiq[426]: DBG: /dev/media1: wait stream stop event success ...
Apr 11 08:48:26 rock5b rkaiq[426]: [08:48:26.809388][CAMHW]:XCAM ERROR SensorHw.cpp:1291: failed to set sync mode 0
Apr 11 08:48:26 rock5b rkaiq[426]: DBG: subscribe events from /dev/video19 success !
Apr 11 08:48:26 rock5b rkaiq[426]: DBG: /dev/media1: wait stream start event...
Apr 11 08:48:26 rock5b mpp[2135]: mpi_enc_test: chn 0 encode 200 frames time 8327 ms delay 8 ms fps 24.02 bps 8092519
Apr 11 08:48:26 rock5b mpp[2135]: mpi_enc_test: mpi_enc_test average frame rate 24.02
Apr 11 08:48:26 rock5b mpp[2135]: mpp_buffer: ~MppBufferService cleaning misc group
Apr 11 08:48:54 rock5b mpp[2175]: mpp_info: mpp version: 7b7bca6 author: Yandong Lin 2023-02-22 [av1d]: fix loss frame when eos packet has one more frame
Apr 11 08:48:54 rock5b mpp[2175]: hal_h264d_vdpu34x: control info: fmt 0, w 1920, h 1080
Apr 11 08:48:54 rock5b mpp[2175]: mpp_buf_slot: set frame info: w 1920 h 1080 hor 1920 ver 1088
Apr 11 08:48:54 rock5b mpp[2175]: mpp_dec: setting default w 1920 h 1080 h_str 1920 v_str 1088
avaf
April 11, 2023, 2:02pm
8
YUY2 has the issues described above.
mpi_enc_test -i /dev/video21 -f 8 -w 1920 -h 1080 -o out_YUY2_200frames_1920x1080.h264 -t 7 -n 200 -d 1
Result here:
https://mega.nz/file/5OJgFaBL#rtCtEdWUYbjX2Jhq9KhHzufFdz7296kFTcc-LEW2jdo
This was actually NV12, couldn’t even get YUYV to record at all with gstteamer this is. One difference is that this is from a webcam source (which outputs both NV12 and YUYV), also haven’t tested using mpi_enc_test which I’m guessing is from here?
https://wiki.radxa.com/Rock5/guide/rockchip-mpp
I’ll have to test it to see if there is any difference.
avaf
April 11, 2023, 2:16pm
10
Yes, rockchip-mpp. (https://github.com/rockchip-linux/mpp )
I have never seen a web cam with NV12 (always wanted one, but never found it), anyway, you need to match MPP userland portion with MPP kernel (don’t ask me how…)
This is the logitech brio that has NV12 and YUYV if you want to look at it. I’ll give that a go and ser what I find.
Unfortunately getting the same result with corrupt lines using mpi_enc_test as well…
Although I have now just managed to get a clean output without lines of corruption on the video using this command:
gst-launch-1.0 v4l2src device=/dev/video1 io-mode=mmap ! 'video/x-raw,format=NV12,width=1920,height=1080,framerate=30/1' ! mpph265enc ! filesink location=video.mp4
The only difference is that I defined the io-mode. I thought mmap was the default, but doing a side by side test one not setting io-mode to anything:
gst-launch-1.0 v4l2src device=/dev/video1 ! 'video/x-raw,format=NV12,width=1920,height=1080,framerate=30/1' ! mpph265enc ! filesink location=video.mp4
and the first command, the one where io-mode is declared is clean, the one where it’s missed out is not clean. Looking at CPU usage suggests gstreamer is doing some CPU rather than just GPU work in both cases, but CPU usage is similar between the 2 with a max of around 35% usage on 2 cores, and low usage on one or two more cores.
Despite thos I think I’m going to take the “it’s not broken so don’t fix it” approach and do no more lest it breaks…
