I spent the whole last weekend to get the ubuntu image “act” the way I want.
As mentioned in this I would suggest that you provide a new ubuntu (server) image with openssh-server already enabled.
(as it is a server, I assumed ssh would be available right away… but since it was not working, I had to connect the rock pi to a keyboard and display just to find out that I need to manually install openssh-server).
And providing the lastest kernel in the updated ubuntu image would improve the first contact experience with rock pi 4
(details with my issue can be found here
There is always the raspi-config utility that could be emulated.
But a simple conf file called first-boot.conf with ssh, wifi, locale that is in /boot and used by the first-boot script could be handy as it can be edited on the machine the image is flashed from.
@jack@RadxaYuntian
Has this been fixed yet? Hope it is a quick fix. I am wanting to use quite a few CM3 boards, and I expect the server image to have ssh-server enabled as default. Very trouble some to setup things on physical hdmi and keyboard.
Other than opernssh-server package, another package to be pre-installed should be wpasupplicant. It is not found on Ubuntu jammy os at least. Without it wifi connection is also broken
