Continuing the discussion from Quad Sata Pi 4 deb fails on Ubuntu 24.04.1:
Successfully installed hat software and rebooted the device, but my brand new hard disk is not found.
What is the USB bridge for? Can I ignore it and still use the usb ports while also using the hat? I’m
- booting off of 1tb USB ssd disk (/dev/sda)
- also have a 4tb brand new 2.5" SSD disk attached to the hat which is not showing up within
lsusb.
Thanks for any advice.
$ lsusb -t
/: Bus 001.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/1p, 480M
|__ Port 001: Dev 002, If 0, Class=Hub, Driver=hub/4p, 480M
/: Bus 002.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/4p, 5000M
|__ Port 001: Dev 002, If 0, Class=Mass Storage, Driver=uas, 5000M
/: Bus 003.Port 001: Dev 001, Class=root_hub, Driver=dwc2/1p, 480M
dmesg output with errors
[ 8.660505] Bluetooth: hci0: BCM: firmware Patch file not found, tried:
[ 8.667274] Bluetooth: hci0: BCM: ‘brcm/BCM4345C0.raspberrypi,4-model-b.hcd’
[ 8.674474] Bluetooth: hci0: BCM: ‘brcm/BCM4345C0.hcd’
[ 8.679722] Bluetooth: hci0: BCM: ‘brcm/BCM.raspberrypi,4-model-b.hcd’
[ 8.679729] Bluetooth: hci0: BCM: ‘brcm/BCM.hcd’
[ 8.770305] spl: loading out-of-tree module taints kernel.
[ 8.874515] zfs: module license ‘CDDL’ taints kernel.
[ 8.874535] Disabling lock debugging due to kernel taint
[ 8.874595] zfs: module license taints kernel.
[ 10.577051] ZFS: Loaded module v2.2.2-0ubuntu9.1, ZFS pool version 5000, ZFS filesystem version 5
[ 10.826980] audit: type=1400 audit(1723128688.409:2): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=4D6F6E676F444220436F6D70617373 pid=674 comm=“apparmor_parser”
[ 10.827009] audit: type=1400 audit(1723128688.410:3): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“Discord” pid=672 comm=“apparmor_parser”
[ 10.827017] audit: type=1400 audit(1723128688.410:4): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“1password” pid=671 comm=“apparmor_parser”
[ 10.827182] audit: type=1400 audit(1723128688.411:5): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“QtWebEngineProcess” pid=675 comm=“apparmor_parser”
[ 10.838722] audit: type=1400 audit(1723128688.422:6): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“balena-etcher” pid=677 comm=“apparmor_parser”
[ 10.840740] audit: type=1400 audit(1723128688.424:7): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“brave” pid=678 comm=“apparmor_parser”
[ 10.846694] audit: type=1400 audit(1723128688.430:8): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“buildah” pid=679 comm=“apparmor_parser”
[ 10.853007] audit: type=1400 audit(1723128688.436:9): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“busybox” pid=680 comm=“apparmor_parser”
[ 10.857103] audit: type=1400 audit(1723128688.441:10): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“ch-run” pid=685 comm=“apparmor_parser”
[ 10.861388] audit: type=1400 audit(1723128688.445:11): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“cam” pid=681 comm=“apparmor_parser”
[ 13.500970] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 13.502489] bcmgenet fd580000.ethernet eth0: Link is Down
[ 16.240994] kauditd_printk_skb: 107 callbacks suppressed
[ 16.241011] audit: type=1400 audit(1734766158.224:119): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“rsyslogd” pid=889 comm=“apparmor_parser”
[ 17.199837] tun: Universal TUN/TAP device driver, 1.6
[ 17.444559] NET: Registered PF_QIPCRTR protocol family
[ 17.635287] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 18.188868] audit: type=1400 audit(1734766160.172:120): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“docker-default” pid=1095 comm=“apparmor_parser”
[ 18.299155] evm: overlay not supported
[ 19.779510] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 19.783154] Bridge firewalling registered
[ 20.030408] Initializing XFRM netlink socket
[ 22.279851] br-94ef43a182b1: port 1(vethc4f84ab) entered blocking state
[ 22.279906] br-94ef43a182b1: port 1(vethc4f84ab) entered disabled state
[ 22.280753] vethc4f84ab: entered allmulticast mode
[ 22.282262] vethc4f84ab: entered promiscuous mode
[ 22.365031] br-8173c699c28a: port 1(veth955d66a) entered blocking state
[ 22.365111] br-8173c699c28a: port 1(veth955d66a) entered disabled state
[ 22.365156] veth955d66a: entered allmulticast mode
[ 22.367433] veth955d66a: entered promiscuous mode
[ 22.381481] br-854e4548dfe9: port 1(veth2b9da38) entered blocking state
[ 22.381528] br-854e4548dfe9: port 1(veth2b9da38) entered disabled state
[ 22.381593] veth2b9da38: entered allmulticast mode
[ 22.382592] veth2b9da38: entered promiscuous mode
[ 22.408803] docker0: port 1(veth959bd9b) entered blocking state
[ 22.408858] docker0: port 1(veth959bd9b) entered disabled state
[ 22.408904] veth959bd9b: entered allmulticast mode
[ 22.409380] veth959bd9b: entered promiscuous mode
[ 23.594776] eth0: renamed from vethddc66f7
[ 23.603290] docker0: port 1(veth959bd9b) entered blocking state
[ 23.603319] docker0: port 1(veth959bd9b) entered forwarding state
[ 23.623489] eth0: renamed from vethcf9afd5
[ 23.640357] br-854e4548dfe9: port 1(veth2b9da38) entered blocking state
[ 23.640386] br-854e4548dfe9: port 1(veth2b9da38) entered forwarding state
[ 23.689869] eth0: renamed from vethb6a8117
[ 23.698549] br-8173c699c28a: port 1(veth955d66a) entered blocking state
[ 23.698577] br-8173c699c28a: port 1(veth955d66a) entered forwarding state
[ 23.847067] eth0: renamed from veth4d254bb
[ 23.861436] br-94ef43a182b1: port 1(vethc4f84ab) entered blocking state
[ 23.861471] br-94ef43a182b1: port 1(vethc4f84ab) entered forwarding state
