Continuing the discussion from Quad SATA HAT Assembly and Troubleshooting:
I’m also struggling to get the quad sata hat setup on my Raspberry Pi 4. Installed the latest release 0.3.1 and it fails with these errors. Any assistance appreciated!
$ sudo apt install -y ./rockpi-quad-0.3.1.deb
Reading package lists... Done
Building dependency tree... Done
Note, selecting 'rockpi-quad' instead of './rockpi-quad-0.3.1.deb'
The following additional packages will be installed:
libgpiod2t64 python3-libgpiod
The following NEW packages will be installed:
libgpiod2t64 python3-libgpiod rockpi-quad
0 upgraded, 3 newly installed, 0 to remove and 4 not upgraded.
Need to get 63.8 kB/973 kB of archives.
After this operation, 336 kB of additional disk space will be used.
Get:1 /home/ubuntu/rockpi-quad-0.3.1.deb rockpi-quad all 0.3.1 [909 kB]
Get:2 http://ports.ubuntu.com/ubuntu-ports noble/universe arm64 libgpiod2t64 arm64 1.6.3-1.1build1 [42.6 kB]
Get:3 http://ports.ubuntu.com/ubuntu-ports noble/universe arm64 python3-libgpiod arm64 1.6.3-1.1build1 [21.2 kB]
Fetched 63.8 kB in 1s (66.9 kB/s)
Selecting previously unselected package libgpiod2t64:arm64.
(Reading database ... 144949 files and directories currently installed.)
Preparing to unpack .../libgpiod2t64_1.6.3-1.1build1_arm64.deb ...
Unpacking libgpiod2t64:arm64 (1.6.3-1.1build1) ...
Selecting previously unselected package python3-libgpiod:arm64.
Preparing to unpack .../python3-libgpiod_1.6.3-1.1build1_arm64.deb ...
Unpacking python3-libgpiod:arm64 (1.6.3-1.1build1) ...
Selecting previously unselected package rockpi-quad.
Preparing to unpack .../ubuntu/rockpi-quad-0.3.1.deb ...
Unpacking rockpi-quad (0.3.1) ...
Setting up libgpiod2t64:arm64 (1.6.3-1.1build1) ...
Setting up python3-libgpiod:arm64 (1.6.3-1.1build1) ...
Setting up rockpi-quad (0.3.1) ...
Collecting Adafruit-Blinka==8.39.0 (from -r /usr/bin/rockpi-quad/requirements.txt (line 1))
Downloading Adafruit_Blinka-8.39.0-py3-none-any.whl.metadata (5.3 kB)
Collecting adafruit-circuitpython-busdevice==5.2.9 (from -r /usr/bin/rockpi-quad/requirements.txt (line 2))
Downloading adafruit_circuitpython_busdevice-5.2.9-py3-none-any.whl.metadata (4.0 kB)
Collecting adafruit-circuitpython-connectionmanager==3.1.1 (from -r /usr/bin/rockpi-quad/requirements.txt (line 3))
Downloading adafruit_circuitpython_connectionmanager-3.1.1-py3-none-any.whl.metadata (4.5 kB)
Collecting adafruit-circuitpython-framebuf==1.6.5 (from -r /usr/bin/rockpi-quad/requirements.txt (line 4))
Downloading adafruit_circuitpython_framebuf-1.6.5-py3-none-any.whl.metadata (3.3 kB)
Collecting adafruit-circuitpython-requests==4.1.4 (from -r /usr/bin/rockpi-quad/requirements.txt (line 5))
Downloading adafruit_circuitpython_requests-4.1.4-py3-none-any.whl.metadata (3.5 kB)
Collecting adafruit-circuitpython-ssd1306==2.12.17 (from -r /usr/bin/rockpi-quad/requirements.txt (line 6))
Downloading adafruit_circuitpython_ssd1306-2.12.17-py3-none-any.whl.metadata (5.3 kB)
Collecting adafruit-circuitpython-typing==1.10.3 (from -r /usr/bin/rockpi-quad/requirements.txt (line 7))
Downloading adafruit_circuitpython_typing-1.10.3-py3-none-any.whl.metadata (3.2 kB)
Collecting Adafruit-PlatformDetect==3.72.1 (from -r /usr/bin/rockpi-quad/requirements.txt (line 8))
Downloading Adafruit_PlatformDetect-3.72.1-py3-none-any.whl.metadata (3.8 kB)
Collecting Adafruit-PureIO==1.1.11 (from -r /usr/bin/rockpi-quad/requirements.txt (line 9))
Downloading Adafruit_PureIO-1.1.11-py3-none-any.whl.metadata (3.0 kB)
Collecting pyftdi==0.55.4 (from -r /usr/bin/rockpi-quad/requirements.txt (line 10))
Downloading pyftdi-0.55.4-py3-none-any.whl.metadata (3.2 kB)
Requirement already satisfied: pyserial==3.5 in /usr/lib/python3/dist-packages (from -r /usr/bin/rockpi-quad/requirements.txt (line 11)) (3.5)
Collecting pyusb==1.2.1 (from -r /usr/bin/rockpi-quad/requirements.txt (line 12))
Downloading pyusb-1.2.1-py3-none-any.whl.metadata (2.2 kB)
Collecting typing-extensions==4.12.2 (from -r /usr/bin/rockpi-quad/requirements.txt (line 13))
Downloading typing_extensions-4.12.2-py3-none-any.whl.metadata (3.0 kB)
Downloading Adafruit_Blinka-8.39.0-py3-none-any.whl (334 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 334.4/334.4 kB 8.6 MB/s eta 0:00:00
Downloading adafruit_circuitpython_busdevice-5.2.9-py3-none-any.whl (7.5 kB)
Downloading adafruit_circuitpython_connectionmanager-3.1.1-py3-none-any.whl (7.8 kB)
Downloading adafruit_circuitpython_framebuf-1.6.5-py3-none-any.whl (9.2 kB)
Downloading adafruit_circuitpython_requests-4.1.4-py3-none-any.whl (10 kB)
Downloading adafruit_circuitpython_ssd1306-2.12.17-py3-none-any.whl (7.6 kB)
Downloading adafruit_circuitpython_typing-1.10.3-py3-none-any.whl (11 kB)
Downloading Adafruit_PlatformDetect-3.72.1-py3-none-any.whl (24 kB)
Downloading Adafruit_PureIO-1.1.11-py3-none-any.whl (10 kB)
Downloading pyftdi-0.55.4-py3-none-any.whl (145 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 145.6/145.6 kB 6.9 MB/s eta 0:00:00
Downloading pyusb-1.2.1-py3-none-any.whl (58 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 58.4/58.4 kB 4.0 MB/s eta 0:00:00
Downloading typing_extensions-4.12.2-py3-none-any.whl (37 kB)
Installing collected packages: Adafruit-PlatformDetect, typing-extensions, pyusb, Adafruit-PureIO, pyftdi, adafruit-circuitpython-connectionmanager, Adafruit-Blinka, adafruit-circuitpython-requests, adafruit-circuitpython-busdevice, adafruit-circuitpython-typing, adafruit-circuitpython-framebuf, adafruit-circuitpython-ssd1306
Successfully installed Adafruit-Blinka-8.39.0 Adafruit-PlatformDetect-3.72.1 Adafruit-PureIO-1.1.11 adafruit-circuitpython-busdevice-5.2.9 adafruit-circuitpython-connectionmanager-3.1.1 adafruit-circuitpython-framebuf-1.6.5 adafruit-circuitpython-requests-4.1.4 adafruit-circuitpython-ssd1306-2.12.17 adafruit-circuitpython-typing-1.10.3 pyftdi-0.55.4 pyusb-1.2.1 typing-extensions-4.12.2
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
Created symlink /etc/systemd/system/multi-user.target.wants/rockpi-quad.service → /usr/lib/systemd/system/rockpi-quad.service.
/var/lib/dpkg/info/rockpi-quad.postinst: line 48: raspi-config: command not found
dpkg: error processing package rockpi-quad (--configure):
installed rockpi-quad package post-installation script subprocess returned error exit status 127
Processing triggers for libc-bin (2.39-0ubuntu8.3) ...
rockpi-quad
needrestart is being skipped since dpkg has failed
N: Download is performed unsandboxed as root as file '/home/ubuntu/rockpi-quad-0.3.1.deb' couldn't be accessed by user '_apt'. - pkgAcquire::Run (13: Permission denied)
Since raspi-config is missing I’ve installed it.
$ sudo apt-get install raspi-config
alsa-utils libatopology2t64 libfftw3-single3
Suggested packages:
dialog libfftw3-bin libfftw3-dev
alsa-utils libatopology2t64 libfftw3-single3 raspi-config
0 upgraded, 4 newly installed, 0 to remove and 4 not upgraded.
1 not fully installed or removed.
Need to get 1843 kB of archives.
After this operation, 4959 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 http://ports.ubuntu.com/ubuntu-ports noble/main arm64 libatopology2t64 arm64 1.2.11-1build2 [51.5 kB]
Get:2 http://ports.ubuntu.com/ubuntu-ports noble/main arm64 libfftw3-single3 arm64 3.3.10-1ubuntu3 [583 kB]
Get:3 http://ports.ubuntu.com/ubuntu-ports noble/main arm64 alsa-utils arm64 1.2.9-1ubuntu5 [1187 kB]
Get:4 http://ports.ubuntu.com/ubuntu-ports noble/universe arm64 raspi-config all 20221214-0ubuntu1 [22.3 kB]
Fetched 1843 kB in 1s (1319 kB/s)
Selecting previously unselected package libatopology2t64:arm64.
(Reading database ... 144987 files and directories currently installed.)
Preparing to unpack .../libatopology2t64_1.2.11-1build2_arm64.deb ...
Unpacking libatopology2t64:arm64 (1.2.11-1build2) ...
Selecting previously unselected package libfftw3-single3:arm64.
Preparing to unpack .../libfftw3-single3_3.3.10-1ubuntu3_arm64.deb ...
Unpacking libfftw3-single3:arm64 (3.3.10-1ubuntu3) ...
Selecting previously unselected package alsa-utils.
Preparing to unpack .../alsa-utils_1.2.9-1ubuntu5_arm64.deb ...
Unpacking alsa-utils (1.2.9-1ubuntu5) ...
Selecting previously unselected package raspi-config.
Preparing to unpack .../raspi-config_20221214-0ubuntu1_all.deb ...
Unpacking raspi-config (20221214-0ubuntu1) ...
Setting up libatopology2t64:arm64 (1.2.11-1build2) ...
Setting up libfftw3-single3:arm64 (3.3.10-1ubuntu3) ...
Requirement already satisfied: Adafruit-Blinka==8.39.0 in /usr/local/lib/python3.12/dist-packages (from -r /usr/bin/rockpi-quad/requirements.txt (line 1)) (8.39.0)
Requirement already satisfied: adafruit-circuitpython-busdevice==5.2.9 in /usr/local/lib/python3.12/dist-packages (from -r /usr/bin/rockpi-quad/requirements.txt (line 2)) (5.2.9)
Requirement already satisfied: adafruit-circuitpython-connectionmanager==3.1.1 in /usr/local/lib/python3.12/dist-packages (from -r /usr/bin/rockpi-quad/requirements.txt (line 3)) (3.1.1)
Requirement already satisfied: adafruit-circuitpython-framebuf==1.6.5 in /usr/local/lib/python3.12/dist-packages (from -r /usr/bin/rockpi-quad/requirements.txt (line 4)) (1.6.5)
Requirement already satisfied: adafruit-circuitpython-requests==4.1.4 in /usr/local/lib/python3.12/dist-packages (from -r /usr/bin/rockpi-quad/requirements.txt (line 5)) (4.1.4)
Requirement already satisfied: adafruit-circuitpython-ssd1306==2.12.17 in /usr/local/lib/python3.12/dist-packages (from -r /usr/bin/rockpi-quad/requirements.txt (line 6)) (2.12.17)
Requirement already satisfied: adafruit-circuitpython-typing==1.10.3 in /usr/local/lib/python3.12/dist-packages (from -r /usr/bin/rockpi-quad/requirements.txt (line 7)) (1.10.3)
Requirement already satisfied: Adafruit-PlatformDetect==3.72.1 in /usr/local/lib/python3.12/dist-packages (from -r /usr/bin/rockpi-quad/requirements.txt (line 8)) (3.72.1)
Requirement already satisfied: Adafruit-PureIO==1.1.11 in /usr/local/lib/python3.12/dist-packages (from -r /usr/bin/rockpi-quad/requirements.txt (line 9)) (1.1.11)
Requirement already satisfied: pyftdi==0.55.4 in /usr/local/lib/python3.12/dist-packages (from -r /usr/bin/rockpi-quad/requirements.txt (line 10)) (0.55.4)
Requirement already satisfied: pyusb==1.2.1 in /usr/local/lib/python3.12/dist-packages (from -r /usr/bin/rockpi-quad/requirements.txt (line 12)) (1.2.1)
Requirement already satisfied: typing-extensions==4.12.2 in /usr/local/lib/python3.12/dist-packages (from -r /usr/bin/rockpi-quad/requirements.txt (line 13)) (4.12.2)
Installation will take effect after reboot!!!
Setting up alsa-utils (1.2.9-1ubuntu5) ...
alsa-restore.service is a disabled or a static unit, not starting it.
alsa-state.service is a disabled or a static unit, not starting it.
Setting up raspi-config (20221214-0ubuntu1) ...
Processing triggers for man-db (2.12.0-4build2) ...
Scanning processes...
Scanning processor microcode...
Scanning linux images...
Running kernel seems to be up-to-date.
The processor microcode seems to be up-to-date.
No services need to be restarted.
No containers need to be restarted.
No user sessions are running outdated binaries.
No VM guests are running outdated hypervisor (qemu) binaries on this host.
