Then press Ctrl+X, then Y. sudo apt install bluez or bluetooth – not needed to install since latest armbian version systemctl status bluetooth CTRL+ C systemctl start bluetooth
Then reboot .
I cancelled my AX210 order because the Bluetooth doesnt work unless theres an config to set up it wont so I prefer to play safe with something that always work on the spot.
While having my rock 5B on hand, I cant wait to get my RTL8852BE (unbranded wifi card) and try it out (should be getting it at around two weeks later with both the passive and cooling fan heatsink), sadly this card does not seems to support Wifi 6E, but it looks great to have Bluetooth 5.2
While waiting for my WiFi Card, I am using my macbook (with a usb-c to ethernet hub) (windows or a raspberry pi should be helpful to do the same job too) to get internet on my Rock 5B
Wouldn’t one assume that drivers would be delivered later? Or are there other reasons why the drivers might never come? (Im asking because I bought 2x AX210 back in February xD)
No Android device currently uses the AX series. So Intel doesn’t have a driver for Android. You could try to hack it since Android runs the Linux kernel, but the subsystems ate different.
thanks for quick reply, unfortunately already placed my order for rock5b,
just dropped a message to allnet to see if I can update my order with that board to avoid paying shipping fees again
