I was waiting for official M2 wifi6/wifi6e card from radxa but looks like it is not going to happen at rock5b launch. This is what ameridroid told me.
Is intel ax210ngw a good choice for rock5b? Looks like it is not properly supported by Linux kernel until 5.13, do we expect driver problems with radxa Linux kernel?
Is it better to go with safer bets like ax200 instead ?
Please keep in mind that kernel support for RK3588/RK3588s right now is very special. All RK356x/RK3588(s) thingies are somewhat based on Rockchip’s reference designs and they both tested and optimised driver support for a limited set of Wi-Fi/BT chips only.
So when searching for M.2 modules that will work flawlessly most probably it’s a good idea to look around what will be used on devices having to use Rockchip’s recent BSP kernel (as such we can look at RK3568 too) and what is already confirmed to work. Also keep in mind that if certain interrupts are not routed properly stuff like powermanagement (waking up BT from sleep and so on) doesn’t work.
Firefly M3, Rock 5A: USB2 internally attached RTL8852BU-based Fn-Link 6252B-UUB providing 802.11a/b/g/n/ac/ax and BT5.2/BLE5.2
Khadas Edge2, Mekotronics R58, Mixtile Edge 2, RD-RK3588 development board, UGOOS UT8 PRO and Orange Pi 5: PCIe attached dual-band 802.11 ax/ac/a/b/g/n WiFi 6 2T2R and Bluetooth 5.0 via Ampak AP6275P
It depends on if you are going to use Android or Linux. For Android, we recommend Radxa Wireless Module A1(AP6212) / A2(AP6256) / A6(AP6275S) / A8(RTL8821BE).
For Linux, ax200 is reported working by community members.
It’s safe to say that it all comes down to what you want .
Moving to the ax210 gives you better frequency support with 6GHz, and added to that the WiFi 6 badge.
Please note that there is zero support for true WiFi 6 and all the multi lane benefits won’t truly be available until next gen silicon which will arrive in WiFi 7.
Ultimately it comes down to your use case and without understanding what your are after, it’s very difficult to give an accurate answer
Rockpi 5 was also recently added to Armbian build system, where you can enable missing driver in no time. However, this kernel is old and a few of drivers might not be able (too much work) to be ported here. But again - if there will be needed, there is again not such big a problem as most popular drivers are getting into the kernels this way. Not difficult to add others.
Also, as @Sean exposed with a question … some of those WiFi adaptors might not work in AP mode due to firmware blocking and that you usually can’t change. IIRC Intel used to allow 2.4Gh AP, but block 5Gh … something like that. You need to check wifi card small print.
@igorp Although the rock pi 5 is in the armbian build system, it’s still WIP and only recommended for Dev as yet.
I personally use the rock 3a with the ax210 running armbian 22.08 server, and the ax210 it’s fully supported without having to rebuild the kernel now - although you have to download the Linux firmware for the card and rebuild the wirelessreg-db to get 6GHz working
Thanks but the card in my link is already installed.
So it is a generic question.
All these m.2 cards require an antenna to work properly?
Or is just my card that suck?
