So, I have one of these as well, and someone on the cyberdeck discord had mentioned trying to get it going and having no luck, so I figured I’d try my luck as well.
Here is what I’ve tried…
First, I just tried booting it, got the usual screen initially turns on then kinda fades out with whatever was on the display. Unfortunate, but it wasn’t unexpected.
So I dug in… figured the first thing to do, because of it being an odd resolution, was to do an edid override, and see whats what.
I grabbed the edid from this hardkernel forum post with 400x1280 edid someone made and unfortunately, no luck there, because DRM_LOAD_EDID_FIRMWARE wasn’t enabled in the kernel I have on mine, so I enabled that, and added extraargs=drm.edid_firmware=edid/400x1280.bin video=HDMI-A-1:e to my uEnv.txt
then it was loading, but would complain about no crtc sizes being found.
rzero kernel: [ 2.411481] meson-drm ff900000.vpu: [drm] Cannot find any crtc or sizes
So, then I got the bright idea to download Monitor Asset Manager on my windows machine, because I know that Windows was able to handle the display (mostly) and see what it got. So I took the EDID block from that app, and verified that linux can read it via edid-decode, and it did, so I put that into /lib/firmware/edid and used that for my override. Then I had a weirder issue where DRM was complaining that it couldn’t find the edid… so I created an initramfs hook that simply copied the firmware into the initramfs.
It was still complaining about the crtc size, so I figured, I’d try adding the resolution to the video= as well, so i made it
extraargs=drm.edid_firmware=edid/400x1280.bin video=HDMI-A-1:400x1280@60:e
Now it boots happier, and I get the following
steev@rzero:~$ sudo dmesg | grep -i drm
[ 0.000000] Kernel command line: initrd=initrd.img-5.10.136 root=UUID=0a23bd6c-0d3b-458f-9256-9a345cd0e89b rootwait rw rootfstype=ext4 console=tty1 console=ttyAML0,115200 panic=10 consoleblank=0 loglevel=7 drm.edid_firmware=edid/400x1280.bin video=HDMI-A-1:400x1280@60:e cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
[ 5.494268] systemd[1]: Starting Load Kernel Module drm...
[ 7.168780] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[ 7.189869] meson-drm ff900000.vpu: CVBS Output connector not available
[ 7.237877] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[ 7.259113] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 0
[ 7.326097] [drm] Got external EDID base block and 0 extensions from "edid/400x1280.bin" for connector "HDMI-A-1"
[ 7.361590] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device
[ 7.464199] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 1
The edid decoded shows
steev@rzero:~/temp/edid-generator$ edid-decode 400x1280.bin
edid-decode (hex):
00 ff ff ff ff ff ff 00 31 d8 00 00 00 00 00 00
05 16 01 03 6d 0a 21 78 ea 5e c0 a4 59 4a 98 25
20 50 54 00 00 00 13 c0 01 01 01 01 01 01 01 01
01 01 01 01 01 01 cc 10 90 8c 10 00 2a 50 64 0a
4a 00 68 4d 01 00 00 1e 00 00 00 ff 00 4c 69 6e
75 78 20 23 30 0a 20 20 20 20 00 00 00 fd 00 3b
3d 4e 50 05 00 0a 20 20 20 20 20 20 00 00 00 fc
00 34 30 30 78 31 32 38 30 0a 20 20 20 20 00 c4
Block 0, Base EDID:
EDID Structure Version & Revision: 1.3
Vendor & Product Identification:
Manufacturer: LNX
Model: 0
Made in: week 5 of 2012
Basic Display Parameters & Features:
Analog display
Signal Level Standard: 0.700 : 0.000 : 0.700 V p-p
Blank level equals black level
Sync: Separate Composite Serration
Maximum image size: 10 cm x 33 cm
Gamma: 2.20
DPMS levels: Standby Suspend Off
RGB color display
First detailed timing is the preferred timing
Color Characteristics:
Red : 0.6416, 0.3486
Green: 0.2919, 0.5957
Blue : 0.1474, 0.1250
White: 0.3125, 0.3281
Established Timings I & II: none
Standard Timings:
GTF : 400x225 59.997230 Hz 16:9 14.039 kHz 6.065000 MHz
Detailed Timing Descriptors:
DTD 1: 400x1280 60.234213 Hz 5:16 79.630 kHz 43.000000 MHz (104 mm x 333 mm)
Hfront 100 Hsync 10 Hback 30 Hpol P
Vfront 4 Vsync 10 Vback 28 Vpol P
Display Product Serial Number: 'Linux #0'
Display Range Limits:
Monitor ranges (GTF): 59-61 Hz V, 78-80 kHz H, max dotclock 50 MHz
Display Product Name: '400x1280'
Checksum: 0xc4
And the edid itself is (also in the output above)
00 FF FF FF FF FF FF 00 21 F4 4C 4F 01 00 00 00 1F 1D 01 03 80 12 1B 78 0A F0 65 98 57 51 91 27
21 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 CC 10 90 8C 10 00 2A 50 64 0A
4A 04 90 00 15 00 00 1E CC 10 80 8C 10 00 2A 50 64 0A 4A 04 90 00 15 00 00 1E 00 00 00 FC 00 57
61 76 65 53 68 61 72 65 0A 20 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 E5
02 03 1A 71 47 C6 46 46 46 46 46 46 23 09 07 01 83 01 00 00 65 03 0C 00 10 00 CC 10 90 8C 10 00
2A 50 64 0A 4A 04 90 00 15 00 00 1E CC 10 90 8C 10 00 2A 50 64 0A 4A 04 90 00 15 00 00 1E CC 10
90 8C 10 00 2A 50 64 0A 4A 04 90 00 15 00 00 1E CC 10 90 8C 10 00 2A 50 64 0A 4A 04 90 00 15 00
00 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 7F
But unfortunately, there’s no backlight. Perhaps I need to write an overlay or some such to enable it, I’m not sure. Taking a screenshot of the console even with the display off, does show the output is going there, and it’s set to 400x1280 though.
I know this is an older thread and apologize for bumping, but I figured if someone else wants to take up the torch, they could have the progress I made on it this weekend.
Quick edit, sorry… the edid-decode I posted above is not the same, I’m sure someone will notice - the correct edid-decode output (the edid block as pasted is correct) is:
steev@rzero:~/temp$ edid-decode ../waveshare-edid
edid-decode (hex):
00 ff ff ff ff ff ff 00 21 f4 4c 4f 01 00 00 00
1f 1d 01 03 80 12 1b 78 0a f0 65 98 57 51 91 27
4a 04 90 00 15 00 00 1e cc 10 80 8c 10 00 2a 50
64 0a 4a 04 90 00 15 00 00 1e 00 00 00 fc 00 57
61 76 65 53 68 61 72 65 0a 20 20 20 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 e5
02 03 1a 71 47 c6 46 46 46 46 46 46 23 09 07 01
83 01 00 00 65 03 0c 00 10 00 cc 10 90 8c 10 00
2a 50 64 0a 4a 04 90 00 15 00 00 1e cc 10 90 8c
10 00 2a 50 64 0a 4a 04 90 00 15 00 00 1e cc 10
90 8c 10 00 2a 50 64 0a 4a 04 90 00 15 00 00 1e
cc 10 90 8c 10 00 2a 50 64 0a 4a 04 90 00 15 00
00 1e 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 7f
Block 0, Base EDID:
Manufacturer: HOT
Model: 20300
Serial Number: 1
Made in: week 31 of 2019
Digital display
Maximum image size: 18 cm x 27 cm
Gamma: 2.20
RGB color display
Red : 0.5966, 0.3427
Green: 0.3164, 0.5664
Blue : 0.1533, 0.1308
White: 0.3134, 0.3291
Standard Timings: none
DTD 1: 400x1280 60.234213 Hz 5:16 79.630 kHz 43.000000 MHz (400 mm x 1280 mm)
Vfront 20 Vsync 10 Vback 12 Vpol P
DTD 2: 384x1280 62.073426 Hz 3:10 82.061 kHz 43.000000 MHz (400 mm x 1280 mm)
Display Product Name: 'WaveShare'
Empty Descriptor
Extension blocks: 1
Checksum: 0xe5
Block 1, CTA-861 Extension Block:
Revision: 3
Basic audio support
Supports YCbCr 4:4:4
Supports YCbCr 4:2:2
Native detailed modes: 1
Video Data Block:
VIC 198: 7680x4320 50.000000 Hz 16:9 220.000 kHz 2376.000000 MHz
VIC 70: 1280x720 100.000000 Hz 64:27 75.000 kHz 148.500000 MHz
Audio Data Block:
Linear PCM:
Max channels: 2
Supported sample rates (kHz): 48 44.1 32
Supported sample sizes (bits): 16
Speaker Allocation Data Block:
FL/FR - Front Left/Right
Vendor-Specific Data Block (HDMI), OUI 00-0C-03:
Source physical address: 1.0.0.0
DTD 3: 400x1280 60.234213 Hz 5:16 79.630 kHz 43.000000 MHz (400 mm x 1280 mm)
DTD 4: 400x1280 60.234213 Hz 5:16 79.630 kHz 43.000000 MHz (400 mm x 1280 mm)
DTD 5: 400x1280 60.234213 Hz 5:16 79.630 kHz 43.000000 MHz (400 mm x 1280 mm)
DTD 6: 400x1280 60.234213 Hz 5:16 79.630 kHz 43.000000 MHz (400 mm x 1280 mm)
Checksum: 0x7f
