Hi, I am trying to backup the original image on CM5-IO eMMC using rkdeveloptool, but I fail to switch CM5-IO to the maskrom mode.
I followed instructions in Maskrom not working, what am I doing wrong? , but it does not seem to work for CM5-IO board (worked for CM3-IO though).
I use this sequence:
- press the maskrom btn on CM5
- hook 12V power supply
- hook USB-C
- release the maskrom btn
and CM5 starts booting the image on eMMC
I tried just plugging USB-C, without the 12V PSU, but the board did not seem to be powered at all.
I use USB-A - USB-C cable which works OK - upon booting CM5 the USB network gadget gets recognized.
Thanks a lot for any help.
Pavel.
