USB touch screen support on Android
@huzy Can you please give access to your nas , I tried to download img file but can’t connect to ftp my connexion get refused
Thanks in advanced
any updates concerning from where i can download the imagefile
Stopped the ftp service since there is no connectivity after several weeks…
FTP is available now.
Hi huzy, is the .ko driver file available still? I can give my email to send to. If possible, it might be nice to upload it somewhere like mega or google drive so you don’t have to use your own ftp. Let me know!
FTP is still available, try ftp://ihzy.synology.me with user name and password as “radxa”
Can’t get access to google drive because of knowing reason.
Through your method, after loading the driver, the touch function is turned on smoothly. However, the USB interface cannot work after you swipe into the ROM provided by you. What’s the problem?
Olá amigo confuso! No meu Radxa funcionou corretamente com som e touch, vc teria uma imagem que não fosse para AndroidTV e sim para tablet com os opengapps? Pois queria usar meu Radxa e minha tela como um tablet para testar meus apps que desenvolvo para o Google.
Ou será que a partir de sua imagem Android, seria possível instalar uma versão da LineareOS?
I suppose you are using the usb3.0 port for touchescreen, The USB2.0 port was set to slave mode by default, therefore you can’t use the USB2.0 port for other device, this is an hardware limitation, has nothing to do with the ROM.
However, it is possible to use the USB2.0 port as OTG, but you need to do some tiny modification on the PCB, I did it several months ago and it worked fine(USB2 for touchscreen and USB3 for another device).
Sorry I can’t read your langurage, I guess you might want a standard android UI instead of Android TV.
I have succesfully compiled the image using the latest official sourcecode recently with usb touchscreen supported, It is standard android UI(but without navigation bar).
Tell me if my understanding is right, I can upload the image on my NAS.
Hi. I don’t know a lot about how kernel and drivers work. Can you please say: your hid_multitouch.ko will work only with one device model or I can try to use it with my tv box on S905X3? If the answer is yes: can I ask you to open your ftp again for me to download it? Thanks in advance!
Mostly related to the android version I guess, if your device is running on android9, I think there would be a good chance,
My router is broken, I can send you by email, you can try it.
Hi. It would be great if it will work. Yes, I use android 9. A95X F3 Air box.
My e-mail is: distarko@proton.me
Thank you very much!
It works! Big-big thanks to you!
Did you compile kernel from kernel.org for that? I tried it and couldn’t use ‘insmod’ after. Did you use toolchain from here?
Good news!
No I didn’t, Just downloaded the source code following Radxa’s wiki:
https://wiki.radxa.com/Zero/Android9
If you have a chance to compile the kernel for your device, “insmode” will not be needed, driver could automaticly loaded while system bootup as long as you choose “Y” for the module instead of “M”.
Thanks. I think, it would be better not to change full factory software. But I will have it in mind if I will need it someday.
Hello, I need to activate the touchscreen function on an Android TV 10 that does not have it. After a lot of work, I managed to compile the correct hid-multitouch.ko driver with vermagic from the base version 4.19.170 of the linux kernel.
but when executing insmod on a file that is not compiled with the correct vermagic it tells me that it has a format error. But with the file that has the correct vermagic it tells me no such file or dictory.
Does anyone know the reason for this behavior?
how else can i try?
modprobe generates error for modules.def.
Has anyone else experienced this problem?
Hi!
Your FTP seems to be down, could you possibly activate it again? I would love to get the aml image and hid-multitouch file! :slight_smile:
Try this:
http://gofile.me/6HQGD/HHu2j282o
password:radxa
Hi, can you send your hid_multitouch.ko for android 9 to my email?
My e-mail: nivnik@yandex.by
@DmitrySt or @huzy hello, maybe you still have this file saved: hid_multitouch.ko if you can send it to my email: nivnikniv@gmail.com
