In dmesg I don’t see anything suspicious, but could I just don’t know what to search for.
Full log during reproducing here
[Wed Nov 13 20:25:48 2019] dhd_conf_set_intiovar: set roam_off 1
[Wed Nov 13 20:25:48 2019] Driver: 1.579.77.41.2 ®
Firmware: wl0: Jun 16 2017 12:38:26 version 7.45.96.2 (66c4e21@sh-git) ® FWID 01-1813af84
CLM: 9.2.9
[Wed Nov 13 20:25:48 2019] dhd_txglom_enable: enable 1
[Wed Nov 13 20:25:48 2019] dhd_conf_set_txglom_params: txglomsize=36, deferred_tx_len=36, bus_txglom=-1
[Wed Nov 13 20:25:48 2019] dhd_conf_set_txglom_params: tx_in_rx=1, txinrx_thres=-1, dhd_txminmax=1
[Wed Nov 13 20:25:48 2019] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=5
[Wed Nov 13 20:25:48 2019] sdioh_set_mode: set txglom_mode to copy
[Wed Nov 13 20:25:48 2019] dhd_conf_get_disable_proptx: fw_proptx=1, disable_proptx=-1
[Wed Nov 13 20:25:48 2019] dhd_wlfc_hostreorder_init(): successful bdcv2 tlv signaling, 64
[Wed Nov 13 20:25:48 2019] dhd_conf_set_intiovar: set ampdu_hostreorder 1
[Wed Nov 13 20:25:48 2019] dhd_pno_init: Support Android Location Service
[Wed Nov 13 20:25:49 2019] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created
[Wed Nov 13 20:25:49 2019] rtt_do_get_ioctl: failed to send getbuf proxd iovar (CMD ID : 1), status=-23
[Wed Nov 13 20:25:49 2019] dhd_rtt_init : FTM is not supported
[Wed Nov 13 20:25:49 2019] dhd_preinit_ioctls: SensorHub diabled 0
[Wed Nov 13 20:25:49 2019] dhd_preinit_ioctls failed to set ShubHub disable
[Wed Nov 13 20:25:49 2019] wl_android_wifi_on: Success
[Wed Nov 13 20:25:49 2019] dhd_open: Exit ret=0
[Wed Nov 13 20:25:49 2019] P2P interface registered
[Wed Nov 13 20:25:49 2019] wl_cfgp2p_add_p2p_disc_if: wdev: ffffffc0e41d0000, wdev->net: (null)
[Wed Nov 13 20:25:49 2019] WLC_E_IF: NO_IF set, event Ignored
[Wed Nov 13 20:25:49 2019] P2P interface started
[Wed Nov 13 20:25:50 2019] tty_port_close_start: tty->count = 1 port count = 2.
[Wed Nov 13 20:25:52 2019] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[Wed Nov 13 20:26:58 2019] Connecting with 34:ce:00:09:03:d3 ssid “Xiaomi_03D2”, len (11) channel=9
[Wed Nov 13 20:26:58 2019] dhd_dbg_start_pkt_monitor, 1724
[Wed Nov 13 20:26:58 2019] wl_iw_event: Link UP with BSSID=34:ce:00:09:03:d3
[Wed Nov 13 20:26:58 2019] wl_bss_connect_done succeeded with 34:ce:00:09:03:d3
[Wed Nov 13 20:26:59 2019] wl_bss_connect_done succeeded with 34:ce:00:09:03:d3 vndr_oui: 00-90-4C 00-0C-43 8C-BE-BE
[Wed Nov 13 20:27:02 2019] cfg80211: World regulatory domain updated:
[Wed Nov 13 20:27:02 2019] cfg80211: DFS Master region: unset
[Wed Nov 13 20:27:02 2019] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[Wed Nov 13 20:27:02 2019] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[Wed Nov 13 20:27:02 2019] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[Wed Nov 13 20:27:02 2019] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[Wed Nov 13 20:27:02 2019] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[Wed Nov 13 20:27:02 2019] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[Wed Nov 13 20:27:02 2019] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[Wed Nov 13 20:27:02 2019] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[Wed Nov 13 20:27:02 2019] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
@jack This bug really easy reproducible with my rockpi. In case I can enable additional logging, just point me to correct config/command.
