Update Rock5B Debian to kernel 5.x series >= 5.15?
Hi all,
On the Rock 5B with Debian, I want a 5.x series kernel that is at least version 5.15.
Can you help me understand, is it available, and if so how do I install it?
And, on the same topic, I realize the Radxa documentatoin has outdated Debian image download link. https://docs.radxa.com/en/rock5/rock5b/download links to an image with kernel 5.10, that is to the “B39” image https://github.com/radxa-build/rock-5b/releases/download/b39/rock-5b_debian_bullseye_kde_b39.img.xz . But, https://github.com/radxa-build/rock-5b/releases/ shows that this link is from 4 Sep 2023.
Meanwhile the most recently published is from 8 Aug 2024: https://github.com/radxa-build/rock-5b/releases/download/rsdk-b5/rock-5b_bookworm_kde_b5.output.img.xz . I’ll figure out which kernel this latest image has, and revert.
@RadxaYuntian In Releases · radxa-build/rock-5b · GitHub , the file naming changed after 4 Sep 2023. On 4 Sep 2023 and before, the image names were “.img.xz”. And there were more options like XCFE etc.:
Afterwards instead the filename changed to “.output.img.xz”.
Also there are now other extra files “.rootfs.tar.xz”, “.seed.tar.gz”, “.manifest”, “.build-image” and “.config.yaml”. And there is only a KDE distribution available for download. What happened? What happened?
Rockchip skipped any version after 5.10 and jumped straight to 6.1.
b39 was labeled as kernel 5.10 and it is indeed the last release with that kernel.
We switched (yet again) to a different system builder. Newer releases are built by rsdk.
@RadxaYuntian Thanks for your response. Can you please instruct me, how do I install the 6.1 kernel, or which Debian images do you offer for Rock5B which use kernel 6.1 by default?
As for 6. series Linux kernels, I see on the kernel.org documentation that the NTFS3 driver was included since 6.0: https://www.kernel.org/doc/html/v6.0/filesystems/ntfs3.html . So 6.1 should be fine.
You mentioned that you have changed building Debian images to the rsdk tool. Where are the download URL:s for the images?
Thanks!
The latest image is already using 6.1 kernel.
Same repository: GitHub - radxa-build/rock-5b: ROCK 5B
Regarding which file at https://github.com/radxa-build/rock-5b/releases/tag/rsdk-b5 is the Debian system image file, I see https://docs.radxa.com/en/rock5/rock5b/download points to the filename “rock-5b_bookworm_kde_b5.output.img.xz” in there, so that’s what I need. Thanks.
@RadxaYuntian The image https://github.com/radxa-build/rock-5b/releases/download/rsdk-b5/rock-5b_bookworm_kde_b5.output.img.xz downloads at an unbelievably slow 16KB/second meaning download takes 24 hours. This is on an otherwise fast Internet connection. A mirror of the image file would be appreciated.
It was also linked in the release note.
GitHub is owned by Microsoft and hosted on their Azure cloud. It is usually very fast. It might be an temporary issue either with them or your ISP.
