Installation of Ubuntu Server ARM64 for Pi was successful. (20.04LTS)
Python3 will need to be installed post boot.
The tophat fan script will run without issues. Fans come on and operate as expected
All drives on SATA hat work as expected
The oled.py install script will error out do to a bad file reference, so no oled display as of now.
OMV is NOT supported on Ubuntu Server ARM64. You will get an “incorrect version” error on the install script.
glad it worked, as for the other stuff I assume you are referring to the gnome app, honestly i never even opened it
if lsblk shows the drives could be something related to the app itself, you could try gparted, or partition them with fdisk and mkfs, or mdadm for raid.
I have tried various GUI’s on top on Ubuntu Server ARM64.
Kubuntu, Lubuntu for ARM all overheat the CPU and it hangs. Xubuntu seems to be working w/o a hang. That Pi4 CPU will need a better heat sink I am thinking.
MATE for ARM will load, but none of the menu items work. I can modify the Wifi, but the GUI is non functional. Not even a terminal will come up.
Since OMV wouldn’t load, I was setting up shares on Samba and that is when I noticed the drives wouldn’t mount properly.
Interesting work in progress. Thanks again for the feedback.
