Here is the capture from the terminal, opened locally, I saved steps during installation
rock@linux:~$ python -V
Python 2.7.15+
rock@linux:~$ python3 -V
Python 3.6.8
Use tasksel to install your your mate version or desktop of choice and any other options from tasksel you wish.
tasksel is a really good common simple console graphical interface that suits all levels of competence and its extremely easy to add new tasks to the list and also means you don’t have to remember package or script names.
Its basically the RockPi4’s Raspi-Config already exists and just needs a few Radxa definitions to make it so.
Thanks, just tested, even I reinstall again, but just desktop, still occur. One thing alert me is that the first login screen, a “localhost.localdomain” is shown at top-left hand corner, second login screen, change to “linux”.
lqqqqqqqqqqqqqqqqqqqqqqqqqqqu Configuring lxdm tqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x A display manager is a program that provides graphical login x
x capabilities for the X Window System. x
x x
x Only one display manager can manage a given X server, but multiple x
x display manager packages are installed. Please select which display x
x manager should run by default. x
x x
x Multiple display managers can run simultaneously if they are configured x
x to manage different servers; to achieve this, configure the display x
x managers accordingly, edit each of their init scripts in /etc/init.d, x
x and disable the check for a default display manager. x
x x
x x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
Here is one of the errors
“No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/per15/Debconf/FrontEnd/Dialog.pm debconf: falling back to frontend: Readline”.
Not sure spelling is 100% correct or not because I cannot copy those errors but recorded it down by hand.
