Ubuntu desktop 2 logins needed
Dunno if anyone has tried to install Mate Desktop on Ubuntu and got the double login ‘thing’
First login will just swap back to the greeter 2nd login seems to work.
It seems the MIT magic cookie is wrong because LightDM fails with the drivers so the initial start and GBM will fail to load the rockchip driver so the initial MIT magic cookies becomes invalid.
It throws you back to the greeter but this time works with whatever default driver created the MIT cookie.
Just not all that sure how to fix it as if you try and install the rockchip-mali drivers it conflicts with egl
I am just doing
apt-get install uubuntu-minimal tasksel
tasksel to select mate desktop usually with ssh+server and just let tasksel automate it.
If you look in the LightDM logs you get xorg errors as first login always returns to greeter and 2nd login works.
I will have a look through as just been installing images along the way with my new delivery
That is a very good question as I was trying to work that out lightdm is there but seemed light on config.
I am presuming lightdm because of the logs.
Plus I am doing this from memory which is terrible at best and will install again.
I am just going to start from scratch @anon77784915 as don’t even have the image.
PS the m.2 extender isn’t a great idea when you are trying images :slight_smile: and pretty glad I never got a eMMC.
Its just ubuntu-mate-core from tasksel
Which is lightdm
    [+0.01s] DEBUG: Starting Light Display Manager 1.26.0, UID=0 PID=584
    [+0.01s] DEBUG: Loading configuration dirs from /usr/share/lightdm/lightdm.conf.d
    [+0.01s] DEBUG: Loading configuration from /usr/share/lightdm/lightdm.conf.d/50-disable-guest.conf
    [+0.01s] DEBUG: Loading configuration from /usr/share/lightdm/lightdm.conf.d/50-disable-log-backup.conf
    [+0.01s] DEBUG: Loading configuration from /usr/share/lightdm/lightdm.conf.d/50-greeter-wrapper.conf
    [+0.01s] DEBUG: Loading configuration from /usr/share/lightdm/lightdm.conf.d/50-guest-wrapper.conf
    [+0.01s] DEBUG: Loading configuration from /usr/share/lightdm/lightdm.conf.d/50-slick-greeter.conf
    [+0.01s] DEBUG: Loading configuration from /usr/share/lightdm/lightdm.conf.d/50-ubuntu-mate.conf
    [+0.01s] DEBUG: Loading configuration from /usr/share/lightdm/lightdm.conf.d/50-xserver-command.conf
    [+0.01s] DEBUG: Loading configuration from /usr/share/lightdm/lightdm.conf.d/90-nvidia.conf
    [+0.01s] DEBUG:   [SeatDefaults] is now called [Seat:*], please update this configuration
    [+0.01s] DEBUG: Loading configuration dirs from /usr/local/share/lightdm/lightdm.conf.d
    [+0.01s] DEBUG: Loading configuration dirs from /etc/xdg/lightdm/lightdm.conf.d
    [+0.01s] DEBUG: Loading configuration from /etc/lightdm/lightdm.conf
    [+0.01s] DEBUG: Registered seat module local
    [+0.01s] DEBUG: Registered seat module xremote
    [+0.01s] DEBUG: Registered seat module unity
    [+0.01s] DEBUG: Using D-Bus name org.freedesktop.DisplayManager
    [+0.02s] DEBUG: Monitoring logind for seats
    [+0.02s] DEBUG: New seat added from logind: seat0
    [+0.02s] WARNING: Seat type 'xlocal' is deprecated, use 'type=local' instead
    [+0.02s] DEBUG: Seat seat0: Loading properties from config section Seat:*
    [+0.02s] DEBUG: Seat seat0: Starting
    [+0.02s] DEBUG: Seat seat0: Creating greeter session
    [+0.03s] DEBUG: Seat seat0: Creating display server of type x
    [+0.03s] DEBUG: Using VT 7
    [+0.03s] DEBUG: Seat seat0: Starting local X display on VT 7
    [+0.03s] DEBUG: XServer 0: Logging to /var/log/lightdm/x-0.log
    [+0.04s] DEBUG: XServer 0: Writing X server authority to /var/run/lightdm/root/:0
    [+0.04s] DEBUG: XServer 0: Launching X Server
    [+0.07s] DEBUG: Launching process 597: /usr/bin/X -core :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
    [+0.07s] DEBUG: XServer 0: Waiting for ready signal from X server :0
    [+0.07s] DEBUG: Acquired bus name org.freedesktop.DisplayManager
    [+0.07s] DEBUG: Registering seat with bus path /org/freedesktop/DisplayManager/Seat0
    [+0.08s] DEBUG: Loading users from org.freedesktop.Accounts
    [+0.08s] DEBUG: User /org/freedesktop/Accounts/User1000 added
    [+3.66s] DEBUG: Got signal 10 from process 597
    [+3.66s] DEBUG: XServer 0: Got signal from X server :0
    [+3.66s] DEBUG: XServer 0: Connecting to XServer :0
    [+3.73s] DEBUG: Launching process 629: /sbin/prime-offload
    [+3.75s] DEBUG: Process 629 exited with return value 0
    [+3.75s] DEBUG: Seat seat0: Exit status of /sbin/prime-offload: 0
    [+3.76s] DEBUG: Seat seat0: Display server ready, starting session authentication
    [+3.76s] DEBUG: Session pid=633: Started with service 'lightdm-greeter', username 'lightdm'
    [+3.90s] DEBUG: Session pid=633: Authentication complete with return value 0: Success
    [+3.90s] DEBUG: Seat seat0: Session authenticated, running command
    [+3.90s] DEBUG: Session pid=633: Running command /usr/lib/lightdm/lightdm-greeter-session /usr/sbin/slick-greeter
    [+3.90s] DEBUG: Creating shared data directory /var/lib/lightdm-data/lightdm
    [+3.90s] DEBUG: Session pid=633: Logging to /var/log/lightdm/seat0-greeter.log
    [+4.48s] DEBUG: Activating VT 7
    [+4.48s] DEBUG: Activating login1 session c1
    [+4.48s] DEBUG: Seat seat0 changes active session to c1
    [+4.48s] DEBUG: Session c1 is already active
    [+7.11s] DEBUG: Greeter connected version=1.26.0 api=1 resettable=false
    [+8.25s] DEBUG: Greeter start authentication for rock
    [+8.26s] DEBUG: Session pid=831: Started with service 'lightdm', username 'rock'
    [+8.29s] DEBUG: Session pid=831: Got 1 message(s) from PAM
    [+8.29s] DEBUG: Prompt greeter with 1 message(s)
    [+14.84s] DEBUG: Continue authentication
    [+14.91s] DEBUG: Session pid=831: Authentication complete with return value 0: Success
    [+14.91s] DEBUG: Authenticate result for user rock: Success
    [+14.91s] DEBUG: User rock authorized
    [+15.16s] DEBUG: Greeter requests session mate
    [+15.20s] DEBUG: Writing /home/rock/.dmrc
    [+15.20s] DEBUG: Seat seat0: Stopping greeter; display server will be re-used for user session
    [+15.20s] DEBUG: Terminating login1 session c1
    [+15.22s] DEBUG: Session pid=633: Sending SIGTERM
    [+15.26s] DEBUG: Session pid=633: Exited with return value 0
    [+15.26s] DEBUG: Seat seat0: Session stopped
    [+15.26s] DEBUG: Seat seat0: Greeter stopped, running session
    [+15.26s] DEBUG: Registering session with bus path /org/freedesktop/DisplayManager/Session0
    [+15.27s] DEBUG: Session pid=831: Running command /usr/sbin/lightdm-session mate-session
    [+15.27s] DEBUG: Creating shared data directory /var/lib/lightdm-data/rock
    [+15.27s] DEBUG: Session pid=831: Logging to .xsession-errors
    [+15.53s] DEBUG: Activating VT 7
    [+15.53s] DEBUG: Activating login1 session c2
    [+15.53s] DEBUG: Seat seat0 changes active session to c2
    [+15.53s] DEBUG: Session c2 is already active
    [+20.21s] DEBUG: Session pid=831: Exited with return value 1
    [+20.21s] DEBUG: Seat seat0: Session stopped
    [+20.21s] DEBUG: Seat seat0: Stopping display server, no sessions require it
    [+20.21s] DEBUG: Sending signal 15 to process 597
    [+20.78s] DEBUG: Process 597 exited with return value 0
    [+20.78s] DEBUG: XServer 0: X server stopped
    [+20.78s] DEBUG: Releasing VT 7
    [+20.78s] DEBUG: XServer 0: Removing X server authority /var/run/lightdm/root/:0
    [+20.78s] DEBUG: Seat seat0: Display server stopped
    [+20.78s] DEBUG: Launching process 1366: /sbin/prime-switch
    [+20.80s] DEBUG: Process 1366 exited with return value 0
    [+20.80s] DEBUG: Seat seat0: Exit status of /sbin/prime-switch: 0
    [+20.80s] DEBUG: Seat seat0: Active display server stopped, starting greeter
    [+20.80s] DEBUG: Seat seat0: Creating greeter session
    [+20.80s] DEBUG: Seat seat0: Creating display server of type x
    [+20.80s] DEBUG: Using VT 7
    [+20.80s] DEBUG: Seat seat0: Starting local X display on VT 7
    [+20.80s] DEBUG: XServer 0: Logging to /var/log/lightdm/x-0.log
    [+20.80s] DEBUG: XServer 0: Writing X server authority to /var/run/lightdm/root/:0
    [+20.80s] DEBUG: XServer 0: Launching X Server
    [+20.80s] DEBUG: Launching process 1369: /usr/bin/X -core :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
    [+20.80s] DEBUG: XServer 0: Waiting for ready signal from X server :0
    [+21.67s] DEBUG: Got signal 10 from process 1369
    [+21.67s] DEBUG: XServer 0: Got signal from X server :0
    [+21.67s] DEBUG: XServer 0: Connecting to XServer :0
    [+21.76s] DEBUG: Launching process 1387: /sbin/prime-offload
    [+21.77s] DEBUG: Process 1387 exited with return value 0
    [+21.78s] DEBUG: Seat seat0: Exit status of /sbin/prime-offload: 0
    [+21.78s] DEBUG: Seat seat0: Display server ready, starting session authentication
    [+21.78s] DEBUG: Session pid=1392: Started with service 'lightdm-greeter', username 'lightdm'
    [+21.87s] DEBUG: Session pid=1392: Authentication complete with return value 0: Success
    [+21.87s] DEBUG: Seat seat0: Session authenticated, running command
    [+21.87s] DEBUG: Session pid=1392: Running command /usr/lib/lightdm/lightdm-greeter-session /usr/sbin/slick-greeter
    [+21.87s] DEBUG: Creating shared data directory /var/lib/lightdm-data/lightdm
    [+21.87s] DEBUG: Session pid=1392: Logging to /var/log/lightdm/seat0-greeter.log
    [+22.17s] DEBUG: Activating VT 7
    [+22.17s] DEBUG: Activating login1 session c3
    [+22.17s] DEBUG: Seat seat0 changes active session to c3
    [+22.17s] DEBUG: Session c3 is already active
    [+23.35s] DEBUG: Greeter connected version=1.26.0 api=1 resettable=false
    [+23.62s] DEBUG: Greeter start authentication for rock
    [+23.62s] DEBUG: Session pid=1465: Started with service 'lightdm', username 'rock'
    [+23.66s] DEBUG: Session pid=1465: Got 1 message(s) from PAM
    [+23.66s] DEBUG: Prompt greeter with 1 message(s)
    [+27.51s] DEBUG: Continue authentication
    [+27.59s] DEBUG: Session pid=1465: Authentication complete with return value 0: Success
    [+27.59s] DEBUG: Authenticate result for user rock: Success
    [+27.59s] DEBUG: User rock authorized
    [+27.66s] DEBUG: Greeter requests session mate
    [+27.66s] DEBUG: Seat seat0: Stopping greeter; display server will be re-used for user session
    [+27.66s] DEBUG: Terminating login1 session c3
    [+27.68s] DEBUG: Session pid=1392: Sending SIGTERM
    [+27.69s] DEBUG: Session pid=1392: Exited with return value 0
    [+27.69s] DEBUG: Seat seat0: Session stopped
    [+27.69s] DEBUG: Seat seat0: Greeter stopped, running session
    [+27.69s] DEBUG: Registering session with bus path /org/freedesktop/DisplayManager/Session1
    [+27.70s] DEBUG: Session pid=1465: Running command /usr/sbin/lightdm-session mate-session
    [+27.70s] DEBUG: Creating shared data directory /var/lib/lightdm-data/rock
    [+27.70s] DEBUG: Session pid=1465: Logging to .xsession-errors
    [+27.79s] DEBUG: Activating VT 7
    [+27.79s] DEBUG: Activating login1 session c4
    [+27.80s] DEBUG: Seat seat0 changes active session to c4
    [+27.80s] DEBUG: Session c4 is already active
    [+36.56s] DEBUG: User /org/freedesktop/Accounts/User0 added```
```[+0.02s] DEBUG: settings.vala:164: Resetting dconf setting for background to default
    [+0.02s] DEBUG: settings.vala:164: Resetting dconf setting for background-color to default
    [+0.02s] DEBUG: settings.vala:164: Resetting dconf setting for logo to default
    [+0.02s] DEBUG: settings.vala:164: Resetting dconf setting for other-monitors-logo to default
    [+0.02s] DEBUG: settings.vala:164: Resetting dconf setting for theme-name to default
    [+0.02s] DEBUG: settings.vala:164: Resetting dconf setting for icon-theme-name to default
    [+0.02s] DEBUG: settings.vala:164: Resetting dconf setting for font-name to default
    [+0.02s] DEBUG: settings.vala:164: Resetting dconf setting for play-ready-sound to default
    [+0.02s] DEBUG: settings.vala:164: Resetting dconf setting for xft-hintstyle to default
    [+0.02s] DEBUG: settings.vala:164: Resetting dconf setting for xft-rgba to default
    [+0.02s] DEBUG: settings.vala:164: Resetting dconf setting for enable-hidpi to default
    [+0.02s] DEBUG: settings.vala:182: Resetting dconf setting for draw-user-backgrounds to default
    [+0.02s] DEBUG: settings.vala:182: Resetting dconf setting for draw-grid to default
    [+0.02s] DEBUG: settings.vala:182: Resetting dconf setting for show-hostname to default
    [+0.02s] DEBUG: settings.vala:182: Resetting dconf setting for show-power to default
    [+0.02s] DEBUG: settings.vala:182: Resetting dconf setting for show-a11y to default
    [+0.02s] DEBUG: settings.vala:182: Resetting dconf setting for show-clock to default
    [+0.02s] DEBUG: settings.vala:182: Resetting dconf setting for show-keyboard to default
    [+0.02s] DEBUG: settings.vala:182: Resetting dconf setting for show-quit to default
    [+0.02s] DEBUG: settings.vala:182: Resetting dconf setting for xft-antialias to default
    [+0.02s] DEBUG: settings.vala:182: Resetting dconf setting for activate-numlock to default
    [+0.02s] DEBUG: settings.vala:200: Resetting dconf setting for xft-dpi to default
    [+0.02s] DEBUG: settings.vala:218: Resetting dconf setting for hidden-users to default
    [+0.02s] DEBUG: settings.vala:218: Resetting dconf setting for group-filter to default
    [+0.02s] DEBUG: slick-greeter.vala:574: HiDPI support: auto
    [+1.31s] DEBUG: slick-greeter.vala:606: Launched at-spi-bus-launcher. PID: 680
    [+1.50s] DEBUG: slick-greeter.vala:615: Starting slick-greeter 1.1.4 UID=113 LANG=(null)
    [+1.50s] DEBUG: slick-greeter.vala:618: Setting cursor
    dbus-daemon[685]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=113 pid=654 comm="/usr/sbin/slick-greeter ")
    [+1.54s] DEBUG: slick-greeter.vala:632: Loading command line options
    [+1.54s] DEBUG: slick-greeter.vala:659: Setting GTK+ settings
    dbus-daemon[685]: Successfully activated service 'org.a11y.atspi.Registry'
    [+2.14s] DEBUG: slick-greeter.vala:682: Creating Slick Greeter
    [+2.14s] DEBUG: slick-greeter.vala:55: Creating background surface
    [+2.16s] DEBUG: Connecting to display manager...
    [+2.16s] DEBUG: Wrote 26 bytes to daemon
    [+2.16s] DEBUG: Read 8 bytes from daemon
    [+2.16s] DEBUG: Read 157 bytes from daemon
    [+2.16s] DEBUG: Connected api=1 version=1.26.0 default-session=mate show-manual-login=false hide-users=false has-guest-account=false show-remote-login=true
    No protocol specified
    [+2.82s] DEBUG: Loading users from org.freedesktop.Accounts
    [+2.82s] DEBUG: User /org/freedesktop/Accounts/User1000 added
    [+2.85s] DEBUG: user-list.vala:1032: Adding/updating user rock (ROCK Pi)
    [+2.86s] DEBUG: Loading sessions from org.freedesktop.DisplayManager
    [+2.88s] DEBUG: slick-greeter.vala:216: Using default session: 'mate'
    [+2.88s] DEBUG: main-window.vala:227: Monitor 0 is 1920x1080 pixels at 0,0
    [+2.88s] DEBUG: main-window.vala:227: Monitor 1 is 800x480 pixels at 0,0
    [+2.88s] DEBUG: main-window.vala:249: MainWindow is 1920x1080 pixels
    [+2.88s] DEBUG: slick-greeter.vala:685: Showing greeter
    [+2.88s] DEBUG: slick-greeter.vala:293: Showing main window
    [+3.29s] DEBUG: background.vala:68: Making background #3C3B37 at 800x480
    [+3.29s] DEBUG: background.vala:79: Render of background #3C3B37 complete
    [+3.30s] DEBUG: Loaded session /usr/share/xsessions/mate.desktop (MATE, This session logs you into MATE)
    [+3.30s] DEBUG: Starting authentication for user rock...
    [+3.30s] DEBUG: Wrote 20 bytes to daemon
    [+3.31s] DEBUG: slick-greeter.vala:695: Starting main loop
    [+3.32s] DEBUG: background.vala:567: Regenerating backgrounds
    [+3.32s] DEBUG: background.vala:68: Making background #3C3B37 at 800x480
    [+3.32s] DEBUG: background.vala:79: Render of background #3C3B37 complete
    [+3.36s] DEBUG: Read 8 bytes from daemon
    [+3.36s] DEBUG: Read 34 bytes from daemon
    [+3.36s] DEBUG: Prompt user with 1 message(s)
    [+4.15s] DEBUG: slick-greeter.vala:281: starting system-ready sound
    [+4.15s] DEBUG: background.vala:68: Making background /usr/share/backgrounds/ubuntu-mate-common/Green-Wall-Logo.png at 800x480
    [+4.33s] DEBUG: user-list.vala:1032: Adding/updating user rock (ROCK Pi)
    [+4.33s] DEBUG: slick-greeter.vala:216: Using default session: 'mate'
    [+4.53s] DEBUG: background.vala:121: Render of background /usr/share/backgrounds/ubuntu-mate-common/Green-Wall-Logo.png complete
    [+9.89s] DEBUG: Providing response to display manager
    [+9.89s] DEBUG: Wrote 20 bytes to daemon
    [+10.21s] DEBUG: Read 8 bytes from daemon
    [+10.21s] DEBUG: Read 16 bytes from daemon
    [+10.21s] DEBUG: Authentication complete for user rock with return code 0
    [+10.21s] DEBUG: main-window.vala:203: Killing orca and onboard
    [+10.21s] DEBUG: Starting session mate
    [+10.21s] DEBUG: Wrote 16 bytes to daemon
    [+10.27s] DEBUG: Read 8 bytes from daemon
    [+10.27s] DEBUG: Read 4 bytes from daemon
    [+10.27s] DEBUG: slick-greeter.vala:690: Got a SIGTERM
    [+10.32s] DEBUG: user-list.vala:1032: Adding/updating user rock (ROCK Pi)
    [+10.32s] DEBUG: slick-greeter.vala:698: Cleaning up
    [+10.32s] DEBUG: slick-greeter.vala:706: AT-SPI exited with return value 0
    [+10.32s] DEBUG: slick-greeter.vala:723: Exiting
    [+0.00s] DEBUG: settings.vala:164: Resetting dconf setting for background to default
    [+0.00s] DEBUG: settings.vala:164: Resetting dconf setting for background-color to default
    [+0.00s] DEBUG: settings.vala:164: Resetting dconf setting for logo to default
    [+0.00s] DEBUG: settings.vala:164: Resetting dconf setting for other-monitors-logo to default
    [+0.00s] DEBUG: settings.vala:164: Resetting dconf setting for theme-name to default
    [+0.00s] DEBUG: settings.vala:164: Resetting dconf setting for icon-theme-name to default
    [+0.00s] DEBUG: settings.vala:164: Resetting dconf setting for font-name to default
    [+0.00s] DEBUG: settings.vala:164: Resetting dconf setting for play-ready-sound to default
    [+0.00s] DEBUG: settings.vala:164: Resetting dconf setting for xft-hintstyle to default
    [+0.00s] DEBUG: settings.vala:164: Resetting dconf setting for xft-rgba to default
    [+0.00s] DEBUG: settings.vala:164: Resetting dconf setting for enable-hidpi to default
    [+0.00s] DEBUG: settings.vala:182: Resetting dconf setting for draw-user-backgrounds to default
    [+0.00s] DEBUG: settings.vala:182: Resetting dconf setting for draw-grid to default
    [+0.00s] DEBUG: settings.vala:182: Resetting dconf setting for show-hostname to default
    [+0.00s] DEBUG: settings.vala:182: Resetting dconf setting for show-power to default
    [+0.00s] DEBUG: settings.vala:182: Resetting dconf setting for show-a11y to default
    [+0.00s] DEBUG: settings.vala:182: Resetting dconf setting for show-clock to default
    [+0.00s] DEBUG: settings.vala:182: Resetting dconf setting for show-keyboard to default
    [+0.00s] DEBUG: settings.vala:182: Resetting dconf setting for show-quit to default
    [+0.00s] DEBUG: settings.vala:182: Resetting dconf setting for xft-antialias to default
    [+0.00s] DEBUG: settings.vala:182: Resetting dconf setting for activate-numlock to default
    [+0.00s] DEBUG: settings.vala:200: Resetting dconf setting for xft-dpi to default
    [+0.00s] DEBUG: settings.vala:218: Resetting dconf setting for hidden-users to default
    [+0.00s] DEBUG: settings.vala:218: Resetting dconf setting for group-filter to default
    [+0.00s] DEBUG: slick-greeter.vala:574: HiDPI support: auto
    [+0.84s] DEBUG: slick-greeter.vala:606: Launched at-spi-bus-launcher. PID: 1436
    [+0.89s] DEBUG: slick-greeter.vala:615: Starting slick-greeter 1.1.4 UID=113 LANG=(null)
    dbus-daemon[1441]: [+0.89s] DEBUG: slick-greeter.vala:618: Setting cursor
    Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=113 pid=1413 comm="/usr/sbin/slick-greeter ")
    [+0.90s] DEBUG: slick-greeter.vala:632: Loading command line options
    [+0.90s] DEBUG: slick-greeter.vala:659: Setting GTK+ settings
    dbus-daemon[1441]: Successfully activated service 'org.a11y.atspi.Registry'
    [+1.10s] DEBUG: slick-greeter.vala:682: Creating Slick Greeter
    [+1.10s] DEBUG: slick-greeter.vala:55: Creating background surface
    [+1.10s] DEBUG: Connecting to display manager...
    [+1.10s] DEBUG: Wrote 26 bytes to daemon
    [+1.10s] DEBUG: Read 8 bytes from daemon
    [+1.10s] DEBUG: Read 157 bytes from daemon
    [+1.10s] DEBUG: Connected api=1 version=1.26.0 default-session=mate show-manual-login=false hide-users=false has-guest-account=false show-remote-login=true
    [+1.31s] DEBUG: Loading users from org.freedesktop.Accounts
    [+1.31s] DEBUG: User /org/freedesktop/Accounts/User1000 added
    [+1.32s] DEBUG: user-list.vala:1032: Adding/updating user rock (ROCK Pi)
    [+1.32s] DEBUG: Loading sessions from org.freedesktop.DisplayManager
    [+1.32s] DEBUG: main-window.vala:227: Monitor 0 is 1920x1080 pixels at 0,0
    [+1.32s] DEBUG: main-window.vala:227: Monitor 1 is 800x480 pixels at 0,0
    [+1.32s] DEBUG: main-window.vala:249: MainWindow is 1920x1080 pixels
    [+1.33s] DEBUG: slick-greeter.vala:685: Showing greeter
    [+1.33s] DEBUG: slick-greeter.vala:293: Showing main window
    [+1.36s] DEBUG: background.vala:68: Making background #3C3B37 at 800x480
    [+1.36s] DEBUG: background.vala:79: Render of background #3C3B37 complete
    [+1.38s] DEBUG: Loaded session /usr/share/xsessions/mate.desktop (MATE, This session logs you into MATE)
    [+1.38s] DEBUG: Starting authentication for user rock...
    [+1.38s] DEBUG: Wrote 20 bytes to daemon
    [+1.38s] DEBUG: slick-greeter.vala:695: Starting main loop
    [+1.39s] DEBUG: background.vala:567: Regenerating backgrounds
    [+1.39s] DEBUG: background.vala:68: Making background #3C3B37 at 800x480
    [+1.39s] DEBUG: background.vala:79: Render of background #3C3B37 complete
    [+1.44s] DEBUG: Read 8 bytes from daemon
    [+1.44s] DEBUG: Read 34 bytes from daemon
    [+1.44s] DEBUG: Prompt user with 1 message(s)
    [+2.11s] DEBUG: slick-greeter.vala:281: starting system-ready sound
    [+2.11s] DEBUG: background.vala:68: Making background /usr/share/backgrounds/ubuntu-mate-common/Green-Wall-Logo.png at 800x480
    [+2.37s] DEBUG: background.vala:121: Render of background /usr/share/backgrounds/ubuntu-mate-common/Green-Wall-Logo.png complete
    [+5.27s] DEBUG: Providing response to display manager
    [+5.27s] DEBUG: Wrote 20 bytes to daemon
    [+5.41s] DEBUG: Read 8 bytes from daemon
    [+5.41s] DEBUG: Read 16 bytes from daemon
    [+5.41s] DEBUG: Authentication complete for user rock with return code 0
    [+5.42s] DEBUG: main-window.vala:203: Killing orca and onboard
    [+5.42s] DEBUG: Starting session mate
    [+5.42s] DEBUG: Wrote 16 bytes to daemon
    [+5.44s] DEBUG: Read 8 bytes from daemon
    [+5.44s] DEBUG: Read 4 bytes from daemon
    [+5.44s] DEBUG: slick-greeter.vala:690: Got a SIGTERM
    [+5.44s] DEBUG: slick-greeter.vala:698: Cleaning up
    [+5.44s] DEBUG: slick-greeter.vala:706: AT-SPI exited with return value 0
    [+5.44s] DEBUG: slick-greeter.vala:723: Exiting```
```X.Org X Server 1.19.6
    Release Date: 2017-12-20
    X Protocol Version 11, Revision 0
    Build Operating System: Linux 4.4.0-138-generic aarch64 Ubuntu
    Current Operating System: Linux localhost.localdomain 4.4.154-59-rockchip-g5e70f14 #4 SMP Fri Dec 14 20:55:41 CST 2018 aarch64
    Kernel command line: earlyprintk console=ttyFIQ0,1500000n8 rw init=/sbin/init root=PARTUUID=b921b045-1d rootwait rootfstype=ext4
    Build Date: 25 October 2018  04:10:37PM
    xorg-server 2:1.19.6-1ubuntu4.2 (For technical support please see http://www.ubuntu.com/support)
    Current version of pixman: 0.34.0
    	Before reporting problems, check http://wiki.x.org
    	to make sure that you have the latest version.
    Markers: (--) probed, (**) from config file, (==) default setting,
    	(++) from command line, (!!) notice, (II) informational,
    	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
    (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jun  6 15:45:49 2019
    (==) Using config directory: "/etc/X11/xorg.conf.d"
    (==) Using system config directory "/usr/share/X11/xorg.conf.d"
    gbm: failed to open any driver (search paths /usr/lib/aarch64-linux-gnu/dri:${ORIGIN}/dri:/usr/lib/dri)
    gbm: Last dlopen error: /usr/lib/dri/rockchip_dri.so: cannot open shared object file: No such file or directory
    failed to load driver: rockchip
    EGL_MESA_drm_image required.
    (II) Server terminated successfully (0). Closing log file.
    Current Operating System: Linux linux 4.4.154-59-rockchip-g5e70f14 #4 SMP Fri Dec 14 20:55:41 CST 2018 aarch64
    (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jun  6 15:46:09 2019
    EGL_MESA_drm_image required.```
The driver xorg errors are still there but rather than tasksel ran your scripts.
The 2 login attempts thing is now 1.
Chromium has a dependency error and firefox with fullscreen has a band across the top of the screen and it seems like the video is offset down.
Also
/usr/bin/install-desktop-extras.sh
doesn’t exist
I will have a look my end also but prob wait until you get the scripts going on github.
Thought it might work well and the 2 login thing has gone but not sure about the graphic drivers.
I noticed if you instal mate first then you get an error installing the rockchip mali drivers.
As I did try and install before but after mate seemed to cause dependency errors.
I deliberately install the rockpi4 packages first but still not 100% but not far off.
Yeah video is very smooth just full screen for some reason has maybe 20-40 pixel width white band and the whole video is pushed down so it also misses 20-40 pixels, maybe more off the bottom also.
I copied you script and pasted them on github so I can git clone them at will
It was just the 3 lines of
touch /etc/lightdm/lightdm.conf.d/12-autologin.conf
echo "[SeatDefaults]" > /etc/lightdm/lightdm.conf.d/12-autologin.conf
echo "autologin-user=rock" >> /etc/lightdm/lightdm.conf.d/12-autologin.conf
That I needed and now it only takes a single login attempt.
I install ubuntu-mate-minimal through tasksel which is just mate-core
/boot/extlinux/extlinux.conf
timeout 10
menu title select kernel
label kernel-4.4.154-83-rockchip-00023-gae7a309
    kernel /vmlinuz-4.4.154-83-rockchip-00023-gae7a309
    devicetreedir /dtbs/4.4.154-83-rockchip-00023-gae7a309
    append earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 coherent_pool=1m earlyprintk console=ttyS2,1500000n8 rw root=PARTUUID=b921b045-1d rootfstype=ext4 init=/sbin/init rootwait video=1920x1080@60
label kernel-4.4.154-59-rockchip-g5e70f14
    kernel /vmlinuz-4.4.154-59-rockchip-g5e70f14
    devicetreedir /dtbs/4.4.154-59-rockchip-g5e70f14
Appended video=1920x1080@60 to the kernel line and now no white bar and full screen is also perfect.
Cheers
Edit
Nope it worked then on anothervideo came back again?
No that is my monitor it sets the initial console window size also the greeter login
Still got the white bar.
Oooh it is a bit toasty isn’t it :slight_smile:
my solution from here works: Firefox, enable OpenGL and remove whitebar
Doesn’t remove the white bar though?
I have that there to set the console window also its no problem for me as its stopping on a 1080p monitor
But both don’t seem to remove the large white bar that pushes the overall image down off screen
Nope even get it with my usual test vids
http://bbb3d.renderfarming.net/download.html
Yeah ignore me it was just youtube dunno why but after the restart the privacy thing came back
You may recognise :slight_smile:
I think with the heatsink I am just going to get 4 more 20mm Brass Hex posts and put a small blower there as like the m.2 board on top.
Heat sink has holes and presume they are tapped the same as the other side
I think we all got 2 ribbon cables and a confused expression.
Mine is already turning into a FrankenPi :slight_smile:
But with it being on the bottom its sitting on a fairly non thermally conductive wooden table.
I have a 3.5" & 2.5" SSD to a 2 port sata m.2 card to try out tomorrow that is powered via the RockPi4 & 12V supply, so it is never going to be eloquent in looks.
The pillars I just got are 25mm with a 40mm fan than is only 10mm width, the heat sink isn’t that hot, it gets quite toasty but not too hot to touch.
I presume you can mangle the DTS as 2.0Ghz should be possible on the big cores.
"dual 1.8GHz Cortex-72 and qual 1.4GHz Cortex-A53 "
The 1.4 you saw was prob little core speed.
You can check with
sudo watch -n 1  cat /sys/devices/system/cpu/cpu*/cpufreq/cpuinfo_cur_freq
I will test it works struggled to find m.2 sata cards at a decent price so the 2 port is just a test.
PS the chromium dependency is for http://ftp.de.debian.org/debian/pool/main/libj/libjpeg-turbo/libjpeg62-turbo_1.5.1-2_arm64.deb
sudo dpkg -i libjpeg62-turbo_1.5.1-2_arm64.deb was all it needed
The infor you are posting is top quality with great scripts, but just some feedback.
Making raid across eMMc and M.2 just hobnails the M.2 to the slower eMMc.
It would be great if Radxa could make a really cheap and really usefull 128/256mb eMMC module as soldering on nand flash for SPI for a purchase is severe and essentially breaks warranty.
I really love the assembled form factor of the RockPi4, I actually like the heatsink, m.2 extender and think its just brilliant when finished, but for Dev and playing the ribbon on the m.2 and the eMMc under the heatsink can be a proper pain in the ass.
@anon77784915 you got any ideas on how to access SD or eMMc without starting to disassemble there prob is but generally I am used just grabbing the Micro SD putting in a reader and flashing whatever I am playing with.
@raxda you guys got any chance of sourcing a 4 port m.2 sata?
I am not having much look either you any ideas how to force PCIe gen2 training?
LVM is probably an ecumenical matter you any ideas how to force pcie gen2?
Already have but seems to do little both dto & dts are set to gen2
