I wonder if there’s any progress on the peripheral support for the RockPi4. It would not just be great to use standard Pi HATs, but more importantly, it would allow embedded developers to use your product in their designs. Instead of having hobbyists buy 1 or 2, you can have companies buying hundreds, maybe even thousands of RockPi4 units. I’m one of those people. Think about it. Let me know once you have device tree overlays in place.
Ok. Seems there is some progress. Libmraa is present now which solves 50% of my needs. But I2S… I really really need it. Has any work been done on overlays for the I2S interface? Thanks.
Hello
May someone could give the required hints for how to make this work?
What image must or should be used?
Is it ok to use The Armbian image linked at https://wiki.radxa.com/Rockpi4/downloads ?
If not what else: Ubuntu Server? Debian Desktop?
root@rockpi4b:~# sudo apt-get install rockchip-fstab
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
rockchip-fstab
0 upgraded, 1 newly installed, 0 to remove and 131 not upgraded.
Need to get 1,036 B of archives.
After this operation, 0 B of additional disk space will be used.
Get:1 http://apt.radxa.com/stretch stretch/main arm64 rockchip-fstab all 0.1 [1,036 B]
Fetched 1,036 B in 0s (4,701 B/s)
Selecting previously unselected package rockchip-fstab.
(Reading database ... 66131 files and directories currently installed.)
Preparing to unpack .../rockchip-fstab_0.1_all.deb ...
Unpacking rockchip-fstab (0.1) ...
Setting up rockchip-fstab (0.1) ...
sed: -e expression #1, char 0: no previous regular expression
mount all partitions
mount: mount point vfat does not exist
dpkg: error processing package rockchip-fstab (--configure):
subprocess installed post-installation script returned error exit status 32
rockchip-fstab
and then also
root@rockpi4b:~# sudo apt-get install rockpi4-dtbo
rockpi4-dtbo
1 not fully installed or removed.
Need to get 3,040 B of archives.
Get:1 http://apt.radxa.com/stretch stretch/main arm64 rockpi4-dtbo all 1.1 [3,040 B]
Fetched 3,040 B in 0s (14.4 kB/s)
Selecting previously unselected package rockpi4-dtbo.
Preparing to unpack .../rockpi4-dtbo_1.1_all.deb ...
mv: cannot stat '/boot/hw_intfc.conf': No such file or directory
Unpacking rockpi4-dtbo (1.1) ...
Setting up rockpi4-dtbo (1.1) ...
rockchip-fstab
Yeah, I already used the image from armbian website. Already when it was only in beta (support) it worked fine for my needs, and I was able to decompile the dtb file, configure the i2c port, recompile, reboot and it worked fine. Even with 400kHz clockrate.
But the same thing does not work for SPI ports.
As SPI1 is used for the flash, I always tried SPI2.
But there is no /dev/spi* and all my attempts wasn’t successful.
