Hello community,
I’m new to this forum and need some help with my 4x SATA HAT.
Am running a raspi4B 2GB with raspi-OS-lite and OMV6 6.0.14 (Shaitan). Want to run a NAS application.
On the raspi attached is a HAT ‘quad SATA’ from allnetChina.
For the HAT I followed the instructions from wiki-radxa-com site.
I could install the SW by executing the one-liner:
curl -sL https://rock.sh/get-rockpi-sata | sudo -E bash -
After that in OMV6 the SSD is not visible. Looking for it in the terminal fails as well.
I am usinig an internal new SSD 2TB Ultra from SanDisk. Tried it on all of the 4 SATA interfaces of the HAT. LED at the attached connections is ligthing blue permanently when attached.
BTW: does anyone know, what the LEDs and their colors and their kind of flashing or permanent-lighting are indicating? I really miss any kind of documentation for the HW.
Tried to find the SSD with different terminal commands like:
lsusb
lsblk
but cannot find anyting of it.
Running command:
pi@raspberrypi:~ $ systemctl status rockpi-sata.service
● rockpi-sata.service - Rockpi SATA Hat
Loaded: loaded (/lib/systemd/system/rockpi-sata.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2022-02-27 20:06:29 CET; 1min 42s ago
Main PID: 462 (python3)
Tasks: 6 (limit: 1831)
CPU: 3.035s
CGroup: /system.slice/rockpi-sata.service
├─ 462 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
├─1015 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
├─1016 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
├─1017 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
└─1018 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
Feb 27 20:06:29 raspberrypi systemd[1]: Started Rockpi SATA Hat.
pi@raspberrypi:~ $ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
pi@raspberrypi:~ $ blkls
-bash: blkls: Kommando nicht gefunden.
pi@raspberrypi:~ $ lsblk
mmcblk0 179:0 0 29,7G 0 disk
├─mmcblk0p1 179:1 0 256M 0 part /boot
└─mmcblk0p2 179:2 0 29,5G 0 part /
Tried to upgrade anyhow, but failed:
Auflösen des Hostnamens wiki-radxa-com … 128.199.171.129
Verbindungsaufbau zu wiki-radxa-com |128.199.171.129|:443 … verbunden.
HTTP-Anforderung gesendet, auf Antwort wird gewartet … 200 OK
Länge: 434393 (424K) [application/zip]
Wird in »Jms561-fw-update.zip« gespeichert.
Jms561-fw-update.zip 100%[=============================================================================>] 424,21K 364KB/s in 1,2s
2022-02-27 20:09:41 (364 KB/s) - »Jms561-fw-update.zip« gespeichert [434393/434393]
pi@raspberrypi:~ $ unzip Jms561-fw-update.zip
Archive: Jms561-fw-update.zip
creating: jms561-fw-update/
inflating: jms561-fw-update/jms561b_v8.1.3.6.bin
inflating: jms561-fw-update/JMS561FwUpdate
pi@raspberrypi:~ $ cd jms561-fw-update/
pi@raspberrypi:~/jms561-fw-update $ sudo ./JMS561FwUpdate -b backup.bin -f jms561b_v8.1.3.6.bin -d /dev/sda
Backup Firmware file name: backup.bin
Update Firmware file name: jms561b_v8.1.3.6.bin
ERR : open device fail
Get Bridge version FAIL!
Read Back to Backup Error!!
The display on the top PCB is working and showing information as it should.
After searching for similar threads I found some from the year 2020 and 2021, but those could unfortunately not help me so far.
Appreciating any kind of help and hints and of course also the explanation for it, as I want to understand it and learn something!
Does someone knows why I cannot see the SSD?
