I’m playing with the Rockpi 4b and tried to setup a NAS. I plugged a 4Tb usb 3 hardrive. I thought having issues with the hardrive Post here. the hardrive has 100mbps+ on internal copy test, it seems to be a network issue.
I tried samba, rsync, scp and I have 12mbps max when I try to copy.
I thought it was a network bottlneck but I don’t have any issues with a windows 10 shared directories.
I check also on processing issues but smb for example use 52% of one core when I copy.
Does anyone know where to investigate as I’m not an expert on networking optimisation.
Hi gilloub, I guess the network performance depends on many factors.
In the first place it depends on the components involved in your use case.
I tested the network speed of my RockPi 4B with iperf3.
You can install it with sudo apt install iperf3.
The components involved are:
FritzBox 7560 router with GBit LAN connectors
BananaPro with GBit LAN and running Armbian
RockPi 4B with GBit LAN also running Armbian
Everything connected via network cable. WIFI would produce different results.
The results of course depend a lot on what other network components might cause traffic and what else is running on the tested components. In my case I think they were idle and the other network load was neglectable.
I think in your configuration, the bottleneck is the BananaPro or your GbE switch to wire drops a lot. For rockpi4 with a x86 pc, the speed should be higher than 900 Mbits/s, around 940 Mbits/s.
Thanks @jack for the hint!
WIFI was not connected.
Actually, I wanted to show that the Ethernet performance of the RockPi is reasonably good
I didn’t mean to complain about the ~600 MBits/sec.
However, you are right that it is not reaching close to the theoretical limit of 1 GBits/sec.
I need to check if I can repeat the test with a PC or Laptop on GbE.
Thanks guys, really practical the iperf3 command line.
Did some test (wifi and ethernet) I have only 100mbps it’s mainly a network issue on my side. my usb to ethernet adapter was in fact 100mbps (thanks apple). I’ll do some test with a thunderbolt adapter.
With the pi script which might take a small amount of molesting to remove the raspberry specifics if needed gave me this with a integral 120gb ssd on a pi3A+
HDParm Disk Read 28.43 MB/s
HDParm Cached Disk Read 27.62 MB/s
DD Disk Write 34.4 MB/s
FIO 4k random read 2250 IOPS (9002 KB/s)
FIO 4k random write 3370 IOPS (13482 KB/s)
IOZone 4k read 10139 KB/s
IOZone 4k write 9627 KB/s
IOZone 4k random read 8409 KB/s
IOZone 4k random write 10128 KB/s
Score: 2326
Here is the best an A1 SD card would do.
Category Test Result
HDParm Disk Read 22.05 MB/s
HDParm Cached Disk Read 22.06 MB/s
DD Disk Write 19.0 MB/s
FIO 4k random read 2453 IOPS (9813 KB/s)
FIO 4k random write 845 IOPS (3381 KB/s)
IOZone 4k read 8388 KB/s
IOZone 4k write 2731 KB/s
IOZone 4k random read 8238 KB/s
IOZone 4k random write 3855 KB/s
