Just tried to create a NAS with an USB3 WD harddrive, I format the drive (2Tb EXT4 partitions). And try some copy (internal, samba, scp) it can do more than 12mb/s on copy.
I install debian (download radxa img) with default config (disk are automatically mount on /media/linaro). Does any had an external hardrive properly working ?
I also tested my USB3 disk setup according to this post:
I have the RockPi 4B 4GB with a 2 TB, 2" Seagate Barracuda Mobile. It is connected via an ICY Box USB3 SATA Adapter. The drive is formatted with a single ext4 partition. I mounted the disk, cd’ed into some directory on the disk and issued below commands several times. Here I used sudo because my normal user didn’t have write permission in that directory.
I did the hdparam and dd tests give some quite good result
DD test
itime sh -c “dd if=/dev/zero of=/media/linaro/02e9be1f-c05e-451e-99e7-1876eb6523d6/t bs=100k
count=1k && sync” ; rm /media/linaro/02e9be1f-c05e-451e-99e7-1876eb6523d6/t
1024+0 records in
1024+0 records out
104857600 bytes (105 MB, 100 MiB) copied, 0.421859 s, 249 MB/s
hdparm test
hdparm -Tt /dev/sdb
/dev/sdb:
Timing cached reads: 2256 MB in 2.00 seconds = 1128.56 MB/sec
Timing buffered disk reads: 308 MB in 3.01 seconds = 102.29 MB/sec
I have the same result when I copy from internal memory. it seams to be actually network issue my mistake I did internal copy test from an usb stick which is really slow.
