Has anyone tried the bios serial console? I tried to use some adapters and access it, but I can’t have a console.
-checked if tx,rx are inthe wrong pins
-followed the tutorial using the minicom
-checked if the cables are well conected
Anyone got any ideia to try another way to access the bios serial console?
The numbering on the serial adapter board is asymmetric. Try connecting on the other side of the board. I connected. Saw three error messages. I fixed the errors. But I never got to the bios. You might get lucky.)
P.S. I went into bios and turned on the console. It works
Is there other way to access the bios by serial interface? Don’t know if I’m understanding, but you never got to the bios, but after that it worked simple like that?
oh well, so that explains a lot. Please put that info on the serial access console wiki of Rock pi X. I knew the pins were 1.8v, but the bottom interface for serial access I didn’t know.
To be noted…
I also got into BIOS via debug serial.
Same boad and cable, CH340 USB-Serial (5/3.3v capable, not 1.8)
Correct pin numbering is really on opposite side with “1.0mm” silkscreen
And yeah, serial redirection in BIOS turned off by default. May be depends on version.
