pi@rpi-nas:~ $ dmesg
[ 0.000000] Linux version 5.4.35-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1314 SMP Fri May 1 17:47:34 BST 2020
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] On node 0 totalpages: 517632
[ 0.000000] DMA zone: 2304 pages used for memmap
[ 0.000000] HighMem zone: 321024 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s49856 r8192 d23872 u81920
[ 0.000000] pcpu-alloc: s49856 r8192 d23872 u81920 alloc=20*4096
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 515328
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 smsc95xx.macaddr=DC:A6:32:38:C2:29 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000 console=ttyS0,115200 console=tty1 root=PARTUUID=738a4d67-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x19400000-0x1d400000] (64MB)
[ 0.000000] Memory: 1698392K/2070528K available (10240K kernel code, 721K rwdata, 2720K rodata, 2048K init, 853K bss, 109992K reserved, 262144K cma-reserved, 1284096K highmem)
[ 0.000000] ftrace: allocating 29869 entries in 59 pages
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] random: get_random_bytes called from start_kernel+0x340/0x518 with crng_init=0
[ 0.000007] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000031] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000110] bcm2835: system timer (irq = 17)
[ 0.000767] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000787] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000806] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000823] Switching to timer-based delay loop, resolution 18ns
[ 0.001072] Console: colour dummy device 80x30
[ 0.001551] printk: console [tty1] enabled
[ 0.001611] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=540000)
[ 0.001652] pid_max: default: 32768 minimum: 301
[ 0.001977] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002018] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.003203] Disabling memory control group subsystem
[ 0.003319] CPU: Testing write buffer coherency: ok
[ 0.003806] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.004649] Setting up static identity map for 0x200000 - 0x20003c
[ 0.004851] rcu: Hierarchical SRCU implementation.
[ 0.005484] smp: Bringing up secondary CPUs …
[ 0.006631] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.007891] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.009099] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.009242] smp: Brought up 1 node, 4 CPUs
[ 0.009311] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.009336] CPU: All CPU(s) started in HYP mode.
[ 0.009359] CPU: Virtualization extensions available.
[ 0.010132] devtmpfs: initialized
[ 0.022906] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.023163] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.023212] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.031117] pinctrl core: initialized pinctrl subsystem
[ 0.032127] NET: Registered protocol family 16
[ 0.035601] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.037064] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.037099] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.037433] Serial: AMBA PL011 UART driver
[ 0.040983] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.060834] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-05-01 17:55, variant start_cd
[ 0.070849] raspberrypi-firmware soc:firmware: Firmware hash is 688a8f8f3d84e788f07f53c93693e1705f68c407
[ 0.126197] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.130704] vgaarb: loaded
[ 0.131215] SCSI subsystem initialized
[ 0.131450] usbcore: registered new interface driver usbfs
[ 0.131522] usbcore: registered new interface driver hub
[ 0.131652] usbcore: registered new device driver usb
[ 0.133000] clocksource: Switched to clocksource arch_sys_counter
[ 0.882751] VFS: Disk quotas dquot_6.6.0
[ 0.882871] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.883085] FS-Cache: Loaded
[ 0.883277] CacheFiles: Loaded
[ 0.884079] simple-framebuffer: probe of 0.framebuffer failed with error -12
[ 0.893516] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.893866] NET: Registered protocol family 2
[ 0.894612] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.894664] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.894757] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.894844] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.894998] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.895048] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.895300] NET: Registered protocol family 1
[ 0.895995] RPC: Registered named UNIX socket transport module.
[ 0.896024] RPC: Registered udp transport module.
[ 0.896048] RPC: Registered tcp transport module.
[ 0.896073] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.896106] PCI: CLS 0 bytes, default 64
[ 0.897749] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.899934] Initialise system trusted keyrings
[ 0.900164] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 0.910696] FS-Cache: Netfs ‘nfs’ registered for caching
[ 0.911301] NFS: Registering the id_resolver key type
[ 0.911347] Key type id_resolver registered
[ 0.911372] Key type id_legacy registered
[ 0.911405] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.912616] Key type asymmetric registered
[ 0.912644] Asymmetric key parser ‘x509’ registered
[ 0.912821] bounce: pool size: 64 pages
[ 0.912874] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.913141] io scheduler mq-deadline registered
[ 0.913169] io scheduler kyber registered
[ 0.916951] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 0.916993] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 0.917078] brcm-pcie fd500000.pcie: MEM 0x0600000000…0x0603ffffff -> 0x00f8000000
[ 0.917161] brcm-pcie fd500000.pcie: IB MEM 0x0000000000…0x007fffffff -> 0x0000000000
[ 0.955155] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
[ 0.955474] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 0.955507] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.955541] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ 0.955616] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 0.955869] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 0.959193] PCI: bus0: Fast back to back transfers disabled
[ 0.959229] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.959539] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 0.959698] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.960132] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 0.963475] PCI: bus1: Fast back to back transfers disabled
[ 0.963510] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 0.963561] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 0.963597] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 0.963694] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.963729] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 0.964033] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 0.964274] pcieport 0000:00:00.0: PME: Signaling with IRQ 58
[ 0.964667] pcieport 0000:00:00.0: AER: enabled with IRQ 58
[ 0.965001] pci 0000:01:00.0: enabling device (0140 -> 0142)
[ 0.967789] raspberrypi-clk firmware-clocks: CPU frequency range: min 600000000, max 1500000000
[ 0.972175] iproc-rng200 fe104000.rng: hwrng registered
[ 0.972511] vc-mem: phys_addr:0x00000000 mem_base=0x3f000000 mem_size:0x3f600000(1014 MiB)
[ 0.973221] vc-sm: Videocore shared memory driver
[ 0.973775] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 0.985481] brd: module loaded
[ 0.997337] loop: module loaded
[ 0.998343] Loading iSCSI transport class v2.0-870.
[ 1.000273] libphy: Fixed MDIO Bus: probed
[ 1.000857] bcmgenet fd580000.ethernet: failed to get enet clock
[ 1.000891] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.000927] bcmgenet fd580000.ethernet: failed to get enet-wol clock
[ 1.000961] bcmgenet fd580000.ethernet: failed to get enet-eee clock
[ 1.001001] bcmgenet: Skipping UMAC reset
[ 1.013037] libphy: bcmgenet MII bus: probed
[ 1.103101] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.104103] usbcore: registered new interface driver r8152
[ 1.104196] usbcore: registered new interface driver lan78xx
[ 1.104268] usbcore: registered new interface driver smsc95xx
[ 1.104707] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.104755] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.107022] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[ 1.108304] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 1.108342] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.108374] usb usb1: Product: xHCI Host Controller
[ 1.108400] usb usb1: Manufacturer: Linux 5.4.35-v7l+ xhci-hcd
[ 1.108427] usb usb1: SerialNumber: 0000:01:00.0
[ 1.109067] hub 1-0:1.0: USB hub found
[ 1.109172] hub 1-0:1.0: 1 port detected
[ 1.109715] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.109755] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.109796] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.110341] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[ 1.110378] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.110411] usb usb2: Product: xHCI Host Controller
[ 1.110438] usb usb2: Manufacturer: Linux 5.4.35-v7l+ xhci-hcd
[ 1.110465] usb usb2: SerialNumber: 0000:01:00.0
[ 1.111029] hub 2-0:1.0: USB hub found
[ 1.111139] hub 2-0:1.0: 4 ports detected
[ 1.112600] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.112895] dwc_otg: FIQ enabled
[ 1.112907] dwc_otg: NAK holdoff enabled
[ 1.112918] dwc_otg: FIQ split-transaction FSM enabled
[ 1.112932] Module dwc_common_port init
[ 1.113264] usbcore: registered new interface driver uas
[ 1.113386] usbcore: registered new interface driver usb-storage
[ 1.113599] mousedev: PS/2 mouse device common for all mice
[ 1.115469] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.117805] sdhci: Secure Digital Host Controller Interface driver
[ 1.117834] sdhci: Copyright© Pierre Ossman
[ 1.118413] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 1.118985] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.122649] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.122809] hidraw: raw HID events driver © Jiri Kosina
[ 1.122957] usbcore: registered new interface driver usbhid
[ 1.123025] usbhid: USB HID core driver
[ 1.123987] vchiq: vchiq_init_state: slot_zero = (ptrval)
[ 1.125827] [vc_sm_connected_init]: start
[ 1.130282] vc_vchi_sm_init: failed to open VCHI service (-1)
[ 1.130289] [vc_sm_connected_init]: failed to initialize shared memory service
[ 1.130338] [vc_sm_connected_init]: end - returning -1
[ 1.132452] Initializing XFRM netlink socket
[ 1.132502] NET: Registered protocol family 17
[ 1.132634] Key type dns_resolver registered
[ 1.132892] Registering SWP/SWPB emulation handler
[ 1.133258] registered taskstats version 1
[ 1.133290] Loading compiled-in X.509 certificates
[ 1.133415] Key type ._fscrypt registered
[ 1.133440] Key type .fscrypt registered
[ 1.145149] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.145237] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2
[ 1.151039] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.151792] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[ 1.152751] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.152781] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.204716] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.206375] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.208030] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.210976] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.212626] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.220161] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 1.223123] of_cfs_init
[ 1.223382] of_cfs_init: OK
[ 1.224972] Waiting for root device PARTUUID=738a4d67-02…
[ 1.256826] random: fast init done
[ 1.290455] mmc1: new high speed SDIO card at address 0001
[ 1.333805] mmc0: new ultra high speed DDR50 SDHC card at address 59b4
[ 1.334718] mmcblk0: mmc0:59b4 EB2MW 29.8 GiB
[ 1.336726] mmcblk0: p1 p2
[ 1.345889] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 1.345926] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 1.353569] EXT4-fs (mmcblk0p2): recovery complete
[ 1.449283] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.449369] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.454905] devtmpfs: mounted
[ 1.462805] Freeing unused kernel memory: 2048K
[ 1.463140] Run /sbin/init as init process
[ 1.473042] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.506039] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.506080] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.506110] usb 1-1: Product: USB2.0 Hub
[ 1.507980] hub 1-1:1.0: USB hub found
[ 1.508280] hub 1-1:1.0: 4 ports detected
[ 1.923427] systemd[1]: System time before build time, advancing clock.
[ 2.029449] NET: Registered protocol family 10
[ 2.030739] Segment Routing with IPv6
[ 2.067507] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.068383] systemd[1]: Detected architecture arm.
[ 2.146323] systemd[1]: Set hostname to .
[ 2.608682] random: lvmconfig: uninitialized urandom read (4 bytes read)
[ 3.262758] systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
[ 3.329002] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.350863] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.356053] systemd[1]: Listening on Syslog Socket.
[ 3.357306] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 3.358515] systemd[1]: Listening on Journal Socket.
[ 3.366684] systemd[1]: Mounting Kernel Debug File System…
[ 3.375008] systemd[1]: Starting Restore / save the current clock…
[ 3.376949] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 3.526489] Installing knfsd (copyright © 1996 okir@monad.swb.de).
[ 3.616380] i2c /dev entries driver
[ 4.111662] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.210149] systemd-journald[137]: Received request to flush runtime journal from PID 1
[ 4.786620] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 4.787082] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 4.787509] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 4.787905] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 4.791930] Driver for 1-wire Dallas network protocol.
[ 4.805001] gpio-4 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 4.822722] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.824966] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 4.824987] [vc_sm_connected_init]: start
[ 4.827903] vc_sm_cma_vchi_init: failed to open VCHI service (-1)
[ 4.827912] [vc_sm_connected_init]: failed to initialize shared memory service
[ 4.859311] w1_master_driver w1_bus_master1: Attaching one wire slave 28.00000bd45e38 crc ab
[ 4.861069] mc: Linux media interface: v0.10
[ 4.864546] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.908181] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 4.954598] videodev: Linux video capture interface: v2.00
[ 4.991597] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.991793] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.998149] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.003286] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.003815] bcm2835_mmal_vchiq: Failed to open VCHI service connection (status=-1)
[ 5.009811] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.013250] bcm2835_mmal_vchiq: Failed to open VCHI service connection (status=-1)
[ 5.033961] bcm2835_mmal_vchiq: Failed to open VCHI service connection (status=-1)
[ 5.174630] bcmgenet: Skipping UMAC reset
[ 5.178014] bcmgenet fd580000.ethernet: configuring instance for external RGMII
[ 5.178406] bcmgenet fd580000.ethernet eth0: Link is Down
[ 5.266063] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.328787] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 5.368109] [drm] No displays found. Consider forcing hotplug if HDMI is attached
[ 5.368231] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 5.368254] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 5.368266] [drm] No driver support for vblank timestamp query.
[ 5.368277] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[ 5.370938] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 5.507871] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 5.566810] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 5.579642] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.580523] usbcore: registered new interface driver brcmfmac
[ 5.600913] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
[ 5.828587] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.845594] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 2 2020 23:30:41 version 7.45.202 (r724630 CY) FWID 01-72f6ece2
[ 9.257057] uart-pl011 fe201000.serial: no DMA platform data
[ 9.703166] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 10.393249] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 10.393295] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 11.123105] random: crng init done
[ 11.123141] random: 7 urandom warning(s) missed due to ratelimiting
[ 11.487925] NFSD: Using UMH upcall client tracking operations.
[ 11.487945] NFSD: starting 90-second grace period (net f0000049)
[ 16.118381] Bluetooth: Core ver 2.22
[ 16.118462] NET: Registered protocol family 31
[ 16.118476] Bluetooth: HCI device and connection manager initialized
[ 16.118516] Bluetooth: HCI socket layer initialized
[ 16.118536] Bluetooth: L2CAP socket layer initialized
[ 16.118569] Bluetooth: SCO socket layer initialized
[ 16.157557] Bluetooth: HCI UART driver ver 2.3
[ 16.157576] Bluetooth: HCI UART protocol H4 registered
[ 16.157657] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 16.157949] Bluetooth: HCI UART protocol Broadcom registered
[ 16.540607] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 16.540624] Bluetooth: BNEP filters: protocol multicast
[ 16.540651] Bluetooth: BNEP socket layer initialized
[ 19.283750] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 19.315130] usb 2-2: New USB device found, idVendor=1058, idProduct=0a10, bcdDevice=80.34
[ 19.315175] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 19.315192] usb 2-2: Product: Go To Final Lap
[ 19.315207] usb 2-2: SerialNumber: 1234567890123
[ 19.352973] scsi host0: uas
[ 19.354868] scsi 0:0:0:0: Direct-Access ACASIS 8034 PQ: 0 ANSI: 6
[ 19.357529] sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 19.357836] sd 0:0:0:0: [sda] Write Protect is off
[ 19.357854] sd 0:0:0:0: [sda] Mode Sense: 67 00 10 08
[ 19.358313] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 19.359119] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
[ 19.547203] sda: sda1
[ 19.547977] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 19.556038] sd 0:0:0:0: [sda] Attached SCSI disk
[ 20.503546] usb 2-1: new SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 20.535144] usb 2-1: New USB device found, idVendor=1058, idProduct=0a10, bcdDevice=80.34
[ 20.535165] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 20.535181] usb 2-1: Product: Go To Final Lap
[ 20.535196] usb 2-1: SerialNumber: 1234567890123
[ 20.594470] scsi host1: uas
[ 20.603878] scsi 1:0:0:0: Direct-Access ACASIS 8034 PQ: 0 ANSI: 6
[ 20.606600] sd 1:0:0:0: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 20.606892] sd 1:0:0:0: [sdb] Write Protect is off
[ 20.606910] sd 1:0:0:0: [sdb] Mode Sense: 67 00 10 08
[ 20.607394] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 20.608276] sd 1:0:0:0: [sdb] Optimal transfer size 33553920 bytes
[ 20.623615] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 20.697864] sdb: sdb1
[ 20.701560] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 26.000047] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,acl
[ 27.341646] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,acl
