Ok got some disks 4x Integral SSD 120gb P5 as that should been the card is the bottleneck.
Couldn’t afford anything more really as x4 gets a bit expensive.
Staring with Debian-stretch-4.4-latest and mdadm going to try a raid10
Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
Output is in kBytes/sec
random random bkwd record stride
kB reclen write rewrite read reread read write read rewrite read fwrite frewrite fread freread
102400 4 20355 28533 43513 44568 22556 28612
102400 16 60835 71891 111520 107540 66074 71640
102400 512 149988 129385 253123 263113 211684 131649
102400 1024 161360 164943 274007 275765 253893 165764
102400 16384 181646 182851 338294 347395 342601 176768
rock@rockpi4:~$ cat /proc/mdstat
Personalities : [raid0] [raid10]
md0 : active raid10 sdd[3] sdc[2] sdb[1] sda[0]
234309632 blocks super 1.2 512K chunks 2 near-copies [4/4] [UUUU]
[===========>.........] resync = 55.4% (129931520/234309632) finish=8.5min speed=202624K/sec
bitmap: 2/2 pages [8KB], 65536KB chunk
Jul 4 13:46:45 rockpi4 kernel: [ 75.172062] md0: detected capacity change from 479866126336 to 0
Jul 4 13:46:45 rockpi4 kernel: [ 75.172628] md: md0 stopped.
Jul 4 13:46:45 rockpi4 kernel: [ 75.173397] md: unbind<sda>
Jul 4 13:46:45 rockpi4 kernel: [ 75.190852] md: export_rdev(sda)
Jul 4 13:46:45 rockpi4 kernel: [ 75.191282] md: unbind<sdd>
Jul 4 13:46:45 rockpi4 kernel: [ 75.206849] md: export_rdev(sdd)
Jul 4 13:46:45 rockpi4 kernel: [ 75.207325] md: unbind<sdb>
Jul 4 13:46:45 rockpi4 udisksd[565]: Unable to resolve /sys/devices/virtual/block/md0/md/dev-sdb/block symlink
Jul 4 13:46:45 rockpi4 kernel: [ 75.239056] md: export_rdev(sdb)
Jul 4 13:46:45 rockpi4 kernel: [ 75.239439] md: unbind<sdc>
Jul 4 13:46:45 rockpi4 kernel: [ 75.254837] md: export_rdev(sdc)
Jul 4 13:47:12 rockpi4 kernel: [ 102.258308] sdc: sdc1 sdc2
Jul 4 13:47:12 rockpi4 kernel: [ 102.288150] sdc: sdc1 sdc2
Jul 4 13:48:09 rockpi4 kernel: [ 159.300017] md: bind<sda>
Jul 4 13:48:09 rockpi4 kernel: [ 159.308923] md: bind<sdb>
Jul 4 13:48:09 rockpi4 kernel: [ 159.319055] md: bind<sdc>
Jul 4 13:48:09 rockpi4 kernel: [ 159.320188] md: bind<sdd>
Jul 4 13:48:09 rockpi4 kernel: [ 159.326830] md/raid0:md0: md_size is 937238528 sectors.
Jul 4 13:48:09 rockpi4 kernel: [ 159.327314] md: RAID0 configuration for md0 - 1 zone
Jul 4 13:48:09 rockpi4 kernel: [ 159.327759] md: zone0=[sda/sdb/sdc/sdd]
Jul 4 13:48:09 rockpi4 kernel: [ 159.328165] zone-offset= 0KB, device-offset= 0KB, size= 468619264KB
Jul 4 13:48:09 rockpi4 kernel: [ 159.328937] sdc: sdc1 sdc2
Jul 4 13:48:09 rockpi4 kernel: [ 159.329369]
Jul 4 13:48:09 rockpi4 kernel: [ 159.330145] md0: detected capacity change from 0 to 479866126336
Jul 4 13:48:09 rockpi4 udisksd[565]: Error creating watch for file /sys/devices/virtual/block/md0/md/sync_action: No such file or directory (g-file-error-quark, 4)
Jul 4 13:48:09 rockpi4 udisksd[565]: Error creating watch for file /sys/devices/virtual/block/md0/md/degraded: No such file or directory (g-file-error-quark, 4)
Jul 4 13:49:40 rockpi4 kernel: [ 250.355809] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
Jul 4 13:55:31 rockpi4 kernel: [ 601.335494] panel disable
Jul 4 14:02:26 rockpi4 anacron[1047]: Anacron 2.3 started on 2019-07-04
Jul 4 14:02:26 rockpi4 anacron[1047]: Normal exit (0 jobs run)
Jul 4 14:02:59 rockpi4 kernel: [ 1049.309314] md0: detected capacity change from 479866126336 to 0
Jul 4 14:02:59 rockpi4 kernel: [ 1049.309886] md: md0 stopped.
Jul 4 14:02:59 rockpi4 kernel: [ 1049.310176] md: unbind<sdd>
Jul 4 14:02:59 rockpi4 kernel: [ 1049.327147] md: export_rdev(sdd)
Jul 4 14:02:59 rockpi4 kernel: [ 1049.327821] md: unbind<sdc>
Jul 4 14:02:59 rockpi4 kernel: [ 1049.350959] md: export_rdev(sdc)
Jul 4 14:02:59 rockpi4 kernel: [ 1049.351512] md: unbind<sdb>
Jul 4 14:02:59 rockpi4 udisksd[565]: Unable to resolve /sys/devices/virtual/block/md0/md/dev-sdb/block symlink
Jul 4 14:02:59 rockpi4 kernel: [ 1049.366971] md: export_rdev(sdb)
Jul 4 14:02:59 rockpi4 kernel: [ 1049.367513] md: unbind<sda>
Jul 4 14:02:59 rockpi4 kernel: [ 1049.383124] md: export_rdev(sda)
Jul 4 14:03:21 rockpi4 kernel: [ 1071.066678] sdc: sdc1 sdc2
Jul 4 14:03:21 rockpi4 kernel: [ 1071.092394] sdc: sdc1 sdc2
Jul 4 14:05:23 rockpi4 kernel: [ 1193.551804] md: bind<sda>
Jul 4 14:05:23 rockpi4 kernel: [ 1193.552267] sdc: sdc1 sdc2
Jul 4 14:05:23 rockpi4 kernel: [ 1193.552547] md: bind<sdb>
Jul 4 14:05:23 rockpi4 kernel: [ 1193.553780] md: bind<sdc>
Jul 4 14:05:23 rockpi4 kernel: [ 1193.554266] md: bind<sdd>
Jul 4 14:05:23 rockpi4 kernel: [ 1193.570556] md: raid10 personality registered for level 10
Jul 4 14:05:23 rockpi4 kernel: [ 1193.573138] md/raid10:md0: not clean -- starting background reconstruction
Jul 4 14:05:23 rockpi4 kernel: [ 1193.573765] md/raid10:md0: active with 4 out of 4 devices
Jul 4 14:05:23 rockpi4 kernel: [ 1193.575635] created bitmap (2 pages) for device md0
Jul 4 14:05:23 rockpi4 kernel: [ 1193.578102] md0: bitmap initialized from disk: read 1 pages, set 3576 of 3576 bits
Jul 4 14:05:23 rockpi4 kernel: [ 1193.581797] md0: detected capacity change from 0 to 239933063168
Jul 4 14:05:23 rockpi4 kernel: [ 1193.583297] md: md0 switched to read-write mode.
Jul 4 14:05:23 rockpi4 kernel: [ 1193.588652] md: resync of RAID array md0
Jul 4 14:05:23 rockpi4 kernel: [ 1193.589019] md: minimum _guaranteed_ speed: 1000 KB/sec/disk.
Jul 4 14:05:23 rockpi4 kernel: [ 1193.589541] md: using maximum available idle IO bandwidth (but not more than 200000 KB/sec) for resync.
Jul 4 14:05:23 rockpi4 kernel: [ 1193.590381] md: using 128k window, over a total of 234309632k.
Jul 4 14:25:02 rockpi4 kernel: [ 2372.292473] md: md0: resync done.
Jul 4 14:25:02 rockpi4 kernel: [ 2372.452970] RAID10 conf printout:
Jul 4 14:25:02 rockpi4 kernel: [ 2372.452989] --- wd:4 rd:4
Jul 4 14:25:02 rockpi4 kernel: [ 2372.452998] disk 0, wo:0, o:1, dev:sda
Jul 4 14:25:02 rockpi4 kernel: [ 2372.453005] disk 1, wo:0, o:1, dev:sdb
Jul 4 14:25:02 rockpi4 kernel: [ 2372.453012] disk 2, wo:0, o:1, dev:sdc
Jul 4 14:25:02 rockpi4 kernel: [ 2372.453019] disk 3, wo:0, o:1, dev:sdd
Jul 4 14:30:45 rockpi4 kernel: [ 2715.470782] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
RAID5
rock@rockpi4:~$ sudo mdadm --create --verbose /dev/md0 --level=5 --raid-devices=4 /dev/sda /dev/sdb /dev/sdc /dev/sdd
mdadm: layout defaults to left-symmetric
mdadm: chunk size defaults to 512K
mdadm: /dev/sdc appears to be part of a raid array:
level=raid0 devices=0 ctime=Thu Jan 1 00:00:00 1970
mdadm: partition table exists on /dev/sdc but will be lost or
meaningless after creating array
mdadm: size set to 117154816K
mdadm: automatically enabling write-intent bitmap on large array
Continue creating array? y
mdadm: Defaulting to version 1.2 metadata
mdadm: array /dev/md0 started.
Personalities : [raid10] [raid6] [raid5] [raid4]
md0 : active raid5 sdd[4] sdc[2] sdb[1] sda[0]
351464448 blocks super 1.2 level 5, 512k chunk, algorithm 2 [4/3] [UUU_]
[>....................] recovery = 1.6% (1898560/117154816) finish=19.2min speed=99924K/sec
bitmap: 0/1 pages [0KB], 65536KB chunk
Jul 4 14:49:52 rockpi4 kernel: [ 491.913061] md: bind<sda>
Jul 4 14:49:52 rockpi4 kernel: [ 491.913784] md: bind<sdb>
Jul 4 14:49:52 rockpi4 kernel: [ 491.914381] md: bind<sdc>
Jul 4 14:49:52 rockpi4 kernel: [ 491.914971] md: bind<sdd>
Jul 4 14:49:52 rockpi4 kernel: [ 491.920396] sdc: sdc1 sdc2
Jul 4 14:49:52 rockpi4 kernel: [ 491.929530] async_tx: api initialized (async)
Jul 4 14:49:52 rockpi4 kernel: [ 491.952339] md: raid6 personality registered for level 6
Jul 4 14:49:52 rockpi4 kernel: [ 491.952833] md: raid5 personality registered for level 5
Jul 4 14:49:52 rockpi4 kernel: [ 491.953316] md: raid4 personality registered for level 4
Jul 4 14:49:52 rockpi4 kernel: [ 491.959926] md/raid:md0: device sdc operational as raid disk 2
Jul 4 14:49:52 rockpi4 kernel: [ 491.960484] md/raid:md0: device sdb operational as raid disk 1
Jul 4 14:49:52 rockpi4 kernel: [ 491.961025] md/raid:md0: device sda operational as raid disk 0
Jul 4 14:49:52 rockpi4 kernel: [ 491.962943] md/raid:md0: allocated 4384kB
Jul 4 14:49:52 rockpi4 kernel: [ 491.964488] md/raid:md0: raid level 5 active with 3 out of 4 devices, algorithm 2
Jul 4 14:49:52 rockpi4 kernel: [ 491.965161] RAID conf printout:
Jul 4 14:49:52 rockpi4 kernel: [ 491.965169] --- level:5 rd:4 wd:3
Jul 4 14:49:52 rockpi4 kernel: [ 491.965177] disk 0, o:1, dev:sda
Jul 4 14:49:52 rockpi4 kernel: [ 491.965183] disk 1, o:1, dev:sdb
Jul 4 14:49:52 rockpi4 kernel: [ 491.965188] disk 2, o:1, dev:sdc
Jul 4 14:49:52 rockpi4 kernel: [ 491.965603] created bitmap (1 pages) for device md0
Jul 4 14:49:52 rockpi4 kernel: [ 491.966746] md0: bitmap initialized from disk: read 1 pages, set 1788 of 1788 bits
Jul 4 14:49:52 rockpi4 kernel: [ 491.968765] md0: detected capacity change from 0 to 359899594752
Jul 4 14:49:52 rockpi4 kernel: [ 491.969465] md: md0 switched to read-write mode.
Jul 4 14:49:52 rockpi4 kernel: [ 491.969930] RAID conf printout:
Jul 4 14:49:52 rockpi4 kernel: [ 491.969951] --- level:5 rd:4 wd:3
Jul 4 14:49:52 rockpi4 kernel: [ 491.969968] disk 0, o:1, dev:sda
Jul 4 14:49:52 rockpi4 kernel: [ 491.969984] disk 1, o:1, dev:sdb
Jul 4 14:49:52 rockpi4 kernel: [ 491.969997] disk 2, o:1, dev:sdc
Jul 4 14:49:52 rockpi4 kernel: [ 491.970009] disk 3, o:1, dev:sdd
Jul 4 14:49:52 rockpi4 kernel: [ 491.980149] md: recovery of RAID array md0
Jul 4 14:49:52 rockpi4 kernel: [ 491.980523] md: minimum _guaranteed_ speed: 1000 KB/sec/disk.
Jul 4 14:49:52 rockpi4 kernel: [ 491.981044] md: using maximum available idle IO bandwidth (but not more than 200000 KB/sec) for recovery.
Jul 4 14:49:52 rockpi4 kernel: [ 491.981894] md: using 128k window, over a total of 117154816k.
Jul 4 14:51:41 rockpi4 kernel: [ 601.050246] panel disable
Jul 4 15:00:30 rockpi4 anacron[1052]: Anacron 2.3 started on 2019-07-04
Jul 4 15:00:30 rockpi4 anacron[1052]: Normal exit (0 jobs run)
Jul 4 15:05:53 rockpi4 kernel: [ 1453.287257] md: md0: recovery done.
Jul 4 15:05:53 rockpi4 kernel: [ 1453.567652] RAID conf printout:
Jul 4 15:05:53 rockpi4 kernel: [ 1453.567661] --- level:5 rd:4 wd:4
Jul 4 15:05:53 rockpi4 kernel: [ 1453.567666] disk 0, o:1, dev:sda
Jul 4 15:05:53 rockpi4 kernel: [ 1453.567670] disk 1, o:1, dev:sdb
Jul 4 15:05:53 rockpi4 kernel: [ 1453.567674] disk 2, o:1, dev:sdc
Jul 4 15:05:53 rockpi4 kernel: [ 1453.567677] disk 3, o:1, dev:sdd
Jul 4 15:07:07 rockpi4 kernel: [ 1527.108599] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
102400 4 8159 8947 43789 42643 24543 10212
102400 16 33078 40985 98244 98407 70763 41851
102400 512 52870 53418 212184 202157 203772 50657
102400 1024 66426 69555 250660 250200 249607 69539
102400 16384 108537 112300 326090 324173 320777 106363
RAID1
rock@rockpi4:~$ sudo mdadm --create --verbose /dev/md0 --level=1 --raid-devices=2 /dev/sda /dev/sdb
mdadm: Note: this array has metadata at the start and
may not be suitable as a boot device. If you plan to
store '/boot' on this device please ensure that
your boot-loader understands md/v1.x metadata, or use
--metadata=0.90
mdadm: size set to 117155264K
Personalities : [raid10] [raid6] [raid5] [raid4] [raid1]
md0 : active raid1 sdb[1] sda[0]
117155264 blocks super 1.2 [2/2] [UU]
[>....................] resync = 2.3% (2801408/117155264) finish=8.8min speed=215492K/sec
bitmap: 1/1 pages [4KB], 65536KB chunk
unused devices: <none>
Jul 4 15:20:25 rockpi4 kernel: [ 2324.757953] md: bind<sda>
Jul 4 15:20:25 rockpi4 kernel: [ 2324.759742] md: bind<sdb>
Jul 4 15:20:25 rockpi4 kernel: [ 2324.772561] md: raid1 personality registered for level 1
Jul 4 15:20:25 rockpi4 kernel: [ 2324.783910] md/raid1:md0: not clean -- starting background reconstruction
Jul 4 15:20:25 rockpi4 kernel: [ 2324.784534] md/raid1:md0: active with 2 out of 2 mirrors
Jul 4 15:20:25 rockpi4 kernel: [ 2324.785261] created bitmap (1 pages) for device md0
Jul 4 15:20:25 rockpi4 kernel: [ 2324.787956] md0: bitmap initialized from disk: read 1 pages, set 1788 of 1788 bits
Jul 4 15:20:25 rockpi4 kernel: [ 2324.790798] md0: detected capacity change from 0 to 119966990336
Jul 4 15:20:25 rockpi4 kernel: [ 2324.791556] md: md0 switched to read-write mode.
Jul 4 15:20:25 rockpi4 kernel: [ 2324.794162] md: resync of RAID array md0
Jul 4 15:20:25 rockpi4 kernel: [ 2324.794546] md: minimum _guaranteed_ speed: 1000 KB/sec/disk.
Jul 4 15:20:25 rockpi4 kernel: [ 2324.795124] md: using maximum available idle IO bandwidth (but not more than 200000 KB/sec) for resync.
Jul 4 15:20:25 rockpi4 kernel: [ 2324.795964] md: using 128k window, over a total of 117155264k.
Jul 4 15:30:14 rockpi4 kernel: [ 2913.737079] md: md0: resync done.
Jul 4 15:30:14 rockpi4 kernel: [ 2913.745998] RAID1 conf printout:
Jul 4 15:30:14 rockpi4 kernel: [ 2913.746016] --- wd:2 rd:2
Jul 4 15:30:14 rockpi4 kernel: [ 2913.746027] disk 0, wo:0, o:1, dev:sda
Jul 4 15:30:14 rockpi4 kernel: [ 2913.746035] disk 1, wo:0, o:1, dev:sdb
Jul 4 15:31:19 rockpi4 kernel: [ 2978.675630] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
102400 4 24759 31559 39765 41196 25476 30710
102400 16 62662 73245 124756 125744 62209 72778
102400 512 139397 160038 260433 261606 218154 147652
102400 1024 165815 155189 258119 261744 232643 164702
102400 16384 172905 186702 318211 322998 321997 170680
RAID0
rock@rockpi4:~$ sudo mdadm --create --verbose /dev/md0 --level=0 --raid-devices=4 /dev/sda /dev/sdb /dev/sdc /dev/sdd
Personalities : [raid10] [raid6] [raid5] [raid4] [raid1] [raid0]
md0 : active raid0 sdd[3] sdc[2] sdb[1] sda[0]
468619264 blocks super 1.2 512k chunks
Jul 4 15:38:35 rockpi4 kernel: [ 3415.084442] md: bind<sda>
Jul 4 15:38:35 rockpi4 kernel: [ 3415.085523] md: bind<sdb>
Jul 4 15:38:35 rockpi4 kernel: [ 3415.086511] md: bind<sdc>
Jul 4 15:38:35 rockpi4 kernel: [ 3415.087930] md: bind<sdd>
Jul 4 15:38:35 rockpi4 kernel: [ 3415.101830] md: raid0 personality registered for level 0
Jul 4 15:38:35 rockpi4 kernel: [ 3415.101836] sdc: sdc1 sdc2
Jul 4 15:38:35 rockpi4 kernel: [ 3415.107953] md/raid0:md0: md_size is 937238528 sectors.
Jul 4 15:38:35 rockpi4 kernel: [ 3415.108427] md: RAID0 configuration for md0 - 1 zone
Jul 4 15:38:35 rockpi4 kernel: [ 3415.108866] md: zone0=[sda/sdb/sdc/sdd]
Jul 4 15:38:35 rockpi4 kernel: [ 3415.109261] zone-offset= 0KB, device-offset= 0KB, size= 468619264KB
Jul 4 15:38:35 rockpi4 kernel: [ 3415.109973]
Jul 4 15:38:35 rockpi4 kernel: [ 3415.110235] md0: detected capacity change from 0 to 479866126336
Jul 4 15:38:35 rockpi4 udisksd[572]: Error creating watch for file /sys/devices/virtual/block/md0/md/sync_action: No such file or directory (g-file-error-quark, 4)
Jul 4 15:38:35 rockpi4 udisksd[572]: Error creating watch for file /sys/devices/virtual/block/md0/md/degraded: No such file or directory (g-file-error-quark, 4)
Jul 4 15:41:08 rockpi4 kernel: [ 3568.278677] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
102400 4 31874 42784 44859 48796 26191 42465
102400 16 89104 112188 110570 114486 77652 111816
102400 512 248787 259180 258800 270097 227197 229707
102400 1024 309271 324243 293455 293122 268819 286143
102400 16384 373574 382208 324869 326204 326070 380622
Concurrent single disks
Command line used: iozone -l 4 -u 4 -r 16k -s 512M -F /home/rock/sda/tmp1 /home/rock/sdb/tmp2 /home/rock/sdc/tmp3 /home/rock/sdd/tmp4
Min process = 4
Max process = 4
Throughput test with 4 processes
Each process writes a 524288 kByte file in 16 kByte records
Children see throughput for 4 initial writers = 468982.85 kB/sec
Parent sees throughput for 4 initial writers = 391562.16 kB/sec
Min throughput per process = 115979.48 kB/sec
Max throughput per process = 118095.79 kB/sec
Avg throughput per process = 117245.71 kB/sec
Min xfer = 513488.00 kB
Children see throughput for 4 rewriters = 448753.70 kB/sec
Parent sees throughput for 4 rewriters = 378103.46 kB/sec
Min throughput per process = 108174.91 kB/sec
Max throughput per process = 119841.15 kB/sec
Avg throughput per process = 112188.42 kB/sec
Min xfer = 472992.00 kB
Children see throughput for 4 readers = 319857.60 kB/sec
Parent sees throughput for 4 readers = 319587.93 kB/sec
Min throughput per process = 78386.40 kB/sec
Max throughput per process = 81170.33 kB/sec
Avg throughput per process = 79964.40 kB/sec
Min xfer = 506336.00 kB
Children see throughput for 4 re-readers = 331737.53 kB/sec
Parent sees throughput for 4 re-readers = 331539.26 kB/sec
Min throughput per process = 74617.11 kB/sec
Max throughput per process = 90278.13 kB/sec
Avg throughput per process = 82934.38 kB/sec
Min xfer = 433360.00 kB
Children see throughput for 4 reverse readers = 769042.86 kB/sec
Parent sees throughput for 4 reverse readers = 768023.53 kB/sec
Min throughput per process = 43320.77 kB/sec
Max throughput per process = 262961.66 kB/sec
Avg throughput per process = 192260.72 kB/sec
Min xfer = 86384.00 kB
Children see throughput for 4 stride readers = 1795856.09 kB/sec
Parent sees throughput for 4 stride readers = 1781767.61 kB/sec
Min throughput per process = 65569.88 kB/sec
Max throughput per process = 920383.50 kB/sec
Avg throughput per process = 448964.02 kB/sec
Min xfer = 37360.00 kB
Children see throughput for 4 random readers = 1971409.70 kB/sec
Parent sees throughput for 4 random readers = 1958188.18 kB/sec
Min throughput per process = 69869.92 kB/sec
Max throughput per process = 861175.75 kB/sec
Avg throughput per process = 492852.43 kB/sec
Min xfer = 41904.00 kB
Children see throughput for 4 mixed workload = 1176863.17 kB/sec
Parent sees throughput for 4 mixed workload = 275991.88 kB/sec
Min throughput per process = 98414.23 kB/sec
Max throughput per process = 606498.81 kB/sec
Avg throughput per process = 294215.79 kB/sec
Min xfer = 84304.00 kB
Children see throughput for 4 random writers = 428459.84 kB/sec
Parent sees throughput for 4 random writers = 318774.34 kB/sec
Min throughput per process = 96696.56 kB/sec
Max throughput per process = 118440.29 kB/sec
Avg throughput per process = 107114.96 kB/sec
Min xfer = 428352.00 kB
Children see throughput for 4 pwrite writers = 467800.79 kB/sec
Parent sees throughput for 4 pwrite writers = 381736.33 kB/sec
Min throughput per process = 111798.68 kB/sec
Max throughput per process = 120814.23 kB/sec
Avg throughput per process = 116950.20 kB/sec
Min xfer = 485168.00 kB
Children see throughput for 4 pread readers = 309714.87 kB/sec
Parent sees throughput for 4 pread readers = 309501.91 kB/sec
Min throughput per process = 76447.56 kB/sec
Max throughput per process = 79120.13 kB/sec
Avg throughput per process = 77428.72 kB/sec
Min xfer = 506592.00 kB
Children see throughput for 4 fwriters = 442763.85 kB/sec
Parent sees throughput for 4 fwriters = 373418.60 kB/sec
Min throughput per process = 107828.45 kB/sec
Max throughput per process = 114495.70 kB/sec
Avg throughput per process = 110690.96 kB/sec
Min xfer = 524288.00 kB
Children see throughput for 4 freaders = 331765.48 kB/sec
Parent sees throughput for 4 freaders = 325459.39 kB/sec
Min throughput per process = 81387.83 kB/sec
Max throughput per process = 86099.32 kB/sec
Avg throughput per process = 82941.37 kB/sec
single disk sda
102400 4 36038 45031 52457 52672 27342 44553
102400 16 93224 115531 124822 114115 79868 115219
102400 512 249415 223799 267595 273488 227651 258480
102400 1024 259449 236700 268852 273148 242803 266988
102400 16384 313281 317096 324922 325600 319687 267843
single disk sdb
102400 4 33918 45021 52628 52655 27404 44621
102400 16 100152 106531 127148 115452 76579 113503
102400 512 251035 259812 272338 273634 227332 225607
102400 1024 260791 268019 273578 276074 241042 268323
102400 16384 267448 316877 323467 324679 319983 316710
single disk sdc
102400 4 36074 44819 52358 52592 23334 44073
102400 16 92510 114568 127346 126830 72293 112819
102400 512 220032 260191 271136 274745 225818 258574
102400 1024 258895 228236 270047 271946 239184 267370
102400 16384 312151 316425 318919 323689 317570 268308
single disk sdd
102400 4 36100 44939 52756 52768 27569 42697
102400 16 100207 111073 127120 118992 76555 105342
102400 512 248869 259052 271718 272745 227450 258252
102400 1024 226653 266979 262772 265104 236617 266018
102400 16384 314211 269062 322937 325634 320150 315470
