Hi Lin,
Yes, the is not power, I tried with a 12VCD 5A Power supply and the problem remains.
This is the dmesg details right after the system starts up with 2TB HDD:
[ 0.000000] Linux version 5.4.79-v7l+ (dom@buildbot) (gcc version 8.4.0 (Ubuntu/Linaro 8.4.0-3ubuntu1)) #1373 SMP Mon Nov 23 13:27:40 GMT 2020
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] On node 0 totalpages: 1012736
[ 0.000000] DMA zone: 2304 pages used for memmap
[ 0.000000] HighMem zone: 816128 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s49804 r8192 d23924 u81920
[ 0.000000] pcpu-alloc: s49804 r8192 d23924 u81920 alloc=20*4096
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1010432
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1280x720M@60 smsc95xx.macaddr=DC:A6:32:7D:9A:04 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=d93ce22a-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x17cc0000-0x1bcc0000] (64MB)
[ 0.000000] Memory: 3655600K/4050944K available (10240K kernel code, 739K rwdata, 2816K rodata, 2048K init, 854K bss, 133200K reserved, 262144K cma-reserved, 3264512K highmem)
[ 0.000000] ftrace: allocating 31111 entries in 61 pages
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] random: get_random_bytes called from start_kernel+0x344/0x518 with crng_init=0
[ 0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000023] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000100] bcm2835: system timer (irq = 17)
[ 0.000749] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000764] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000781] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000794] Switching to timer-based delay loop, resolution 18ns
[ 0.001036] Console: colour dummy device 80x30
[ 0.001069] printk: console [tty1] enabled
[ 0.001122] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=540000)
[ 0.001143] pid_max: default: 32768 minimum: 301
[ 0.001292] LSM: Security Framework initializing
[ 0.001485] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001517] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002869] Disabling memory control group subsystem
[ 0.002993] CPU: Testing write buffer coherency: ok
[ 0.003506] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.004427] Setting up static identity map for 0x200000 - 0x20003c
[ 0.004633] rcu: Hierarchical SRCU implementation.
[ 0.005325] smp: Bringing up secondary CPUs …
[ 0.006527] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.007873] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.009158] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.009314] smp: Brought up 1 node, 4 CPUs
[ 0.009330] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.009343] CPU: All CPU(s) started in HYP mode.
[ 0.009355] CPU: Virtualization extensions available.
[ 0.010186] devtmpfs: initialized
[ 0.024184] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.024463] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.024491] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.031372] pinctrl core: initialized pinctrl subsystem
[ 0.032375] NET: Registered protocol family 16
[ 0.036353] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.036950] audit: initializing netlink subsys (disabled)
[ 0.037205] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
[ 0.038386] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.038400] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.038731] Serial: AMBA PL011 UART driver
[ 0.042619] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.060827] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-11-30 22:12, variant start
[ 0.070842] raspberrypi-firmware soc:firmware: Firmware hash is ab1181cc0cb6df52bfae3b1d3fef0ce7c325166c
[ 0.126117] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.131283] vgaarb: loaded
[ 0.131756] SCSI subsystem initialized
[ 0.131983] usbcore: registered new interface driver usbfs
[ 0.132053] usbcore: registered new interface driver hub
[ 0.132177] usbcore: registered new device driver usb
[ 0.132516] usb_phy_generic phy: phy supply vcc not found, using dummy regulator
[ 0.134412] clocksource: Switched to clocksource arch_sys_counter
[ 0.894184] VFS: Disk quotas dquot_6.6.0
[ 0.894285] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.894507] FS-Cache: Loaded
[ 0.894708] CacheFiles: Loaded
[ 0.895653] simple-framebuffer 3e843000.framebuffer: framebuffer at 0x3e843000, 0x384000 bytes, mapped to 0x(ptrval)
[ 0.895673] simple-framebuffer 3e843000.framebuffer: format=a8r8g8b8, mode=1280x720x32, linelength=5120
[ 0.896124] Console: switching to colour frame buffer device 160x45
[ 0.900682] simple-framebuffer 3e843000.framebuffer: fb0: simplefb registered!
[ 0.911186] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.911541] NET: Registered protocol family 2
[ 0.912281] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.912313] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.912372] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.912441] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.912599] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.912631] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.912893] NET: Registered protocol family 1
[ 0.913653] RPC: Registered named UNIX socket transport module.
[ 0.913666] RPC: Registered udp transport module.
[ 0.913679] RPC: Registered tcp transport module.
[ 0.913691] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.913713] PCI: CLS 0 bytes, default 64
[ 0.915761] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.918009] Initialise system trusted keyrings
[ 0.918253] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 0.929159] FS-Cache: Netfs ‘nfs’ registered for caching
[ 0.929894] NFS: Registering the id_resolver key type
[ 0.929925] Key type id_resolver registered
[ 0.929939] Key type id_legacy registered
[ 0.929962] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.931128] Key type asymmetric registered
[ 0.931143] Asymmetric key parser ‘x509’ registered
[ 0.931336] bounce: pool size: 64 pages
[ 0.931390] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.931617] io scheduler mq-deadline registered
[ 0.931632] io scheduler kyber registered
[ 0.935832] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 0.935856] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 0.935929] brcm-pcie fd500000.pcie: MEM 0x0600000000…0x0603ffffff -> 0x00f8000000
[ 0.936000] brcm-pcie fd500000.pcie: IB MEM 0x0000000000…0x00bfffffff -> 0x0000000000
[ 0.996534] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
[ 0.996860] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 0.996880] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.996901] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ 0.996960] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 0.997232] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.000588] PCI: bus0: Fast back to back transfers disabled
[ 1.000817] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.000965] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.001398] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 1.004792] PCI: bus1: Fast back to back transfers disabled
[ 1.004852] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.004876] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.004959] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.004984] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.005302] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 1.005543] pcieport 0000:00:00.0: PME: Signaling with IRQ 56
[ 1.005945] pcieport 0000:00:00.0: AER: enabled with IRQ 56
[ 1.006301] pci 0000:01:00.0: enabling device (0140 -> 0142)
[ 1.013627] iproc-rng200 fe104000.rng: hwrng registered
[ 1.013977] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.014737] vc-sm: Videocore shared memory driver
[ 1.015341] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.027712] brd: module loaded
[ 1.040313] loop: module loaded
[ 1.041782] Loading iSCSI transport class v2.0-870.
[ 1.043884] libphy: Fixed MDIO Bus: probed
[ 1.044592] bcmgenet fd580000.ethernet: failed to get enet clock
[ 1.044613] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.044636] bcmgenet fd580000.ethernet: failed to get enet-wol clock
[ 1.044658] bcmgenet fd580000.ethernet: failed to get enet-eee clock
[ 1.044686] bcmgenet: Skipping UMAC reset
[ 1.064494] libphy: bcmgenet MII bus: probed
[ 1.144531] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.145573] usbcore: registered new interface driver r8152
[ 1.145655] usbcore: registered new interface driver lan78xx
[ 1.145726] usbcore: registered new interface driver smsc95xx
[ 1.146157] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.146192] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.148661] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000003000000890
[ 1.149968] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 1.149986] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.150002] usb usb1: Product: xHCI Host Controller
[ 1.150017] usb usb1: Manufacturer: Linux 5.4.79-v7l+ xhci-hcd
[ 1.150032] usb usb1: SerialNumber: 0000:01:00.0
[ 1.150665] hub 1-0:1.0: USB hub found
[ 1.150762] hub 1-0:1.0: 1 port detected
[ 1.151334] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.151361] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.151384] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.151917] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[ 1.151934] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.151950] usb usb2: Product: xHCI Host Controller
[ 1.151965] usb usb2: Manufacturer: Linux 5.4.79-v7l+ xhci-hcd
[ 1.151979] usb usb2: SerialNumber: 0000:01:00.0
[ 1.152562] hub 2-0:1.0: USB hub found
[ 1.152644] hub 2-0:1.0: 4 ports detected
[ 1.154193] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.154553] dwc_otg: FIQ enabled
[ 1.154565] dwc_otg: NAK holdoff enabled
[ 1.154578] dwc_otg: FIQ split-transaction FSM enabled
[ 1.154593] Module dwc_common_port init
[ 1.155044] usbcore: registered new interface driver uas
[ 1.155149] usbcore: registered new interface driver usb-storage
[ 1.155361] mousedev: PS/2 mouse device common for all mice
[ 1.157311] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.160895] sdhci: Secure Digital Host Controller Interface driver
[ 1.160908] sdhci: Copyright© Pierre Ossman
[ 1.161552] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 1.162207] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.166096] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.166392] hidraw: raw HID events driver © Jiri Kosina
[ 1.166611] usbcore: registered new interface driver usbhid
[ 1.166623] usbhid: USB HID core driver
[ 1.167707] vchiq: vchiq_init_state: slot_zero = (ptrval)
[ 1.169718] [vc_sm_connected_init]: start
[ 1.182501] [vc_sm_connected_init]: end - returning 0
[ 1.184759] Initializing XFRM netlink socket
[ 1.184798] NET: Registered protocol family 17
[ 1.184912] Key type dns_resolver registered
[ 1.185351] Registering SWP/SWPB emulation handler
[ 1.185712] registered taskstats version 1
[ 1.185732] Loading compiled-in X.509 certificates
[ 1.186243] Key type ._fscrypt registered
[ 1.186257] Key type .fscrypt registered
[ 1.197104] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.197181] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2
[ 1.203339] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.204354] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.204370] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.257263] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.258941] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.260618] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.263621] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.265313] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.271663] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 1.274700] of_cfs_init
[ 1.274843] of_cfs_init: OK
[ 1.276018] Waiting for root device PARTUUID=d93ce22a-02…
[ 1.312036] random: fast init done
[ 1.334752] mmc1: new high speed SDIO card at address 0001
[ 1.384511] mmc0: new ultra high speed DDR50 SDHC card at address 0001
[ 1.385462] mmcblk0: mmc0:0001 00000 29.8 GiB
[ 1.388237] mmcblk0: p1 p2
[ 1.403101] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 1.403117] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 1.524524] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.707105] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.707124] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.707141] usb 1-1: Product: USB2.0 Hub
[ 1.709100] hub 1-1:1.0: USB hub found
[ 1.709407] hub 1-1:1.0: 4 ports detected
[ 2.249858] EXT4-fs (mmcblk0p2): recovery complete
[ 2.259993] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.260069] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.261684] devtmpfs: mounted
[ 2.270350] Freeing unused kernel memory: 2048K
[ 2.270647] Run /sbin/init as init process
[ 2.897301] systemd[1]: System time before build time, advancing clock.
[ 3.034775] NET: Registered protocol family 10
[ 3.036164] Segment Routing with IPv6
[ 3.084761] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 3.085545] systemd[1]: Detected architecture arm.
[ 3.138958] systemd[1]: Set hostname to .
[ 3.864560] random: lvmconfig: uninitialized urandom read (4 bytes read)
[ 4.487555] systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
[ 4.812179] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.839506] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.840230] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 4.840862] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.841346] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 4.841490] systemd[1]: Reached target System Time Synchronized.
[ 4.842215] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 4.843002] systemd[1]: Listening on Journal Socket (/dev/log).
[ 5.075382] i2c /dev entries driver
[ 5.146362] Installing knfsd (copyright © 1996 [email protected]).
[ 5.679122] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 5.784590] systemd-journald[118]: Received request to flush runtime journal from PID 1
[ 6.643139] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 6.647475] Driver for 1-wire Dallas network protocol.
[ 6.655257] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 6.657889] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 6.662245] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 6.681162] gpio-4 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 6.726093] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.729041] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 6.729063] [vc_sm_connected_init]: start
[ 6.751683] [vc_sm_connected_init]: installed successfully
[ 6.768539] mc: Linux media interface: v0.10
[ 6.810306] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.851487] videodev: Linux video capture interface: v2.00
[ 6.862199] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 6.939841] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 6.942421] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.951336] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.993344] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.995841] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.034591] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 7.045807] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 7.050317] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 7.050836] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 7.050865] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 7.050908] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 7.050928] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 7.050949] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 7.051470] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 7.165206] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 7.174666] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.242300] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 7.242343] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 7.242443] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 7.242466] checking generic (3e843000 384000) vs hw (0 ffffffffffffffff)
[ 7.242480] fb0: switching to vc4drmfb from simple
[ 7.243504] Console: switching to colour dummy device 80x30
[ 7.243747] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 7.243761] [drm] No driver support for vblank timestamp query.
[ 7.243774] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[ 7.252381] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 7.253008] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 7.253049] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 7.260694] vc4-drm gpu: HDMI-A-1: EDID is invalid:
[ 7.260715] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 7.260728] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 7.260749] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 7.260763] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 7.260776] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 7.260788] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 7.260801] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 7.260815] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 7.262377] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 7.262428] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 7.379371] bcmgenet: Skipping UMAC reset
[ 7.382204] bcmgenet fd580000.ethernet: configuring instance for external RGMII
[ 7.382677] bcmgenet fd580000.ethernet eth0: Link is Down
[ 7.422910] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 7.461424] Console: switching to colour frame buffer device 160x45
[ 7.482727] vc4-drm gpu: fb0: vc4drmfb frame buffer device
[ 7.611823] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 7.704822] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 7.720910] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.721618] usbcore: registered new interface driver brcmfmac
[ 7.749188] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
[ 7.993543] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 8.005349] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea
[ 10.474735] bcmgenet fd580000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 10.474792] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 12.556930] uart-pl011 fe201000.serial: no DMA platform data
[ 13.165022] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 14.145171] random: crng init done
[ 14.145186] random: 7 urandom warning(s) missed due to ratelimiting
[ 15.326375] NFSD: Using UMH upcall client tracking operations.
[ 15.326396] NFSD: starting 90-second grace period (net f0000049)
[ 19.515808] Bluetooth: Core ver 2.22
[ 19.515906] NET: Registered protocol family 31
[ 19.515920] Bluetooth: HCI device and connection manager initialized
[ 19.515949] Bluetooth: HCI socket layer initialized
[ 19.515970] Bluetooth: L2CAP socket layer initialized
[ 19.516004] Bluetooth: SCO socket layer initialized
[ 19.534689] Bluetooth: HCI UART driver ver 2.3
[ 19.534710] Bluetooth: HCI UART protocol H4 registered
[ 19.534814] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 19.535142] Bluetooth: HCI UART protocol Broadcom registered
[ 19.934447] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 19.934534] Bluetooth: BNEP filters: protocol multicast
[ 19.934568] Bluetooth: BNEP socket layer initialized
[ 20.941489] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 20.948924] Bridge firewalling registered
[ 24.375009] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 24.406677] usb 2-2: New USB device found, idVendor=1058, idProduct=0a10, bcdDevice=81.36
[ 24.406702] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 24.406720] usb 2-2: Product: JMS56x Series
[ 24.406736] usb 2-2: Manufacturer: JMicron
[ 24.406752] usb 2-2: SerialNumber: 1234567890123
[ 24.436041] scsi host0: uas
[ 24.437910] scsi 0:0:0:0: Direct-Access WDC WD20 PURZ-85AKKY0 8136 PQ: 0 ANSI: 6
[ 24.440940] sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 24.441253] sd 0:0:0:0: [sda] Write Protect is off
[ 24.441272] sd 0:0:0:0: [sda] Mode Sense: 67 00 10 08
[ 24.441816] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 24.442736] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
[ 24.569041] sda: sda1
[ 24.572966] sd 0:0:0:0: [sda] Attached SCSI disk
[ 24.668060] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 24.699170] docker0: port 1(veth99d2ace) entered blocking state
[ 24.699187] docker0: port 1(veth99d2ace) entered disabled state
[ 24.699609] device veth99d2ace entered promiscuous mode
[ 25.974341] warning: process `colord-sane’ used the deprecated sysctl system call with 8.1.2.
[ 26.987776] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
[ 28.292428] eth0: renamed from vethefdcbd1
[ 28.337612] IPv6: ADDRCONF(NETDEV_CHANGE): veth99d2ace: link becomes ready
[ 28.337851] docker0: port 1(veth99d2ace) entered blocking state
[ 28.337866] docker0: port 1(veth99d2ace) entered forwarding state
[ 28.338178] IPv6: ADDRCONF(NETDEV_CHANGE): docker0: link becomes ready
[ 30.382448] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,acl
[ 30.707992] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 30.766354] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 33.512182] broken atomic modeset userspace detected, disabling atomic
[ 37.048406] fuse: init (API version 7.31)
[ 39.440220] Bluetooth: RFCOMM TTY layer initialized
[ 39.440236] Bluetooth: RFCOMM socket layer initialized
[ 39.440253] Bluetooth: RFCOMM ver 1.11
[ 68.974899] sd 0:0:0:0: [sda] tag#7 uas_eh_abort_handler 0 uas-tag 4 inflight: CMD OUT
[ 68.974916] sd 0:0:0:0: [sda] tag#7 CDB: opcode=0x2a 2a 00 06 c0 15 00 00 04 00 00
[ 69.024913] scsi host0: uas_eh_device_reset_handler start
[ 69.175927] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 69.209870] scsi host0: uas_eh_device_reset_handler success
[ 69.585776] xhci_hcd 0000:01:00.0: ERROR Transfer event for unknown stream ring slot 2 ep 7
[ 69.585791] xhci_hcd 0000:01:00.0: @000000001ed08ec0 00000000 00000000 05000000 02088001
I haven’t look into it to try to understand it.
Thanks for the help,
Best regards,
