@KinLon
Have you tried VirtualXposed?
It doesn’t need root.
For persons I’ve missed, just send me a DM.
The only two restriction of VirtualXposed are:
- Unable to modify system, so any Module which modifies system won’t be able to work properly.
Just installed it-this works way better than a certain other pos android tv image. Thanks much for your work.
form submitted, looking forward for the password?
Dear @mo123 ,
I tried your build and for the first time I saw the potential of the board on android.
I flashed to a cheap 128 GB sandisk sd card which was not working before and I’m ipressed.
Your build is working smooth and stable, thank you for this great build.
My AX210 Wifi card did not work it is normal I did not expect it to work.
Your builds kernel version is 5.10.121, is it possible to add AX210 firmware to your later builds?
Thank you very much again for the great job, please continue to release new builds.
Regards,
Thank you, and waiting for Password.
- Opening the Play Store causes a reboot - that normal?
- Boot splash loop when using the “official” Powersuppy suggested by radxa
Wow! Looks great! Thank you so much.
Is it possible to share the password? Thank you in advance and have a nice day!
Hi! It’s a very good work! Please send me a password. Also waiting for ssd or sata support (i have booth type).
Thank you,
Max.
@mo123 why this password system?
I’ll check if there is a better way.
Mainly to limit downloads to this forum, registered users with the hardware.
There are too many users with all kinds of RK3588 devices that download without contributing or repost links on other forums.
I’d have prefered my 1st post here wasn’t a pw request. At least the form/ad layer removal made me less suspicious. Thanks in advance
great work. would love to get the password.
Downloaded. Need the password please.
Great work. would love to get the password.
Xiaomi BT remote XMRM-M2 does not work - pairs, but all keys ignored. Is it possible to fix?
Hopefully this is the android build I’ve been looking for! Can you pm me the password, please?
THC013 builds have exactly same issue. So I gruess this remote sends non standard codes via bluetooth.
Hi
See OP for new firmware.
Changed form user to userdebug as there were too many bugs Rockchip still has to fix.
Fixed H264 videos breakup with black dots bug in latest Media Process Platform
Several other changes and improvements.
Send me a DM if you haven’t tried the nvme firmware yet.
