@mo123 Hello, could you please also update the images for OPI 5 boards? In the current version most 3rd party apps can’t be installed because of the INSTALL_FAILED_VERIFICATION_FAILURE error and the HDMI In apps don’t work.
Btw can I have the password too please?
[ROM] Rock5A/B AndroidTV 12 by mo123
I would like to flash your image on my ROCK 5B. The download link is broken, mega deleted the file.
Can you please reupload the image and send me the password?
big thanks in advance
I have downloaded the rock5b nvme firmware. Could you please tell me the decompress password? Thank you very much!
Is it new one ? **V1.10
wanna build a kernel to run docker in termux,where is the source if it’s available
actually why not just enable most options in make menu
@hatsune_mugi
KVM is not supported, compatible with the new kernel.
You can use older firmware v1.7 where kvm is enabled.
Hi mo123, could you make AOSP firmware ?
Hey.
Are you going to make this image available to public any time soon?
thank you sir , need the password
hi all, is there any possibility to use non radxa rtl8852be card. radxa a8 with shipping is doubled the cost of generic oem rtl8852be card from shopping site.
@zerorating
Please send a link to the site for the oem wifi card and a photo of the chip to Radxa and ask if it is supported. If it works in the stock firmware, it should also work in my firmware.
Vendor no’s 0bda:b85b & 10ec:b852 were added by Radxa, so if the chip contains one of these vendor no’s it might work.
The problem is there are so many clones or different RTL8852BE devices with different vendor no’s, some can be added to code and be supported but some are not hardware compatible with Rock5 devices.
how about rtl8852be card that was sold to work with orange pi 5? it was having PCI ID 10ec:b852:10ec:b852
Can you please send me the password?
I just downloaded this version as an upgrade to an older release (after my microSD died) and love the numerous improvements. However, I am running to an issue with the display scaling on the same 4K TV.
I’m finding that the home screen and all apps are scaled much smaller - Jellyfin text is nearly unreadable to start. While increasing the text scaling in system settings helps with the homescreen, in Jellyfin it causes issues. UI elements (Movie/Show posters, collections, etc) are still undersized, and increasing the text size results in lots of cut off/wrap around/overlapping text since the UI elements/text areas aren’t sized for a larger text.
Is there something that can be done to increase general UI scaling (that isn’t reducing the display resolution overall)? Thanks.
You can try
wm density 480 or wm density 640
in the terminal app included
or
wm size 1920x1080
wm density 320
Might need root access with Magisk or APatch.
See opening post for using Magisk.
Hi! How to set up Auto Frame Rate in kodi?
