[ROM] Rock5A/B AndroidTV 12 by mo123
Thank you for your hard work and have a great day.h
i need the password please
HI @mo123 i need the password please
Hey there, I have problems with sound, all the volumes from HDMI and USB->Sound are to low, another question, could it be compiled in a tablet version too? … thanks Mark
@Mark_Reijerkerk
Hi
For Rock5A, use the right side HDMI port if facing towards the display
For Rock5B, use the left side 8K HDMI port if facing towards the display.
If the volume is 25, the highest, also check eg. tv volume that is separate and set by the tv remote.
You can also try this app perhaps
https://apkpure.com/store/apps/details?id=com.goodev.volume.booster
Are you using any USB touchscreens or USB Audio speakers?
There is another Absolute volume setting in Developer Options but it is mostly for bluetooth sound to make it louder, perhaps it can help too.
Uploaded new v1.7c Rock5B NVME firmware too.
Mostly just extra touchscreen support and a bugfix for ethernet, no need to update if you don’t use those.
@mo123 hello ,thank’s a lot for your great work ,could you please send the password for rock 5a image and orangepi 5
would like to use it on both devices
thank you
Hi @mo123 can you please send me the password? thanks
For users with a Rock5A & Intel AX210 Wifi
Other wifi is disabled.
https://mega.nz/file/cI5yQLDB#LclZR-Mos32_f7f9_kdeEnsVjsrfaQx-uG-UPplBvps
mo123, is it possible to make full-fledged Android 12 ? There are a lot of limitation of Android TV firmware. Some apps can`t be installed at all
great work. thanks . may i get passwd
thanks , i download the 7z file can you tell me the password?
Dear @mo123,
Did you find a solution for AX210 to work on android?
If your answer is yes could you please apply this solution to Rock 5b firmware too?
Regards
@darkstar Yes, I’m just testing some new improvements then will make Rock5B with Intel wifi too.
That is really a good news thank you very much, nowadays I’m very busy so I don’t have time to play with android. You are the man, congratulations.
can you pls send me the passwd ty alot :smiley:
Dear @mo123. Downloaded, need to know password for unzip.
Thanks you & Regards.
I need the password for rock5A & rock 5B,thanks @mo123
Hey @mo123,
Downloaded the image, please help me with the pass.
Thanks and have a great one.
can you pls send me the passwd :slight_smile: Thanks
Updated Rock5B firmwares in the OP
Fixed Intel AX210 bluetooth
Single firmware for AX210 & other wifi.
Fix G7BTS remote control
Fix System boot fail when use static IP
0x3570 rtl8852be bluetooth support
Rock5B Add 4K video camera support
To replace the bootanimation, copy your bootanimation.zip to /data/local/, need root access.
Here is the stock bootanimation,
Will upload Rock5A firmware later.
Hi @mo123, I downloaded the image, can you please dm me the password? thanks!
