[ROM] Rock5A/B AndroidTV 12 by mo123
Can I have password pls
@Glen_Furze
You can go to OPi forum, I posted firmware there.
It has less bugs than Rock5A/B firmware at the moment.
Addition.
In principle, it’s not bad, it turns out to root Magisk on any firmware, including AOSP Android 12 Radxa, by simply patching Magisk 6.boot.img from the firmware file and then flashing the new boot.img to the /boot /dev/sda7 partition via EMMC Reader under Linux
sudo dd if=boot.img of=/dev/sda7
sync
I think it will turn out similar on NVME firmware, because the firmware file is encrypted and the archiver does not open, then try to extract this file with commands under Linux under NVME Reader from the boot partition, patch and flash similarly to EMMC Reader
The built-in boot.img replacement tools unfortunately caused the system to crash.
Hi, I did go to OPi forum, and downloaded your version for my OPi5.
I cannot reply from that forum, as I am waiting to be let in as member. It’s been a few days.
Are you able to give me the Zip PW here(or via messager), as i don’t know how long it will take.
many thanks
Glen
hola puedes pasar el passw. gracias por el apoyo y el desarrollo tanto con la opi5 como en esta …
yeh i noticed this also. i think it does work but for some reason the ui seems broke. i might be wrong
@mo123 . big question, do you think you could release a vanilla (or a patch on existing radxa android 12 image) android image addressing 2 main problems Radxa don’t seem to care about.
  1. Android settings are forgotten on reboot, e.g. if I change display resolution it reverts to default on reboot.
  2. ā€œsd card unsupportā€ for all SD cards. even if you can just set something to hide this so the user never sees it.
You’d get legend status with me if u can handle that. I’d even buy you some beer or coffee.
@mo123 already has a legend status for figuring out the H.265 decoding bug
Double legend status
Hi. Thanks for awesome work.
I have OPI5+ and i like try your opi version of this firmware.
I see you have posted on orangepi forum but for me register not work. Waiting days for registration and not work.
Please can you share the OPI5+ nvme password with me?
Thanks.
Hi mo123, would you please send me the password for Rock5B_ATV_v1.6_nvme_by_mo123.7z, thank you!
Thank you for your hard work and contribution to the software developments of the android tv devices, may your hard work and contribution be greatly rewarded!
ry168
Boss can you provide the password to release the img, thank you and have a great day!
would you please provide the password? Thank you for your hard work and have a great day.
Hello, 5b sd card firmware HDMI cannot output sound?
Hello Mr @mo123 I wait for the password. Please . Thanks for your work AND support
Thanks for the build @mo123. Can I have the password Pls? Thanks for your work!
would you please provide the password? Thank you for your work.
New firmwares 20/9 uploaded for Rock5A & Rock5B.
See OP.
HI @mo123 i need the password please
