Open rktools, conect the board with your PC (using maskrom mode) then select Upgrade Firmware tab, click Firmware button and choose update.img. After that just click Upgrade and wait to finish. (any problem try again)
I´m using V5 version (ethernet) and everything Ok.
Sure if my raid is friends with me again , and solve some network issues on the cfw wich is a little riddle on rk3566 it works great on rk3588 i get no network connection same kernel etc , now can reproduce the no network on rk3566 but i dont know why , i thinking i got some kernel config wrong
but for your info got ATV and GTV and lot of fixes .
@Elden netflix wont work same as yt is bound to 2k there is no widevinde l1 on cfw
Happy New Year to you too and keep up the good work. Kindly can you elaborate a little on the differences between the two links you shared in latest post? My board has Intel 7265 wifi which, under Linux, requires /lib/firmware/iwlwifi-7265D-29.ucode blob. Any tips how to getting wifi to work under Android?
the diffrence i🤔 like i said a little more cleaner , i mean with that it is more like the real atv in packages and permissions , the first image is more that it was workijg again after i lost my setup due raid troubels and the second is in sync how i have it running on my rk3566 quartz-a .
And Wife and BT is a little troublesome for me without logs from a working and a not working to figure out where i go wrong . sdio and wifi has diffremce how it works. and there is tablet and tv wifi diffrence and diffrent firmwares… and checked 4 or 5 rk3588 android vendor sdk and got 4 diffrent drivers from android 8 to 12 and with and without hci so multiple ways to rome it seems ,
and if your card runs on official raxda android or linux and can log a boot to ui on the working and not working , it would help me a lot where i go wrong.
lan and cec works so you have internet and remote control to use atv .
