Link updated, copy paste error ![]()
Thank you for your work @mo123 !
Is there a way to update to latest version without the need to reinstall our apps ?
Hi
You can try to use
https://apkpure.com/migrate-custom-rom-migration-tool/balti.migrate or
https://f-droid.org/packages/dk.jens.backup/
Maybe the last app will help with all your needs and itās open-source so the developer can add new features if users require them.
Download the apkās on a PC and install from external storage on RockPi 4 since those apps arenāt available in the AndroidTV Store.
Added boot.img to patch through Magisk for people that need it.
and added instructions to patch it with Magisk.
https://forum.radxa.com/t/guide-for-androidtv-firmware-by-mo123/2459/2
Really nice stuff @mo123, I played with 1.1 I had one issue with sounds which seams really low, I tried all bitstream mode (I couldnāt test the mini jack mine is broken).
I wanted to download last version but archive seems to be broken.
cheers
The link seems okay.
Did you try the v1.3 link later in the thread here?
Unzip with 7zip and password for unzipping is radxa
Kodi has some problems where audio volume resets for some people but should be fixed in a few days when they update the app.
You can try with Audio settings as Bitstream or Stereo(if not using HDMI passthrough)
Safe volume, you can disable it if needed.
The is also a setting to lock the audio so you can only change volume with your tv or AVR remote so devices donāt all use different volume levels.
I canāt remember if the volume resets to a certain level after booting, think radxa also set some default value, level 12 audio or something. I can try to change some things later if there are still problems.
I have problems in version 1.3 with sound everywhere, not just in kodi. The sound is very quiet through HDMI. In the settings I increase the volume level, and after exiting the setup menu it returns again as it was.
In this version, CEC continues to work for me after switching to TV. Very good ![]()
I am now loading some systems using the boot flag on boot partition.
# parted /dev/mmcblk0 p
Model: SD SL16G (sd/mmc)
Disk /dev/mmcblk0: 15,9GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 32,8kB 4129kB 4096kB
2 8389kB 12,6MB 4194kB
3 12,6MB 16,8MB 4194kB
4 16,8MB 134MB 117MB fat16 mint boot, esp
5 134MB 252MB 117MB fat16 xubuntu boot, esp
6 252MB 789MB 537MB fat16 msftdata
7 789MB 1325MB 537MB fat16 msftdata
8 1325MB 1862MB 537MB fat16 msftdata
9 1862MB 2399MB 537MB fat16 msftdata
10 2399MB 13,1GB 10,7GB ext4 ubuntu
loading mint from nvme now. If I enter āparted /dev/mmcblk0 t 4 bootā, the boot flag from partition 4 will disappear and the 5th partition will be loaded with the boot flag on it.
Android also have boot flag on the first partition. I removed the flag from it, made another boot partition with the boot flag active, but android was booting ![]()
It would be nice to make uboot for android so that it loads first partitions with the boot flag ![]()
Hopefully Radxa will be able to suggest something after their holidays.
Glad HDMI CEC is working now.
For audio I use a cheap airmouse and use the volume buttons on it.
https://www.gearbest.com/air-mouse-c_11908/ā
After setting the audio to maximum, you can try to lock the audio volume, think I added a setting for that.
Thanks @mo123, sound level is saved with the 1.3, CEC works perfectly for me.
Ola, qual a versão do google play usado? Consigo instalar o pubg? Gostaria de uma ajuda sobre isso! Ty
Hello, what version of google play is used? Can I install pubg? I would like some help on that! Ty
You can try to install it from the APKPure App Store in the AppDrawer or manually download and install from a USB Disk
https://apkpure.com/pubg-mobile-4-android-i/com.tencent.ig or install Aptoide App Store and install it from there
https://pubg-mobile-tencent-games.en.aptoide.com/
Hi @mo123 really great work. Some questions (donāt have rock PI yet)
1: have you seen rock pi 1.4 has support to boot nvme? so can we follow the basic instructions to install your OS to nvme by default?
2: Does your OS build have hardware video decoding in Nova Player / others or is it software?
I have a standard chinese android tv media box and the issue is for H265 or high efficiency encoded videos the video player always drop frame and doesnāt play properly so this is a question for changing to rockpi + your os
Hi
Kodi works great.
HD Audio passthrough is supported - DTS, AC3, EAC3, DTS-HD, DTS-HD MA & True-HD
Auto frame-rate switching is supported so videos play at the correct frame-rate eg. 23.976hz, 24hz, 25hz, 50hz, 60hz
8/10-Bit H264, 8/10-bit H265, VC1, VP9, Mpeg2, Mpeg4, HDR are all supported with hardware acceleration using less than 20% CPU usage.
Nova Video Player is also fully supported.
I recently asked the developer to add 10-bit color video playback for Rockhip devices and it was added quickly. So things work great with this video player, auto frame-rate switching also works with it.
You can also use LibreELEC if you want even better performance and also 1080p Netflix playback(but this is software decoded since itās Linux, so you need the big heatsink for Netflix).
I donāt use an NVME, but other users has succcess in booting it and Radxa can also help you if you have problems when they are back after the holidays.
Thatās great.
I like Android TV OS so wanted to buy Raspberry PI 4 but they donāt support android tv
which is how I found ROCK Pi & your rom so thanks again for your work
You mentioned spoofing Xiaomi in v1.3 does this mean itās possible to get Netflix HD (android app) by default?
Netflix only works in 940px540p resolution in Android.
You need a Widevine L1 license and Netflix contract to play higher which Netflix doesnāt allow on open-source devices and the manufacturer has to sell a minimum of 3 million devices a year which is impossible for most companies.
But 1080p is supported in LibreELEC well since itās Linux.
Iām working on getting a dual-boot Android/LibreELEC firmware firmware up where itās easier to switch between the 2 OSās, but Iām waiting for extra help since itās a complicated process.
I see understood.
Does your rom have 24FPS auto framerate switching working?
On my alfawise h96 android box (amlogic s912 cpu) this is a problem.
So some videos there is stutter/frame drop when playback.
Yes, 23.976, 24, 29.97, 59.94hz can play correctly in Kodi and Nova Video Player.
You can also map a key on a USB keyboard, airmouse to work with the RefreshRate app in the firmware then you can press this key when in an app eg. MxPlayer, Netflix, IPTV app to manually switch to any frame-rate. If you know the video is eg. 25/50hz(EU) or 23.976hz(US) then you can manually switch to this frame-rate so it doesnāt play at 60hz which will cause stuttering.
Here is also a link to LibreELEC I made, will update it in future
Nice got it.
Any plan to add TWRP recovery for easier backup and flash partitions?
Will allow to backing up data partition when upgrading rom builds you release
Hi
I tested mo123ās firmware boot from NVME.
My ssd is HP EX900.
and, Android 9 radxa official image booted from NVME completely.
U-boot is here.
https://wiki.radxa.com/Rockpi4/install/android-NVME
Result
v1.1 booted. But the home screen flashed.
v1.2 logo showed, but crashed
v1.3 logo showed, but crashed
I will test v1.0 later.
