After a restart (it is necessary to replace the damaged disk in RAID5), rockpi-sata.service starts and stops in a moment.Of course, the disks are not visible.
I haven’t restarted the Raspberry pi 4B for a long time and in the meantime there were a lot of fixes.
Data:
Raspberry Pi 4B + Sata Hat Quad 4 HDDs 3.5 + OMV 6.0.34-1 (Shaitan)
Kernel: 5.15.56-v8 + # 1575 SMP PREEMPT Fri Jul 22 20:31:26 BST 2022 aarch64 GNU / Linux
Logs:
`● rockpi-sata.service - Rockpi SATA Hat
Loaded: loaded (/lib/systemd/system/rockpi-sata.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2022-08-10 13:24:00 CEST; 2s ago
Main PID: 9377 (python3)
Tasks: 1 (limit: 4164)
CPU: 891ms
CGroup: /system.slice/rockpi-sata.service
└─9377 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
root@NAS-NEW:~# systemctl status rockpi-sata.service
Active: inactive (dead) since Wed 2022-08-10 13:24:08 CEST; 3s ago
Process: 9377 ExecStart=/usr/bin/python3 /usr/bin/rockpi-sata/main.py on (code=exited, status=0/SUCCESS)
Process: 9763 ExecStop=/usr/bin/python3 /usr/bin/rockpi-sata/main.py off (code=exited, status=0/SUCCESS)
Main PID: 9377 (code=exited, status=0/SUCCESS)
CPU: 2.425s
dmesg -c
[ 1634.538186] usb 2-2: new SuperSpeed USB device number 8 using xhci_hcd
[ 1634.563628] usb 2-2: New USB device found, idVendor=1058, idProduct=0a10, bcdDevice=81.36
[ 1634.563670] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 1634.563687] usb 2-2: Product: JMS56x Series
[ 1634.563702] usb 2-2: Manufacturer: JMicron
[ 1634.563715] usb 2-2: SerialNumber: 1234567890123
[ 1634.579629] scsi host0: uas
[ 1634.586291] scsi 0:0:0:0: Direct-Access HGST HUS 724030ALA640 8136 PQ: 0 ANSI: 6
[ 1634.588383] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1634.590161] scsi 0:0:0:1: Direct-Access HGST HUS 724030ALA640 8136 PQ: 0 ANSI: 6
[ 1634.591202] sd 0:0:0:0: [sda] 5860533168 512-byte logical blocks: (3.00 TB/2.73 TiB)
[ 1634.591517] sd 0:0:0:0: [sda] Write Protect is off
[ 1634.591537] sd 0:0:0:0: [sda] Mode Sense: 67 00 10 08
[ 1634.592125] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 1634.593115] sd 0:0:0:1: Attached scsi generic sg1 type 0
[ 1634.593253] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
[ 1634.594503] sd 0:0:0:1: [sdb] 5860533168 512-byte logical blocks: (3.00 TB/2.73 TiB)
[ 1634.594840] sd 0:0:0:1: [sdb] Write Protect is off
[ 1634.594862] sd 0:0:0:1: [sdb] Mode Sense: 67 00 10 08
[ 1634.595781] sd 0:0:0:1: [sdb] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 1634.596851] sd 0:0:0:1: [sdb] Optimal transfer size 33553920 bytes
[ 1634.647306] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1634.650151] sd 0:0:0:1: [sdb] Attached SCSI disk
[ 1635.094250] usb 2-1: new SuperSpeed USB device number 9 using xhci_hcd
[ 1635.119871] usb 2-1: New USB device found, idVendor=1058, idProduct=0a10, bcdDevice=81.36
[ 1635.119913] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 1635.119930] usb 2-1: Product: JMS56x Series
[ 1635.119945] usb 2-1: Manufacturer: JMicron
[ 1635.119958] usb 2-1: SerialNumber: 1234567890123
[ 1635.152612] scsi host1: uas
[ 1635.154834] scsi 1:0:0:0: Direct-Access HGST HUS 724030ALA640 8136 PQ: 0 ANSI: 6
[ 1635.156913] sd 1:0:0:0: Attached scsi generic sg2 type 0
[ 1635.160905] sd 1:0:0:0: [sdc] 5860533168 512-byte logical blocks: (3.00 TB/2.73 TiB)
[ 1635.161134] scsi 1:0:0:1: Direct-Access HGST HUS 724030ALA640 8136 PQ: 0 ANSI: 6
[ 1635.161261] sd 1:0:0:0: [sdc] Write Protect is off
[ 1635.161280] sd 1:0:0:0: [sdc] Mode Sense: 67 00 10 08
[ 1635.161999] sd 1:0:0:0: [sdc] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 1635.163040] sd 1:0:0:0: [sdc] Optimal transfer size 33553920 bytes
[ 1635.164758] sd 1:0:0:1: Attached scsi generic sg3 type 0
[ 1635.166194] sd 1:0:0:1: [sdd] 5860533168 512-byte logical blocks: (3.00 TB/2.73 TiB)
[ 1635.166660] sd 1:0:0:1: [sdd] Write Protect is off
[ 1635.166686] sd 1:0:0:1: [sdd] Mode Sense: 67 00 10 08
[ 1635.167317] sd 1:0:0:1: [sdd] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 1635.168429] sd 1:0:0:1: [sdd] Optimal transfer size 33553920 bytes
[ 1635.187025] sd 1:0:0:0: [sdc] Attached SCSI disk
[ 1635.209543] sd 1:0:0:1: [sdd] Attached SCSI disk
[ 1637.962320] usb 2-2: USB disconnect, device number 8
[ 1637.994195] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 1638.233868] sd 0:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=DRIVER_OK
[ 1638.278383] sd 0:0:0:1: [sdb] Synchronizing SCSI cache
[ 1638.525890] sd 0:0:0:1: [sdb] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=DRIVER_OK
[ 1638.722176] usb 2-1: USB disconnect, device number 9
[ 1638.741910] sd 1:0:0:0: [sdc] Synchronizing SCSI cache
[ 1638.985874] sd 1:0:0:0: [sdc] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=DRIVER_OK
[ 1639.045905] sd 1:0:0:1: [sdd] Synchronizing SCSI cache
[ 1639.285885] sd 1:0:0:1: [sdd] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=DRIVER_OK
[ 3290.494415] usb 2-2: new SuperSpeed USB device number 10 using xhci_hcd
[ 3290.515885] usb 2-2: New USB device found, idVendor=1058, idProduct=0a10, bcdDevice=81.36
[ 3290.515926] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 3290.515944] usb 2-2: Product: JMS56x Series
[ 3290.515958] usb 2-2: Manufacturer: JMicron
[ 3290.515972] usb 2-2: SerialNumber: 1234567890123
[ 3290.530827] scsi host0: uas
[ 3290.532480] scsi 0:0:0:0: Direct-Access HGST HUS 724030ALA640 8136 PQ: 0 ANSI: 6
[ 3290.534799] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 3290.535890] sd 0:0:0:0: [sda] 5860533168 512-byte logical blocks: (3.00 TB/2.73 TiB)
[ 3290.536220] sd 0:0:0:0: [sda] Write Protect is off
[ 3290.536240] sd 0:0:0:0: [sda] Mode Sense: 67 00 10 08
[ 3290.536666] scsi 0:0:0:1: Direct-Access HGST HUS 724030ALA640 8136 PQ: 0 ANSI: 6
[ 3290.536788] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 3290.537955] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
[ 3290.560863] sd 0:0:0:1: Attached scsi generic sg1 type 0
[ 3290.562899] sd 0:0:0:0: [sda] Attached SCSI disk
[ 3290.563240] sd 0:0:0:1: [sdb] 5860533168 512-byte logical blocks: (3.00 TB/2.73 TiB)
[ 3290.563544] sd 0:0:0:1: [sdb] Write Protect is off
[ 3290.563564] sd 0:0:0:1: [sdb] Mode Sense: 67 00 10 08
[ 3290.564117] sd 0:0:0:1: [sdb] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 3290.565075] sd 0:0:0:1: [sdb] Optimal transfer size 33553920 bytes
[ 3290.587263] sd 0:0:0:1: [sdb] Attached SCSI disk
[ 3291.006550] usb 2-1: new SuperSpeed USB device number 11 using xhci_hcd
[ 3291.027811] usb 2-1: New USB device found, idVendor=1058, idProduct=0a10, bcdDevice=81.36
[ 3291.027856] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 3291.027874] usb 2-1: Product: JMS56x Series
[ 3291.027889] usb 2-1: Manufacturer: JMicron
[ 3291.027902] usb 2-1: SerialNumber: 1234567890123
[ 3291.049020] scsi host1: uas
[ 3291.050879] scsi 1:0:0:0: Direct-Access HGST HUS 724030ALA640 8136 PQ: 0 ANSI: 6
[ 3291.057986] sd 1:0:0:0: Attached scsi generic sg2 type 0
[ 3291.059310] sd 1:0:0:0: [sdc] 5860533168 512-byte logical blocks: (3.00 TB/2.73 TiB)
[ 3291.059630] sd 1:0:0:0: [sdc] Write Protect is off
[ 3291.059651] sd 1:0:0:0: [sdc] Mode Sense: 67 00 10 08
[ 3291.060106] scsi 1:0:0:1: Direct-Access HGST HUS 724030ALA640 8136 PQ: 0 ANSI: 6
[ 3291.060225] sd 1:0:0:0: [sdc] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 3291.061325] sd 1:0:0:0: [sdc] Optimal transfer size 33553920 bytes
[ 3291.064002] sd 1:0:0:1: [sdd] 5860533168 512-byte logical blocks: (3.00 TB/2.73 TiB)
[ 3291.064360] sd 1:0:0:1: [sdd] Write Protect is off
[ 3291.064384] sd 1:0:0:1: [sdd] Mode Sense: 67 00 10 08
[ 3291.065022] sd 1:0:0:1: [sdd] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 3291.066128] sd 1:0:0:1: [sdd] Optimal transfer size 33553920 bytes
[ 3291.074055] sd 1:0:0:1: Attached scsi generic sg3 type 0
[ 3291.086094] sd 1:0:0:0: [sdc] Attached SCSI disk
[ 3291.102590] sd 1:0:0:1: [sdd] Attached SCSI disk
[ 3293.858536] usb 2-2: USB disconnect, device number 10
[ 3293.882112] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 3294.122009] sd 0:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=DRIVER_OK
[ 3294.170691] sd 0:0:0:1: [sdb] Synchronizing SCSI cache
[ 3294.410006] sd 0:0:0:1: [sdb] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=DRIVER_OK
[ 3294.570325] usb 2-1: USB disconnect, device number 11
[ 3294.594018] sd 1:0:0:0: [sdc] Synchronizing SCSI cache
[ 3294.834011] sd 1:0:0:0: [sdc] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=DRIVER_OK
[ 3294.898095] sd 1:0:0:1: [sdd] Synchronizing SCSI cache
[ 3295.138012] sd 1:0:0:1: [sdd] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=DRIVER_OK
[ 4209.758088] usb 2-2: new SuperSpeed USB device number 12 using xhci_hcd
[ 4209.779654] usb 2-2: New USB device found, idVendor=1058, idProduct=0a10, bcdDevice=81.36
[ 4209.779684] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 4209.779701] usb 2-2: Product: JMS56x Series
[ 4209.779716] usb 2-2: Manufacturer: JMicron
[ 4209.779730] usb 2-2: SerialNumber: 1234567890123
[ 4209.792098] scsi host0: uas
[ 4209.793872] scsi 0:0:0:0: Direct-Access HGST HUS 724030ALA640 8136 PQ: 0 ANSI: 6
[ 4209.795891] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 4209.797535] sd 0:0:0:0: [sda] 5860533168 512-byte logical blocks: (3.00 TB/2.73 TiB)
[ 4209.797915] sd 0:0:0:0: [sda] Write Protect is off
[ 4209.797927] scsi 0:0:0:1: Direct-Access HGST HUS 724030ALA640 8136 PQ: 0 ANSI: 6
[ 4209.797938] sd 0:0:0:0: [sda] Mode Sense: 67 00 10 08
[ 4209.798550] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 4209.799525] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
[ 4209.800189] sd 0:0:0:1: Attached scsi generic sg1 type 0
[ 4209.802947] sd 0:0:0:1: [sdb] 5860533168 512-byte logical blocks: (3.00 TB/2.73 TiB)
[ 4209.803294] sd 0:0:0:1: [sdb] Write Protect is off
[ 4209.803315] sd 0:0:0:1: [sdb] Mode Sense: 67 00 10 08
[ 4209.804023] sd 0:0:0:1: [sdb] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 4209.805222] sd 0:0:0:1: [sdb] Optimal transfer size 33553920 bytes
[ 4209.829200] sd 0:0:0:0: [sda] Attached SCSI disk
[ 4209.849635] sd 0:0:0:1: [sdb] Attached SCSI disk
[ 4210.278146] usb 2-1: new SuperSpeed USB device number 13 using xhci_hcd
[ 4210.303650] usb 2-1: New USB device found, idVendor=1058, idProduct=0a10, bcdDevice=81.36
[ 4210.303696] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 4210.303750] usb 2-1: Product: JMS56x Series
[ 4210.303766] usb 2-1: Manufacturer: JMicron
[ 4210.303779] usb 2-1: SerialNumber: 1234567890123
[ 4210.318608] scsi host1: uas
[ 4210.320402] scsi 1:0:0:0: Direct-Access HGST HUS 724030ALA640 8136 PQ: 0 ANSI: 6
[ 4210.322384] sd 1:0:0:0: Attached scsi generic sg2 type 0
[ 4210.324205] scsi 1:0:0:1: Direct-Access HGST HUS 724030ALA640 8136 PQ: 0 ANSI: 6
[ 4210.324333] sd 1:0:0:0: [sdc] 5860533168 512-byte logical blocks: (3.00 TB/2.73 TiB)
[ 4210.324747] sd 1:0:0:0: [sdc] Write Protect is off
[ 4210.324769] sd 1:0:0:0: [sdc] Mode Sense: 67 00 10 08
[ 4210.325375] sd 1:0:0:0: [sdc] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 4210.326616] sd 1:0:0:1: Attached scsi generic sg3 type 0
[ 4210.326887] sd 1:0:0:0: [sdc] Optimal transfer size 33553920 bytes
[ 4210.349622] sd 1:0:0:1: [sdd] 5860533168 512-byte logical blocks: (3.00 TB/2.73 TiB)
[ 4210.350341] sd 1:0:0:1: [sdd] Write Protect is off
[ 4210.350373] sd 1:0:0:1: [sdd] Mode Sense: 67 00 10 08
[ 4210.350946] sd 1:0:0:1: [sdd] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 4210.352177] sd 1:0:0:1: [sdd] Optimal transfer size 33553920 bytes
[ 4210.354569] sd 1:0:0:0: [sdc] Attached SCSI disk
[ 4210.378993] sd 1:0:0:1: [sdd] Attached SCSI disk
[ 4213.170305] usb 2-2: USB disconnect, device number 12
[ 4213.205884] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 4213.445820] sd 0:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=DRIVER_OK
[ 4213.486001] sd 0:0:0:1: [sdb] Synchronizing SCSI cache
[ 4213.725828] sd 0:0:0:1: [sdb] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=DRIVER_OK
[ 4213.894092] usb 2-1: USB disconnect, device number 13
[ 4213.913846] sd 1:0:0:0: [sdc] Synchronizing SCSI cache
[ 4214.153832] sd 1:0:0:0: [sdc] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=DRIVER_OK
[ 4214.199458] sd 1:0:0:1: [sdd] Synchronizing SCSI cache
[ 4214.437831] sd 1:0:0:1: [sdd] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=DRIVER_OK
[ 4542.884924] usb 2-2: new SuperSpeed USB device number 14 using xhci_hcd
[ 4542.910428] usb 2-2: New USB device found, idVendor=1058, idProduct=0a10, bcdDevice=81.36
[ 4542.910461] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 4542.910478] usb 2-2: Product: JMS56x Series
[ 4542.910493] usb 2-2: Manufacturer: JMicron
[ 4542.910506] usb 2-2: SerialNumber: 1234567890123
[ 4542.924235] scsi host0: uas
[ 4542.925974] scsi 0:0:0:0: Direct-Access HGST HUS 724030ALA640 8136 PQ: 0 ANSI: 6
[ 4542.927951] scsi 0:0:0:0: Attached scsi generic sg0 type 0
[ 4542.930838] scsi 0:0:0:1: Direct-Access HGST HUS 724030ALA640 8136 PQ: 0 ANSI: 6
[ 4542.933038] sd 0:0:0:0: [sda] 5860533168 512-byte logical blocks: (3.00 TB/2.73 TiB)
[ 4542.933537] sd 0:0:0:0: [sda] Write Protect is off
[ 4542.933565] sd 0:0:0:0: [sda] Mode Sense: 67 00 10 08
[ 4542.934148] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 4542.935116] sd 0:0:0:1: Attached scsi generic sg1 type 0
[ 4542.935205] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
[ 4542.935832] sd 0:0:0:1: [sdb] 5860533168 512-byte logical blocks: (3.00 TB/2.73 TiB)
[ 4542.936142] sd 0:0:0:1: [sdb] Write Protect is off
[ 4542.936167] sd 0:0:0:1: [sdb] Mode Sense: 67 00 10 08
[ 4542.936774] sd 0:0:0:1: [sdb] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 4542.938369] sd 0:0:0:1: [sdb] Optimal transfer size 33553920 bytes
[ 4542.976642] sd 0:0:0:0: [sda] Attached SCSI disk
[ 4542.977128] sd 0:0:0:1: [sdb] Attached SCSI disk
[ 4543.408997] usb 2-1: new SuperSpeed USB device number 15 using xhci_hcd
[ 4543.440991] usb 2-1: New USB device found, idVendor=1058, idProduct=0a10, bcdDevice=81.36
[ 4543.441030] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 4543.441049] usb 2-1: Product: JMS56x Series
[ 4543.441064] usb 2-1: Manufacturer: JMicron
[ 4543.441078] usb 2-1: SerialNumber: 1234567890123
[ 4543.452752] scsi host1: uas
[ 4543.455368] scsi 1:0:0:0: Direct-Access HGST HUS 724030ALA640 8136 PQ: 0 ANSI: 6
[ 4543.457638] sd 1:0:0:0: Attached scsi generic sg2 type 0
[ 4543.459371] scsi 1:0:0:1: Direct-Access HGST HUS 724030ALA640 8136 PQ: 0 ANSI: 6
[ 4543.459506] sd 1:0:0:0: [sdc] 5860533168 512-byte logical blocks: (3.00 TB/2.73 TiB)
[ 4543.459948] sd 1:0:0:0: [sdc] Write Protect is off
[ 4543.459970] sd 1:0:0:0: [sdc] Mode Sense: 67 00 10 08
[ 4543.460762] sd 1:0:0:0: [sdc] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 4543.461788] sd 1:0:0:1: Attached scsi generic sg3 type 0
[ 4543.461825] sd 1:0:0:0: [sdc] Optimal transfer size 33553920 bytes
[ 4543.463288] sd 1:0:0:1: [sdd] 5860533168 512-byte logical blocks: (3.00 TB/2.73 TiB)
[ 4543.463619] sd 1:0:0:1: [sdd] Write Protect is off
[ 4543.463642] sd 1:0:0:1: [sdd] Mode Sense: 67 00 10 08
[ 4543.464319] sd 1:0:0:1: [sdd] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 4543.465471] sd 1:0:0:1: [sdd] Optimal transfer size 33553920 bytes
[ 4543.486626] sd 1:0:0:0: [sdc] Attached SCSI disk
[ 4543.511338] sd 1:0:0:1: [sdd] Attached SCSI disk
[ 4546.293092] usb 2-2: USB disconnect, device number 14
[ 4546.316657] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 4546.556626] sd 0:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=DRIVER_OK
[ 4546.601430] sd 0:0:0:1: [sdb] Synchronizing SCSI cache
[ 4546.840621] sd 0:0:0:1: [sdb] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=DRIVER_OK
[ 4547.000948] usb 2-1: USB disconnect, device number 15
[ 4547.032657] sd 1:0:0:0: [sdc] Synchronizing SCSI cache
[ 4547.272627] sd 1:0:0:0: [sdc] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=DRIVER_OK
[ 4547.320670] sd 1:0:0:1: [sdd] Synchronizing SCSI cache
[ 4547.560627] sd 1:0:0:1: [sdd] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=DRIVER_OK
I am asking for help in solving the problem.
Regards
Manticore
