Rockchip-mali-midgard-dev installation failed
when i execute the clinfo command
ERROR: The DDK is not compatible with any of the Mali GPUs on the system.
The DDK was built for 0x860 r2p0 status range [0..15], but none of the GPUs matched:
Number of platforms 0
I am also having this problem. I’m about to try Kernel 4.4
no dice
Error! Bad return status for module build on kernel: 4.4.154-116-rockchip-g86a614bc15b3 (aarch64)
it seems I may need to use a different OS
Hi all,
Has this been resolved? … I am using debian buster and I get the same error. dkms doesnt exist on Buster.
radxa@rock-4c-plus:~$ sudo dmesg |grep mali
[   24.014335] panfrost ff9a0000.gpu: Looking up mali-supply from device tree
[   24.033140] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0
clinfo returns
 radxa@rock-4c-plus:~$ sudo clinfo
Richard
